petricz 0 Posted December 17, 2011 Da li je neko pokusao da napravi dijagnostiku za LPG ili ako ima neku semu izrade neka postavi . Quote Share this post Link to post Share on other sites
batakolestb 15 Posted December 18, 2011 Koliko ja znam ima da se kupi kod uvoznika za određene marke pa za ACStag košta oko 30 evra Quote Share this post Link to post Share on other sites
galex 0 Posted December 25, 2011 @petriczReklo bi se da sema `pije vodu`(klasika sa MAX232),ali koji softver koristiti za STAG4,npr? Quote Share this post Link to post Share on other sites
Mijailović P. 3449 Posted December 25, 2011 Druze, imas besplatan softver na njihovom sajtu! Quote Share this post Link to post Share on other sites
batakolestb 15 Posted December 30, 2011 Bas tako na sajtu AC postoji softver za svaki ECU besplatno za download Quote Share this post Link to post Share on other sites
petricz 0 Posted January 17, 2012 Ima li neko broj nekog uvoznika auto gas opreme (potreban mi je interfejs za AutoGas Italia)? Quote Share this post Link to post Share on other sites
branko981 0 Posted February 9, 2012 Zna li neko mozda moze li ELM 327 da se upari sa sekventom?Ima li neko program za Stilogas? Quote Share this post Link to post Share on other sites
kanjavi 3 Posted February 12, 2012 Evo jos nesto od mene, mislim da ce vam koristiti! STAG 4, STAG 300plus, uputstvohttp://www.iwebgas.com/Download/mn_Stag-4%20_Stag%20300plus.pdf Quote Share this post Link to post Share on other sites
MMica 0 Posted December 11, 2012 Da malo osvezim temu, posto je napolju veeeeliki sneg i mraz. Dijagnostiku na mom Stilu radim sa ELM 327 1,4 i FES programom sto mi sasvim zadovoljava potrebe, ali posto imam i STAG/LANDI sekvent plinski uredjaj voleo bih da mogu i to da povremeno proverim, jer mi auto na plin kada se dobro zagreje trza i kada mu stisnem gas prebaci na benzin sto po meni indikuje nizak pritisak/dotok plina. Da li kolega Mijaljevic ima tako nesto u ponudi ili zna koga da pitam.Pozdrav Quote Share this post Link to post Share on other sites
Mijailović P. 3449 Posted December 11, 2012 Ne , nemam ja nista slicno... i ne bavim se izradom , trgovinom i slicno. Sebi sam nabavio od jednog lika iz PA i zadovoljan sam.Evo kontakt Pancevacki put 9926232 Starcevo, SrbijaJužno-banatski okrugTelefon 1: 013632576Mobilni: 0654249804 Quote Share this post Link to post Share on other sites
MMica 0 Posted December 12, 2012 OK. Hvala na informaciji. Pozdrav Quote Share this post Link to post Share on other sites
crnisale 17 Posted December 15, 2012 (edited) Ja sam pravio za lovato.Sema je malo prostija od te gore,a ovako izgleda original fabrickiAko pravite i konektor GND (masa) mora biti malo duza od ostalih pinova. Edited December 15, 2012 by crnisale Quote Share this post Link to post Share on other sites
TheWickerMan 928 Posted December 15, 2012 A koji si software koristio? I ovo je i za Fast i za Smart? Quote Share this post Link to post Share on other sites
crnisale 17 Posted December 22, 2012 Imam lovato smart sistem i za njega sam ga i pravio.Interface je isti za stag i jos neke,ali su konektori i raspored pinova drugaciji.Koristim software lovato 1.6.1 ,a u njemu nasao "EASY FAST SMART control unit" odradio podesavanja i to je to.Ako nekog zanima, mogu postaviti proceduru podesavanja.Ne bavim se ugradnjom gasa,niti me to interesuje.Poznati problem sa gasenjem,trzanjem,paljenjem check engine me nateralo da se i ovim pozabavim. Quote Share this post Link to post Share on other sites
TheWickerMan 928 Posted December 22, 2012 Postavi slobodno,ja se neću buniti Quote Share this post Link to post Share on other sites
galex 0 Posted March 21, 2013 Evo i seme na koju je mislio crnisale...P.S.ima li neko iskustva oko podesavanja mape za STAG plinske uredjaje? Quote Share this post Link to post Share on other sites
petricz 0 Posted March 23, 2013 Na Limundu sam kupio Usb kabl sa Max 232 cipom za Autogas Italia sa tri zice RX TX GND ima i sa cetiri. Na nihovom sajti skinuo program i sve funkcionise besprekorno tako da se ne morate muciti da pravite.Ako nadjem poslacu link pa kome treba nema kupi.Ja sam ga platio 300 din.http://www4.slikomat.com/13/0323/jre-IMG-20.jpg Quote Share this post Link to post Share on other sites
prof.stefan 0 Posted September 16, 2013 Druze mozes li pustiti link za ovaj usb kabal sa max 323 chipom. Quote Share this post Link to post Share on other sites
crnisale 17 Posted June 20, 2016 Novi soft 1.8.1 sa usb kablom i drajvere za win 8 http://www.ecoengines.eu/eco_partner/index.php?kat=25_4&pid=e58f468e2d19caf845e76e3da6d92165_825 Povezivanje preko modula USB-TTL - 400rsd Paznja! Jako bitno da se iskljuce opcije za stednju energije baterije na laptopu,jer se desavalo da zablokira posle 15s. Quote Share this post Link to post Share on other sites
jevta 251 Posted June 21, 2016 Jel to radi za Landi Quote Share this post Link to post Share on other sites
Coa123 0 Posted June 21, 2016 A za BRC? Sent from my LG-D802 using Tapatalk Quote Share this post Link to post Share on other sites
crnisale 17 Posted June 22, 2016 (edited) Ja imam lovato.Isti interfejs bi trebalo da moze i kod drugih,jer je stari mogao.Razlika je sto se vise ne koristi 12V za napajanje interfejsa ,jer isto dobija sa usb-a. Znaci povezujete samo masu(GND) ,RXD i TXD. Naravno koristite softver za svoj sistem! Edited June 22, 2016 by crnisale Quote Share this post Link to post Share on other sites
