ivan.ik 625 Posted July 26, 2014 (edited) Konkurenti Fiat Stilo MW 1.9 JTD 1910 ccm 82x90,4 mm 18,585 kW (115 KS) pri 4000 o/min250 Nm pri 2000 o/min prenosni odnosi....................................................................brzina 4000 o/min 1. 3.577:1 ..............................................................................35.6 km/h 2. 1.887:1 ..............................................................................67.6 km/h 3. 1.192:1 .............................................................................107.0 km/h 4. 0.848:1 .............................................................................150.4 km/h 5. 0.686:1 .............................................................................186.4 km/h R 3.308:1 .............................................................................. 38.5 km/h Dif 3.632:1 120 km/h V ...........................................................................2582 o/min 130 km/h V ...........................................................................2797 o/min 150 km/h V ...........................................................................3227 o/min 0-100 km/h- 11.2 s max (fabrička)........................................................190 km/h pri 4088 o/min 0-100 km/h 11,2 spneu 205/55 R 16 O=1.930 m H-1,580 m M- 1430 - 1480 kg Cd 0,31potrošnja 7,5/4,4/5,6 l 100 km Ford Focus Turnier MK1 1.8 TDCI 1753 ccm 82,5x82 mm 18,585kW (115 KS)/ 3800 o/min250 Nm / 1850 o/minprenosni odnosi..................................................................brzina pri 4000 o/min1. 3.66:1................................................................................36,10 km/h2. 2,14:1................................................................................61,70 km/h3. 1.45:1............................................................................... 91,10 km/h4. 1,03:1...............................................................................128,20 km/h5. 0.77:1...............................................................................171,50 km/h Dif 3.41 120 km/h ...............................................................................2799 o/min130 km/h ...............................................................................3032 o/min150 km/h................................................................................3499 o/minmax 196 km/h..........................................................................4572 o/min 0-100 km/h 11 sH 1.532 m M=1240 kg Cd 0,32pneu 195/60 R15 O=1.876 m potrošnja 7,2/4,4/5,5 l 100 km Edited July 26, 2014 by ivan.ik Quote Share this post Link to post Share on other sites
Rile_bg 347 Posted August 10, 2014 @ivan.ik odakle vadis ove podatke? Quote Share this post Link to post Share on other sites
ivan.ik 625 Posted August 11, 2014 Odavde i gde god nađem prenosne odnose u menjaču. Sajt gde ima dosta podataka za vozila vezano za menjače i prenosne odnose itd http://www.automobile-catalog.com/ .Sve što treba skinuti recimo Continentalove tablice (pdf) http://www.conti-online.com/generator/www/de/en/continental/automobile/general/download-area/download/tech_ratgeber_en.pdf sa dimenzijama guma i obimom guma i tačno izračunati broj obrtaja motora zavisno od stepena u menjaču i brzine kretanja vozila (obimi su za nove gume). Odstupanja mogu biti u odnosu na realno (u praksi) stanje zbog istrošenosti pneumatika ili pneumatici drugih dimenzija i odstupanje tj laganje brzinomera. Brzinomer na mom Stilu pokazuje 150 km/h a GPS oko 145 km/h (a obrtaji se slažu sa mojim proračunima). Ne bi bilo loše da neko sa dijagnostikom proveri da li i obrtomer ima odstupanja. Na osnovu rezultata lako se iscrta dijagram menjača. Quote Share this post Link to post Share on other sites
Rile_bg 347 Posted August 11, 2014 a hvala,nasao sam tu onaj grafik sa obrtnim momentom i snagom po obrtajima,e sad me interesuje da li tu moze da se ocita gde je najidealnije menjanje brzina (konkretno za moj auto) ? Quote Share this post Link to post Share on other sites
Ivan 17663 Posted August 12, 2014 (edited) Pitanje je malo opste - sve zavisi sta hoces da postignes saltanjem... Da li je u pitanju optimalna voznja ili minimalna potrosnja ili snaga u preticanju ili...Ako iole poznajes i osecas auto, ovi grafikoncici samo treba da ti potvrde da si u pravu . Edited August 12, 2014 by Ivan Quote Share this post Link to post Share on other sites
