milan93 0 Posted September 24, 2016 Uh, super, ako se ispostavi da je to, koliko to moze da kosta? Quote Share this post Link to post Share on other sites
zoran rakita 0 Posted September 24, 2016 Sta je tu super pa mnogo je jeftinija bobina nego da ti ode kompijuter... Quote Share this post Link to post Share on other sites
milan93 0 Posted September 24, 2016 Bilo je ironicno inace Quote Share this post Link to post Share on other sites
alexpapi 0 Posted September 24, 2016 Imas celu temu o tome malo pretrazi forum. Sumnjam da je bobina a nov kom je misaona imenica. Imaju neki likovi na tosinom bunaru koji to sredjuju. Problem je u losim lemovima na kompu. Al ko sto rekoh procesalj forum ima vec https://www.fiat-lancia.org.rs/forum/index.php?/topic/37364-Punto-mk.2-1.2-8v---rešenje-ECU-problema Quote Share this post Link to post Share on other sites
kakoonobese 43 Posted September 25, 2016 Problem sa kompjuterom kod Punta je cest ali mislim da ne treba donositi zakljucke pre provere svecica, kablova i bobina. Meni su kolege sa foruma sugerisale da je komp uzrok problema ali se ispostavilo da nisu bili u pravu (na moju srecu). Quote Share this post Link to post Share on other sites
milan93 0 Posted September 25, 2016 Hvala svima na odgovorima, otici cu na dijagnostiku pa da vidim sta se desava, iskreno se nadam da su kablovi i svecice, jer ima smisla, po proizvodjacu vec je vreme za zamenu istih... Quote Share this post Link to post Share on other sites
Trifke 0 Posted March 3, 2017 (edited) Desava se da variraju obratiju u leru. U voznji nekad vuce kao na 3 cilindra a nekad super Edited March 3, 2017 by Trifke Quote Share this post Link to post Share on other sites
cuore_sportivo 79 Posted March 3, 2017 Kod 1.2 16v obicno su problem.kablovi,svecice,bobina a redje ECU. Ispravite me ako gresim..ja sam isto pretrnuo pre 2 meseca..sva sreca bili su samo kablovi problem. Quote Share this post Link to post Share on other sites
Axic 20029 Posted March 3, 2017 Nije zgoreg da se očisti klapna gasa. Quote Share this post Link to post Share on other sites
dule2812 0 Posted March 4, 2017 Врло могуће да је неки вентил отишао, у мом случају је тако билоSent from my iPhone using Tapatalk Quote Share this post Link to post Share on other sites
gile smederevo 574 Posted March 4, 2017 (edited) +1. Da je struja-trokirao bi i prijavljivao Check Engine. Edited March 4, 2017 by gile smederevo Quote Share this post Link to post Share on other sites
Trifke 0 Posted March 6, 2017 Problem je uspesno resen ciscenjem klapne a uspust sam ocistio i map senzor. Auto je prodisao ler je stabilian kod mene je 850rpm Quote Share this post Link to post Share on other sites
Trifke 0 Posted March 10, 2017 (edited) Problem se ponovo pojavio, sada je mnogo gore bio samkod majstora cela Klapna skinuta i ociscena, map zamenjnjen, Kablovi zamenjeni, ali se auto mnogo gore ponasa. Da li je moguce da je lambda sonda.auto u voznji trokira kada dam gas kao da krene da guta knedlu i samo probije. Edited March 10, 2017 by Trifke Quote Share this post Link to post Share on other sites
Mijailović P. 3445 Posted March 10, 2017 Samo struja (kablovi,svećice i bobina).U Autodati postoje podaci koji su otpori na kalemima bobine. Proverite i nakon rešavanja problema kalibrirajte klapnu. Quote Share this post Link to post Share on other sites
Trifke 0 Posted March 11, 2017 Problem resen lambada sonda je brljavila i pokazivala cas 45 cas 750. Stavljena nova problem Nestao. Quote Share this post Link to post Share on other sites
Rile_bg 347 Posted March 11, 2017 koja je bila u problemu,prva ( pre do motora ) ili druga posle katalizatora? Quote Share this post Link to post Share on other sites
