beli_Punto 123 Posted March 2, 2015 To sam i ja mislio, video si da je jedan kolega stavljao plasticnu mrezicu? I meni se svidja tako nesto, one resetke se uklone, a postavi se mrezica i jedan deo ofarba u crno, malo skupo, ali lepo Quote Share this post Link to post Share on other sites
diskusija 9 Posted March 2, 2015 odlične i fotke i auto.. samo si mogao bar malo gume da opereš Quote Share this post Link to post Share on other sites
SikterBre 31 Posted March 2, 2015 Totalno sam zaboravo na to, imam na poslu sprej i za gume i za felne i uvek kad operem auto, očistim i njih, ali ovog puta zaboravih... nešto nisam za mrežice, nisu mi se nikad dopadale, ali farbanje same rešetke u crno bi dalo dobar efekat, ali sve je ono "neka drugi put" i tako i ostaje... Ono što mi je još želja da uradim jesu štopovi od mk2b i neke elipse nazad, ali sve to skupa otom potom.. Quote Share this post Link to post Share on other sites
saledelagano 26 Posted March 3, 2015 Dobri kadrovi i mesto za fotkanje generalno. 2 zamerke, previse vuku na zuto i steta sto su ti strokave gume, ostalo ok Puntac u fullu Quote Share this post Link to post Share on other sites
kAcA 0 Posted March 3, 2015 Odlican Punto a i slike! Quote Share this post Link to post Share on other sites
SikterBre 31 Posted March 6, 2015 Radovi u toku Quote Share this post Link to post Share on other sites
paun 1 Posted March 6, 2015 Sta mu je sada?Neka izmena ili? Quote Share this post Link to post Share on other sites
igor0511 2882 Posted March 6, 2015 Možda ubacuje šestobrzinac Quote Share this post Link to post Share on other sites
swifty_kg 1 Posted March 6, 2015 Ako sam ga dobro razumeo, kvacilo ga zeza. Quote Share this post Link to post Share on other sites
Kuvalja 406 Posted March 6, 2015 Opet kvacilo? Quote Share this post Link to post Share on other sites
SikterBre 31 Posted March 6, 2015 Opet, kliza, ali sam uspeo ovoga puta da se vratim u Kg i dovezem auto u servis... Dešava se sledeće.. Šrafovi koji drže zamajac nisu namazani lepkom pri prethodnoj zameni seta kvačila i kada se auto zagreje, kroz šrafove prođe ulje iz motora u menjač i došlo je do toga da je ulepilo lamelu i ona kliza.. Na svu sreću imam neki rezervni set kvačila, tako da to neće da me košta ništa, ali kada sam već to skinuo, zameniću semering radilice i proverismo trap, jabučice nisu bog zna kako dobre, pa će i one na reparaciju.. Dakle, nov semering radilice, nove jabučice (sa obe strane), nov druk lager, pošto se ovaj čuje i ravnanje zamajca i korpe.. Kontam da će do ponedeljka biti sve gotovo, pošto su vozila mušterija prioritet.. Quote Share this post Link to post Share on other sites
kolega.jankovic 23 Posted March 6, 2015 Isti slucaj bio kod mene pre oko 1.5god.Jbg, sta da se radi Quote Share this post Link to post Share on other sites
SikterBre 31 Posted March 6, 2015 Sreća je što sad ne plaćam 40€ za ruku, kao što je bila situacija letos.. Jbg, zbog propusta upropašten set kvačila.. Quote Share this post Link to post Share on other sites
kolega.jankovic 23 Posted March 7, 2015 Kod mene sreca pa je set menjao bivsi vlasnik-kad je pocelo da kliza nisam mogao da verujem, znam da me ne bi slagao, a nisam lud vidim da kliza.Onda je Goran skinuo sve i objasnio o cemu se radi. I stvarno korpa nova, lamela nova......samo masna Sta da se radi. Quote Share this post Link to post Share on other sites
paun 1 Posted March 7, 2015 E jbg.Sta da se radi,sredices to opet si na putu.Bitno je da si dosao do Kg.Jabucice radi kod Tejovica,provereno. Quote Share this post Link to post Share on other sites
