kicerica 5 Posted January 26, 2013 Ma ko zna da li su te remenice uopste od tog motora i sta je sve jos tu cackano.I eto vracamo se unazad. Quote Share this post Link to post Share on other sites
Gusar 4 Posted January 26, 2013 uzgred evo ti 2 stepena pogledaj koliko je to?!!!http://www.dynapod.c...yna-a-prot.htmlHM! pivo je mnogo dobro kad je na temperaturi od 2 stepena... Quote Share this post Link to post Share on other sites
mstankovic 0 Posted January 26, 2013 jel rasturao nekad neko varijator? Quote Share this post Link to post Share on other sites
Gusar 4 Posted January 26, 2013 a nema sta tu da se rastura dva zupcanika koja ulaze jedan u drugi i ne smeju da imaju lufta nego bas onako nevino da ulaze... Quote Share this post Link to post Share on other sites
mstankovic 0 Posted January 26, 2013 da se gadjaju rupuce na njima? a ispod njih da lezi plastican podmetac ili sajbnica kako vec?I da se gadjaju rupice na njima, plastican podmetac koji lezi na dnu ispod njih ? jeli tako? Quote Share this post Link to post Share on other sites
mstankovic 0 Posted January 26, 2013 Moram pitati ima li nekog odavde ko je blizu nisa? Quote Share this post Link to post Share on other sites
Gusar 4 Posted January 26, 2013 mada ne bi bilo lose da odes do auto servisa misic u nisu i da pitas za pomoc... mislim da ce ti izaci u susret...http://autoservisi.c...a-radnja-misic/cuo sam da su dosta dobriako je verovati.... Quote Share this post Link to post Share on other sites
mstankovic 0 Posted January 26, 2013 nisam cuo za ovaj servis do sad, sto ne mora da znaci da su losi,raspitacu se i za njih Quote Share this post Link to post Share on other sites
Gusar 4 Posted January 26, 2013 baba vanga je bila slepa tesko da bi pogodila mesto gde treba da baci zarici... pa prema tome promeni izborI PROMENI |EBENE REMENICE PA DA VIDIMO STA CE DA BUDE ONDA! Quote Share this post Link to post Share on other sites
mstankovic 0 Posted January 26, 2013 a ako i sa novim remenicama to uradi? jedino mi ostaje da se obesim za drugo necu da imam para hahahahhaha Quote Share this post Link to post Share on other sites
Gusar 4 Posted January 26, 2013 (edited) ma bre mislio sam da uzmes remenice na zajam i da probas samo ili da ih premerispa da otklonimo tu sumnju...jel ima neka radnja gde mozes da uzmes remenice samo da premeris? da prebrojis zube... Edited January 26, 2013 by Gusar Quote Share this post Link to post Share on other sites
mstankovic 0 Posted January 26, 2013 Nece brate niko da daje,potrazio sam celu bregastu sa varijatorom od lika koji drzi otpad i rekao ako sve funkcionise uzimam je a ako ne nista onda on je rekao da moze samo da je proda a nece da je pozajmi,ma debili ljudi mogu li ja da izbrojim zube i da izmerim remenice pa da mi da neko podatke odavde ako ima dostupnih, posto ne verujem da ce mi neko dati da ih merim? Quote Share this post Link to post Share on other sites
kicerica 5 Posted January 26, 2013 Poneses tvoje i uporedis na licu mesta. Quote Share this post Link to post Share on other sites
kolega.jankovic 23 Posted January 26, 2013 htedoh reci da mislim da nema veze da li zuri sa tim da li je do remenice.Ako radi u leru sat i po kao sto kaze covek, pa napravi bre 100.000 obrtaja i ne prezubi. Za to vreme bi se kais pomerio da nije ista remenica sigurno.jeste logicno da je remenica manja i pravi veci br okretaja za jedan krug kaisa i tako ode unapred da kais i ne preskoci, ali bi to uradila na bilo kojim obrtajima a ne bas na 3-4000 iskljucivo. Ne bi nista moglo da 'pegla' razliku u precniku remenice na leru ili preko 4000 o/min. Quote Share this post Link to post Share on other sites
kolega.jankovic 23 Posted January 26, 2013 (edited) Edited January 26, 2013 by kolega.jankovic Quote Share this post Link to post Share on other sites
