Milos911 2 Posted January 4, 2014 Ja sam polirao relativno skoro, granulacija 800 pa 2000 (mrzelo me da radim sa 1500), prezadovoljan sam kako je ispalo. Presao sam lepih km od tad, i far je jos uvek kristalno cist... Pocetno stanje: Zavrseno smirglanje: Sa ovim sam polirao: Na kraju dobio ovo: Quote Share this post Link to post Share on other sites
igor0511 2882 Posted January 4, 2014 Baš se vidi razlika. Odlično si odradio Quote Share this post Link to post Share on other sites
MilanStilo 2 Posted January 5, 2014 Extra Послато са GT-S5670 користећи Тапаток 2 Quote Share this post Link to post Share on other sites
Milos911 2 Posted January 16, 2014 Razmisljam nesto, posto bih hteo i iznutra far da ocistim, ima neka paucina pa me iritira, da li bi moglo da se pridje sa zadnje strane? Povadim sve sijalice pa gurnem onog praska sto se kupi paucina sa zidova sa njim ili nesto sitnije, i pokupim paucinu? Da nije mozda neko radio, ne rastura mi se sve da bi na kraju provalio da to ne moze da se uradi...? Quote Share this post Link to post Share on other sites
Mijailović P. 3449 Posted January 16, 2014 Tesko izvodljivo. Drugaru smo sredjivali farove blagim deterdzentom i vodom i evo 1,5god. nema problem. Quote Share this post Link to post Share on other sites
MS PK 7732 Posted January 16, 2014 Probaj da povadis sijalice pa zavezi krpici na ltaj neke cvtste zice i skini paucinu, a za ciscenje moras da skines far Sent from my GT-S7560 using Tapatalk Quote Share this post Link to post Share on other sites
Beri 0 Posted May 15, 2014 (edited) Zar nije bolje sa polirnom pastom čistiti farove ? Edited May 15, 2014 by Beri Quote Share this post Link to post Share on other sites
MS PK 7732 Posted May 15, 2014 Pa naravno da je bolje al otvori ga ako smes Quote Share this post Link to post Share on other sites
Beri 0 Posted May 15, 2014 Vanjski dio sam mislio Quote Share this post Link to post Share on other sites
MS PK 7732 Posted May 15, 2014 Razmisljam nesto, posto bih hteo i iznutra far da ocistim, ima neka paucina pa me iritira, da li bi moglo da se pridje sa zadnje strane? Povadim sve sijalice pa gurnem onog praska sto se kupi paucina sa zidova sa njim ili nesto sitnije, i pokupim paucinu? Da nije mozda neko radio, ne rastura mi se sve da bi na kraju provalio da to ne moze da se uradi...? Quote Share this post Link to post Share on other sites
Milos911 2 Posted May 20, 2014 Iiii ovo nemojte da radite Ne moze lepo da se pridje, onaj sjaj se lako osteti, i ako imate sitne prasine napravicete nered... Jedino mozda kompresorom da se izduva, mozda i paucinu izvuce... Quote Share this post Link to post Share on other sites
kicerica 5 Posted May 20, 2014 Isperes far destilovanom vodom. Quote Share this post Link to post Share on other sites
banjo1990 264 Posted May 27, 2014 (edited) Nisam stigao ranije, ali evo da prikažem moj slučaj. Farovi su bili u stvarno lošem stanju, što se može i videti na slikama. Brušenje sam počeo sa P1000, u više prolaza da bih izvukao sve riseve koji su obilovali na površini fara. Nastavio sam sa P1500 u dva prilaza, i na kraju sa P2000 isto u dva prolaza. Rezultati su bili odlični, ali ponavljam bili su... Na kraju postupka nisam odmah naneo vosak jer ga nisam imao, ali ipak nisam očekivao da za bukvalno 3-4 dana farovi potpuno zamagle. U čemu je greška, stvarno ne znam... Sumnjam na polir pastu. Evo i slika. Početno stanje Posle šmirglanja Na kraju. Ovde napominjem da je situacija na kraju bila još bolja, ovo je uslikano tek posle prvog prolaza pastom. Posle par dana Edited May 27, 2014 by banjo1990 Quote Share this post Link to post Share on other sites
beli_Punto 123 Posted May 27, 2014 Koju si pastu koristio, znas da nije ista za farove i limariju? Quote Share this post Link to post Share on other sites
Vule 795 Posted May 27, 2014 Nije uopšte bitno, ja farove nakon šmirglanja radim sa redovnim 3M pastama (FastCut pa ExtraFine), svaki put ispadne perfektno i nakon dobre zaštite, nikada se ne desi ovako nešto. Quote Share this post Link to post Share on other sites
skile86 539 Posted May 27, 2014 @banjo1990Takvi su ti farovi jer je verovatno padala kisa, koja verovatno samo spere tu polir pastu ili sta vec. Quote Share this post Link to post Share on other sites
banjo1990 264 Posted May 28, 2014 @beli_Punto: Neka sonax, na limariji je dobro radila posao... @Vule: Ali ja da bih uzeo 3M paste treba mi 7000 din, da bih sredio far...? @Skile: Jeste padala kiša, i to ona što nije stala 4 dana... Ali svejedno, razočaran sam. Probaću ponovo da poliram sa drugom pastom... Quote Share this post Link to post Share on other sites
French Connection 0 Posted May 28, 2014 Probaj da nadjes u nekoj farbari 3M paste na merenje prodaju isto. Ja sam uzimao nedavno, izmere ti 1dl, ili 2dl koliko ti treba, 3M zuti cep 1dl sam platio oko 550din. Quote Share this post Link to post Share on other sites
yuhica 1 Posted May 28, 2014 banjo@Farbara Dumix u Zemunu ulica Marina Prilaz,bivsa Jakuba Kuburovica.Imas 3M paste na merenje.Zelena je 490 din 100gr,zuta 280din. Quote Share this post Link to post Share on other sites
banjo1990 264 Posted May 28, 2014 E to sam baš hteo da pitam da li ima!!! Hvala vam momci! Quote Share this post Link to post Share on other sites
Vule 795 Posted May 28, 2014 Padala kiša pa sprala pastu... Quote Share this post Link to post Share on other sites
DjoleKG 0 Posted May 28, 2014 ahahah predobra slika Quote Share this post Link to post Share on other sites
Milos911 2 Posted May 29, 2014 Mrsko mi sad da trazim, imas u mojoj temi (link u potpisu) kako sam polirao farove, i imas sliku zastite koju sam kasnije stavio. Plava bocica, moze za stakla i plastiku, kosta oko 500-600 din.... Quote Share this post Link to post Share on other sites
banjo1990 264 Posted May 29, 2014 Uradio sam juče sa 3M, sad je odlično, ali moram zaštitu da stavim....pogledaću u temi. Hvala! Quote Share this post Link to post Share on other sites
