mikisxy 6 Posted February 17, 2011 posto je stara rucica pukla bilo je potrebno lepo zapeti da se izvadi ostatak,nova se nabija i preporuka naciljati iz prvog jer naknadne korekcije deluju nemoguce Quote Share this post Link to post Share on other sites
coanew 0 Posted February 17, 2011 a gde si kupio novu Quote Share this post Link to post Share on other sites
mikisxy 6 Posted February 17, 2011 kupila musterija u delti oko 5 hiljada din Quote Share this post Link to post Share on other sites
Mateo 2 Posted February 17, 2011 (edited) Rucica je fabricki upresovana....treba bas dobro da se zapne da bi se izvadila.Mozda je mogao prvo da se raspita po otpadima mada i nije toliko strasno za Grandea je u delti 9 Hiljada zvao pre 15-ak dana... Edited February 17, 2011 by Mateo Quote Share this post Link to post Share on other sites
Mijailović P. 3448 Posted February 17, 2011 Ako nije problem da me uputite ? Kako vidim nova rucica je sela, medjutim , kako sada "ide u rikverc" ? Istinu govoreci,kod mene je rucica jos uvek u dobrom stanju ali eto iz rdoznalosti pitam. Quote Share this post Link to post Share on other sites
neshaoct 9592 Posted February 18, 2011 Kod JTD dizela, za razliku od naših benzinaca i MJet dizela nema prstena koji se povlači gore kada prebacuješ u rikverc. EDIT: Vidim sada da piše i da 1.8 nema prsten.Drugim rečima, šareno...k'o po običaju kod Fiata. Quote Share this post Link to post Share on other sites
Mijailović P. 3448 Posted February 18, 2011 Hvala ! Trt-mrt ! To znaci da je rikverc u istom nivou ili je na pritisak ruke (odozgo) , da se teko izrazim ? Quote Share this post Link to post Share on other sites
Manfred 2 Posted February 18, 2011 u istom nivou kao druga i cetvrta brzina... samo desno do kraja i na dole.. Quote Share this post Link to post Share on other sites
srkiv 1 Posted October 4, 2012 Trreba mi pomoc,kako da skinem rucicu menjaca? Quote Share this post Link to post Share on other sites
Mirko_NS 19 Posted October 4, 2012 Hehehe, sad odmah moze da skine bar 100000km... Quote Share this post Link to post Share on other sites
kolega.jankovic 23 Posted October 5, 2012 Zamenio bih i ja ručicu menjaca rado (ova mi je ok stanje ali ruzna) međutim-ne znam kako da je skinem-gde da kupim lepu rucicu a kvalitetnu (bez kosturskih glava i sl nego neki stock koza i to... da bude clean look ali onako fino moze i aluminijum) Quote Share this post Link to post Share on other sites
ivan.ik 625 Posted October 5, 2012 Uhvatiš čvrsto i čupaj na gore, i pri tome lagano uvrći. Cela mudrost, pazi samo zube da ne izbiješ. Evo kako na mom stilu izgleda + sad je niža za par cm. http://www.fiat-lancia.org.rs/forum/index.php?showtopic=54772 Quote Share this post Link to post Share on other sites
kolega.jankovic 23 Posted October 8, 2012 jako lepa rucica. u kom je sad stanju-kvalitet? Gde si je kupio? Ako sam te dobro razumeo samo treba jako da se iščupa stara i posle sta-nabije nova? silom? Quote Share this post Link to post Share on other sites
ivan.ik 625 Posted October 8, 2012 Bubanj potok, subota. Tražio sam najmanje upadljivu, ali nije neki biser inžinjerstva. Ima metalni prsten na dnu sa par imbusa, sa kojim se fiksira. Međutim meni se taj prsten odlepio, pa se na kraju koristila dobra pur pena. Odradila posao fantastično. Quote Share this post Link to post Share on other sites
Dior 0 Posted February 22, 2013 A sta da radimo mi sa benzincima, da li postoji neko resenje? Quote Share this post Link to post Share on other sites
Mijailović P. 3448 Posted February 22, 2013 Ko benzinjara je sve kako treba, da ne kažem drugačije.Samo ovi traktori moraju da se doradjuju ! p.s.Par odgovora ranije je objašnjeno.zulutapka Quote Share this post Link to post Share on other sites
Dior 0 Posted February 22, 2013 (edited) Zasto je uopšte ubačen taj prsten ako nije bilo potrebe,koliko sam ja razumeo nabodes novi bez prstena sve radi isto? Edited February 22, 2013 by Dior Quote Share this post Link to post Share on other sites
Mijailović P. 3448 Posted February 22, 2013 Predlažem da se vratiš opet unazad i polako pročitaš sve ! zulutapka Quote Share this post Link to post Share on other sites
Dior 0 Posted February 22, 2013 (edited) Predlazem da mi ti objasnis jer ja verovatno ne kapiram.Sad vidim da jedino JTD motori nemaju prsten ali moje pitanje i dalje glasi da li moze da se zameni ručica menjača na benzincu a da nije original fijatova i koji je postupak skidanja ,predpostavljam da je skidanje nesto komplikovanije zbog tog prstena? Edited February 22, 2013 by Dior Quote Share this post Link to post Share on other sites
Ivan 17667 Posted February 22, 2013 A sta da radimo mi sa benzincima, da li postoji neko resenje?Naravno,najpametnije resenje je prebaciti se na dizelasa . Quote Share this post Link to post Share on other sites
Mijailović P. 3448 Posted February 22, 2013 Haha, ništa ja tu ne b' dir'o ! zulutapka Quote Share this post Link to post Share on other sites
Dragan G 0 Posted February 22, 2013 (edited) Ni ja, sasvim zadovoljan rucicom, dosta lepsa od ove bez prstena. http://img59.imagesh.../imag0283da.jpg Edited February 22, 2013 by Dragan G Quote Share this post Link to post Share on other sites
Dior 0 Posted February 22, 2013 (edited) Vidim ja da je vama zabavno ali izgleda od ovog posla nema nista.Kupicu stiker pa cu da ga prelepim preko izgrebane ručice i gotova stvar! Edited February 22, 2013 by Dior Quote Share this post Link to post Share on other sites
Ivan 17667 Posted February 22, 2013 Ako ti je samo do izgrebanog "poklopca" na rucici, a hoces da ostavis tu fabricku, imas i ovu varijantu kao sto je moj prijatelj uradio - da je "obelis", tj. sastruzes onaj sivi sloj sve do brojeva (ako ti se svidja tako). Evo kako izgleda:Na otpadima ce ti vrlo tesko dati samo taj poklopac, uglavnom uvaljuju samo cele rucice, pisali smo vec. Quote Share this post Link to post Share on other sites
