sremarko 0 Posted November 12, 2011 da li neko zna dal treba da svetle krugovi za podesavanje klime? Quote Share this post Link to post Share on other sites
neshaoct 9591 Posted November 12, 2011 Naravno da treba. Svetli to i kod Stila, starog Brava... Quote Share this post Link to post Share on other sites
sremarko 0 Posted November 13, 2011 jel zna neko kako se skida ova maska,da se zamene sijalice? Quote Share this post Link to post Share on other sites
neshaoct 9591 Posted November 13, 2011 Na forumu još niko nije pisao o tome kod novog Brava, ali jeste kod Stila:http://www.fiat-lancia.org.rs/forum/index.php?showtopic=40961Možda ti pomogne čisto da stekneš ideju kako se to inače skida. Quote Share this post Link to post Share on other sites
Mirko_NS 19 Posted November 14, 2011 Iako nije tako ePer-u moj savet je da se prvo izvadi CD, a, zatim ona plastika ispod njega...Za vadjenje CDa treba specijalan "kljuc" - vecina servisa ga nema, jer Bravo je jos uvek nov model...Ako pokusas da izvadis plastiku ispod CDa, bez da vadis CD (kako stoji u ePer-u) rizikujes da ostetis (ogrebes) ili polomis tu plastiku... Quote Share this post Link to post Share on other sites
Branko 23 1 Posted November 14, 2011 ePER, nije katalog kako se sta skida i montira, vec katalog auto delova (originalnih rezervnih delova) za to imas ilirn i isidji po srpski receno...,nemoj po eperu da shatas sve zdravo za gotovo, znam ga do sitinih detalja, pa ti zato kazem Quote Share this post Link to post Share on other sites
Mirko_NS 19 Posted November 14, 2011 (edited) Izvinjavam se - u mom gornjem postu sam mislio na eLearn, a napisao ePer Sve ostalo stoji... Edited November 14, 2011 by Mirko_NS Quote Share this post Link to post Share on other sites
sremarko 0 Posted November 14, 2011 uspesno promenjene sijalice...skida se cd,menjac i karbon oko menjaca.... Quote Share this post Link to post Share on other sites
becke021 0 Posted June 14, 2012 uspesno promenjene sijalice...skida se cd,menjac i karbon oko menjaca....Jel mozes malo bolje da objasnis (da li mora da se skine cd ili moze samo mejac i karbon oko menjaca i koliko ima srafova i gde se nalaze i da li moraju da se skidaju tockici za regulisanje temperature, jacine vent i onaj treci)?Hvala unapred! Quote Share this post Link to post Share on other sites
Mirko_NS 19 Posted June 15, 2012 Zapravo se ne skida menjac, tj. rucica istog, nego se na onoj kozi oko menjaca kroz prorez uvuce par pristiju i napipaju kopce koje drze tu kozu (tj. onaj ukrasni aluminijumski okvir) za plastiku/karbon oko menjaca...Kada se nosac otkaci (sto ide lako) dolazi se do sarafa koji drze taj karbon... Quote Share this post Link to post Share on other sites
becke021 0 Posted June 15, 2012 Na to sam i mislio, bilo bi bezveze da moras menjac da skines da bi promenio jednu sijalicu... Hvala Quote Share this post Link to post Share on other sites
bane1321 5963 Posted October 13, 2012 najzahebanije ti je da skines plasticno g*vance ispod samog CDa. Budi veoma pazljiv. drzi se na dve zabice sa gornje strane. Quote Share this post Link to post Share on other sites
ivan.ik 625 Posted October 13, 2012 https://www.fiatdalys.lt/en/catalog/parts/705/2/0/3/3L/0/0/CC1.6/CMBDS/GSX/instrument-panel prostudiraj ovde Quote Share this post Link to post Share on other sites
k.dejan.123 3 Posted December 23, 2012 moj savet je da se prvo izvadi CD, a, zatim ona plastika ispod njega...ok...izvadio sam cd ali nikako da provalim kako da izvučem onu prokletu plastiku.....imaju neke dve žabice sa nekakvim metalnim dodacima/žabicama..kada povučem na dole izađe možda 1cm ..da li te metalne žabice ostaju na ukrasnoj plastici ili u otvoru u koji žabice upadaju?čini mi se i da ona mala plastika ispod takođe sprečava dalje pomeranje....help? Quote Share this post Link to post Share on other sites
neshaoct 9591 Posted January 4, 2013 Deo izdvojen u posebnu temu:Nuova Bravo - zamena osvetljenja analogne klime Quote Share this post Link to post Share on other sites
