Ivan BG 720 Posted June 13, 2015 Sinoc bese pobedio Partizan?Nisam nesto pratio, gosti mi neki bili. :-) Quote Share this post Link to post Share on other sites
totti 13165 Posted June 13, 2015 Imaš drugu temu za krađe Quote Share this post Link to post Share on other sites
beli_Punto 123 Posted June 13, 2015 (edited) Nemoj ja da ti dodjem u goste Izgubismo posteno, uz malo srece i cudne odluke sudija Edited June 13, 2015 by beli_Punto Quote Share this post Link to post Share on other sites
totti 13165 Posted June 13, 2015 Možeš u Kuda ide ovaj svet ili Povećan broj krađa Quote Share this post Link to post Share on other sites
Ivan BG 720 Posted June 13, 2015 Beli, svrati slobodno u frizideru imam flasu Rubinovog Vinjaka, mozes da zamislis koliko je hladan, naravno kisela i Jeger se cuvaju na istom mestu sa Vinjakom, mozes da biras.Totti,Znaci da predjem u temu o kradjama, ili veciti derbi, mada je basket u pitanju? Quote Share this post Link to post Share on other sites
Buca_Tipo 31 Posted June 13, 2015 Ja cu Jeger ako nije problem Quote Share this post Link to post Share on other sites
beli_Punto 123 Posted June 13, 2015 Samo da nadjem akumulator i dolazim Gledam ga nesto, gore je mokar, izasla kiselina, pa razmisljam da li vredi puniti i cackati ili da odmah jurim drugi? Quote Share this post Link to post Share on other sites
Ivan BG 720 Posted June 13, 2015 Da nije probila neka celija? Quote Share this post Link to post Share on other sites
beli_Punto 123 Posted June 13, 2015 kako to da proverim? Quote Share this post Link to post Share on other sites
Ivan BG 720 Posted June 13, 2015 Treba ti neki hidrometar, meri odnos kiseline i vode u accu i valjda pritisak u celijama, a imaju ga valjda ovi sto rade servise akumulatora, ima jedan takav servis na Zrenjaninskom putu, a valjda to neko radi u SD. Quote Share this post Link to post Share on other sites
beli_Punto 123 Posted June 13, 2015 mislim da znam na sta mislis, cekam brata da mi javi sta ima od polovnih pa da uzmem od njega Quote Share this post Link to post Share on other sites
Dezurni 399 Posted June 13, 2015 Imaš drugu temu za krađe Ja nešto ne mogu da pronađem tu temu Quote Share this post Link to post Share on other sites
beli_Punto 123 Posted June 13, 2015 Nadji akumulator ... o temi cemo drugi put Quote Share this post Link to post Share on other sites
totti 13165 Posted June 13, 2015 Imaš drugu temu za krađe Ja nešto ne mogu da pronađem tu temu Izvolte kolega: https://www.fiat-lancia.org.rs/forum/index.php?/topic/45653-pove%C4%87an-broj-kra%C4%91a/ Quote Share this post Link to post Share on other sites
beli_Punto 123 Posted June 13, 2015 Nasao sam od 54ah, jel dovoljno to za Puntaru preko leta? Quote Share this post Link to post Share on other sites
Ivan BG 720 Posted June 13, 2015 Koji accu ti je sada, koje jacine? Quote Share this post Link to post Share on other sites
beli_Punto 123 Posted June 13, 2015 Mislim 66ah Ali ako se dobro secam drugar je prosle godine pred zimu za punta JTD uzeo 56 i radi normalno Quote Share this post Link to post Share on other sites
Ivan BG 720 Posted June 13, 2015 Mislim da je bitnije koliki procenat accu-a moze da napuni sam alternator, od same jacine akumulatora. Dzabe mu velik kapacitet kad je uvek poluprazan, samo ce crci ranije.Mislim da je Ivan.IK pisao negde o tome po forumu. Quote Share this post Link to post Share on other sites
totti 13165 Posted June 13, 2015 Ne prizivaj ga, da ne bi sad izbacio tri stranice raznih grafikona... Zagušiće temu Quote Share this post Link to post Share on other sites
Ivan BG 720 Posted June 13, 2015 Ajde grafikoni su jos i ok, pa cak i clanci iz Auto bild-a, jeste da su na svapskom pa mogu samo slike da gledam, ali oni GIF-ovi su mu cudo, pitam se samo gde ih iskopava. Quote Share this post Link to post Share on other sites
beli_Punto 123 Posted June 13, 2015 Nasao sam banner od 64ah ... upalio na pola kljuca Quote Share this post Link to post Share on other sites
Ivan BG 720 Posted June 13, 2015 Polovan, koliko para? Quote Share this post Link to post Share on other sites
beli_Punto 123 Posted June 13, 2015 20€Skinut sa Clia stranca Quote Share this post Link to post Share on other sites
beli_Punto 123 Posted June 13, 2015 Pa nije bas dzabe, ali mi se ne daju pare za nov Quote Share this post Link to post Share on other sites
