Ivan 17583 Posted May 21, 2015 Polirao ja jednom sa pastom ali uskoro opet su pozutili.Pa nisi mnogo uradio ako si ih ispolirao, a nisi ponovo zastitio. Izuzev ako su bas u ocajnom stanju. Quote Share this post Link to post Share on other sites
Rista JTD 0 Posted May 21, 2015 Odlucio sam da cu sa busilicom raditi jer mogu da kontrolisem brzinu zavisi koliko jako pritisnem, nastavak koji ima cicak i sundjer koji se lepi na cicak, gruba pasta i smirgle 1000,1500 i 2000 ta zanimacija je nesto malo ispod 1500din danas se raspitao Quote Share this post Link to post Share on other sites
MS PK 7724 Posted May 21, 2015 Brate, za te pare ima neko da ti ih odradi vrhunski. Quote Share this post Link to post Share on other sites
Axic 19947 Posted May 21, 2015 (edited) Slazem se Mico, pritom može da se desi da ih zaj*be još gore pa na kraju ispadne da mora kupiti 2 polovna fara. Edited May 21, 2015 by Axic Quote Share this post Link to post Share on other sites
MS PK 7724 Posted May 21, 2015 Jok, dva nova kineza i jos 150e za Morimoto i full brate Quote Share this post Link to post Share on other sites
ordemeprogresso 1 Posted May 23, 2015 (edited) Procitah ovu temu pre par dna i rekoh ajd da se i ja bacim na posao . ] Prvo je bilo ovako nakon 5,6 minuta trljanja i na kraju kad su mi utrnule ruke kad budem raspolozen okrenucu jos jednu ruku, cisto kao finis Edited April 28, 2022 by neshaoct prebacio slike na FLCS server 1 neshaoct reacted to this Quote Share this post Link to post Share on other sites
Angell 11 Posted May 23, 2015 Super.Cime si trljao? Quote Share this post Link to post Share on other sites
Markobgd 609 Posted May 23, 2015 Rukama... 1 notalone reacted to this Quote Share this post Link to post Share on other sites
Angell 11 Posted May 23, 2015 (edited) Da si upotrebio pastu, bilo bi efikasnije 100% Salim se Edited May 23, 2015 by Angell Quote Share this post Link to post Share on other sites
totti 13160 Posted May 23, 2015 Rukama...Žicom za sudove Quote Share this post Link to post Share on other sites
ordemeprogresso 1 Posted May 23, 2015 uzeo sam onaj dzak od krompira crveni i kolgejt maks vajt rezultat govori sve Quote Share this post Link to post Share on other sites
Rista JTD 0 Posted May 23, 2015 Ma ne mogu da ih sjebem, a mocicu jos da poliram ne samo jednom za 1500din i verovatno cu busilicom pa cu neku blazu brzinu upotrebiti jedino sto mozda je malo kriticno to smirglanje, al uspecu valjda Quote Share this post Link to post Share on other sites
milan81 24 Posted May 24, 2015 (edited) Ima u farbarama profi pasta na merenje,npr 3M,Farecla,Roberlo,uzmes najmanje kolko daju,neku grublju sa vecom granulacijom,3 tabaka vodene smirgle,1200,1500,2000 i 3 puta omatiras farove sa sve 3 vrste smirgle,kad zavrsis operes i osusis farove i posle ih odradis sa ovom pastom polirkom ili cime vec,ima u farbarama i ona fina krpa namenjena za poliranje,tu ti je efekat 100%! Edited May 24, 2015 by milan81 Quote Share this post Link to post Share on other sites
Rista JTD 0 Posted May 24, 2015 Posle smirglanja fatovi trebajo da budu matirani kao prljavi? Ma da ta grupa pasta za fatove je 260din, i uzecu sundjere za grubo poliranje to znam Quote Share this post Link to post Share on other sites
banjo1990 264 Posted May 24, 2015 (edited) Evo moja fotografija sa 5. strane. Tako nekako bi trebalo da izgleda posle šmirglanja. Edited April 28, 2022 by neshaoct prebacio sliku na FLCS server Quote Share this post Link to post Share on other sites
Rista JTD 0 Posted May 24, 2015 Da da tako sam i mislio Quote Share this post Link to post Share on other sites