Urosh1 0 Posted October 16, 2013 (edited) Imam problem sa svetlom na delu gde se podešava grejanje , tačnije dva kruga jer imam manuelnu klimu tj manuelna podešavanja. Leva strana mi radi, tj levi krug je osvetljen a desni nije. Kako se uopšte menja sijalicu tu i da li je uopšte sijalica ili osigurač ?! Edited October 17, 2013 by neshaoct spojeno Quote Share this post Link to post Share on other sites
milos_84 1 Posted October 16, 2013 Sijalica je.Pogledaj temu http://www.fiat-lancia.org.rs/forum/index.php?showtopic=57366 . Quote Share this post Link to post Share on other sites
Urosh1 0 Posted October 16, 2013 Hvala.. Nisam uopšte video tu temu. Quote Share this post Link to post Share on other sites
Urosh1 0 Posted October 17, 2013 A koje sijalice idu ? Quote Share this post Link to post Share on other sites
milos_84 1 Posted October 18, 2013 Ubodna za instrument tablu, 1,2W/12V Quote Share this post Link to post Share on other sites
la_bomba 0 Posted June 7, 2014 (edited) Pozdrav svima. Da li treba da svetle sijalice na ventilacionim tockicima ili na dugmicima sa bocnih strana mp3 plejera kada se startuje auto? A nije ukljucena pozicija.Ako moze neko od vlasnika Nuova Fiat bravo da proba pa da javi. Manuelna klima je u pitanju.Hvala Edited June 7, 2014 by Ivan Spojeno Quote Share this post Link to post Share on other sites
ISV_01 4023 Posted October 28, 2019 Pozdrav ekipa,Naime vec neko duze vreme (citaj od kupovine) mi ne radi osvetljenje moje reso klime, sto mi ne predstavlja prevelik problem jer sam se i navikao na raspored (ubodem dobro) al me pocelo nervirati kad vec ima osvetljenje. Ono, malo je mracno. Elem, sam postupak za skidanje svega sam jednom vec prosao u varijanti bez skidanja radija, odnosno varijanta skidanja prednjeg panela klime skidanjem tockica klime i tu se zaglavio...Srednji tockic, za brzine ventilatora, odbija da se skine jer pruza prilican otpor pri vucenju ka napolje te se plasim da ga ne pocupam i ostetim panel pa onda igranka oko nabavke istog. Sto se tice 'podgrevanja' tockica fenom i slicnog radi popustanja lepka ili cime je vec vezan, mogucnost za to nemam jerbo je garaza zauzeta do daljnjeg.Da li postoji neki poseban polozaj sa kojim ide lakse to skidanje ili jednostavno cupanje pomocu neke polugice (citaj viljuska ili slicno) da tockic izleti ? Verovatno prosli vlasnik je isto pizdeo, a menjano nije jerbo bi mu sigurno u Nemackoj papreno naplatili zezanje od pola cuke. Hvala unapred.Sent from NOMU S10 PRO using Tapatalk Quote Share this post Link to post Share on other sites
Ivan 17593 Posted October 28, 2019 (edited) @ISV_01 Sam modul analogne klime je vrlo slican kao na Stilu, razlika je sto ima prilicno vise posla da se raskupusa i dodje do njega. Svi tockici se skidaju povlacenjem i ispod njih je onda ona providna plastika, ispod koje su sijalice. Sijalice su one male od 1,2W. Evo da imate i postupak iz eLearn: PS: Evo kako izgledaju osovine tockica, kada se dodje do providne plastike. U gornjem delu, izmedju osovina ces videti 2 sijalicna mesta: Edited October 28, 2019 by Ivan Quote Share this post Link to post Share on other sites
ISV_01 4023 Posted October 28, 2019 Hvala kolega, al sve sam to raskupusao jednom (vatreno krstenje) al nece srednji tocak d sidje svakako bez njega (osim da raskupusavam sa skidanjem radija iz lezista i od njega sve srafove/inbuse odvrcem i skinem celu klimu) ne mogu panel skinuti...kao da je zapekao u centru gde mu je osovina i ni makac. Primenio sam silu dovoljno jaku da je pod prstima pocela guma oko tockica da se oseca kako se struze, pa sam stao...onaj fazon, tako blizu al tako daleko Sent from NOMU S10 PRO using Tapatalk Quote Share this post Link to post Share on other sites
Ivan 17593 Posted October 28, 2019 (edited) Verovatno zapeklo. Ne znam da li si video ovu temu, kazu ljudi da su uspevali gimnastikom da zamene sijalice i bez skidanja tockica... Pogledaj i neki post ispod, takodje je objasnjeno: A imas odlican tutorial i na fiatforum.com: https://www.fiatforum.com/bravo-guides/308785-replacing-failed-bulbs-heater-control-panel.html Edited October 28, 2019 by Ivan Quote Share this post Link to post Share on other sites
