neshaoct 9590 Posted July 7, 2014 Bilo koja dijagnostika koja može da uradi (pristupi) tablu. Ovako se radi reset:http://www.fiat-lancia.org.rs/forum/index.php?/topic/44243-fiat-stilo-service-due-resetovanje-servisa/Nemoj da te buni što piše Stilo, isto je i kod tvog auta. 1 Ljukigrobar reacted to this Quote Share this post Link to post Share on other sites
punto75 0 Posted August 31, 2014 (edited) pozdrav svima uradio sam diagnostiku u mom Puntu mk1 75 97god.i imao sam 2 error ali ne znam sta znaci1.Mixture ratio Max LEAN2.Autocallibration Parameter Max LEANsta znaci ovih codi ako znate da mi pomognete? Edited September 1, 2014 by neshaoct spojeno Quote Share this post Link to post Share on other sites
neshaoct 9590 Posted September 1, 2014 Odnos vazduha i goriva nije ok. Pogledaj svećice, pogledaj filter vazduha. Ovo LEAN znači da je smeša takva da imaš više vazduha nego što treba. Quote Share this post Link to post Share on other sites
punto75 0 Posted September 1, 2014 hvala sam sam resio danas problem je vio jedan crev zamjenio sam insad sve ok je Quote Share this post Link to post Share on other sites
gorans90 0 Posted November 3, 2014 (edited) Pozdrav ljudi, Da li neko moze da mi objasni koje greske predstavljaju sledeci kodovi? P1135P0105U1602 Znaci bio je povezan na dijagnostiku auto i izbacene su ove greske. Unapred hvala. Edited November 3, 2014 by neshaoct spojeno Quote Share this post Link to post Share on other sites
deki87 7 Posted November 3, 2014 Ne znam napamet ova druga ako nije map senzor,ostalo mogu da javim veceras...naci ce se neko da ti kaze ako ne javicu ti. Quote Share this post Link to post Share on other sites
gorans90 0 Posted November 3, 2014 Ajde javi molim te. Cisto da znam sta mi je raditi.. Hvala Deki. Quote Share this post Link to post Share on other sites
gogi1101 0 Posted November 3, 2014 (edited) P1135 = "Oxygen sensor heater resistance Bank 1 (Pre-cat)-lambda sondaOBD Code P0105refers to The MAP (Manifold Absolute Pressure ili MAP U1602 greska u CAN komunikaciji-nebitna greska Edited November 3, 2014 by gogi1101 Quote Share this post Link to post Share on other sites
gorans90 0 Posted November 3, 2014 Pre svega hvala na odgovoru.. I jel mozes samo za ovu drugu po redu gresku da mi kazes na sta se tacno odnosi i koliko ozbiljno da je shvatim posto nisam bas skapirao. Hvala jos jednom. Quote Share this post Link to post Share on other sites
deki87 7 Posted November 3, 2014 Ta se odnosi na senzor koji meri apsolutni pritisak u usisnoj grani ili ti map senzor,kad on zeza auto nece ili slabije ide. Quote Share this post Link to post Share on other sites
SrdjanNS86 20 Posted November 3, 2014 Pozdrav ljudi, Da li neko moze da mi objasni koje greske predstavljaju sledeci kodovi? P1135P0105U1602 Znaci bio je povezan na dijagnostiku auto i izbacene su ove greske. UnapredPrva ti je "Grejanje lambda sonde, red 1 – sen 1Druga ti je"Senzor apsolutnog pritiska usisne grane (MAP)/senzor atmosferskog pritiska (BARO) - kolo neispravno radiTreca i najgora mislim je greska CAN linije sto moze biti da je problem do neke instalacije,ali neka neko iskusni jos kaze nesto o ovome mislim da ce ti "neshaoct" bolje objasniti jer je vec pricao o tome a evo ovde http://www.fiat-lancia.org.rs/forum/index.php?/topic/60813-fiat-stilo-16-jtd-mjet-prijavljuje-can-liniju/ Quote Share this post Link to post Share on other sites
gogi1101 0 Posted November 3, 2014 ta druga se odnosi na MAP senzor kao sto rece deki87,ali moze da se javi i ako brljavi klapna gasa,ako su ozicenja do MAP -a i klapne labava.Moj predlog je da proveris zice do map -a i klapne ,eventualno uradis kalibraciju klapne i map senzora.Ako ti Auto dobro ide,samo obrisi greske i vozi pa nakon par dana proveri greske dijagnostikom.Ako su i dalje tu Auto mora da ima simptome tipa gusenja,slabije vuce.... Quote Share this post Link to post Share on other sites
gorans90 0 Posted November 4, 2014 Brisao sam greske i one su se vracale, ali nikakve promene na autu nisam primetio zaista. Sasvim normalno ide i vuce. Quote Share this post Link to post Share on other sites
deki87 7 Posted November 4, 2014 Mozda i ne vuce kako treba,ko zna od kada su te greske mozda si ga tako i kupio... Quote Share this post Link to post Share on other sites
gorans90 0 Posted November 4, 2014 Pa to sad je vec diskutabilno. Kod mene je auto od marta i radi isto. Da li ta greska moze da ima veze s tim sto nemam katalizator? A ova greska U1602, da li ona moze da se vezuje za neke sijalice i slicno, posto koliko sam skapirao ona mi se na instrumental tabili prikazuje kao ona zuta sijalica sa uzvicnikom. A znam da sam menjao zadnje stop svetlo i da sam stavio slabiju sijalicu nego sto je pre bila. Quote Share this post Link to post Share on other sites
cileee 1 Posted November 7, 2014 Sta znaci sledece? Quote Share this post Link to post Share on other sites
zrnke 41 Posted November 8, 2014 Cile, kod tebe je HDI Quote Share this post Link to post Share on other sites
kanjavi 3 Posted November 9, 2014 P0000 Nije pronadjena nijedna greska P0010 Aktuator pozicije bregaste osovine (CMP) , usis/levo/napred, grupa 1 - kolo neispravno radi P0011 Pozicija bregaste osovine (CMP) , usis/levo/napred, grupa 1 - suvise rano vreme paljenja/rad sistema P0012 Pozicija bregaste osovine (CMP) , usis/levo/napred, grupa 1 - suvise kasno vreme paljenja P0013 Aktuator pozicije bregaste osovine (CMP) , usis/levo/napred, grupa 1 - kolo neispravno radi P0014 Aktuator pozicije bregaste osovine (CMP) , izduv/desno/pozadi, grupa 1 - suvise rano vreme paljenja/rad sistema P0015 Aktuator pozicije bregaste osovine (CMP) , izduv/desno/pozadi, grupa 1 - suvise kasno vreme paljenja P0020 Aktuator pozicije bregaste osovine (CMP) , usis/levo/napred, grupa 2 - kolo neispravno radi P0021 Pozicija bregaste osovine (CMP) , usis/levo/napred, grupa 2 - suvise rano vreme paljenja/rad sistema P0022 Pozicija bregaste osovine (CMP) , usis/levo/napred, grupa 2 - suvise kasno vreme paljenja P0023 Aktuator pozicije bregaste osovine (CMP) , izduv/desno/pozadi,grupa 2 - kolo neispravno radi P0024 Pozicija bregaste osovine (CMP) , izduv/desno/pozadi, grupa 2- suvise rano vreme paljenja/rad sistema P0025 Pozicija bregaste osovine (CMP) , izduv/desno/pozadi, grupa 2- suvise kasno vreme paljenja P0030 Lambda sonda (HO2S) 1, grupa 1, kontrola grejaca - kolo neispravno radi P0031 Lambda sonda (HO2S) 1, grupa 1, kontrola grejaca - niska vrednost u kolu P0032 Lambda sonda (HO2S) 1, grupa 1, kontrola grejaca - visoka vrednost u kolu P0033 Ventil za regulaciju radnog pritiska u turbo punjacu (TC) - kolo neispravno radi P0034 Ventil za regulaciju radnog pritiska u turbo punjacu (TC) - niska vrednost u kolu P0035 Ventil za regulaciju radnog pritiska u turbo punjacu (TC) - visoka vrednost u kolu P0036 Lambda sonda (HO2S) 2, grupa 1, kontrola grejaca - kolo neispravno radi P0037 Lambda sonda (HO2S) 2, grupa 1, kontrola grejaca - niska vrednost u kolu P0038 Lambda sonda (HO2S) 2, grupa 1, kontrola grejaca - visoka vrednost u kolu P0042 Lambda sonda (HO2S) 3, grupa 1, kontrola grejaca - kolo neispravno radi P0043 Lambda sonda (HO2S) 3, grupa 1, kontrola grejaca - niska vrednost u kolu P0044 Lambda sonda (HO2S) 3, grupa 1, kontrola grejaca - visoka vrednost u kolu P0050 Lambda sonda (HO2S) 1, grupa 2, kontrola grejaca - kolo neispravno radi P0051 Lambda sonda (HO2S) 1, grupa 2, kontrola grejaca - niska vrednost u kolu P0052 Lambda sonda (HO2S) 1, grupa 2, kontrola grejaca - visoka vrednost u kolu P0056 Lambda sonda (HO2S) 2, grupa 2, kontrola grejaca - kolo neispravno radi P0057 Lambda sonda (HO2S) 2, grupa 2, kontrola grejaca - niska vrednost u kolu grejacaP0058 Lambda sonda (HO2S) 2, grupa 2, kontrola grejaca - visoka vrednost u kolu P0062 Lambda sonda (HO2S) 3, grupa 2, kontrola grejaca - kolo neispravno radi P0063 Lambda sonda (HO2S) 3, grupa 2, kontrola grejaca - niska vrednost u kolu P0064 Lambda sonda (HO2S) 3, grupa 