Rile_bg 347 Posted August 12, 2014 od dosta ljudi sam cuo da je za sportinga najoptimalnije saltanje izmedju 3000-3500 obrtaja i tad je najmanja i potrosnja,interesuje me dal je to tacno Quote Share this post Link to post Share on other sites
vladan115ph 0 Posted August 13, 2014 ne znam da li je ovo odgovarajuca tema,ali nesto me zivo interesuje.da li je neko probavao kolika je maksimalna brzina na stilu 1.9 jtd 115konja?ako je probavao voleo bi da se javi ovde posto vidim fabricki max brzina je 193km\h.a to sam lako neki dan presao kad sam ga malo pritisnuo Quote Share this post Link to post Share on other sites
MS PK 7732 Posted August 13, 2014 Oko 210-15 po satu Quote Share this post Link to post Share on other sites
vladan115ph 0 Posted August 13, 2014 bili smo ja i drugar u autu i imao sam u gepeku oko 100kg tereta,(imam ga malo vise od godinu dana i nisam ga probavao do maksimale) i kada sam naisao na lep deo puta pritisnuo sam ga i dosao je do 215.osetim kako je to navukao da bi sigurno jos mogao ali morao sam da popustim zbog auta ispred.inace u pitanju je stilo 3 vrata,1.9 jtd, 115 ph 2005 godiste Quote Share this post Link to post Share on other sites
Ivan 17663 Posted August 13, 2014 da li je neko probavao kolika je maksimalna brzina na stilu 1.9 jtd 115konjaNije . Quote Share this post Link to post Share on other sites
vladan115ph 0 Posted August 13, 2014 hehehehehehe jbg nisam ni ja onda trebao da probam Quote Share this post Link to post Share on other sites
kolega.jankovic 23 Posted August 14, 2014 Satovi inace lazu svi. Quote Share this post Link to post Share on other sites
ivan.ik 625 Posted August 14, 2014 Samo ravan deo puta i GPS sve ostalo za lovce i ribolovce. Quote Share this post Link to post Share on other sites
vladan115ph 0 Posted August 14, 2014 da,znam da svi satovi po malo lazu,a to pitanje sam postavio cisto da vidim utiske drugih koji imaju takvog stila.jer par drugara koji su ga vozili kazu da ide kao lud. jedino jedan (mislim) dobar i pomalo ljubomoran drugar koji ima stila karavana 85 ph,mi je rekao pa druze kao ide mozda malo bolje nego moj Quote Share this post Link to post Share on other sites
Buca_Tipo 31 Posted August 14, 2014 Nije li to dejicin brat? Quote Share this post Link to post Share on other sites
ivan.ik 625 Posted August 14, 2014 da,znam da svi satovi po malo lazu,a to pitanje sam postavio cisto da vidim utiske drugih koji imaju takvog stila.jer par drugara koji su ga vozili kazu da ide kao lud. jedino jedan (mislim) dobar i pomalo ljubomoran drugar koji ima stila karavana 85 ph,mi je rekao pa druze kao ide mozda malo bolje nego moj Istina, karavani i pored težine najbolje idu. Quote Share this post Link to post Share on other sites
vladan115ph 0 Posted August 14, 2014 Nije li to dejicin brat?nerazumem na koga mislis? ako se to odnosilo pitanje na mene? ivan.ik ne znam,nisam vozio karavana ali mislim da je glupo i porediti karavana 85 ks,i kupe 115 ks u tome koji bolje ide Quote Share this post Link to post Share on other sites
ivan.ik 625 Posted August 14, 2014 da,znam da svi satovi po malo lazu,a to pitanje sam postavio cisto da vidim utiske drugih koji imaju takvog stila.jer par drugara koji su ga vozili kazu da ide kao lud. jedino jedan (mislim) dobar i pomalo ljubomoran drugar koji ima stila karavana 85 ph,mi je rekao pa druze kao ide mozda malo bolje nego moj Ovo 85 ph mi više vuklo ka 85 kW nego ka 80 KS.Nije bilo Stila sa 85 KS već sa 80. Quote Share this post Link to post Share on other sites
vladan115ph 0 Posted August 14, 2014 da,znam da svi satovi po malo lazu,a to pitanje sam postavio cisto da vidim utiske drugih koji imaju takvog stila.jer par drugara koji su ga vozili kazu da ide kao lud. jedino jedan (mislim) dobar i pomalo ljubomoran drugar koji ima stila karavana 85 ph,mi je rekao pa druze kao ide mozda malo bolje nego moj Ovo 85 ph mi više vuklo ka 85 kW nego ka 80 KS.Nije bilo Stila sa 85 KS već sa 80. u pravu si,moja greska.njegov je 80 ks. greskom sam kucao 85 Quote Share this post Link to post Share on other sites
