saledelagano 26 Posted July 1, 2014 KAd se uzme ova blutut varijanta, jel imate za preporuku neki programcic za android ? Quote Share this post Link to post Share on other sites
Nidzo 2 Posted July 1, 2014 Torque Pro (OBD 2 & Car) Quote Share this post Link to post Share on other sites
saledelagano 26 Posted July 1, 2014 Ovo je verzija koja se placa, dz verovatno ne moze pola toga a ? Quote Share this post Link to post Share on other sites
Nidzo 2 Posted July 1, 2014 Ima "narodna" verzija. Quote Share this post Link to post Share on other sites
saledelagano 26 Posted July 1, 2014 Baci link na PP ako imas Quote Share this post Link to post Share on other sites
Prijatelj 4 Posted July 2, 2014 KAd se uzme ova blutut varijanta, jel imate za preporuku neki programcic za android ? Uz ELM327 bluetooth dobijate (pored ostalog) TorquePro sa svim dostupnim funkcijama. Pozdrav Quote Share this post Link to post Share on other sites
Prijatelj 4 Posted August 18, 2014 Obaveštavamo sve zainteresovane mušterije da smo od 04.08.2014. godine postali ovlašćeni distributeri za Multiecuscan i to za područje Srbije, Bosne i Hercegovine, Crne Gore i Makedonije. Sajt www.multiecuscan.rs je u izradi, a do puštanja sajta u rad možete nam se obratiti putem e-pošte na adresu: info@multiecuscan.rs ili putem poruka na ovom forumu. Pozdrav Quote Share this post Link to post Share on other sites
Kuvalja 406 Posted August 18, 2014 Cestitam i zelim uspeh. Quote Share this post Link to post Share on other sites
deki87 7 Posted September 10, 2014 Koja je cena za zeleni adapter? Quote Share this post Link to post Share on other sites
Prijatelj 4 Posted September 11, 2014 Trenutno nemamo rasparen A1 adapter. Pozdrav Quote Share this post Link to post Share on other sites
Markobgd 609 Posted September 11, 2014 Koliko bi izašao komplet koji je potreban za navedeno vozilo? Evo slika: Quote Share this post Link to post Share on other sites
Prijatelj 4 Posted September 11, 2014 (edited) Za ovo vozilo je potreban ELM327 u bluetooth ili USB varijanti (po želji) i adapter A1. Adapter A1 je potreban samo za ABS i servo volan i u tim slučajevima se može koristiti i KKL sa DIP prekidačem. Dakle, postoje dve opcije: 1) ELM327 + A1 adapter2) ELM327 + KKL sa DIP prekidačem Trenutni problem je što nemamo na stanju odvojeno samo adapter A1 već samo ceo komplet adaptera A1+A2+A3 pa su cene po ovim varijantama: 1) 5000,00rsd (ELM327 USB) odnosno 4500,00rsd (ELM327 BT) - sa celim kompletom adaptera A1+A2+A32) 4500,00rsd (ELM327 USB) odnosno 4000,00rsd (ELM327 BT) Na Vama je da odlučite šta Vam je najjednostavnije. Na navedene cene važi popust od 20% za članove Kluba. Pozdrav Edited September 11, 2014 by Prijatelj Quote Share this post Link to post Share on other sites
Markobgd 609 Posted September 11, 2014 Hvala. Javljam kad se odlučim. Quote Share this post Link to post Share on other sites
deki87 7 Posted September 22, 2014 Ima elm 327 i A1 adapter sa kojim mogu da citam eps,i abs,sta jos moze da se cita sa ovim adapterom,da limoze da se brise servisni interval? Quote Share this post Link to post Share on other sites
Prijatelj 4 Posted September 23, 2014 Niste naveli za koje vozilo Vas interesuje informacija, ali svakako u svakom trenutku možete pogledati listu podržanih funkcija na zvaničnom sajtu Multiecuscan-a: http://www.multiecuscan.net/SupportedVehiclesList.aspx Pozdrav Quote Share this post Link to post Share on other sites
deki87 7 Posted September 23, 2014 U pitanju je Fiat Stilo 1.9jtd. Quote Share this post Link to post Share on other sites
Zarkusi 2 Posted September 23, 2014 (edited) Potreban mi je kabl/adapter koji u multiecuscan-u moze da iscita body sekciju i da pristupi i odradi CAN Setup/proxy alignment? Konkretno hocu da upalim lampicu tempomata posle ugradnje i sve to na autu iz profila. Vag/kkl imam ali on to ne moze. Pozdrav Edited September 23, 2014 by Zarkusi Quote Share this post Link to post Share on other sites
Prijatelj 4 Posted September 24, 2014 Prema specifikaciji proizvođača Multiecuscan-a: http://www.multiecuscan.net/SupportedVehiclesList.aspx Potreban Vam je ELM327 za pristup Body računaru i Proxy procedurama. ELM327 postoji u USB i bluetooth varijanti, ali je za Proxy procedure ipak preporuka USB varijanta zbog stabilnosti veze. Pozdrav Quote Share this post Link to post Share on other sites
Zarkusi 2 Posted September 24, 2014 Koja je cena USB varijante kod vas i da li bi poslali za Niš? Quote Share this post Link to post Share on other sites
Prijatelj 4 Posted September 25, 2014 Kao što stoji na sajtu, USB verzija je 2000,00rsd i normalno šaljemo kurirskim službama bilo gde u Srbiji. Pozdrav Quote Share this post Link to post Share on other sites
petarcirjanic 70 Posted September 27, 2014 da limoze vag 409 I vcds 12.12 da radi sa win7 -64bit? Quote Share this post Link to post Share on other sites
Prijatelj 4 Posted September 27, 2014 Nemojte mešati uređaje i softvere. Dakle, uređaj VAGCOM 409.1 KKL radi samo i isključivo sa verzijom programa VAGCOM 409.1 i on ne može raditi na 64-bitnom operativnom sistemu. Takođe, program VCDS 12.12 se koristi samo i isključivo uz uređaj VAGCOM 12.12 i on može raditi na 64-bitnom operativnom sistemu. Pozdrav Quote Share this post Link to post Share on other sites
petarcirjanic 70 Posted September 27, 2014 Nisam se dobro izrazio. Hvala. Quote Share this post Link to post Share on other sites
RSS 0 Posted October 3, 2014 Ja imam ELM327 ali ne mogu da vidim podatke sa DPF-a.Koja je onda dijagnostika za mene?!Naravno nesto amaterski, nista fensi nista skupo jer nista oko kola i ne znam. Quote Share this post Link to post Share on other sites
Prijatelj 4 Posted October 6, 2014 Ja imam ELM327 ali ne mogu da vidim podatke sa DPF-a.Koja je onda dijagnostika za mene?!Naravno nesto amaterski, nista fensi nista skupo jer nista oko kola i ne znam. Niste napisali koje je vozilo u pitanju. Ako se radi o vozilu iz garaže, Fiat Bravo 1,9 150KS, za to vozilo Vam je potreban ELM i adapter A1 za potpun pristup svim modulima na vozilu. Pozdrav Quote Share this post Link to post Share on other sites