2, kontrola grejaca - visoka vrednost u kolu P0065 Ubrizgivac - problem sa opsegom/radom P0066 Ubrizgivac - kolo neispravno radi/niska vrednost u kolu P0067 Ubrizgivac - visoka vrednost u kolu P0070 Senzor temperature spoljasnjeg vazduha - kolo neispravno radi P0071 Senzor temperature spoljasnjeg vazduha - problem sa opsegom/radom P0072 Senzor temperature spoljasnjeg vazduha - niska ulazna vrednost P0073 Senzor temperature spoljasnjeg vazduha - visok ulaz P0074 Senzor temperature spoljasnjeg vazduha - periodicno kolo P0075 Solenoid za kontrolu usisnog ventila, grupa 1 - kolo neispravno radi P0076 Solenoid za kontrolu usisnog ventila, grupa 1 - niska vrednost u kolu P0077 Solenoid za kontrolu usisnog ventila, grupa 1 - visoka vrednost u kolu P0078 Solenoid za kontrolu izduvnog ventila, grupa 1 - kolo neispravno radi P0079 Solenoid za kontrolu izduvnog ventila, grupa 1 - niska vrednost u kolu P0080 Solenoid za kontrolu izduvnog ventila, grupa 1 - visoka vrednost u kolu P0081 Solenoid za kontrolu usisnog ventila, grupa 2 - kolo neispravno radi P0082 Solenoid za kontrolu usisnog ventila, grupa 2 - niska vrednost u kolu P0083 Solenoid za kontrolu usisnog ventila, grupa 2 - visoka vrednost u kolu P0084 Solenoid za kontrolu izduvnog ventila, grupa 2 - kolo neispravno radi P0085 Solenoid za kontrolu izduvnog ventila, grupa 2 - niska vrednost u kolu P0086 Solenoid za kontrolu izduvnog ventila, grupa 2 - visoka vrednost u kolu P0090 Solenoid za merenje goriva - otvoreno kolo P0091 Solenoid za merenje goriva - kratak spoj prema masi P0092 Solenoid za merenje goriva - kratak spoj prema plusu P0100 Senzor protoka mase vazduha (MAF)/Senzor protoka mase vazduha (MAF) - kolo neispravno radi P0101 Senzor protoka mase vazduha (MAF)/Senzor protoka zapremine vazduha (MAF) - problem sa opsegom/radom P0102 Senzor protoka mase vazduha (MAF)/Senzor protoka zapremine vazduha (MAF) - nizak ulaz P0103 Senzor protoka mase vazduha (MAF)/Senzor protoka zapremine vazduha (MAF) - visok ulaz P0104 Senzor protoka mase vazduha (MAF)/Senzor protoka zapremine vazduha (MAF) - periodicno koloP0105 Senzor apsolutnog pritiska usisne grane (MAP)/senzor atmosferskog pritiska (BARO) - kolo neispravno radi P0106 Senzor apsolutnog pritiska usisne grane (MAP)/senzor atmosferskog pritiska (BARO) - problem sa opsegom/radom P0107 Senzor apsolutnog pritiska usisne grane (MAP)/senzor atmosferskog pritiska (BARO) - nizak ulaz P0108 Senzor apsolutnog pritiska usisne grane (MAP)/senzor atmosferskog pritiska (BARO) - visok ulaz P0109 Senzor apsolutnog pritiska usisne grane (MAP)/senzor atmosferskog pritiska (BARO) - periodicno kolo P0110 Senzor temperature usisanog vazduha (IAT) - kolo neispravno radi P0111 Senzor temperature usisanog vazduha (IAT) - problem sa opsegom/radom P0112 Senzor temperature usisanog vazduha (IAT) - nizak ulaz P0113 Senzor temperature usisanog vazduha (IAT) - visok ulaz P0114 Senzor temperature usisanog vazduha (IAT) - periodicno kolo P0115 Senzor temperature rashladnog sredstva motora (ECT) - kolo neispravno radi P0116 Senzor temperature rashladnog sredstva motora (ECT) - problem sa opsegom/radom P0117 Senzor temperature rashladnog sredstva motora (ECT) - nizak ulaz P0118 Senzor temperature rashladnog sredstva motora (ECT) - visok ulaz P0119 Senzor temperature rashladnog sredstva motora (ECT) - periodicno kolo P0120 Senzor pozicije leptira (TP) A/senzor pozicije papucice gasa (APP) A - kolo neispravno radi P0120 Prekidac pozicije leptira (TP) A/prekidac pozicije papucice gasa (APP) A - circuit malfunction P0121 Senzor pozicije leptira (TP) A/senzor pozicije papucice gasa (APP) A - problem sa opsegom/radom P0121 Prekidac pozicije leptira (TP) A/prekidac pozicije papucice gasa (APP) A - problem sa opsegom/radom P0122 Senzor pozicije leptira (TP) A/senzor pozicije papucice gasa (APP) A - nizak ulaz P0122 Prekidac pozicije leptira (TP) A/prekidac pozicije papucice gasa (APP) A - nizak ulaz P0123 Senzor pozicije leptira (TP) A/senzor pozicije papucice gasa (APP) A - visok ulaz P0123 Prekidac pozicije leptira (TP) A/prekidac pozicije papucice gasa (APP) A - visok ulaz P0124 Senzor pozicije leptira (TP) A/senzor pozicije papucice gasa (APP) A - periodicno kolo P0124 Prekidac pozicije leptira (TP) A/prekidac pozicije papucice gasa (APP) A - periodicno kolo P0125 Nedovoljna temperatura rashladnog sredstva za zatvorenu petlju kontrole goriva P0126 Nedovoljna temperatura rashladnog sredstva za stabilan rad P0130 Lambda sonda (HO2S) 1, grupa 1 - kolo neispravno radi P0130 Lambda sonda (O2S) 1, grupa 1 - kolo neispravno radi P0131 Lambda sonda sa grejacem (HO2S) 1, grupa 1 - nizak napon P0131 Lambda sonda (O2S) 1, grupa 1 - nizak napon P0132 Lambda sonda sa grejacem (HO2S) 1, grupa 1 - visok napon P0132 Lambda sonda (O2S) 1, grupa 1 - visok napon P0133 Lambda sonda sa grejacem (HO2S) 1, grupa 1 - spora reakcija P0133 Lambda sonda (O2S) 1, grupa 1 - spora reakcija P0134 Lambda sonda sa grejacem (HO2S) 1, grupa 1 - nije detektovana nikakva aktivnost P0134 Lambda sonda (O2S) 1, grupa 1 - nije detektovana nikakva aktivnost P0135 Lambda sonda sa grejacem (HO2S) 1, grupa 1, kontrola grejaca - kolo neispravno radi P0136 Lambda sonda sa grejacem (HO2S) 2, grupa 1 - kolo neispravno radi P0136 Lambda sonda (O2S) 2, grupa 1 - kolo neispravno radi P0137 Lambda sonda sa grejacem (HO2S) 2, grupa 1 - nizak napon P0137 Lambda sonda (O2S) 2, grupa 1 - nizak napon P0138 Lambda sonda sa grejacem (HO2S) 2, grupa 1 - visok napon P0138 Lambda sonda (O2S) 2, grupa 1 - visok napon P0139 Lambda sonda sa grejacem (HO2S) 2, grupa 1 - spora reakcija P0139 Lambda sonda (O2S) 2, grupa 1 - spora reakcija P0140 Lambda sonda sa grejacem (HO2S) 2, grupa 1 - nije detektovana nikakva aktivnost P0140 Lambda sonda (O2S) 2, grupa 1 - nije detektovana nikakva aktivnost P0141 Lambda sonda sa grejacem (HO2S) 2, grupa 1, kontrola grejaca - kolo neispravno radi P0142 Lambda sonda sa grejacem (HO2S) 3, grupa 1 - koloneispravno radi P0143 Lambda sonda sa grejacem (HO2S) 3, grupa 1 - nizak napon P0143 Lambda sonda (O2S) 3, grupa 1 - nizak napon P0144 Lambda sonda sa grejacem (HO2S) 3, grupa 1 - visok napon P0144 Lambda sonda (O2S) 3, grupa 1 - visok napon P0145 Lambda sonda sa grejacem (HO2S) 3, grupa 1 - spora reakcija P0145 Lambda sonda (O2S) 3, grupa 1 - spora reakcija P0146 Lambda sonda sa grejacem (HO2S) 3, grupa 1 - nije detektovana nikakva aktivnost P0146 Lambda sonda (O2S) 3, grupa 1 - nije detektovana nikakva aktivnost P0147 Lambda sonda sa grejacem (HO2S) 3, grupa 1, kontrola grejaca - kolo neispravno radi P0150 Lambda sonda sa grejacem (HO2S) 1, grupa 2 - kolo neispravno radi P0150 Lambda sonda (O2S) 1, grupa 2 - kolo neispravno radi P0151 Lambda sonda sa grejacem (HO2S) 1, grupa 2 - nizak napon P0151 Lambda sonda (O2S) 1, grupa 2 - nizak napon P0152 Lambda sonda sa grejacem (HO2S) 1, grupa 2 - visok napon P0152 Lambda sonda (O2S) 1, grupa 2 - visok napon P0153 Lambda sonda sa grejacem (HO2S) 1, grupa 2 - spora reakcija P0153 Lambda sonda (O2S) 1, grupa 2 - spora reakcija P0154 Lambda sonda sa grejacem (HO2S) 1, grupa 2 - nije detektovana nikakva aktivnost P0154 Lambda sonda (O2S) 1, grupa 2 - nije detektovana nikakva aktivnost P0155 Lambda sonda sa grejacem (HO2S) 1, grupa 2, kontrola grejaca - kolo neispravno radi P0156 Lambda sonda sa grejacem (HO2S) 2, grupa 2 - kolo neispravno radi P0156 Lambda sonda (O2S) 2, grupa 2 - kolo neispravno radi P0157 Lambda sonda sa grejacem (HO2S) 2, grupa 2 - nizak napon P0157 Lambda sonda (O2S) 2, grupa 2 - nizak napon P0158 Lambda sonda sa grejacem (HO2S) 2, grupa 2 - visok napon P0158 Lambda sonda (O2S) 2, grupa 2 - visok napon P0159 Lambda sonda sa grejacem (HO2S) 2, grupa 2 - spora reakcija P0159 Lambda sonda (O2S) 2, grupa 2 - spora reakcija P0160 Lambda sonda sa grejacem (HO2S) 2, grupa 2 - nije detektovana nikakva aktivnost P0160 Lambda sonda (O2S) 2, grupa 2 - nije detektovana nikakva aktivnost P0161 Lambda sonda sa grejacem (HO2S) 2, grupa 