jevta 251 Posted February 5, 2012 Jutros konstatujem da mi se ne pali lampica ABSa kad se aktivira.Kad dam kontakt pre paljenja sve redovno popali ali kad kocim i aktivira se ABS ne upali lampicu.Imali ko neku ideju zasto? Quote Share this post Link to post Share on other sites
NED 10 Posted February 5, 2012 Ja se ne secam ni na jednom autu koji sam vozio da se ukljuci lampica kada se aktivira ABS, mozda nisam primetio, ne znam... Quote Share this post Link to post Share on other sites
jevta 251 Posted February 5, 2012 Moguce je da ni ne treba da sam ja utripovo da treba Quote Share this post Link to post Share on other sites
boki 10 Posted February 5, 2012 ako ti se upali lampica ABS ti ne radi.. Quote Share this post Link to post Share on other sites
Martini 11 Posted February 5, 2012 Lampica ABS-a se ne pali kad se aktivira, dok lampica od ASR-a i ESP-a treperi prilikom aktiviranja. Quote Share this post Link to post Share on other sites
Mateo 2 Posted February 6, 2012 jefto sve je ok tako treba...ako ti je upali nakon startovanja motora znaci da nesto nije uredu sa njim.. Quote Share this post Link to post Share on other sites
jevta 251 Posted February 6, 2012 Odlicno znaci samo sam ja utripovo da treba da signalizira kad radi ABS.A svakako se nisam mnogo uzbudjavao meni ABS radi pa sad lampica manje vise. Quote Share this post Link to post Share on other sites
pliver 2 Posted December 11, 2014 (edited) Pozdrav, u pitanju je GP 2006 god, 1.3 Mjet. Pre godinu dana se upalila lampica od ABS-a. Dijagnostika kaze prednji levi senzor. Isti je zamenjen ali problem ostaje. Proveravan lezaj, stavljan drugi senzor ali nista. Ima li neko nekakav predlog? Edited December 12, 2014 by neshaoct spojeno Quote Share this post Link to post Share on other sites
Ticma 535 Posted December 11, 2014 Centrala ABS-a? Quote Share this post Link to post Share on other sites
Baccara 0 Posted December 12, 2014 (edited) Na samoj poluosovini treba da ima nazubljeni deo koji taj senzor gadja. Moze da se desi da je ostecen ili debelo zaprljan, pa da ne moze da ocita, ali moze da bude i centrala sto kaze Ticma, mada mislim da u tom slucaju sija i indikator rucne kocnice Edited December 12, 2014 by Baccara Quote Share this post Link to post Share on other sites
golf sdi 2 Posted April 11, 2017 Pre par dana mi se upalila lampica ABS-a. Dijagnostika prijavljuje suvozačev senzor abs-a. Uzimam polovan,namontiram i dok je auto još na dizalici upalim i lampica se ugasila. Nakon nekih dvadesetak kilometara (sve do tad radilo) ponovo lampa, kad ugasim auto i ponovo upalim nestane i posle par minuta ponovo svetli (tako par puta). Posle toga konstantno sija. Odem na otpad i probam još 4 senzora, jedan je još bio na glavčini (navodno tako se proverava čitač na glavčini), i kod svih odmah sija ABS. Da li neko ima ideju šta bi moglo da bude, i kako da utvrdim? I kako da proverim centralu (ako je do nje da li sija još neka greška i da li bi prijavilo na dijagnostici). Quote Share this post Link to post Share on other sites
golf sdi 2 Posted April 23, 2017 Problem je rešen, pa da napišem i kako jer bi možda nekom moglo da bude od pomoći. Problem je bio u dva (kockasta) osigurača koji stoje u u kutiji u motornom prostoru. Zamenjeni i lampa ne sija, a ABS radi. Sve vreme je majstore bunilo to što je prikazivo na dijagnostici da je neispravan senzor ABS-a. Quote Share this post Link to post Share on other sites
plavac 0 Posted July 3, 2017 On 23.4.2017. at 0:15 PM, golf sdi said: Problem je rešen, pa da napišem i kako jer bi možda nekom moglo da bude od pomoći. Problem je bio u dva (kockasta) osigurača koji stoje u u kutiji u motornom prostoru. Zamenjeni i lampa ne sija, a ABS radi. Sve vreme je majstore bunilo to što je prikazivo na dijagnostici da je neispravan senzor ABS-a. Mogu da potvrdim ovakvu priču i na svom primeru. U februaru sam prepakivao tu kutiju (iz drugog razloga) i kada je sve sastavljeno, dotadašnji problem sa ABS, ESP, HILL HOLDER lampicom je prestao da postoji. Od tada rade sve tri funkcije. Quote Share this post Link to post Share on other sites
VozimFiat 1 Posted August 20, 2017 Imam jedno pitanje.Treba da zamenim zadnji desni ABS senzor na Puntu 1,3mjt 2003.Interesuje me dali mora senzor da bude baš od tog modela ili je taj senzor isti za sve Punto 2 sa dobošima pozadi? On 23.4.2017. at 0:15 PM, golf sdi said: Problem je rešen, pa da napišem i kako jer bi možda nekom moglo da bude od pomoći. Problem je bio u dva (kockasta) osigurača koji stoje u u kutiji u motornom prostoru. Zamenjeni i lampa ne sija, a ABS radi. Sve vreme je majstore bunilo to što je prikazivo na dijagnostici da je neispravan senzor ABS-a. Dali se možda sećaš koji su konkretno osigurači bili u pitanju? Šta je bio problem sa njima?Pregoreli?Korodirali kontakti? Quote Share this post Link to post Share on other sites
golf sdi 2 Posted August 20, 2017 Veliki kockasti osigurači u motornom prostoru, ne znam tačno koji, ali svaki električar ti to može proveriti. Ne znam da li su korodirali ili šta, ali su bili neispravni. Quote Share this post Link to post Share on other sites
