joeya1k 0 Posted July 14, 2012 Na Z10 kad palim iskljuci se sve sa kontrolne table i resetuje se bord, i posle pola sekunde sve normalno.. Znaci kad dam kontakt svetli, i dok pali sve se pogasi. Akumulator je dobar, a ovo mi se desilo par puta zimi na -20C. Posle voznje, tj ugasim upalim onda je normalno. Quote Share this post Link to post Share on other sites
MS PK 7728 Posted July 14, 2012 Lici na neki veliki pad napona, a sad sta mu je...procackaj malo kontakte, kleme.. Quote Share this post Link to post Share on other sites
Hardvet 2 Posted July 14, 2012 Sta je ovo spopalo ove nase Zoromobile pa to je cudo. Izgleda razmnozavanju Gremlina pogoduje ova vrucina Stvarno lici na pad napona... Quote Share this post Link to post Share on other sites
chikavili 511 Posted July 14, 2012 Meni se to isto desavalo kada mi je akumulator bio na izdisaju. Proveri ti to jos jednom.Sent from my Casio Scientific Calculator Quote Share this post Link to post Share on other sites
joeya1k 0 Posted July 16, 2012 Danas da odem do majstora, i nece da upali, vergla ali tada nema struje, merio akumulator daje 12... kaze da uradi dijagnostiku pa cemo videti.. Quote Share this post Link to post Share on other sites
pasha.fcrs 0 Posted September 16, 2012 Isti problem sam imao, promenio sam akumulator, radi kao zmaj! Quote Share this post Link to post Share on other sites
Gusar 4 Posted September 16, 2012 Taj problem se resava i dotezanjem + kleme na akumulatoru... Quote Share this post Link to post Share on other sites
markosdbg 0 Posted January 16, 2014 Pozdrav ljudi,naime danas sam primetio jedan problem na mojim kolima.Kad dam kontakt,na tabli mi zablinkaju sve lampice par puta,pa se ugase i izbaci mi gresku led error.Upalim auto i posle par trenutka,ili se popravi,ili moram da iskljucim auto,pa da nekoliko puta da dajem kontakt,dok ne bude normalno.Sta bi to moglo da bude,zna li neko?U pitanju je punto mk2a Quote Share this post Link to post Share on other sites
profa_chb 18 Posted January 17, 2014 Led error, to bi trebalo da znači da ti neka od signalnih lampica ne radi. Je l' ti sve lampice rade? Quote Share this post Link to post Share on other sites
markosdbg 0 Posted January 17, 2014 Rade sve lampice,u tome i jeste fora. Danas mi se to ni jednom nije desilo,sto ne znaci da nece u buducnosti. Quote Share this post Link to post Share on other sites
markosdbg 0 Posted April 4, 2014 Evo sta se desava sa mojom tablom.Vec sam postavio klip na forumu,ali reko ajde i ovde https://www.youtube.com/watch?v=zWW0yTFdslI Quote Share this post Link to post Share on other sites
endbringer 15 Posted April 6, 2014 Akumulator? Послато са GT-I9300 уз помоћ Тапатока Quote Share this post Link to post Share on other sites
markosdbg 0 Posted April 7, 2014 Akumulator je star godinu dana.Послато са Telenor Touch Plus користећи Тапаток 2 Quote Share this post Link to post Share on other sites
Veki 8 Posted April 7, 2014 +1 za akumulator moj je star dva meseca pa nevalja Quote Share this post Link to post Share on other sites
markosdbg 0 Posted April 7, 2014 Pa bas cu danas da odem kod ovih da proverim,gde sam kupio. Imam 3 godine garanciju. Mada normalno pali,bez problema.Послато са Telenor Touch Plus користећи Тапаток 2 Quote Share this post Link to post Share on other sites
Chika Kure 6 Posted April 10, 2014 (edited) Nije akumulator, Crkla ti je neka ili sve diode u Alternatoru (na takozvanom regleru-regulatoru izlaznog napona iz alternatora), proveri i servisiraj altrenator, ocosti i dotegni sve mase od akumulatora do alternatora ....itd itd. Sa novim akumulatorom ce da pali odlicno neko krace vreme( par dana) dok ne izgubi snagu zato sto alternator ne moze da ga dopuni dovoljno Edited April 10, 2014 by Čika Kure Quote Share this post Link to post Share on other sites
markosdbg 0 Posted April 10, 2014 Nije akumulator, Crkla ti je neka ili sve diode u Alternatoru (na takozvanom regleru-regulatoru izlaznog napona iz alternatora), proveri i servisiraj altrenator, ocosti i dotegni sve mase od akumulatora do alternatora ....itd itd. Sa novim akumulatorom ce da pali odlicno neko krace vreme( par dana) dok ne izgubi snagu zato sto alternator ne moze da ga dopuni dovoljno Merio sam punjenje alternatora,kad ukljucim sve potrosace preko 14 je.Akumulator imam vec godinu dana i auto sjajno pali,bez problema.Ovo sa tablom mi se desava par meseci,ali ne stalno,kad mu dodje. Quote Share this post Link to post Share on other sites
Chika Kure 6 Posted April 11, 2014 Marko,ne mogu da vidim na snimku kako izgleda zuta lampica koja treperi par puta ? Quote Share this post Link to post Share on other sites
markosdbg 0 Posted April 11, 2014 Mislis od airbag-a?Послато са Telenor Touch Plus користећи Тапаток 2 Quote Share this post Link to post Share on other sites
markosdbg 0 Posted April 14, 2014 Drugari,da li se meni cini,ili mi je tabla KREPALA NACISTO https://www.youtube.com/watch?v=X5GL-E_Gk8o&feature=youtu.be Quote Share this post Link to post Share on other sites
markosdbg 0 Posted April 14, 2014 Da li neko mozda moze da mi kaze da li moze tabla od sportinga na moj auto? Quote Share this post Link to post Share on other sites
