YUgisa 2528 Posted January 26, 2016 Ko su ti ljudi i po cemu su bitni? Quote Share this post Link to post Share on other sites
baron21 7 Posted January 27, 2016 Pa FT1P,sta ti nije jasno? Ne razumem sta ft1? (Ako se odnosi na moj post) Quote Share this post Link to post Share on other sites
Dezurni 399 Posted January 27, 2016 Nisi slušao Micu ubicu šalterskog radnika??? FT1P-Fali ti 1 papir Quote Share this post Link to post Share on other sites
beli_Punto 123 Posted January 27, 2016 Roditelji zauzeti sviranjem klavira, a deca vole 2oo na sat Quote Share this post Link to post Share on other sites
baron21 7 Posted January 27, 2016 Hahahaha, cuo sam za ovo al nisam slusao do sad Quote Share this post Link to post Share on other sites
baron21 7 Posted January 28, 2016 Evo da se javim, otisao danas opet na biro, bila neka druga i sve najnormalnije, nikakvih problema nije bilo.. kakva drzava.. treba nas sve sravniti sa zemljom kad nas ebe ko kako hoce Quote Share this post Link to post Share on other sites
Kaniđa 1 Posted January 28, 2016 Ja sam imao isth problema kad sam prebacivao karton za lečenje,nakon mastera.Kao da sam došao trodone da im tražim,što se prebacuješ,ja reko završio sam faks više nisam u Bg-u,kako si završio faks i slično,dva meseca im trebalo da mi pošalju karton,a kod njih se lečio jednom i to na početku studija.Ne zanju ni šalteruše šta više kome traže,pa idu svima isto,ako terba super,ako ne terba jbg nije znala Quote Share this post Link to post Share on other sites
Woodoo 22917 Posted January 31, 2016 https://www.facebook.com/mihajlo.cepi?fref=photo Obavezno pogledajte snimke, hronoloski, mislim da je snimalno malo posle poplava. Quote Share this post Link to post Share on other sites
Axic 19989 Posted February 1, 2016 (edited) Evo ga njegov kanal na YT, ima 4 video snimka i sve vezano za Matijevichttps://www.youtube.com/channel/UC7R1i1H7fVhIg5wD_vRbs0g https://www.youtube.com/watch?v=lJTmVx7hKrU https://www.youtube.com/watch?v=3vpuzKdrRFY https://www.youtube.com/watch?v=rbUE9KeSpRE https://www.youtube.com/watch?v=RIY-HQgkjec Edited February 1, 2016 by neshaoct dodao YT linkove Quote Share this post Link to post Share on other sites
Transporter131 138 Posted February 1, 2016 Siromasi ce hteti imetak bogatih,a demokratija ce im to dati. Mladi ce hteti da budu uvazavani kao stari,zene ce hteti da budu kao muski,stranci ce hteti prava starosedelaca,demokratija ce im to dati. Lopovi i prevaranti ce hteti drzavne funkcije,demokratija ce im to dati.A kad lopvi i prevaranti konacno demokratski preuzmu vlast,jer kriminalci i zlocinci teze za moci, nastace gora tiranija nego u vreme bilo koje monarhije ili oligarhije. Demokratija, Sokrat 470-399 g. P.N.E Quote Share this post Link to post Share on other sites
Zhorz 102 Posted February 2, 2016 vidim da su predali tuzilastvu.....e sad je zavrsena prica Quote Share this post Link to post Share on other sites
totti 13160 Posted February 2, 2016 http://www.blic.rs/vesti/srbija/osudjen-za-falsifikat-diplomirao-na-srukovnoj-skoli/tc7h7gv Quote Share this post Link to post Share on other sites
beli_Punto 123 Posted February 2, 2016 Bivši vodja navijača Smedereva Quote Share this post Link to post Share on other sites
totti 13160 Posted February 5, 2016 Hoće li u ovoj državi ikad iko odgovarati za neke stvari - ovaj ako je lagao, Matijevići ako su mu pretili da promeni iskaz ili konkurencija koja ga je vrbovala i naterala...B92: "Lagao sam da Matijević koristi neispravno meso" http://www.b92.net/info/vesti/index.php?yyyy=2016&mm=02&dd=05&nav_category=12&nav_id=1093444 Quote Share this post Link to post Share on other sites
beli_Punto 123 Posted February 5, 2016 Zanimljivo ... pa ovo ni u diznilendu nema sto se kod nas radi I taman kad pomislis da ne moze gore ... http://www.b92.net/info/vesti/index.php?yyyy=2016&mm=02&dd=04&nav_category=12&nav_id=1092965 Quote Share this post Link to post Share on other sites