SikterBre 31 Posted March 7, 2015 Sve skockano danas, ali opet problemi Kako je sve sklopljeno i na prvi pritisak kvačila osetio sam da je to to, ali takođe osetio da mi je cilindar sumnjiv, što se pokazalo posle par test vožnji, papučica ostala dole, tako da će i cilindar na zamenu... Nešto mi lupka u prednjem desnom dok je auto u pokretu, ne mogu da ustanovim šta je, pa je auto ostao u garaži da ga u ponedeljak opet pretresemo.. Popeli smo ga na dizalicu i pošto su točkovi u vazduhu ne lupka ništa, ali čim krenem opet se javi lupkanje, kao da nešto kači negde.. Quote Share this post Link to post Share on other sites
Axic 20048 Posted March 7, 2015 Proveri oprugu i solju amortizera. Quote Share this post Link to post Share on other sites
SikterBre 31 Posted March 7, 2015 Pa posumnjao sam i ja na to, kada vozim lupka na svaki okretaj točka, čuje se tup-tup-tup, ali čim ga podignemo na dizalicu i bukvalno u vazuhu ga doteram do 140km/h i nikakav zvuk se ne javlja, onda ga spustimo i čim krenem, opet lupa.. Dakle, samo pod opterećenjem.. Ubi me ovih par dana, a pred kraj meseca mi ide registracija.. Quote Share this post Link to post Share on other sites
bane17 24 Posted March 7, 2015 ja sam imao takav problem,da bi se ispostavilo da je sraf od felni,bio malo duzi. Quote Share this post Link to post Share on other sites
Ivan 17670 Posted March 8, 2015 Jeste banalno, ali proveri da ti se nesto nije zabolo u gumu? Desilo mi se isto relativno skoro, krenuo - lupka u prednjem delu, kao sto i ti kazes na svaki okretaj tocka.Odmah stanem, slicno se cuje kad je razlabavljena felna, izvadim kljuc - sve OK, zategnuto. Pregledam onako brzinski koliko mogu na ulici, gumu, vesanje, sve deluje normalno.Opet krenem, lupka, morao sam da izadjem na autoput, oko 80km/h nista, usporim - lupka. Stanem opet na prvo prosirenje, spustim rucnu i sada bas pazljivo pregledam gumu celim obimom i nadjem uzrok. Gume su nove, sa dubokom sarom i u kanalu sare se zaglavilo parcence crne plastike koje sam negde pokupio. Banalna stvar, ali uopste nije zvucalo tako, pa proveri i to. Quote Share this post Link to post Share on other sites
SikterBre 31 Posted March 8, 2015 Videću to sutra, pošto je auto ostao na poslu, isto tako se i kod mene manifestuje, a nekako mi je i logično, jer kada je točak u visini se ništa ne čuje.. Quote Share this post Link to post Share on other sites
bane17 24 Posted March 8, 2015 (edited) ovo onaj tvoj drugar? http://www.polovniautomobili.com/felne-ratkapne/5935387/aluminijumske-felne-15-4-x-98 Edited March 8, 2015 by bane 17 Quote Share this post Link to post Share on other sites
SikterBre 31 Posted March 9, 2015 Nije, on je svoje prodao brzo.. Danas je konačno sve završeno oko kvačila, nije morao da se menja cilindar kvačila, ispušten je vazduh i sada sve funkcioniše besprekorno, sa te strane sam prezadovoljan.. Što se lupkanja tiče, nije prestalo, a pošto nikako ne možemo da ustanovimo šta je, jer kada je auto na dizalici sve radi normalno, ali kada je na zemlji i kada ide, onda lupka.. Sada ne lupka na ravnom, osim kada kočim i kada pomerim volan levo-desno, tako da je neka pretpostavka da su u pitanju pločice, jer je izgleda ispao osigurač.. Sledeće ulaganje je leptir gasa, vozim ga onako sa lerom koji ume da zavarira, ali srediću i to do registracije, a to je za dve nedelje.. Quote Share this post Link to post Share on other sites
MS PK 7732 Posted March 9, 2015 Kako ces da ga registrujes ako sve to sredis Quote Share this post Link to post Share on other sites
