Mijailović P. 3449 Posted February 16, 2014 Stvarno ne znam. Ovako , ne izgleda lose. Nisam zagledao podkrilo a nisam ni primetio nista neobicno u vezi lajsne. Cu poglecnem ! Sigurno znas neku istoriju ? Quote Share this post Link to post Share on other sites
Martini 11 Posted February 16, 2014 Pre neki dan sam slao u zr delove za novog vlasnika jednog Thesisa. Quote Share this post Link to post Share on other sites
Mijailović P. 3449 Posted February 17, 2014 Jeste, da ! Lajsna i podkrilo. Sad, dosta zahembancije vec ako neko moze pomoci neka se javi ! Ne znam ni jezik sa 'taljanskog da prebacim na ... Quote Share this post Link to post Share on other sites
neshaoct 9592 Posted February 17, 2014 Osnovnih stvari ima ovde:http://www.fiat-lancia.org.rs/forum/index.php?/topic/38858-uputstvo-lancia-thesis/ Quote Share this post Link to post Share on other sites
Martini 11 Posted February 17, 2014 (edited) Ne znam ni jezik sa 'taljanskog da prebacim na ... Ne mozes ni da prebacis bez update cd-a. Problem je sto ni jedan koji sam ja trazio da skinem na netu ne radi. Original cd je bio u Vozdovcu 300e i to da se naruci. Neka fala. ... i ne zezajte se mnogo oko Connecta na Thesisu da ne bi bilo belaja. Bice jeftinije da nabaci navigaciju na soferku i da vozi. Edited February 17, 2014 by Martini Quote Share this post Link to post Share on other sites
Mijailović P. 3449 Posted February 18, 2014 Necemo se zezati cika Martini ! Sta deca znaju sta su halteri ?! Quote Share this post Link to post Share on other sites
Mijailović P. 3449 Posted March 7, 2014 Poskkidao sam te mape i svašta - nešto ali ne čita CD! Kanda je lejzer baciJo kašiku. :-( Quote Share this post Link to post Share on other sites
Martini 11 Posted March 7, 2014 I to hoce da se desi... Nazalost Quote Share this post Link to post Share on other sites
LANCIATHESIS 0 Posted May 8, 2015 U Thesisa cd se stavja naopako. Quote Share this post Link to post Share on other sites
Mijailović P. 3449 Posted May 8, 2015 Nisi morao sada... Dobro, možda nekom zatreba. Quote Share this post Link to post Share on other sites
torla 0 Posted April 2, 2016 Sa itelijanskog na engleski pls download CD. Quote Share this post Link to post Share on other sites
torla 0 Posted April 13, 2016 jezik je preveden, parkin kamera ovdje pise da pashe za Thesis interesuje me kako je prikopcadi da se vidi na lcd-u. Quote Share this post Link to post Share on other sites
Uros D 0 Posted September 11, 2016 (edited) Pozdrav, da li neko zna dobrog majstora za otkljucavanje-osposobljavanje navigacije na Lancia Thesis-u? kada se pritisne na dugme Navigacija pokazuje tekst "Navigation not available". Interesuje me majstor na podru;ju Novog Sada i okoline, moze i Subotica. Hvala Edited September 14, 2016 by neshaoct spojeno Quote Share this post Link to post Share on other sites
lan_fan 36 Posted September 13, 2016 nema takvog majstora nadaleko i naširoki. Quote Share this post Link to post Share on other sites
neshaoct 9592 Posted September 14, 2016 @Uros D @lan_fan On 4/3/2013 at 11:30 PM, stevaalegro said: ...Svi thezisi imaju sav hardver sto se tice conect sistema samo je na nekim modelima nesto od tog hardvera blokirano pa prikazuje kao da nema tel.navigaciju... veceras sam nasao neki nemacki forum gd neki tip pise da je uspeo da hakuje connect sistem i da "otkljuca" navigaciju. Saljem link sutra On 4/4/2013 at 1:10 PM, stevaalegro said: http://www.viva-lancia.com/lancia_fora/read.php?99,1087242,1087620#msg-1087620 Ali, izgleda na tom linku više nema tog sadržaja. Onda: On 2/17/2014 at 9:35 PM, Martini said: i ne zezajte se mnogo oko Connecta na Thesisu da ne bi bilo belaja. Bice jeftinije da nabaci navigaciju na soferku i da vozi. Evo za svaki slučaj notifikacije za @stevaalegro ako je nekim čudom uspeo i sačuvao sadržaj sa tog linka. Quote Share this post Link to post Share on other sites