Dezurni 399 Posted February 5, 2016 Aj da dodam nešto na ovu temu. Kum (Mićo, imam i ja kuma ) radi kod njih oko 8 godina. Znam i generalnog direktora koji je prošle godine otišao u penziju (održavam mu kola). Ovo što je ovaj lik snimio nema baš puno veze sa istinom. Ono jeste otpad, ali koji ide u kereću hranu. Ne kažem da su idealni, ali nisu baš ni takvi kreteni. Quote Share this post Link to post Share on other sites
beli_Punto 123 Posted February 5, 2016 Sad kad se pobune ovi sto kupuju kerecu hranu ... znas da u poslednje vreme ljudi vise gledaju kerove i macke nego decu Quote Share this post Link to post Share on other sites
Kaniđa 1 Posted February 5, 2016 Biće da se malo provozao u gepeku,ili je bio an korak od toga da postane kobasica Quote Share this post Link to post Share on other sites
marko1984 2 Posted February 5, 2016 Zanimljivo ... pa ovo ni u diznilendu nema sto se kod nas radi I taman kad pomislis da ne moze gore ... http://www.b92.net/info/vesti/index.php?yyyy=2016&mm=02&dd=04&nav_category=12&nav_id=1092965 Moje misljenje je da ako vec promovise silovanje i zalaze se za isto,onda ne bi trebalo da se buni ako bi njega neko silovao! Ne mora silovanje da bude usmereno samo protiv zene! A posto nije precizirao za kakvo silovanje se zalaze,onda bi trebalo da cuti ako ga siluju njih desetorica,nekih 4,5 dana! Jbg,usao si u neciji stan samovoljno,pa izvoli! To bi onda trebalo da vazi i za sve one bolesnike,koji su pi..ku videli samo na monitoru i koji ga podrzavaju... Quote Share this post Link to post Share on other sites
Kaniđa 1 Posted February 5, 2016 Kevina kancelarija u kojoj radi ima parnicu koju vodi od 2002,a u pitanju je tužba žene koju je muž silovao.I samo jedna rečenica je spor odvukla na 10 različitih strana,a to je konstatacija njegovog advokata dal muž može da siluje ženu.I dan danas taj spor traje. Quote Share this post Link to post Share on other sites
ivan.ik 625 Posted February 5, 2016 Šta je silovanje ?I ko može nekome da da pravo nekog da siluje ? Druga priča što je to jedno od oružja koje lako može da se zloupotrebi.U Crnoj Gori se vodio spor i da li da bude smešno ili tužno zavisi ko kako gleda. Radnik muškarac je optužio šefovicu ženu za silovanje (mislim višestruko) i tu nebi bio problem da problem nisu našli u erekciji. Ako je imao da li je to onda bilo voljno ? Quote Share this post Link to post Share on other sites
Zhorz 102 Posted February 5, 2016 Aj da dodam nešto na ovu temu. Kum (Mićo, imam i ja kuma ) radi kod njih oko 8 godina. Znam i generalnog direktora koji je prošle godine otišao u penziju (održavam mu kola). Ovo što je ovaj lik snimio nema baš puno veze sa istinom. Ono jeste otpad, ali koji ide u kereću hranu.Ne kažem da su idealni, ali nisu baš ni takvi kreteni. Mozda ne radi sada kada je zgrnuo milione, ali na pocetku.....nije mi jasna ova recenica:upravo javio sadašnji radnik "Matijevića", bivši kolega, koji je rekao da su spali s nogu poslednjih dana otkako je cela priča počela, jer su morali danonoćno da sklanjaju sporne količine mesa znajući da će im na vrata uskoro zakucati inspekcije znaci imaju sporne kolicine mesa? a da ce da se pobune vlasnici kucica to ce se cuti vise nego za ovo prvo. Quote Share this post Link to post Share on other sites
Kaniđa 1 Posted February 5, 2016 Zna se šta je silovanje.Al živimo u tako izopačenom svetu,gde svako ima neko svoje pravo pa čak i onaj koji siluje zamisli kad advokat tuženog kaže,žena nije obavljala bračne dužnosti i sve je to bio samo malo grublji sex Quote Share this post Link to post Share on other sites
The Punisher 6604 Posted February 5, 2016 Povodom legalizacije silovanja, odgledajte novi film Borisa Malagurskog, dokumentarac je odličan, https://www.facebook.com/b.malagurski/videos/949209595162392/ nađite ga znate već gde. U filmu se između ostalog pominje ustrojstvo Saudijske Arabije, pokazuju ženske egzekucije i ostala bizarna pogubljenja koja Amerika zdušno podržava. Mnoge stvari sam video prvi put u životu. Quote Share this post Link to post Share on other sites