2, kontrola grejaca - kolo neispravno radi P0162 Lambda sonda sa grejacem (HO2S) 3, grupa 2 - kolo neispravno radi P0162 Lambda sonda (O2S) 3, grupa 2 - kolo neispravno radi P0163 Lambda sonda sa grejacem (HO2S) 3, grupa 2 - nizak napon P0163 Lambda sonda (O2S) 3, grupa 2 - nizak napon P0164 Lambda sonda sa grejacem (HO2S) 3, grupa 2 - visok napon P0164 Lambda sonda (O2S) 3, grupa 2 - visok napon P0165 Lambda sonda sa grejacem (HO2S) 3, grupa 2 - spora reakcija P0165 Lambda sonda (O2S) 3, grupa 2 - spora reakcija P0166 Lambda sonda sa grejacem (HO2S) 3, grupa 2 - nije detektovana nikakva aktivnost P0166 Lambda sonda (O2S) 3, grupa 2 - nije detektovana nikakva aktivnost P0167 Lambda sonda sa grejacem (HO2S) 3, grupa 2, kontrola grejaca - kolo neispravno radi P0170 Podesavanje goriva (FT), grupa 1 - lose radi P0171 Sistem – suvise siromasno, grupa 1 P0172 Sistem – suvise bogato, grupa 1 P0173 Podesavanje goriva (FT), grupa 2 - lose radi P0174 Sistem – suvise siromasno, grupa 2 P0175 Sistem – suvise bogato, grupa 2 P0176 Senzor potrosnje goriva - kolo neispravno radi P0177 Senzor potrosnje goriva - problem sa opsegom/radom P0178 Senzor potrosnje goriva - nizak ulaz P0179 Senzor potrosnje goriva - visok ulaz P0180 Senzor temperature goriva A - kolo neispravno radi P0181 Senzor temperature goriva A - problem sa opsegom/radom P0182 Senzor temperature goriva A - nizak ulaz P0183 Senzor temperature goriva A - visok ulaz P0184 Senzor temperature goriva A - periodicno kolo P0185 Senzor temperature goriva B - kolo neispravno radi P0186 Senzor temperature goriva B - problem sa opsegom/radom P0187 Senzor temperature goriva B - nizak ulaz P0188 Senzor temperature goriva B - visok ulaz P0189 Senzor temperature goriva B - periodicno kolo P0190 Senzor pritiska voda goriva (FRP) - kolo neispravno radi P0191 Senzor pritiska voda goriva (FRP) - problem sa opsegom/radom P0192 Senzor pritiska voda goriva (FRP) - nizak ulaz P0193 Senzor pritiska voda goriva (FRP) - visok ulaz P0194 Senzor pritiska voda goriva (FRP) - periodicno kolo P0195 Senzor temperature ulja motora (EOT) - kolo neispravno radi P0196 Senzor temperature ulja motora (EOT) - problem sa opsegom/radom P0197 Senzor temperature ulja motora (EOT) - nizak ulaz P0198 Senzor temperature ulja motora (EOT) - visok ulaz P0199 Senzor temperature ulja motora (EOT) - periodicno kolo P0200 Ubrizgivac - kolo neispravno radi P0201 Ubrizgivac 1 - kolo neispravno radi P0202 Ubrizgivac 2 - kolo neispravno radi P0203 Ubrizgivac 3 - kolo neispravno radi P0204 Ubrizgivac 4 - kolo neispravno radi P0205 Ubrizgivac 5 - kolo neispravno radi P0206 Ubrizgivac 6 - kolo neispravno radi P0207 Ubrizgivac 7 - kolo neispravno radi P0208 Ubrizgivac 8 - kolo neispravno radi P0209 Ubrizgivac 9 - kolo neispravno radi P0210 Ubrizgivac 10 - kolo neispravno radi P0211 Ubrizgivac 11 - kolo neispravno radi P0212 Ubrizgivac 12 - kolo neispravno radi P0213 Ubrizgivac hladnog starta 1 - kolo neispravno radi P0214 Ubrizgivac hladnog starta 2 - kolo neispravno radi P0215 Solenoid iskljucenja goriva - kolo neispravno radi P0216 Kontrola tajminga ubrizgavanja goriva - kolo neispravno radi P0217 Uslovi prekoracenja temperature motora P0218 Uslovi prekoracenja temperature menjaca P0219 Uslovi nad-brzine motora P0220 Senzor pozicije leptira (TP) B/senzor pozicije papucice gasa (APP) B - kolo neispravno radi P0220 Prekidac pozicije leptira (TP) B/prekidac pozicije papucice gasa (APP) B - kolo neispravno radi P0221 Senzor pozicije leptira (TP) B/senzor pozicije papucice gasa (APP) B - problem sa opsegom/radom P0221 Prekidac pozicije leptira (TP) B/prekidac pozicije papucice gasa (APP) B - range/performance problem P0222 Senzor pozicije leptira (TP) B/senzor pozicije papucice gasa (APP) B - nizak ulaz P0222 Prekidac pozicije leptira (TP) B/prekidac pozicije papucice gasa (APP) B - nizak ulaz P0223 Senzor pozicije leptira (TP) B/senzor pozicije papucice gasa (APP) B - visok ulaz P0223 Prekidac pozicije leptira (TP) B/prekidac pozicije papucice gasa (APP) B - visok ulaz P0224 Senzor pozicije leptira (TP) B/senzor pozicije papucice gasa (APP) B - periodicno kolo P0224 Prekidac pozicije leptira (TP) B/prekidac pozicije papucice gasa (APP) B - periodicno kolo P0225 Senzor pozicije leptira (TP) C/senzor pozicije papucice gasa (APP) C - kolo neispravno radi P0225 Prekidac pozicije leptira (TP) C/prekidac pozicije papucice gasa (APP) C - kolo neispravno radi P0226 Senzor pozicije leptira (TP) C/senzor pozicije papucice gasa (APP) C - problem sa opsegom/radom P0226 Prekidac pozicije leptira (TP) C/prekidac pozicije papucice gasa (APP) C - problem sa opsegom/radom P0227 Senzor pozicije leptira (TP) C/senzor pozicije papucice gasa (APP) C - nizak ulaz P0227 Prekidac pozicije leptira (TP) C/prekidac pozicije papucice gasa (APP) C - nizak ulaz P0228 Senzor pozicije leptira (TP) C/senzor pozicije papucice gasa (APP) C - visok ulaz P0228 Prekidac pozicije leptira (TP) C/prekidac pozicije papucice gasa (APP) C - visok ulaz P0229 Senzor pozicije leptira (TP) C/senzor pozicije papucice gasa (APP) C - circuit intermittent P0229 Prekidac pozicije leptira (TP) C/prekidac pozicije papucice gasa (APP) C - periodicno kolo P0230 Relej pumpe za gorivo - kolo neispravno radi P0231 Relej pumpe za gorivo - niska vrednost u kolu P0232 Relej pumpe za gorivo - visoka vrednost u kolu P0233 Relej pumpe za gorivo - periodicno kolo P0234 Uslovi dodatnog pritiska motora - limit prekoracen P0235 Uslovi dodatnog pritiska motora - limit nije dostignut P0236 Senzor apsolutnog pritiska usisne grane (MAP) A, TC sistem - problem sa opsegom/radom P0237 Senzor apsolutnog pritiska usisne grane (MAP) A, TC sistem - nizak ulaz P0238 Senzor apsolutnog pritiska usisne grane (MAP) A, TC sistem - visok ulaz P0239 Senzor apsolutnog pritiska usisne grane (MAP) B, TC sistem - kolo neispravno radi P0240 Senzor apsolutnog pritiska usisne grane (MAP) B, TC sistem - problem sa opsegom/radom P0241 Senzor apsolutnog pritiska usisne grane (MAP) B, TC sistem - nizak ulaz P0242 Senzor apsolutnog pritiska usisne grane (MAP) B, TC sistem - visok ulaz P0243 Ventil za regulaciju radnog pritiska u turbo punjacu (TC) A -kolo neispravno radi P0244 Ventil za regulaciju radnog pritiska u turbo punjacu (TC) A -problem sa opsegom/radom P0245 Ventil za regulaciju radnog pritiska u turbo punjacu (TC) A -circuit low P0246 Turbocharger (TC) wastegate regulating valve A - circuit high P0247 Regulator radnog pritiska u turbo punjacu (TC) B - kolo neispravno radi P0248 Ventil za regulaciju radnog pritiska u turbo punjacu (TC) B -problem sa opsegom/radom P0249 Ventil za regulaciju radnog pritiska u turbo punjacu (TC) B -niska vrednost u kolu P0250 Ventil za regulaciju radnog pritiska u turbo punjacu (TC) B -visoka vrednost u kolu P0251 Pumpa za ubrizgavanje A, rotor/cam - kolo neispravno radi P0252 Pumpa za ubrizgavanje A, rotor/cam - problem sa opsegom/radom P0253 Pumpa za ubrizgavanje A, rotor/brega - niska vrednost u kolu P0254 Pumpa za ubrizgavanje A, rotor/brega - visoka vrednost u kolu P0255 Pumpa za ubrizgavanje A, rotor/brega - periodicno kolo P0256 Pumpa za ubrizgavanje B, rotor/brega - kolo neispravno radi P0257 Pumpa za ubrizgavanje B, rotor/brega - problem sa opsegom/radom P0258 Pumpa za ubrizgavanje B, rotor/brega - niska vrednost u kolu P0259 Pumpa za ubrizgavanje B, rotor/brega - visoka vrednost u kolu P0260 Pumpa za ubrizgavanje B, rotor/brega - periodicno kolo P0261 Ubrizgivac 1 - niska vrednost u kolu P0262 Ubrizgivac 1 - visoka vrednost u kolu P0263 Cilindar 1 - Nedovoljan ucinak cilindra/greska u odnosu izmedju pojedinacnih cilindara P0264 Ubrizgivac 2 - niska vrednost u kolu P0265 Ubrizgivac 2 - visoka vrednost u kolu P0266 Cilindar 2 - Solenoidni ventil ne radi ispravno ili ne uspeva da odgovori na signale koje salje kontrolni modul i ostaje konstantno u poziciji OFF (iskljuceno) P0267 Ubrizgivac 3 - niska vrednost u kolu P0268 Ubrizgivac 3 - visoka vrednost u kolu