Trifke 0 Posted March 11, 2017 Prva do motora.auto je brljavio i nalivao previse benzina. posle ostre voznje se ocecao miris benzina i dimio je na auspuhu. Sada sve sve normalizovalo Quote Share this post Link to post Share on other sites
marac 0 Posted September 20, 2017 Pozdrav, imam problema sa svojim puntom. Problem je sporo ubrzavanje. Ipak je to 1.2 motor i nije mu ubrzanje neko, al je 16v tako da mislim da bi trebao bolje ic nego trenutno. Zamijeno sam kablove i svjecice te pumpu goriva, jer je pritisak goriva bio los. Ali stanje je isto. Ne svijetli niti jedna lampica tako da mi dijagnostika nece pomoc. Nekad imam osjecaj na 4000 da ga koci nesto, naglo ga zablokira/zagusi na 2 sekunde i pusti opet Ako netko zna u cemo moze bit problem bio bi zahvalan Jer ako odem na bezveze u servis rec ce mi da trebam boga oca zamjenit Quote Share this post Link to post Share on other sites
cuore_sportivo 79 Posted September 20, 2017 (edited) Ne znam gde zivis ali se meni slicno desilo. Sipao sam na drugoj pumpi gorivo i razvukao ga na autoputu do Malog Pozarevca i nazad za Beograd. Problem mi je nestao..isto sam sve to sto si nabrojao menjao...posle te voznje na autoputu auto je poceo da se ponasa kako treba. Neka jos neko nesto doda ako ima..mozda je drugi problem kod tebe. A da ne zaboravim..cistio sam dizne,radio mali servis tad i cistio klapnu. Tek posle autoputa mi se stanje normalizovalo. Pozdrav Edited September 20, 2017 by cuore_sportivo Quote Share this post Link to post Share on other sites
marac 0 Posted September 20, 2017 probat cu sam tim makar sumnjam, jer ga uvijek razvlacim gdje god krenem tocim gorivo na ini, a ina kolko sam cuo nije bas pouzdana al ajd, kad druge nema u krugu od 50km Ne bitno bilo uzbrdo, ravno ili nizbrdo auto krene kocit sam od sebe stuca na leru, nemiran ler gas takoder I sad pogledam onako slucajno potrosnju, skoro me fraz pogodio, 15.3l nisam mogo vjerovat ocima ako netko ima kakvu ideju kako pomoc bio bih zahvalan Quote Share this post Link to post Share on other sites
cuore_sportivo 79 Posted September 20, 2017 Jel ti bas na bordu tako pise? 15.3l? Ili si preracunao tj 100 podelio sa cifrom na bordu ako ti stvarno toliko trosi onda moze i lambda sonda da bude...ja sam je menjao ali nisam tad imao gore navedeni problem...vec mi je trosio kao sumanut sa check engine lampicom u paketu. Quote Share this post Link to post Share on other sites
marac 0 Posted September 20, 2017 ma na bordu pise nisam skuzio na prvi pogled da je km/l tako da je oke, znaci nekih 6.5l po otvorenoj znaci potrosnja je oke eh sad, koji je uzrok lose vuce leptir gasa cu ocistit, ali tu necu dobit nista osim mirnijeg ler gasa, bar sam tako procito na dosta forumova Quote Share this post Link to post Share on other sites
gorank82 183 Posted September 21, 2017 Probaj da očistiš dizne možda ga to muči... Quote Share this post Link to post Share on other sites
Markobgd 609 Posted September 21, 2017 (edited) A da nije možda 15,3km/l ? Edit: Tek sad vidim da si skontao grešku Edited September 21, 2017 by Markobgd 1 cuore_sportivo reacted to this Quote Share this post Link to post Share on other sites
Alki 2 Posted February 7, 2019 (edited) fiat punto 1.2 16v 2002 sporting .kad je hladan uglavnom na nekih 2 3 min ume ponekad da kako da objasnim nista on ne trese ili trza nego jednostavno 200 300rpm .cuje se neki mali gas kako sam dok je hladan samo malo daje gas na 200 300 rpm.kao sto sam do sada pita jel nesto sve to ozbiljno .imao sam jednu flashu gde je bilo 2 3 kapice antifriza i tu sam sipao gorivo a nisam znao pa sam sipao u rezervoar .jel moguce da zbog toga sve ovo radi ,gusi ,ne vuce . Edited February 7, 2019 by neshaoct spojeno Quote Share this post Link to post Share on other sites