DimeKg 0 Posted March 26, 2019 (edited) Pozdrav drugari... interesuje me kako da dodjem do Vladimira iz Slovačke odnosno, da rešim promenu jezika na conectu. Hvala unapred Edited March 29, 2019 by neshaoct spojeno Quote Share this post Link to post Share on other sites
Ivan 17670 Posted March 27, 2019 Na Stilovom ConnectNav+ bio je potreban samo dodatni Setup disc (za Language i Voice Recognition). Quote Share this post Link to post Share on other sites
neshaoct 9592 Posted March 29, 2019 @DimeKg Kao što verovatno već znaš, ne može se jezik promeniti bez CD-a. Videćeš da se o tome i pisalo ranije u temi na kojoj smo sada. Quote Language This option makes it possible to set the CONNECT language for the messages/functions shown on the displayand for the voice command dialogs; itis only possible to set one language. Languages available are the following: – D (German) – GB (English UK) – USA (English US) – E (Spanish) – F (French) – I (Italian). To change language, the system requires, through amessage on the display, the SETUP CD (versions without navigation system) or the navigation CD. If the required CD is not inserted thelanguage will not be changed. The language change could take a few minutes, during this period certain CONNECT functions may not be available; in this condition the display will show a dedicated warning message. If the CD is not inserted, the display will show the following message: ''Please insert Setup CD!'' or ''Please insert Navi CD!'' (system fitted with navigation function). Should the inserted CD be not recognized or be unsuitable for language change, the display will show a dedicated warning message. When starting the language change procedure, the system requires the user's confirmation through a dedicated message, press ''Yes'' to continue, otherwise press ''No''. During language change the status bar (indicating that the procedure is inprogress) together with message ''Please wait! Language change inprogress...'' are displayed. This message will stay on until the procedure is over then the system goes back to the screen used to enter the new setting. New language setting remains active also after switching the system off. Vladimir je koristio ovaj Email: vladimir.duro@lanciathesis.eu Trebalo bi da bude i na ovoj FB stranici, tj. da je to on: https://www.facebook.com/lanciathesiseu Quote Share this post Link to post Share on other sites
Dark Phoenix 2 Posted August 24, 2020 Pozdrav ljudi, Da li je mozda neko skoro na neki nacin uspeo da ubaci mapu Balkana (Ili mozda samo mapu Srbije)? Sve linkove koje sam nasao ovde su generalno stari. Cuo sam se sa Vladimirom iz Slovenije ali nazalost nema mapu Srbije. Naravno, zanima me za Thesisa. Quote Share this post Link to post Share on other sites
lan_fan 36 Posted August 25, 2020 13 hours ago, Dark Phoenix said: Pozdrav ljudi, Da li je mozda neko skoro na neki nacin uspeo da ubaci mapu Balkana (Ili mozda samo mapu Srbije)? Sve linkove koje sam nasao ovde su generalno stari. Cuo sam se sa Vladimirom iz Slovenije ali nazalost nema mapu Srbije. Naravno, zanima me za Thesisa. kratko rečeno: ZABORAVI. Quote Share this post Link to post Share on other sites
GreatMondello 0 Posted April 7, 2023 Pozdrav drugari. Moze li pomoc sa update cd-om za thesis-a? Gde ga naci? Ne zanimaju me mape, samo update cd da promenim jezik sa `talijanskog. Quote Share this post Link to post Share on other sites
GreatMondello 0 Posted April 7, 2023 1 hour ago, GreatMondello said: Pozdrav drugari. Moze li pomoc sa update cd-om za thesis-a? Gde ga naci? Ne zanimaju me mape, samo update cd da promenim jezik sa `talijanskog. U medjuvremenu je Vladimir odgovorio(sjajan lik), dobih cd, sad samo da ga sprzim i ubacim a za mape cu se svojski potruditi pa ako nesto uspem, kacim ovde, ako uopste i dalje ima interesenata za temu. Quote Share this post Link to post Share on other sites