P0269 Cilindar 3 - Solenoidni ventil ne radi ispravno ili ne uspeva da odgovori na signale koje salje kontrolni modul i ostaje konstantno u poziciji OFF (iskljuceno) P0270 Ubrizgivac 4 - niska vrednost u kolu P0271 Ubrizgivac 4 - visoka vrednost u kolu P0272 Cilindar 4 - Solenoidni ventil ne radi ispravno ili ne uspeva da odgovori na signale koje salje kontrolni modul i ostaje konstantno u poziciji OFF (iskljuceno) P0273 Ubrizgivac 5 - niska vrednost u kolu P0274 Ubrizgivac 5 - visoka vrednost u kolu P0275 Cilindar 5 - Solenoidni ventil ne radi ispravno ili ne uspeva da odgovori na signale koje salje kontrolni modul i ostaje konstantno u poziciji OFF (iskljuceno) P0276 Ubrizgivac 6 - niska vrednost u kolu P0277 Ubrizgivac 6 - visoka vrednost u kolu P0278 Cilindar 6 - Solenoidni ventil ne radi ispravno ili ne uspeva da odgovori na signale koje salje kontrolni modul i ostaje konstantno u poziciji OFF (iskljuceno) P0279 Ubrizgivac 7 - niska vrednost u kolu P0280 Ubrizgivac 7 - visoka vrednost u kolu P0281 Cilindar 7 - Solenoidni ventil ne radi ispravno ili ne uspeva da odgovori na signale koje salje kontrolni modul i ostaje konstantno u poziciji OFF (iskljuceno) P0282 Ubrizgivac 8 - niska vrednost u kolu P0283 Ubrizgivac 8 - visoka vrednost u kolu P0284 Cilindar 8 - Solenoidni ventil ne radi ispravno ili ne uspeva da odgovori na signale koje salje kontrolni modul i ostaje konstantno u poziciji OFF (iskljuceno) P0285 Ubrizgivac 9 - niska vrednost u kolu P0286 Ubrizgivac 9 - visoka vrednost u kolu P0287 Cilindar 9 - Solenoidni ventil ne radi ispravno ili ne uspeva da odgovori na signale koje salje kontrolni modul i ostaje konstantno u poziciji OFF (iskljuceno) P0288 Ubrizgivac 10 - niska vrednost u kolu P0289 Ubrizgivac 10 - visoka vrednost u kolu P0290 Cilindar 10 - Solenoidni ventil ne radi ispravno ili ne uspeva da odgovori na signale koje salje kontrolni modul i ostaje konstantno u poziciji OFF (iskljuceno) P0291 Ubrizgivac 11 - niska vrednost u kolu P0292 Ubrizgivac 11 - visoka vrednost u kolu P0293 Cilindar 11 - Nedovoljan ucinak cilindra/greska u odnosu izmedju pojedinacnih cilindara P0294 Ubrizgivac 12 - niska vrednost u kolu P0295 Ubrizgivac 12 - visoka vrednost u kolu P0296 Cilindar 12 - Nedovoljan ucinak cilindra/greska u odnosu izmedju pojedinacnih cilindara P0300 Random/multiple cilindar(i) - detektovano nepravilno paljenje P0301 Cilindar 1 - detektovano nepravilno paljenje P0302 Cilindar 2 - detektovano nepravilno paljenje P0303 Cilindar 3 - detektovano nepravilno paljenje P0304 Cilindar 4 - detektovano nepravilno paljenje P0305 Cilindar 5 - detektovano nepravilno paljenje P0306 Cilindar 6 - detektovano nepravilno paljenje P0307 Cilindar 7 - detektovano nepravilno paljenje P0308 Cilindar 8 - detektovano nepravilno paljenje P0309 Cilindar 9 - detektovano nepravilno paljenje P0310 Cilindar 10 - detektovano nepravilno paljenje P0311 Cilindar 11 - detektovano nepravilno paljenje P0312 Cilindar 12 - detektovano nepravilno paljenje P0320 Senzor pozicije radilice (CKP)/senzor broja obrtaja motora (RPM) - kolo neispravno radi P0321 Senzor pozicije radilice (CKP)/senzor broja obrtaja motora (RPM) - problem sa opsegom/radom P0322 Senzor pozicije radilice (CKP)/senzor broja obrtaja motora (RPM) - nema signala P0323 Senzor pozicije radilice (CKP)/senzor broja obrtaja motora (RPM) - periodicno kolo P0325 Senzor detonacije (KS) 1, grupa 1 - kolo neispravno radi P0326 Senzor detonacije (KS) 1, grupa 1 - problem sa opsegom/radom P0327 Senzor detonacije (KS) 1, grupa 1 - nizak ulaz P0328 Senzor detonacije (KS) 1, grupa 1 - visok ulaz P0329 Senzor detonacije (KS) 1, grupa 1 - periodicno kolo P0330 Senzor detonacije (KS) 2, grupa 2 - kolo neispravno radi P0331 Senzor detonacije (KS) 2, grupa 2 - problem sa opsegom/radom P0332 Senzor detonacije (KS) 2, grupa 2 - nizak ulaz P0333 Senzor detonacije (KS) 2, grupa 2 - visok ulaz P0334 Senzor detonacije (KS) 2, grupa 2 - periodicno kolo P0335 Senzor pozicije radilice (CKP) - kolo neispravno radi P0336 Senzor pozicije radilice (CKP) - problem sa opsegom/radom P0337 Senzor pozicije radilice (CKP) - nizak ulaz P0338 Senzor pozicije radilice (CKP) - visok ulaz P0339 Senzor pozicije radilice (CKP) - periodicno kolo P0340 Senzor pozicije bregaste osovine (CMP) A, grupa 1 - kolo neispravno radi P0341 Senzor pozicije bregaste osovine (CMP) A, grupa 1 - problem sa opsegom/radom P0342 Senzor pozicije bregaste osovine (CMP) A, grupa 1 - nizak ulaz P0343 Senzor pozicije bregaste osovine (CMP) A, grupa 1 - visok ulaz P0344 Senzor pozicije bregaste osovine (CMP) A, grupa 1 - periodicno kolo P0346 Senzor pozicije bregaste osovine (CMP) A, grupa 2 - problem sa opsegom/radom P0347 Senzor pozicije bregaste osovine (CMP) A, grupa 2 - nizak ulaz P0348 Senzor pozicije bregaste osovine (CMP) A, grupa 2 - visok ulaz P0350 Bobina, primar/sekundar - kolo neispravno radi P0351 Bobina A, primar/sekundar - kolo neispravno radi P0352 Bobina B, primar/sekundar - kolo neispravno radi P0353 Bobina C, primar/sekundar - kolo neispravno radi P0354 Bobina D, primar/sekundar - kolo neispravno radi P0355 Bobina E, primar/sekundar - kolo neispravno radi P0356 Bobina F, primar/sekundar - kolo neispravno radi P0357 Bobina G, primar/sekundar - kolo neispravno radi P0358 Bobina H, primar/sekundar - kolo neispravno radi P0359 Bobina I, primar/sekundar - kolo neispravno radi P0360 Bobina J, primar/sekundar - kolo neispravno radi P0361 Bobina K, primar/sekundar - kolo neispravno radi P0362 Bobina L, primar/sekundar - kolo neispravno radi P0370 Referenca tajminga, signal visoke rezolucije A - lose radi P0371 Referenca tajminga, signal visoke rezolucije A - suvise impulsa P0372 Referenca tajminga, signal visoke rezolucije A - suvise malo impulsa P0373 Referenca tajminga, signal visoke rezolucije A - periodicni nepravilni impulsi P0374 Referenca tajminga, signal visoke rezolucije A - nema impulsa P0375 Referenca tajminga, signal visoke rezolucije B - lose radi P0376 Referenca tajminga, signal visoke rezolucije B - suvise impulsa P0377 Referenca tajminga, signal visoke rezolucije B - suvise malo impulsa P0378 Referenca tajminga, signal visoke rezolucije B - periodicni nepravilni impulsi P0379 Referenca tajminga, signal visoke rezolucije B - nema impulsa P0380 Grejaci, kolo A - lose radi P0381 Kontrolna lampica grejaca - kolo neispravno radi P0382 Grejaci, kolo B - lose radi P0385 Senzor pozicije radilice (CKP) B - kolo neispravno radi P0386 Senzor pozicije radilice (CKP) B - problem sa opsegom/radom P0387 Senzor pozicije radilice (CKP) B - nizak ulaz P0388 Senzor pozicije radilice (CKP) B - visok ulaz P0389 Senzor pozicije radilice (CKP) B - periodicno kolo P0400 Sistem recirkulacije izduvnih gasova (EGR) - lose funkcionise protok P0401 Sistem recirkulacije izduvnih gasova (EGR) - detektovan nedovoljan protok P0402 Sistem recirkulacije izduvnih gasova (EGR) - detektovan prejak protok P0403 Sistem recirkulacije izduvnih gasova (EGR) - kolo neispravno radi P0404 Sistem recirkulacije izduvnih gasova (EGR) - problem sa opsegom/radom P0405 Senzor pozicije ventila recirkulacije izduvnih gasova (EGR) A - nizak ulaz P0406 Senzor pozicije ventila recirkulacije izduvnih gasova (EGR) A - visok ulaz P0407 Senzor pozicije ventila recirkulacije izduvnih gasova (EGR) B - nizak ulaz P0408 Senzor pozicije ventila recirkulacije izduvnih gasova (EGR) B - visok ulaz P0410 Sistem ubrizgavanja sekundarnog vazduha (AIR) - lose radi P0411 Sistem ubrizgavanja sekundarnog vazduha (AIR) - detektovan neodgovarajuci protok P0412 Solenoid ubrizgavanja sekundarnog vazduha (AIR) A - circuit malfunction P0413 Solenoid ubrizgavanja sekundarnog vazduha (AIR) A - open circuit P0414 Solenoid ubrizgavanja sekundarnog vazduha (AIR) A - kratak spoj P0415 Solenoid ubrizgavanja sekundarnog vazduha (AIR) B - kolo neispravno radi P0416 Solenoid ubrizgavanja sekundarnog vazduha (AIR) B - otvoreno kolo P0417 Solenoid ubrizgavanja sekundarnog vazduha (AIR) B - kratak spoj P0418 Relej pumpe ubrizgavanja sekundarnog vazduha (AIR) A - kolo neispravno radi P0419 Relej pumpe ubrizgavanja sekundarnog vazduha (AIR) B - kolo neispravno radi P0420 Sistem katalizatora, grupa 1 - efikasnost ispod granicne vrednosti P0421 Zagrejte katalizator, grupa 1 - efikasnost ispod granicne vrednosti P0422 Glavni katalizator, grupa 1 - efikasnost ispod granicne vrednosti P0423 Katalizator sa grejanjem, grupa 1 - efikasnost ispod granicne vrednosti P0424 Katalizator sa grejanjem, grupa 1 - temperatura ispod granicne vrednosti P0430 Sistem katalizatora, grupa 2 - efikasnost ispod granicne vrednosti P0431 Zagrejte katalizator, grupa 2 - efikasnost ispod granicne vrednosti P0432 Glavni katalizator, grupa 2 - efikasnost ispod granicne vrednosti P0433 Katalizator sa grejanjem, grupa 2 - efikasnost ispod granicne vrednosti P0434 Katalizator sa grejanjem, grupa 2 - temperatura ispod granicne vrednosti P0440 Sistem isparavanja goriva (EVAP) - lose radi P0441 Sistem isparavanja goriva (EVAP) - detektovan neodgovarajuci protok P0442 Sistem isparavanja goriva (EVAP) - detektovano malo curenje P0443 Ventil ciscenja kanistra za isparavanje goriva (EVAP) - kolo neispravno radi P0444 Ventil ciscenja kanistra za isparavanje goriva (EVAP) - otvoreno kolo P0445 Ventil ciscenja kanistra za isparavanje goriva (EVAP) - kratak spoj P0446 Sistem isparavanja goriva (EVAP), kontrola ventilacije - kolo neispravno radi P0447 Sistem isparavanja goriva (EVAP), kontrola ventilacije - otvoreno kolo P0448 Sistem isparavanja goriva (EVAP), kontrola ventilacije - kratak spoj P0449 Sistem isparavanja goriva (EVAP), ventil ventilacije - kolo neispravno radi P0450 Senzor pritiska isparavanja goriva (EVAP) - kolo neispravno radi P0451 Senzor pritiska isparavanja goriva (EVAP) - problem sa opsegom/radom P0452 Senzor pritiska isparavanja goriva (EVAP) - nizak ulaz P0453 Senzor pritiska isparavanja goriva (EVAP) - visok ulaz P0454 Senzor pritiska isparavanja goriva (EVAP) - periodicno kolo P0455 Sistem isparavanja goriva (EVAP) - detektovano veliko curenje P0460 Senzor nivoa rezervoara za gorivo - kolo neispravno radi P0461 Senzor nivoa rezervoara za gorivo - problem sa opsegom/radom P0462 Senzor nivoa rezervoara za gorivo - nizak ulaz P0463 Senzor nivoa rezervoara za gorivo - visok ulaz P0464 Senzor nivoa rezervoara za gorivo - periodicno kolo P0465 Senzor protoka ciscenja kanistra za isparavanje goriva (EVAP) - kolo neispravno radi P0466 Senzor protoka ciscenja kanistra za isparavanje goriva (EVAP) - problem sa opsegom/radom P0467 Senzor protoka ciscenja kanistra za isparavanje goriva (EVAP) - nizak ulaz P0468 Senzor protoka ciscenja kanistra za isparavanje goriva (EVAP) - visok ulaz P0469 Senzor protoka ciscenja kanistra za isparavanje goriva (EVAP) - periodicno kolo P0470 Senzor pritiska izduvnih gasova - kolo neispravno radi P0471 Senzor pritiska izduvnih gasova - problem sa opsegom/radom P0472 Senzor pritiska izduvnih gasova - nizak ulaz P0473 Senzor pritiska izduvnih gasova - visok ulaz P0474 Senzor pritiska izduvnih gasova - periodicno kolo P0475 Ventil za kontrolu pritiska izduvnih gasova - kolo neispravno radi P0476 Ventil za kontrolu pritiska izduvnih gasova - problem sa opsegom/radom P0477 Ventil za kontrolu pritiska izduvnih gasova - nizak ulaz P0478 Ventil za kontrolu pritiska izduvnih gasova - visok ulaz P0479 Ventil za kontrolu pritiska izduvnih gasova - periodicno kolo P0480 Motor ventilatora motora 1 - kolo neispravno radi P0481 Motor ventilatora motora 2 - kolo neispravno radi P0482 Motor ventilatora motora 3 - kolo neispravno radi P0483 Motor ventilatora motora, provera racionalnosti - lose radi P0484 Motor ventilatora motora - nad-struja kola P0485 Motor ventilatora motora, snaga/masa - kolo neispravno radi P0500 Senzor brzine vozila (VSS) - kolo neispravno radi P0501 Senzor brzine vozila (VSS) - problem sa opsegom/radom P0502 Senzor brzine vozila (VSS) - nizak ulaz P0503 Senzor brzine vozila (VSS) - periodicna/nepravilna/visoka ulazna vrednost P0505 Sistem kontrole broja obrtaja na leer - lose radi P0506 Sistem kontrole broja obrtaja na leer (ISC) - broj obrtaja u minuti nizi od ocekivanog P0507 Sistem kontrole broja obrtaja na leer (ISC) - broj obrtaja u minuti visi od ocekivanog P0510 Prekidac zatvorene pozicije leptira (TP) - kolo neispravno radi P0520 Senzor/sklopka pritiska ulja motora - kolo neispravno radi P0521 Senzor/sklopka pritiska ulja motora - problem sa opsegom/radom P0522 Senzor/sklopka pritiska ulja motora - nizak napon P0523 Senzor/sklopka pritiska ulja motora - visok napon P0530 Senzor pritiska rashladnog fluida klime - kolo neispravno radi P0531 Senzor pritiska rashladnog fluida klime - problem sa opsegom/radom P0532 Senzor pritiska rashladnog fluida klime - nizak ulaz P0533 Senzor pritiska rashladnog fluida klime - visok ulaz P0534 Gubitak pri punjenju rashladnog fluida klime P0544 Senzor temperature recirkulacije izduvnih gasova (EGRT), grupa 1 - kolo neispravno radi P0545 Senzor temperature recirkulacije izduvnih gasova (EGRT), grupa 1 - nizak ulaz P0546 Senzor temperature recirkulacije izduvnih gasova (EGRT), grupa 1 - visok ulaz P0550 Prekidac/senzor pritiska servo upravljaca (PSP) - kolo neispravno radi P0551 Prekidac/senzor pritiska servo upravljaca (PSP) - problem sa opsegom/radom P0552 Prekidac/senzor pritiska servo upravljaca (PSP) - nizak ulaz P0553 Prekidac/senzor pritiska servo upravljaca (PSP) - visok ulaz P0554 Prekidac/senzor pritiska servo upravljaca (PSP) - periodicno kolo P0560 Napon sistema - lose radi P0561 Napon sistema - nestabilno P0562 Napon sistema - nisko P0563 Napon sistema - visoko P0565 Glavni prekidac kontrole brzine voznje, Signal ON (ukljuceno) - lose radi P0566 Glavni prekidac kontrole brzine voznje, Signal OFF (iskljuceno) - lose radi P0567 Prekidac za izbor kontrole brzine voznje, Signal RESUME - lose radi P0568 Glavni prekidac kontrole brzine voznje, Signal SET (podesi) - lose radi P0569 Prekidac za izbor kontrole brzine voznje, Signal COAST - lose radi P0570 Sistem kontrole brzine voznje, Signal APP senzora - lose radi P0571 Prekidac kontrole/kocnice A - kolo neispravno radi P0572 Prekidac kontrole/kocnice A - niska vrednost u kolu P0573 Prekidac kontrole/kocnice A - visoka vrednost u kolu P0600 CAN magistrala podataka - lose radi P0601 Kontrolni modul motora (ECM) - greska provere memorije P0602 Kontrolni modul motora (ECM) - greska programiranja P0603 Kontrolni modul motora (ECM) - KAM greska P0604 Kontrolni modul motora (ECM) - RAM greska P0605 Kontrolni modul motora (ECM) - ROM greska P0606 Kontrolni modul motora (ECM)/Kontrolni modul pogonskog sklopa motora (PCM) - greska procesora P0608 Kontrolni modul motora (ECM), VSS izlaz A - lose radi P0609 Kontrolni modul motora (ECM), VSS izlaz B - lose radi P0620 Alternator, kontrola - kolo neispravno radi P0621 Kontrolna lampica alternatora - kolo neispravno radi P0622 Alternator, kontrola polja - kolo neispravno radi P0638 Kontrola aktuatora leptira, grupa 1 - problem sa opsegom/radom P0642 Kontrolni modul motora (ECM), kontrola detonacije - defektivno P0645 Klima uredjaj (AC) P0650 Kontrolna lampica za los rad (MIL) - kolo neispravno radi P0654 Broj obrtaja motora, izlaz - kolo neispravno radi P0655 Izlaz kontrolne lampice koja upozorava na pregrevanje motora kolo neispravno radi P0656 Izlaz nivoa goriva - kolo neispravno radi P0687 Relej kontrole motora - kratak spoj prema masi P0688 Relej kontrole motora - kratak spoj prema plusu P0691 Motor ventilatora motora 1 - kratak spoj prema masi P0692 Motor ventilatora motora 1 - kratak spoj prema plusu P0693 Motor ventilatora motora 2 - kratak spoj prema masi P0694 Motor ventilatora motora 2 - kratak spoj prema plusu P0700 Sistem kontrole menjaca - lose radi P0701 Sistem kontrole menjaca - problem sa opsegom/radom P0702 Sistem kontrole menjaca - elektricno P0703 Hidraulicni konvertor/prekidac kocnice B - kolo neispravno radi P0704 Prekidac pozicije