baneee 7 Posted May 9, 2014 Vidim nema konkretnog odgovora,a i mene zanima. Staviti prohromski auspuh ili neki "obican" od krstene firme ? Quote Share this post Link to post Share on other sites
miske17 0 Posted May 26, 2014 (edited) Treba mi strucno misljenje i savet o stavljanju drugog izduva na moju alfu?Sta treba obratiti paznju i kome je najbolje obratiti se za to? Edited May 26, 2014 by miske17 Quote Share this post Link to post Share on other sites
Djole_M 142 Posted May 26, 2014 Za tvog dizela samo streight pipe.... Quote Share this post Link to post Share on other sites
stefankmn 164 Posted May 26, 2014 +1 za straight pipe.. mizda si cuo na skupu kako to zvuci kod mene Quote Share this post Link to post Share on other sites
Djole_M 142 Posted May 26, 2014 Ja sam npr. kod Kubure na Tdi Seatu oduševljen kako zvuči Quote Share this post Link to post Share on other sites
miske17 0 Posted May 26, 2014 da skidam zadnji lonac i napravim racvu za levi i desni izduv ili sta? Ne bih da oteram da urade a da se ispostavi da ne valja tako. Quote Share this post Link to post Share on other sites
Djole_M 142 Posted May 26, 2014 (edited) ja ovo što sam video je jedna cev i na kraju ukras...Ali ima da se dere uuuuu Edited May 26, 2014 by matdjo Quote Share this post Link to post Share on other sites
stefankmn 164 Posted May 26, 2014 Miske odes i kazes ocu cev od pocetka do kraja.. pazi da te ne razumeju pogresno :-D skines sve lonce i katalizator .. to je taj proces.. straight pipe Ako oces .. vidim da si bg .. mozes da dodjes do mene pa da cujes sta je to i da ti objasnim Quote Share this post Link to post Share on other sites
miske17 0 Posted May 26, 2014 Onda ce mnogo da se dernja. Ne zelim neki zvuk dodatni i da bolje ide, samo da ima komata dva pozadi Quote Share this post Link to post Share on other sites
Djole_M 142 Posted May 26, 2014 Imaš par klipova na YT kako se čuju AR Jtd Quote Share this post Link to post Share on other sites
miske17 0 Posted May 26, 2014 Gledao sam to, ima par crnogoraca koji su to radili. Ne bih skidao katalizator i lonce zbog sondi i tih gluposti. Videcu vec sta moze da se uradi Quote Share this post Link to post Share on other sites
stefankmn 164 Posted May 26, 2014 Pa ako oces da ima samo dve cevke pozadi odradi samo nastavak i to je to Ne moras da skidas nista Quote Share this post Link to post Share on other sites
Djole_M 142 Posted May 26, 2014 (edited) Tako sam ja prvo odradio.....a skoro sam stavio protočan i super mi je malo smo omašili temu.... http://www.fiat-lancia.org.rs/forum/index.php?/topic/44596-Sport-auspuh-/-protočni-/-straight-pipe Edited May 26, 2014 by matdjo Quote Share this post Link to post Share on other sites
kicerica 5 Posted May 26, 2014 (edited) ovako nesto... http://www.auspuhpirke.co.rs/katalog/?album=37&gallery=97 http://www.auspuhpirke.co.rs/galerija/?album=4&gallery=11 Edited May 26, 2014 by kičerica Quote Share this post Link to post Share on other sites
miske17 0 Posted May 26, 2014 jel mogu da stavim racvu iza zadnjeg lonca ili ispred a da ne poremetim nista? da pazim na fi cevke itd, za ukrasne nastavke cu lako, to mi je najmanji problem . kao ova sa zadnje slike na linku koji je kicerica postaviohttp://www.auspuhpirke.co.rs/galerija/?album=4&gallery=11 Quote Share this post Link to post Share on other sites
niksaklecak 0 Posted June 15, 2014 cao, imam GP 1.4 8v, i imam osecaj da slabo ubrzava. mozda je bolje reci, da je auto tezak za taj motor.takodje imam ugradjen plin, i auto je presao dosta. 260000. i sve je ispravno na njemu. da li bi mi promena izduvne grane povecala obrtni moment (koliko), i da li je ista modifikacija losa po motor? kao i po o2 senzor? kao i sta je potrebno da se odradi da mi greska ne iskace?citam vec danima o ovome, ali nigde nema konkretanog odgovora. Quote Share this post Link to post Share on other sites
neshaoct 9590 Posted June 16, 2014 Dobio bi lepši zvuk. Ne smeta motoru ništa.Nema na 1.4 dobitaka KS, a naročito nema dobitaka Nm. Quote Share this post Link to post Share on other sites
Djole_M 142 Posted June 16, 2014 (edited) evo baci pogled na moju temu,ja sam stavio protočni lonac,nisam dobio ništa osim zvuka....možda je malo rasterećeniji pri bržem šaltovanju ili je to samo moj trip zbog zvuka.... Edited June 16, 2014 by matdjo Quote Share this post Link to post Share on other sites
milos.becejac 5 Posted October 25, 2014 (edited) Da li neko zna neki auspuh servis u Nisu ali da radi Nedeljom, stigo mi izduv pa ne mogu da cekam do ponedeljka Edited October 27, 2014 by neshaoct spojeno Quote Share this post Link to post Share on other sites
Buca_Tipo 31 Posted October 25, 2014 Jok. U ponedeljak kod Srdjana! Quote Share this post Link to post Share on other sites
milos.becejac 5 Posted October 26, 2014 Ma kod Spalije cu sutra, kakav srdjan Quote Share this post Link to post Share on other sites
MS PK 7729 Posted October 26, 2014 Kod Srdjana bre, Bucin veliki prijatelj Quote Share this post Link to post Share on other sites
genca 2 Posted October 26, 2014 Eeeee...pitaj ga koliko bi kostalo da mi odradi izduv i sa desne strane....nesto preko veze. Quote Share this post Link to post Share on other sites
deki87 7 Posted October 26, 2014 Ja bre tetke mu ga....sta si se uplasio malopre kad sam bio iza tebe nemoz 5min da ugasis sva 4.... :laughing:Imas i bokita na l.stenu isto radi ok. Quote Share this post Link to post Share on other sites
