Multi 0 Posted January 16, 2017 (edited) Rijedio ssm problem. Raskopcavao sam protokomjer,nije bilo do njega. Opet skinuo egr, posto prvi put kad sam cistio nisam imao zvjezdastog kljuca i skinem onaj motor i fino ocistim polugu. Sad sam to uradio, ocistio i ide odlicno. Skidao i map filter, al nece da se izvuce. Smijem li ga jace povuci da ga iscupam ili ima neki fazon kako se vadi. I cim da ga ocistim? Edited January 17, 2017 by Ivan Obrisan dupliran deo posta Quote Share this post Link to post Share on other sites
Kuvalja 406 Posted January 17, 2017 Map senzor mislis, skines onaj jedan sraf i lagano ga izvlaci, malo ga okreci da popusti ili zavuci ravan srafciger i natezi lagano, operes ga sa carb cleaner ili brake cleaner-om.Sent from my HTC One M9 using Tapatalk Quote Share this post Link to post Share on other sites
Multi 0 Posted January 17, 2017 Aha, zapekao znaci. Pogrijesio sam, map senzor sam mislio. Vazi, tako cu uraditi, valjda je pametniji pa popusti. Quote Share this post Link to post Share on other sites
MS PK 7728 Posted January 17, 2017 Ne drzi ga nista kad skines sraf, verovatno ga garez malo zacementirala Quote Share this post Link to post Share on other sites