papucice kvacila (CPP) - kolo neispravno radi P0705 Prekidac/senzor opsega menjaca (TR), PRNDL ulaz - kolo neispravno radi P0706 Prekidac/senzor opsega menjaca (TR) - problem sa opsegom/radom P0707 Prekidac/senzor opsega menjaca (TR) - nizak ulaz P0708 Prekidac/senzor opsega menjaca (TR) - visok ulaz P0709 Prekidac/senzor opsega menjaca (TR) - periodicno kolo P0710 Senzor temperature tecnosti menjaca (TFT) - kolo neispravno radi P0711 Senzor temperature tecnosti menjaca (TFT) - problem sa opsegom/radom P0712 Senzor temperature tecnosti menjaca (TFT) - nizak ulaz P0713 Senzor temperature tecnosti menjaca (TFT) - visok ulaz P0714 Senzor temperature tecnosti menjaca (TFT) - periodicno kolo P0715 Senzor brzine osovine turbine (TSS) - kolo neispravno radi P0716 Senzor brzine osovine turbine (TSS) - problem sa opsegom/radom P0717 Senzor brzine osovine turbine (TSS) - nema signala P0718 Senzor brzine osovine turbine (TSS) - periodicno kolo P0719 Hidraulicni konvertor/prekidac kocnice B - niska vrednost u kolu P0720 Senzor brzine vozila (VSS) - kolo neispravno radi P0721 Senzor brzine vozila (VSS) - problem sa opsegom/radom P0722 Senzor brzine vozila (VSS) - nema signala P0723 Senzor brzine vozila (VSS) - periodicno kolo P0724 Hidraulicni konvertor/prekidac kocnice B - visoka vrednost u kolu P0725 Ulazni broj obrtaja motora - kolo neispravno radi P0726 Ulazni broj obrtaja motora - problem sa opsegom/radom P0727 Ulazni broj obrtaja motora - nema signala P0728 Ulazni broj obrtaja motora - periodicno kolo P0730 Neispravan prenosni odnos zupcanika P0731 Zupcanik 1 - neispravan odnos P0732 Zupcanik 2 - neispravan odnos P0733 Zupcanik 3 - neispravan odnos P0734 Zupcanik 4 - neispravan odnos P0735 Zupcanik 5 - neispravan odnos P0736 Rikverc - neispravan odnos P0740 Solenoid hidraulicnog konvertora (TCC) - kolo neispravno radi P0741 Solenoid hidraulicnog konvertora (TCC) - Solenoidni ventil ne radi ispravno ili ne uspeva da odgovori na signale koje saljekontrolni modul i ostaje konstantno u poziciji OFF (iskljuceno) P0742 Solenoid hidraulicnog konvertora (TCC) - Solenoidni ventil ne uspeva da odgovori na signale koje salje kontrolni modul i ostaje konstantno u poziciji ON (ukljuceno) P0743 Solenoid hidraulicnog konvertora (TCC) - elektricno P0744 Solenoid hidraulicnog konvertora (TCC) - periodicno kolo P0745 Solenoid pritiska tecnosti menjaca (TFP) - kolo neispravno radi P0746 Solenoid pritiska tecnosti menjaca (TFP) - performance or stuck off P0747 Transmission fluid pressure (TFP) solenoid - stuck on P0748 Solenoid pritiska tecnosti menjaca (TFP) - elektricno P0749 Solenoid pritiska tecnosti menjaca (TFP) - periodicno kolo P0750 Solenoidi prenosa (SS) A - kolo neispravno radi P0751 Solenoid prenosa (SS) A - Solenoidni ventil ne radi ispravno ili ne uspeva da odgovori na signale koje salje kontrolni modul i ostaje konstantno u poziciji OFF (iskljuceno) P0752 Solenoid prenosa (SS) A - Solenoidni ventil ne uspeva da odgovori na signale koje salje kontrolni modul i ostaje konstantno u poziciji ON (ukljuceno) P0753 Solenoid prenosa (SS) A - elektricno P0754 Solenoid prenosa (SS) A - periodicno kolo P0755 Solenoid prenosa (SS) B - kolo neispravno radi P0756 Solenoid prenosa (SS) B - Solenoidni ventil ne radi ispravno ili ne uspeva da odgovori na signale koje salje kontrolni modul i ostaje konstantno u poziciji OFF (iskljuceno) P0757 Solenoid prenosa (SS) B - Solenoidni ventil ne uspeva da odgovori na signale koje salje kontrolni modul i ostaje konstantno u poziciji ON (ukljuceno) P0758 Solenoid prenosa (SS) B - elektricno P0759 Solenoid prenosa (SS) B - periodicno kolo P0760 Solenoid prenosa (SS) C - kolo neispravno radi P0761 Solenoid prenosa (SS) C - Solenoidni ventil ne radi ispravno ili ne uspeva da odgovori na signale koje salje kontrolni modul i ostaje konstantno u poziciji OFF (iskljuceno) P0762 Solenoid prenosa (SS) C - Solenoidni ventil ne uspeva da odgovori na signale koje salje kontrolni modul i ostaje konstantno u poziciji ON (ukljuceno) P0763 Solenoid prenosa (SS) C - elektricno P0764 Solenoid prenosa (SS) C - periodicno kolo P0765 Solenoid prenosa (SS) D - kolo neispravno radi P0766 Solenoid prenosa (SS) D - Solenoidni ventil ne radi ispravno ili ne uspeva da odgovori na signale koje salje kontrolni modul i ostaje konstantno u poziciji OFF (iskljuceno) P0767 Solenoid prenosa (SS) D - Solenoidni ventil ne uspeva da odgovori na signale koje salje kontrolni modul i ostaje konstantno u poziciji ON (ukljuceno) P0768 Solenoid prenosa (SS) D - elektricno P0769 Solenoid prenosa (SS) D - periodicno kolo P0770 Solenoid prenosa (SS) E - kolo neispravno radi P0771 Solenoid prenosa (SS) E - Solenoidni ventil ne radi ispravno ili ne uspeva da odgovori na signale koje salje kontrolni modul i ostaje konstantno u poziciji OFF (iskljuceno) P0772 Solenoid prenosa (SS) E - Solenoidni ventil ne uspeva da odgovori na signale koje salje kontrolni modul i ostaje konstantno u poziciji ON (ukljuceno) P0773 Solenoid prenosa (SS) E - elektricno P0774 Solenoid prenosa (SS) E - periodicno kolo P0780 Izbor prenosa (brzine) - lose radi prebacivanje P0781 Izbor prenosa (brzine), 1-2 - lose radi prebacivanje P0782 Izbor prenosa (brzine), 2-3 - lose radi prebacivanje P0783 Izbor prenosa (brzine), 3-4 - lose radi prebacivanje P0784 Izbor prenosa (brzine), 4-5 - lose radi prebacivanje P0785 Solenoid prebacivanja/tajminga - kolo neispravno radi P0786 Solenoid prebacivanja/tajminga - problem sa opsegom/radom P0787 Solenoid prebacivanja/tajminga - nisko P0788 Solenoid prebacivanja/tajminga - visoko P0789 Solenoid prebacivanja/tajminga - periodicno P0790 Prekidac za izbor moda menjaca - kolo neispravno radi P0791 Senzor brzine medjuvratila - kolo neispravno radi P0792 Senzor brzine medjuvratila - problem sa opsegom/radom P0793 Senzor brzine medjuvratila - nema signala P0794 Senzor brzine medjuvratila - los rad periodicnog kola P0795 Solenoid pritiska tecnosti menjaca (TFP) C - kolo neispravno radi P0796 Solenoid pritiska tecnosti menjaca (TFP) C - Solenoidni ventil ne radi ispravno ili ne uspeva da odgovori na signale koje salje kontrolni modul i ostaje konstantno u poziciji OFF (iskljuceno) P0797 Solenoid pritiska tecnosti menjaca (TFP) C - Solenoidni ventil ne uspeva da odgovori na signale koje salje kontrolni modul i ostaje konstantno u poziciji ON (ukljuceno) P0798 Solenoid pritiska tecnosti menjaca (TFP) C - problem u funkcionisanju elektrike P0799 Solenoid pritiska tecnosti menjaca (TFP) C - los rad periodicnog kola P0801 Kolo inhibicije rikverca - lose radi P0803 Solenoid prebacivanje u veci stepen prenosa 1-4 (preskoci prebacivanje) - kolo neispravno radi P0804 Kontrolna lampica prebacivanje u veci stepen prenosa 1-4 (preskoci prebacivanje) - kolo neispravno radi P0805 Senzor pozicije kvacila - kolo neispravno radi P0806 Senzor pozicije kvacila - problem sa opsegom/radom P0807 Senzor pozicije kvacila - nizak ulaz P0808 Senzor pozicije kvacila - visok ulaz P0809 Senzor pozicije kvacila - los rad periodicnog kola P0810 Greska kontrole pozicije kvacila P0811 Prejako proklizavanje kvacila P0812 Zupcanik rikverca - lose radi kolo ulaza P0813 Zupcanik rikverca - lose radi kolo izlaza P0814 Displej opsega menjaca (TR) - kolo neispravno radi P0815 Prekidac za prebacivanje na visi stepen prenosa - kolo neispravno radi P0816 Prekidac za prebacivanje na nizi stepen prenosa - kolo neispravno radi P0817 Kolo onemogucivanja startera - lose radi P0818 Prekidac za iskljucivanje sistema transmisije sa izlaznog vratila motora na pogonske tockove - kolo neispravno radi P0820 Senzor pozicije rucice menjaca X-Y - kolo neispravno radi P0821 Senzor pozicije rucice menjaca X - kolo neispravno radi P0822 Senzor pozicije rucice menjaca Y - kolo neispravno radi P0823 Senzor pozicije rucice menjaca X - periodicno kolo P0824 Senzor pozicije rucice menjaca Y - periodicno kolo P0825 Prekidac “gurni-povuci” rucice menjaca - kolo neispravno radi P0830 Prekidac