saleTIPO 3 Posted December 14, 2011 Boki,priznaj da si ga ovo terao nizbrdo Auto ide Jos da vidimo maximalnu Quote Share this post Link to post Share on other sites
boki 10 Posted December 14, 2011 (edited) Evo priznajem Edited December 14, 2011 by boki Quote Share this post Link to post Share on other sites
saleTIPO 3 Posted December 14, 2011 ko prizna pola mu se... doda Quote Share this post Link to post Share on other sites
kole 2 Posted December 14, 2011 (edited) Da bi moglo tačno da se očitatrecahttp://www.youtube.com/watch?v=axwdzJKdpK4četvrtahttp://www.youtube.com/watch?v=Arux-Yx71DEVeoma dobar rezultat iako si išao sa malim zaletom. Edited December 14, 2011 by kole Quote Share this post Link to post Share on other sites
chela 2 Posted December 14, 2011 Kole, ne znas ti koja je muka da on zadrzi konstantnu brzinu :D Decko je blago petardiran i kod njega ne postoji konstantan gas, vec samo stisnut ili pusten gas. Ned'o bog nikome da se vozi duze vreme na auto putu s njim, taj provereno zabada morsku boles'!!! Quote Share this post Link to post Share on other sites
filipovic 0 Posted December 14, 2011 Sa ovakvom radnom temperaturom po ovolikom gasu??? i posle ne valja Stilo brzo crkava turbina pa normalno Quote Share this post Link to post Share on other sites
STILISTA 2 Posted December 14, 2011 (edited) pa na prvoj tacki po satu cim pocne da se dize kazaljka ima vec 50 stepeni.na ovoj drugoj crti ima 70 i tu nema sta da crkne i rikne!samo cepaj pun gas i ne sekiraj se za turbinu i karike! Edited December 14, 2011 by STILISTA Quote Share this post Link to post Share on other sites
Vule 791 Posted December 14, 2011 Ide Stilo kao zmaj! Quote Share this post Link to post Share on other sites
FantomX 5 Posted December 14, 2011 A ima li dima?Nije bas ubedljiv 3. 80-120km\h. Ali ide jako lepo. Quote Share this post Link to post Share on other sites
boki 10 Posted December 14, 2011 kad budem hteo da bude ubedljiviji javicu se tebi da dosolis malo,nacicu negde poklon vaucer za mapiranje... Quote Share this post Link to post Share on other sites
Dr cosworth 5 Posted December 14, 2011 Ja znam kako se ovo resava da ne bude nedoumica samo nam treba pravac pada vidimo razliku Nije bas ubedljiv 3. 80-120km\h. Ali ide jako lepo.Ako hoces nesto ubedljivo uvek mogu da te provozam u cosworthu pa da osetis sta su medju ubrzanja kad budem hteo da bude ubedljiviji javicu se tebi da dosolis malo,nacicu negde poklon vaucer za mapiranje... Opet kuhinjski izrazi Quote Share this post Link to post Share on other sites
Amater 0 Posted December 14, 2011 Ej, super je zanimljivo na forumu pa ovde se razvije diskusija ni iz cega ocas posla Quote Share this post Link to post Share on other sites
FantomX 5 Posted December 14, 2011 Cini mi se samo ono sto sam rekao, ne mora da znaci da je lose, ja to nisam ni merio, vec onako od oka, ne zamerite mi Quote Share this post Link to post Share on other sites
kole 2 Posted December 14, 2011 (edited) Onaj ko misli da je ovo loše neka pogleda kako ide: Jaguar S V8 4.2http://www.youtube.com/watch?v=b0jrdSUBeWEBMW 530 d ili Stilo mjet 16v malo dopingovanhttp://www.youtube.com/watch?v=4wsQOLETIs4 Edited December 14, 2011 by kole Quote Share this post Link to post Share on other sites
FantomX 5 Posted December 14, 2011 Rekoh ucinilo mi se da je lose - videcu sutra da usnimim svoja kola, nekako mi se cini da u 3. stepenu ide/vuce bolje. Bez zlih namera Quote Share this post Link to post Share on other sites