SeriouS 6 Posted April 28, 2022 Hteo sam da podelim pa mozda nekome pomognem oko sredjivanja farova, ovo je vudzet varijanta, a rezultate vidite i sami. Moji su bili osrednje matirali, i pozuteli. Sta mi je bilo potrebno: -vodene smirgle (800, 1200, 2000, 2500, 3000) -sundjer za poliranje -set za reparaciju farova iz lidla -busilica sa potenciometrom Najbolje je uzeti prskalicu i natociti vodu u nju za prskanje farova, ali posto nisam imao istu, izbusio sam cep od flase i tako polivao farove prilikom smirglanja. Prvo poceti sa 800 gradacijom, i sa njom smirglati uz konstantno dodavanje vode dokle god nema vise zute boje, i obavezno osmirglati ceo far da bude isto matirano sa avih strana, koristiti pokret linijski, na primer levo desno po duzini fara. Sledeca gradacija 1200, isto smirglati ali u suprotnim pravcima, ako ste do sada smirglali lrvo desno, sada idete gore dole, dokle god far ne bude isto matiran sa svih strana. Ponoviti sa ostalim smirglama. Na kraju sam koristio smirglice iz seta kao zadnju gradaciju za smirglanje. Ja sam u setu dobio 2 paste, 2 maramice sa uv zastitom, 4 smirglice male, 2 krpe i onaj sundjer za smirglanje, vidim da sada ima neki drugi set u lidlu koji je nesto sasvim drugo. Obavezno ocistiti far vodom i osusiti skroz, ne sme biti uopste mokar far. Uzeti pastu i naneti na sundjet i razmazati na far, obavezno koristiti masinu sa potenciometrom (stelovanje brzine okretanja busilice u zavisnosti koliko jako pritisnete), u mom slucaju je to bila busilica. Polirati farove ali ne velikom brzinom, osrednjom. Meni je otisla jedna mala tubica za oba fara. Raditi dve ruke poliranja, pa ocistite mikrofiber krpom, odmah bi trebalo da vidite rezultate, u mom slucaju su odlicni iako se nisam nadao. Premazati far uv zastitom koja se dobija u pakovanju. Sve ukupno me je kostalo oko 15e, a rezultati su me iznenadili. Moze da se polira i rucno, ali rezultat ce digurno biti malo losiji. Smirglanje ze obavezno jer se tako skida povrsinski sloj koji je oksidirao, ako se smirgla samo sa smirglom koja ide u setu nece se dobiti dobar rezultat jer je smirgla jako fina i ne skida kako bi trebala da skida, kao na primer 800. Da napomenem da ze prozirnost fara dobija tek na kraju kada se ispolira. U prilogu ide slika kakvi su farovi bili pre sredjivanja, nakom smirglanja, mutni i matirani, i nakon poliranja, kristalno jasni. Meni je ovo prvi put da se srecem sa poliranjem farova, set za reparaciju farova sam uzeo iz razloga sto ima uv zastitu koja je obavezna, i sto ima pastu za poliranje, nasao sam ga za nekih 6 eura nov na kp, tako da mi se isplatilo. Ovim sam dobio lep far na izgled, i najbitnije od svega odlicnu vidljivost nocu. Nadam se da ce nekome pomoci. 3 skile86, neshaoct and alfini0507 reacted to this Quote Share this post Link to post Share on other sites
alfini0507 1653 Posted April 29, 2022 Eno ga u gepeku komplet iz Lidla kupljen danas... Quote Share this post Link to post Share on other sites
Vule 791 Posted April 29, 2022 U celoj priči je najbitnija zaštita nakon poliranja. Bez nje, kroz par meseci će ponovo sve da požuti, jer šmirlganjem skidate fabrički zaštitni sloj. 1 Ivan reacted to this Quote Share this post Link to post Share on other sites
OMP 2173 Posted April 29, 2022 ima one sonax kesice jeftine su bas za tu namenu, kazu da nisu lose, svakako bolje ista nego nista, prava stvar je lakiranje posle poliranja ali to vec iziskuje vreme i opremu, ja imam opremu ali me iskreno mrzi, lakse mi jednom godisnje da ih prepoliram po potrebi. Sto se tice smirglanja ja uzimam smirgle za masinsko smirglanje (mokro ili suvo nebitno) lakse i brze nego rucno posebno kad su bas losi farovi. Quote Share this post Link to post Share on other sites
Vule 791 Posted April 29, 2022 (edited) Ovo deluje kao odlična varijanta, ako može kod nas da se nađe taj 2K lak, ne znam da li je neko već kačio klip. Edited April 29, 2022 by neshaoct formatiranje Quote Share this post Link to post Share on other sites