pozicije papucice kvacila (CPP) A - kolo neispravno radi P0831 Prekidac pozicije papucice kvacila (CPP) A - niska ulazna vrednost P0832 Prekidac pozicije papucice kvacila (CPP) A - visoka ulazna vrednost P0833 Prekidac pozicije papucice kvacila (CPP) B - kolo neispravno radi P0834 Prekidac pozicije papucice kvacila (CPP) B - niska ulazna vrednost P0835 Prekidac pozicije papucice kvacila (CPP) B - visoka ulazna vrednost P0836 Prekidac pogona na sva 4 tocka - kolo neispravno radi P0837 Prekidac pogona na sva 4 tocka - problem sa opsegom/radom P0838 Prekidac pogona na sva 4 tocka - niska ulazna vrednost P0839 Prekidac pogona na sva 4 tocka - visoka ulazna vrednost P0840 Senzor pritiska tecnosti menjaca (TFP) A - kolo neispravno radi P0840 Prekidac pritiska tecnosti menjaca (TFP) A - kolo neispravn radi P0841 Senzor pritiska tecnosti menjaca (TFP) A - problem sa opsegom/radom P0841 Prekidac pritiska tecnosti menjaca (TFP) A - problem sa opsegom/radom P0842 Senzor pritiska tecnosti menjaca (TFP) A - niska ulazna vrednost P0842 Prekidac pritiska tecnosti menjaca (TFP) A - niska ulazna vrednost P0843 Senzor pritiska tecnosti menjaca (TFP) A - visoka ulazna vrednost P0843 Prekidac pritiska tecnosti menjaca (TFP) A - visoka ulazna vrednost P0844 Senzor pritiska tecnosti menjaca (TFP) A - los rad periodicnog kola P0844 Prekidac pritiska tecnosti menjaca (TFP) A - los rad periodicnog kola P0845 Senzor pritiska tecnosti menjaca (TFP) B - kolo neispravno radi P0845 Prekidac pritiska tecnosti menjaca (TFP) B - kolo neispravno radi P0846 Senzor pritiska tecnosti menjaca (TFP) B - problem sa opsegom/radom P0846 Prekidac pritiska tecnosti menjaca (TFP) B - problem sa opsegom/radom P0847 Senzor pritiska tecnosti menjaca (TFP) B - niska ulazna vrednost P0847 Prekidac pritiska tecnosti menjaca (TFP) B - niska ulazna vrednost P0848 Senzor pritiska tecnosti menjaca (TFP) B - visoka ulazna vrednost P0848 Prekidac pritiska tecnosti menjaca (TFP) B - visoka ulazna vrednost P0849 Senzor pritiska tecnosti menjaca (TFP) B - los rad periodicnog kola P0849 Prekidac pritiska tecnosti menjaca (TFP) B - los rad periodicnog kola P0850 Prekidac pozicije parking/leer (PNP) - lose radi kolo ulaza P0851 Prekidac pozicije parking/leer (PNP) - niska vrednost kola ulaza P0852 Prekidac pozicije parking/leer (PNP) - visoka vrednost kola ulaza P0853 Prekidac pogona - lose radi kolo ulaza P0854 Prekidac pogona - niska vrednost kola ulaza P0855 Prekidac pogona - visoka vrednost kola ulaza P0856 Ulazni signal kontrole vuce - lose radi P0857 Ulazni signal kontrole vuce - problem sa opsegom/radom P0858 Ulazni signal kontrole vuce - nisko P0859 Ulazni signal kontrole vuce - visoko P0860 Kolo komunikacije modula promene brzine - lose radi P0861 Kolo komunikacije modula promene brzine - niska ulazna vrednost P0862 Kolo komunikacije modula promene brzine - visoka ulazna vrednost P0863 Kolo komunikacije modula kontrole menjaca (TCM) - lose radi P0864 Kolo komunikacije modula kontrole menjaca (TCM) - problem sa opsegom/radom P0865 Kolo komunikacije modula kontrole menjaca (TCM) - niska ulazna vrednost P0866 Kolo komunikacije modula kontrole menjaca (TCM) - visoka ulazna vrednost P0867 Senzor pritiska tecnosti menjaca (TFP) P0868 Senzor pritiska tecnosti menjaca (TFP) - nisko P0869 Senzor pritiska tecnosti menjaca (TFP) - visoko P0870 Senzor pritiska tecnosti menjaca (TFP) C - kolo neispravno radi P0870 Prekidac pritiska tecnosti menjaca (TFP) C - kolo neispravno radi P0871 Senzor pritiska tecnosti menjaca (TFP) C - opseg/rad P0871 Prekidac pritiska tecnosti menjaca (TFP) C - opseg/rad P0872 Senzor pritiska tecnosti menjaca (TFP) C - niska vrednost u kolu P0872 Prekidac pritiska tecnosti menjaca (TFP) C - niska vrednost u kolu P0873 Senzor pritiska tecnosti menjaca (TFP) C - visoka vrednost u kolu P0873 Prekidac pritiska tecnosti menjaca (TFP) C - visoka vrednost u kolu P0874 Senzor pritiska tecnosti menjaca (TFP) C - los rad periodicnog kola P0874 Prekidac pritiska tecnosti menjaca (TFP) C - los rad periodicnog kola P0875 Senzor pritiska tecnosti menjaca (TFP) D - kolo neispravno radi P0875 Prekidac pritiska tecnosti menjaca (TFP) D - kolo neispravno radi P0876 Senzor pritiska tecnosti menjaca (TFP) D - opseg/rad P0876 Prekidac pritiska tecnosti menjaca (TFP) D - opseg/rad P0877 Senzor pritiska tecnosti menjaca (TFP) D - niska vrednost u kolu P0877 Prekidac pritiska tecnosti menjaca (TFP) D - niska vrednost u kolu P0878 Senzor pritiska tecnosti menjaca (TFP) D - visoka vrednost u kolu P0878 Prekidac pritiska tecnosti menjaca (TFP) D - visoka vrednost u kolu P0879 Senzor pritiska tecnosti menjaca (TFP) D - los rad periodicnog kola P0879 Prekidac pritiska tecnosti menjaca (TFP) D - los rad periodicnog kola P0880 Kontrolni modul menjaca (TCM) - los ulazni signal snage P0881 Kontrolni modul menjaca (TCM) - opseg/performanse ulaznog signala snage P0882 Kontrolni modul menjaca (TCM) - ulazni signal snage slab P0883 Kontrolni modul menjaca (TCM) - visok ulazni signal snage P0884 Kontrolni modul menjaca (TCM) - periodicno los ulazni signal snage P0885 Relej snage kontrolnog modula menjaca (TCM) - otvoreno kontrolno kolo P0886 Relej snage kontrolnog modula menjaca (TCM) - niska vrednost kontrolnog kola P0887 Relej snage kontrolnog modula menjaca (TCM) - visoka vrednost kontrolnog kola P0888 Relej snage kontrolnog modula menjaca (TCM) - Kolo kontrole pozicije kontakta releja lose funkcionise P0889 Relej snage kontrolnog modula menjaca (TCM) - opseg kola kontrole pozicije kontakta releja/rad kola P0890 Relej snage kontrolnog modula menjaca (TCM) - niska vrednost u kolu kontrole pozicije kontakta releja P0891 Relej snage kontrolnog modula menjaca (TCM) - visoka vrednost u kolu kontrole pozicije kontakta releja P0892 Relej snage kontrolnog modula menjaca (TCM) - periodicno rad kola kontrole pozicije kontakta releja P0893 Aktivirano vise zupcanika P0894 Proklizava komponenta menjaca P0895 Vreme prebacivanja suvise kratko P0896 Vreme prebacivanja suvise dugo P0897 Smanjen kvalitet fluida menjaca P0898 Sistem kontrole menjaca - Zahtev MIL - niska vrednost u kolu P0899 Sistem kontrole menjaca - Zahtev MIL - visoka vrednost u kolu P0900 Aktuator kvacila - otvoreno kolo P0901 Aktuator kvacila - opseg/rad kola P0902 Aktuator kvacila - niska vrednost u kolu P0903 Aktuator kvacila - visoka vrednost u kolu P0904 Kolo izbora pozicije promene brzine - lose radi P0905 Kolo izbora pozicije promene brzine - opseg/rad P0906 Kolo izbora pozicije promene brzine - nisko P0907 Kolo izbora pozicije promene brzine - visoko P0908 Kolo izbora pozicije promene brzine - los rad periodicnog kola P0909 Greska u kolu izbora pozicije promene brzine P0910 Aktuator izbora promene brzine - otvoreno kolo P0911 Aktuator izbora promene brzine - opseg/rad kola P0912 Aktuator izbora promene brzine - circuit low P0913 Aktuator izbora promene brzine - visoka vrednost u kolu P0914 Kolo pozicije promene brzine - lose radi P0915 Kolo pozicije promene brzine - opseg/rad P0916 Kolo pozicije promene brzine - nisko P0917 Kolo pozicije promene brzine - visoko P0918 Kolo pozicije promene brzine - Periodicni los rad P0919 Kontrola pozicije promene brzine - greska P0920 Aktuator promene brzine unapred - otvoreno kolo P0921 Aktuator promene brzine unapred - opseg/rad kola P0922 Aktuator promene brzine unapred - niska vrednost u kolu P0923 Aktuator promene brzine unapred - visoka vrednost u kolu P0924 Aktuator prebacivanja u rikverc - otvoreno kolo P0925 Aktuator prebacivanja u rikverc - opseg/rad kola P0926 Aktuator prebacivanja u rikverc - niska vrednost u kolu P0927 Aktuator prebacivanja u rikverc - visoka vrednost u kolu P0928 Solenoid blokade prebacivanja brzine - otvoreno kolo P0929 Solenoid blokade prebacivanja brzine - opseg/rad kola P0930 Solenoid blokade prebacivanja brzine - niska vrednost u kolu P0931 Solenoid blokade prebacivanja brzine - visoka vrednost u kolu P0932 Senzor hidraulicnog pritiska - kolo