chela 2 Posted December 14, 2011 Ok je kad izmeris da javis i kazes da auto ne ide. Gledali smo Vulov snimak gde je vreme slicno Bokijevom sa optimum mapom, sto znaci da Stilo bolje poteze sa optimum mapom renomiranog proizvodjaca, nego sa Power mapom nekog drugog domaceg tunera, koja je na Dynu bila jaca samo 4KS i 4Nm a ubrzanja se znatno razlikuju. Da napomenem da je od 0-100 sa prethodnom mapom bilo 8.5sec. a sada skoro 1 sec. manje, od 80-120 u 4. je bilo oko 6sec. kad je boki bio sam u kolima a sad sa dvoje u kolima bilo ispod 6... ne znam tacno, moram da proverim a u 3. je sad 1. put izmereno od 80-120.P.S Mislim da nema potrebe da pokusavas da meris ubrzanja na bravu od 80-120 u 3. posto je menjac dosta kraci i ne verujem da ce do 5000rpm uspeti da napuni 120Kmh. Quote Share this post Link to post Share on other sites
FantomX 5 Posted December 14, 2011 Videcu sutra, mislim da moze da izgura do 120, limiter je pomeren na 5000rpm, pa zapuca malo ako ne presaltas, ima cut off. Mislim da sam se istripovao, sad kontam da je sub 6sec dobar rezultat! Quote Share this post Link to post Share on other sites
Dr cosworth 5 Posted December 14, 2011 A od kada se to mere medju ubrzanja u 3 i 4?Valjda ti medju ubrzanje treba u 5 ili 6 Quote Share this post Link to post Share on other sites
Vule 791 Posted December 15, 2011 (edited) Gledali smo Vulov snimak gde je vreme slicno Bokijevom sa optimum mapom, sto znaci da Stilo bolje poteze sa optimum mapom renomiranog proizvodjaca, nego sa Power mapom nekog drugog domaceg tuneraDa, ali Stilo u odnosu na Bravu ima 15KS i 50Nm više u startu, dakle drastična razlika. Jeste malo teži, neznatno, ali mu daleko više znači jači motor... Edited December 15, 2011 by Vule Quote Share this post Link to post Share on other sites
neshaoct 9590 Posted December 15, 2011 Koliko ono beše KS sada ima tvoja Brava na točku, tj. koliko konja su dali oni valjci kod Žeravice...142? Quote Share this post Link to post Share on other sites
Vule 791 Posted December 15, 2011 Da, mada to od početka uzimam sa rezervom, zbog neutvrđene tačnosti valjaka... Quote Share this post Link to post Share on other sites
Amater 0 Posted December 15, 2011 Tuneri, evo vam link gde neka firma iz bgd prodaje kojekakva cuda i za 75 evra mozete kupite alat ( neki Galeto ili slicno ) i nekih 4000 tuning mapa za kojekakva kola i udri po mapiranju do mile volje http://autoobdshop.com/19-chiptuning/41-galletto-1260-ecu-chip-tuning.html?sid=a23a79d797ab7a1b9fa1147aac28b433Odmah moze ko god hoce da se nazove "tunerom" , e sad kakve su mape i sta je unutra, bem li ga Snimis mapu, prekrstis se i sednes da probas pa sta ti bog da Zvao sam ih i naravno, niko tu nista ne garantuje...Sve je na bazi ako hoces probaj pa sta bude al na svoju odgovornost( valjda za 75 evra ne treba drugo ni ocekivati ) Quote Share this post Link to post Share on other sites
chela 2 Posted December 15, 2011 Tuneri, evo vam link gde neka firma iz bgd prodaje kojekakva cuda i za 75 evra mozete kupite alat ( neki Galeto ili slicno ) i nekih 4000 tuning mapa za kojekakva kola i udri po mapiranju do mile volje http://autoobdshop.com/19-chiptuning/41-galletto-1260-ecu-chip-tuning.html?sid=a23a79d797ab7a1b9fa1147aac28b433Odmah moze ko god hoce da se nazove "tunerom" , e sad kakve su mape i sta je unutra, bem li ga Snimis mapu, prekrstis se i sednes da probas pa sta ti bog da Zvao sam ih i naravno, niko tu nista ne garantuje...Sve je na bazi ako hoces probaj pa sta bude al na svoju odgovornost( valjda za 75 evra ne treba drugo ni ocekivati ) Al su te zaxxxxebali za 75 jura Quote Share this post Link to post Share on other sites
neshaoct 9590 Posted December 15, 2011 Ae sad svi pogledajte naslov teme. Zato je deo ovde:http://www.fiat-lancia.org.rs/forum/index.php?showtopic=45802&view=findpost&p=787127 Quote Share this post Link to post Share on other sites