simonen 81 Posted January 26, 2013 Deleci iskustva sa vama moja procena je da samo varijator to uradi,posto slika kaze da bregasta se pomera za 2 stepena,znaci kad se u varijatoru napravi pritisak bregasta podje za 2 stepena napred i onda kad treba da ispusti pritisak da bi se vratila u svoj polozaj to se ne desi ona ostane napeta za ta 2 stepena sto se na remenicu manifestuje za par zuba,varijator ostaneo pod pritiskom ne zatvori ventile na vreme i sretnu se sa klipm??? da limoze tako da se kaze? da ipak ventil ne pusta pritisak,ili kanal povratnog pritisa je zacepljen?Jedan zub na remenici je oko osam stepeni puta cetiri zuba oko trideset dva stepena,e to krivi ventile,dva stepena ne krive.U varijatoru postoji plasticna podloska ,opruga,rotor i stator,ova opruga sluzi da drzi u fiksnom polozaju rotor i stator posto su oni spiralno ozubljeni i da nije opruge oni bi se usled vibracije motora stalno pomerali i pravili kliktanje koje mozes cuti kada opruga izgubi svojstva,sto bi rekli "lupa varijator".Kada ventil pusti ulje ono pod pritiskom udje u varijator sabije oprugu i po spiralnom ozubljenju gurne rotor preko statora sto se manifestuje zakretanjem remenice.Mozda sam malo konfuzno objasnio.Posto tebi usisna remenica "zuri " u odnosu na kais jedan od mogucih uzroka moze da bude pohabanost zuba rotora i statora i da sam varijator prezubi unutar sebe.To ti se manifestovalo kada si na autu pomerao remenicu i kazes da je klimala levo desno.Rasturi varijator nije to neka nauka i proveri stanje zuba na rotoru i statoru moguce da je tu problem... Quote Share this post Link to post Share on other sites
Ticma 535 Posted January 26, 2013 Evo da ne pametujem, sve je lepo objasnjeno na snimku od 4 minuta i ako se ne razume spanski Ukratko ono sto se vidi na snimku je da ili ti ventil ne zatvara kad spustis auto ispod 4000rpm ili ti zupcanici u varijatoru glave i trece solucije nema. On tebi prezupci zato sto ta bregasta ima drukciji da kazem ugao i veci broj obrtaja od predvidjenog za taj broj obrtaja pa ti samim tim i preyupci posto ne uspori sto je izvodljivo samo ako je ili pritisak ulje kroz ventil ostao ne promenjen ili je varijator zaglavio u tom polozaju. Sad ne znam bas tu konstrukciju motora ali pretpostavljam da je varijator samo na toj bregastoj i da ima samo jedan ventil koji dovodi pritisak pa samim tim ili glavi ventil ili glave zupcanici u varijatoru. Koliko sam procitao nosio si varijator kod majstora koji je rekao da je u OK stanju sto dovodi do zakljucka da zamenis ventil i resio si problem.http://www.youtube.com/watch?v=T96Fnk_0AzM Quote Share this post Link to post Share on other sites
kicerica 5 Posted January 26, 2013 Bregasta se vrti isto ali joj je polozaj drugaciji do 4000 i od 4000rpm. zahvaljujuci variatoru. Quote Share this post Link to post Share on other sites
Ticma 535 Posted January 26, 2013 Ok lose sam razumeo to oko obrtaja bregaste i nije mi bilo bas logicno u svakom slucaju ja i dalje stojim pri tome da ili ventil ne zatvori kad se spusti ispod 4000rpm ili zaglavi varijator. Pretpostavljam da ventil dobija signal od ECU jedinice pa problem moze da potekne i od nje ili od senzora broja obrtaja . . . Quote Share this post Link to post Share on other sites
kicerica 5 Posted January 26, 2013 (edited) Pa vidis u tome je problem sto ima vise stvari koje su povezane i da bi resio problem mora da ima krstenog majstora koji ce po redu sve da proveri.Ovako je prilicno zajebano objasniti.Recimo moze banalna stvar kao sto je relej da pravi biiip zato sto lepi ali o tome cemo kasnije. Edited January 26, 2013 by kičerica Quote Share this post Link to post Share on other sites
Ticma 535 Posted January 26, 2013 Pa treba kao sto kazes poceti od banalnih stvari, mozda je kvar u bezveznom el signali Quote Share this post Link to post Share on other sites
kicerica 5 Posted January 26, 2013 (edited) To je malo verovatno ili skoro pa nemoguce jer bi mu odmah pokazao gresku! Edited January 26, 2013 by kičerica Quote Share this post Link to post Share on other sites
Ticma 535 Posted January 26, 2013 Trebalo bi tj moralo bi. Ja pucam na ventil posto ECU ne moze da registruje da je ventil ostao otvoren . . . Quote Share this post Link to post Share on other sites
MS PK 7729 Posted January 26, 2013 Jos pre 4 strane smo svi zakljucili da ljudi ne znaju sta rade i kako to da rade.Ja razumem da covek hoce sam da resi problem ali za to treba debela praksa i iskustvo pa da bi onda mogao da ukapiras to sto ti neko strucan objasnjava. Dokle god ne dodje covek koji poznaje Fiata, a takvih ima samo 2 u Nisu, verovali ili ne, majstor za platu i burazer koji razbija elektroniku ima da lome ventile kao palidrvca...Ne kapiram kako moze da se vrati stari zupcasti kais i to sa prezubljenog auta, mislim svaka cast kada imate m..a za tako nesto, mada i to dovoljno govori o necemu...@ GusarMisic je boshista-bosh servis Quote Share this post Link to post Share on other sites