Ivan 17583 Posted April 29, 2022 (edited) 2 hours ago, OMP said: ima one sonax kesice jeftine su bas za tu namenu, kazu da nisu lose, svakako bolje ista nego nista Rade posao itakako, stite od UV zraka i ponovnog matiranja i zutila. Pogotovo znaci kod vozila koja zbog dizajna imaju ravan gornji deo fara. Cena je smesna za par farova, cca 300 kinti: On 2/19/2022 at 9:51 PM, Ivan said: Znam ovako iz glave da prodaju Sonax keramiku na Tektionu. Samo 290 kinti je pakovanje keramickog premaza, koji je dovoljan za par farova: https://tektion.rs/auto-kozmetika/sredstva-za-ciscenje-pranje-i-poliranje/sredstva-za-poliranje/sonax-profiline-keramicka-zastita-farova-1-komad/ 15 hours ago, SeriouS said: Ovim sam dobio lep far na izgled, i najbitnije od svega odlicnu vidljivost nocu. Dobio si 99% lep far na izgled, a od odlicne vidljivosti placebo efekat . Jer je emitovanje svetla projektorsko (zavisi od stanja soljice i sociva projektora, koje nisi ni pipnuo). A svetlo, koje se na Bravo 2.5'' projektoru isijava sa samo 30-ak cm2 povrsine sociva, prolazi kroz prednji deo stakla fara, koji uglavnom bude u dobrom stanju (jer matira gornja strana izlozena suncu). Pricam iz iskustva, jer su "Al" farovi i projektori (Magneti Marelli) generalno tanki. Na restyle Bravu su mi jos projektori bili relativno sacuvani (mladji restyle model je u pitanju). Prvih godinu dana nisam hteo nista da cackam - u fazonu moze da prodje, necu nista zbog tehnickih... Dok mi nije prekipelo, jer sam u prici oko xenona (i vozim ih) od 2008. kada su se kod nas pojavili. Jos se na Bravu sijalica vrlo lako menja, mesta za balaste da biras, a na benzincu na sve to moze kolo da se igra izmedju farova i motora . Kada se iza toga farovi pedantno upucaju, obicna sijalica i xenon je bukvalno kao du*e i glava, da mi je samo bilo zao sto sam pala*udio i nisam montirao odmah po kupovini. Pije vodu i za trenutno stanje projektora koji se koriste stalno kao dnevno svetlo, tako da apsolutno nije bilo potrebe za otvaranjem i menjanjem projektora. Naravno da bi sa novim projektorima situacija bila za stepenik bolja, ali opet je puno bofla u ponudi pa i tu treba biti pazljiv pri izboru. Summa summarum, iz iskustva sa gomilom Bravaca i uopste Fiata sa "Al" projektorima do sada - hocu da kazem da je halogena sijalica na fabrickom (i obicno vec dobrano nacetom) projektoru, iz mog iskustva golo g*** koje ckilji . Evo kako je kod mene na kraju "ispala" dvorsina varijanta sredjivanja farova sa slojem zastite, u kombinaciji sa par godina ranije stavljenim 4300K "CN Light" AC setom: https://www.fiat-lancia.org.rs/forum/index.php?/topic/44283-poliranje-farova/&do=findComment&comment=1607886 Edited April 29, 2022 by Ivan 1 spaad reacted to this Quote Share this post Link to post Share on other sites
OMP 2173 Posted April 29, 2022 On 4/29/2022 at 1:41 PM, Vule said: Ovo deluje kao odlična varijanta, ako može kod nas da se nađe taj 2K lak, ne znam da li je neko već kačio klip. svaki lak je 2K (dvokomponentni) bilo u spreju ili ovako kad kupujes za pistolj Quote Share this post Link to post Share on other sites
Vule 791 Posted April 29, 2022 Nisam viđao ovakav kakav on koristi, da se "aktivira", mada dugo nisam ništa kupovao... Quote Share this post Link to post Share on other sites
OMP 2173 Posted April 29, 2022 (edited) ne znam ja retko koristim te u spreju, za neke sitnice uglavnom kad me mrzi da prljam pistolj, to uzmem mipa ili motip lak sprej ali generalno dok se pistoljem ne nanese neki krsteniji lak sve ostalo je bzvz Edited April 29, 2022 by OMP Quote Share this post Link to post Share on other sites