neispravno radi P0933 Senzor hidraulicnog pritiska - opseg/rad P0934 Senzor hidraulicnog pritiska - niska vrednost kola ulaza P0935 Senzor hidraulicnog pritiska - visoka vrednost kola ulaza P0936 Senzor hidraulicnog pritiska - periodicno kolo P0937 Senzor temperature hidraulicnog ulja - kolo neispravno radi P0938 Senzor temperature hidraulicnog ulja - opseg/rad P0939 Senzor temperature hidraulicnog ulja - niska ulazna vrednost kola P0940 Senzor temperature hidraulicnog ulja - visoka ulazna vrednost kola P0941 Senzor temperature hidraulicnog ulja - periodicno kolo P0942 Jedinica hidraulicnog pritiska P0943 Jedinica hidraulicnog pritiska - period ciklusa suvise kratak P0944 Jedinica hidraulicnog pritiska - gubitak pritiska P0945 Relej hidraulicne pumpe - otvoreno kolo P0946 Relej hidraulicne pumpe - opseg/rad kola P0947 Relej hidraulicne pumpe - niska vrednost u kolu P0948 Relej hidraulicne pumpe - visoka vrednost u kolu P0949 ASM - nije izvrseno adaptivno ucenje P0950 ASM kontrolno kolo P0951 ASM kontrolno kolo - opseg/rad P0952 ASM kontrolno kolo - nisko P0953 ASM kontrolno kolo - visoko P0954 ASM - los rad periodicnog kola P0955 Kolo ASM moda - lose radi P0956 Kolo ASM moda - opseg/rad P0957 Kolo ASM moda - nisko P0958 Kolo ASM moda - visoko P0959 Kolo ASM moda - los rad periodicnog kola P0960 Solenoid kontrole pritiska (PC) A - otvoreno kontrolno kolo P0961 Solenoid kontrole pritiska (PC) A - opseg/rad kontrolnog kola P0962 Solenoid kontrole pritiska (PC) A - niska vrednost kontrolnog kola P0963 Solenoid kontrole pritiska (PC) A - visoka vrednost kontrolnog kola P0964 Solenoid kontrole pritiska (PC) B - otvoreno kontrolno kolo P0965 Solenoid kontrole pritiska (PC) B - opseg/rad kontrolnog kola P0966 Solenoid kontrole pritiska (PC) B - niska vrednost kontrolnog kola P0967 Solenoid kontrole pritiska (PC) B - visoka vrednost kontrolnog kola P0968 Solenoid kontrole pritiska (PC) C - otvoreno kontrolno kolo P0969 Solenoid kontrole pritiska (PC) C - opseg/rad kontrolnog kola P0970 Solenoid kontrole pritiska (PC) C - niska vrednost kontrolnog kola P0971 Solenoid kontrole pritiska (PC) C - visoka vrednost kontrolnog kola P0972 Solenoid prenosa (SS) A - opseg/rad kontrolnog kola P0973 Solenoid prenosa (SS) A - niska vrednost kontrolnog kola P0974 Solenoid prenosa (SS) A - visoka vrednost kontrolnog kola P0975 Solenoid prenosa (SS) B - opseg/rad kontrolnog kola P0976 Solenoid prenosa (SS) B - niska vrednost kontrolnog kola P0977 Solenoid prenosa (SS) B - visoka vrednost kontrolnog kola P0978 Solenoid prenosa (SS) C - opseg/rad kontrolnog kola P0979 Solenoid prenosa (SS) C - niska vrednost kontrolnog kola P0980 Solenoid prenosa (SS) C - visoka vrednost kontrolnog kola P0981 Solenoid prenosa (SS) D - opseg/rad kontrolnog kola P0982 Solenoid prenosa (SS) D - niska vrednost kontrolnog kola P0983 Solenoid prenosa (SS) D - visoka vrednost kontrolnog kola P0984 Solenoid prenosa (SS) E - opseg/rad kontrolnog kola P0985 Solenoid prenosa (SS) E - niska vrednost kontrolnog kola P0986 Solenoid prenosa (SS) E - visoka vrednost kontrolnog kola P0987 Senzor pritiska tecnosti menjaca (TFP) E - kolo neispravno radi P0987 Prekidac pritiska tecnosti menjaca (TFP) E - kolo neispravno radi P0988 Senzor pritiska tecnosti menjaca (TFP) E - opseg/rad kola P0988 Prekidac pritiska tecnosti menjaca (TFP) E - opseg/rad kola P0989 Senzor pritiska tecnosti menjaca (TFP) E - niska vrednost u kolu P0989 Prekidac pritiska tecnosti menjaca (TFP) E - niska vrednost u kolu P0990 Senzor pritiska tecnosti menjaca (TFP) E - visoka vrednost u kolu P0990 Prekidac pritiska tecnosti menjaca (TFP) E - visoka vrednost u kolu P0991 Senzor pritiska tecnosti menjaca (TFP) E - periodicno kolo P0991 Prekidac pritiska tecnosti menjaca (TFP) E - periodicno kolo P0992 Senzor pritiska tecnosti menjaca (TFP) F - kolo neispravno radi P0992 Prekidac pritiska tecnosti menjaca (TFP) F - kolo neispravno radi P0993 Senzor pritiska tecnosti menjaca (TFP) F - opseg/rad kola P0993 Prekidac pritiska tecnosti menjaca (TFP) F - opseg/rad kola P0994 Senzor pritiska tecnosti menjaca (TFP) F - niska vrednost u kolu P0994 Prekidac pritiska tecnosti menjaca (TFP) F - niska vrednost u kolu P0995 Senzor pritiska tecnosti menjaca (TFP) F - visoka vrednost u kolu P0995 Prekidac pritiska tecnosti menjaca (TFP) F - visoka vrednost kolu P0996 Senzor pritiska tecnosti menjaca (TFP) F - periodicno kolo P0996 Prekidac pritiska tecnosti menjaca (TFP) F - periodicno kolo P0997 Solenoid prenosa (SS) F - opseg/rad kontrolnog kola P0998 Solenoid prenosa (SS) F - niska vrednost kontrolnog kola P0999 Solenoid prenosa (SS) F - visoka vrednost kontrolnog kola 2 neshaoct and Cowboy reacted to this Quote Share this post Link to post Share on other sites
kiza70 0 Posted February 6, 2015 (edited) Molio bih za pomoc oko greske koja mi se pojavila. Dobio sam gresku B0018, valjda motoric klapne reciklacije vazduha. Dajte mi smernice gde da kopam, u koji rudnik da zalegnem i dodjem do njega pa cu ga ispitivati napolju. Edited February 9, 2015 by neshaoct spojeno Quote Share this post Link to post Share on other sites
Angell 11 Posted February 6, 2015 Generic OBD Error Code Details for B0018Right Front/Passenger Frontal Deployment Loop (Single Stage or Stage 1) Short to Ground/Voltage Out of Range Quote Share this post Link to post Share on other sites
kiza70 0 Posted February 6, 2015 nisam bas sve skontao (probao i sa google translet) Quote Share this post Link to post Share on other sites
neshaoct 9590 Posted February 9, 2015 Greška u vezi vazdušnih jastuka.Ne mora da znači da je nešto neispravno, već da ima problem u ''komunikaciji'' između modula, drugim rečima zezaju žice, i/ili neki kontakti. ...test the I/P module high and low circuits for a short to ground or a short to voltage. The inflatable restraint I/P module deployment loop consists of the inflatable restraint I/P module and the I/P module high and low circuits. A shorting bar used within the I/P module connector shorts together the I/P module high and low circuits when the connector is disconnected. This helps to prevent unwanted deployment of the inflator module during servicing. During a frontal crash of sufficient force, the inflatable restraint sensing and diagnostic module (SDM) allows current to flow through the deployment loop in order to deploy the I/P module. When the ignition is turned ON, the SDM performs continuous diagnostic tests on the deployment loops to check for proper circuit continuity and for shorts to ground or voltage. If a malfunction is detected, a diagnostic trouble code (DTC) will be stored in memory.A, može biti da je ispucan jastuk sa vozačke strane, ali prilikom popravke nije zamenjen svaki senzor koji je trebalo, pa zato sija greška. Quote Share this post Link to post Share on other sites
detlic 0 Posted September 27, 2015 Koji je kvar u pitanju sa greskom P0170 i Greskom P1170 na zastavi 10 2007 godiste?nije hteo dobro da vuce, a sada nece da predje 4500 obrtajaHvala Dragan tip 188 Quote Share this post Link to post Share on other sites
Dusan 4 Posted September 28, 2015 P0170 Podesavanje goriva (FT), grupa 1 - lose radiDruga greska ima veze sa Lamba sondom. Kod tebe je problem pumpa za gorivo, jer je na kraju i nema konstantan pritisak, zato i izbacuje ove greske. Uzmi na nekom otpadu polovnu pumpu, zameni tvoju i probaj, trebalo bi da resis problem.... Quote Share this post Link to post Share on other sites
SrdjanNS86 20 Posted October 27, 2015 C1340 , C1522 , C1505 Ove tri greske mimo EGR greske a on je zatvoren mi je danas izbacio posle iznenadnog gasenja auta u toku voznje.Svuda sam trazio sta tacno znace ove tri greske i nemogu da nadjem pa reko da zamolim nekoga ko zna da napise.Posle toga sam vozio auto sasvim normalno nista cudno se nije desilo sv radi kako treba.Videcu za dan dva da opet prikopcam dijagnostiku i da vidim hoce li se ponoviti greska. Quote Share this post Link to post Share on other sites