Markobgd 609 Posted July 11, 2015 Ha, ja tek sad vidim ovu temu Aj za Deltu baci tabelu...ne znam da li je ista kao i za Brava 2.0 što si pisao?Evo ti vodilja da vidiš koliko si tačan! Quote Share this post Link to post Share on other sites
ivan.ik 625 Posted July 13, 2015 Fiat Bravo 2.0 MJ165 KS pri 4000 o/min360 Nm pri 1750 o/min prenosni odnosi brzina pri 4000 o/min1. 3,917:1........................................33.4 km/h2. 2,040:1........................................64.1 km/h3. 1,321:1........................................98.9 km/h4. 0,954:1......................................137.0 km/h5. 0.755:1......................................173.2 km/h6. 0.623:1......................................209.9 km/h R 3.750:1........................................34.9 km/hDif 3.550:1 120 km/h V....................................2772 o/min120 km/h VI...................................2287 o/min130 km/h VI...................................2478 o/min150 km/h VI...................................2859 o/min max...............215 km/h..................4098 o/minpneu........ 225/45 R17...............O=1.934 mmmasa 1360 kgnorma 6.9 / 4.3 / 5.3 l Identični prenosi , samo je mala razlika / kod Jelte se pojavljuje dif 3,56. Mada lako može da bude greška ili nečije zaokruživanje.Uporedi brzine sa GPS-om. Quote Share this post Link to post Share on other sites
Markobgd 609 Posted July 13, 2015 (edited) Pa dobro, vidiš da se otprilike poklapa sa stvarnim stanjem...120 km/h V....................................2772 o/min120 km/h VI...................................2287 o/min130 km/h VI...................................2478 o/min150 km/h VI...................................2859 o/min170 km/h VI..............................3100 o/min190 km/h VI..............................3400 o/min210 km/h VI..............................3750 o/minIma tu prostora za još...bar po satuEdit: odakle vadiš sve ovo?! Edited July 13, 2015 by Markobgd Quote Share this post Link to post Share on other sites
ivan.ik 625 Posted July 13, 2015 izvor ja i ostaliSajt gde ima dosta podataka za vozila vezano za menjače i prenosne odnose itd http://www.automobile-catalog.com/ .Sve što treba skinuti recimo Continentalove tablice (pdf) http://www.conti-online.com/generator/www/de/en/continental/automobile/general/download-area/download/tech_ratgeber_en.pdf sa dimenzijama guma i obimom guma i tačno izračunati broj obrtaja motora zavisno od stepena u menjaču i brzine kretanja vozila (obimi su za nove gume). Odstupanja mogu biti u odnosu na realno (u praksi) stanje zbog istrošenosti pneumatika ili pneumatici drugih dimenzija i odstupanje tj laganje brzinomera. Brzinomer na mom Stilu pokazuje 150 km/h a GPS oko 145 km/h (a obrtaji se slažu sa mojim proračunima). Ne bi bilo loše da neko sa dijagnostikom proveri da li i obrtomer ima odstupanja. Na osnovu rezultata lako se iscrta dijagram menjača. Quote Share this post Link to post Share on other sites
zrnke 41 Posted July 13, 2015 Ha, ja tek sad vidim ovu temu Aj za Deltu baci tabelu...ne znam da li je ista kao i za Brava 2.0 što si pisao?Evo ti vodilja da vidiš koliko si tačan! Nisi vezan na 210..ccc Koliko si je vozio max po satu, bas me interesuje ima li razlike u tih 15KS, s tim da ne znam koliko Delta ima kg, Astri fali koji kg do 1.5t. Quote Share this post Link to post Share on other sites
ivan.ik 625 Posted April 28, 2016 On 7.4.2012. at 9:05 AM, ivan.ik said: Evo jedan primer; Fiat Stilo MW 1.9 JTD 115 ks prenosni odnosi................................brzina 4000 o/min 1. 3.577:1 ...........................................35.6 km/h 2. 1.887:1 ...........................................67.6 km/h 3. 1.192:1 ..........................................107.0 km/h 4. 0.848:1 ..........................................150.4 km/h 5. 0.686:1 ..........................................186.4 km/h R 3.308:1 .......................................... 38.5 km/h Dif 3.632:1 120 km/h V ..........................................2582 o/min 130 km/h V ..........................................2797 o/min 150 km/h V ..........................................3227 o/min 0-100 km/h- 11.2 s max (fabrička)...........................190 km/h pri 4088 o/min pneu......................................205/55 R 16 O=1.930 m Sa dijagnostike . Quote Share this post Link to post Share on other sites
