profa_chb 18 Posted October 27, 2017 Hehe, satisfakcija Malo sam bio lutao po yt-u pa sam se dodatno okuražio. Još mi je ćale pustio buvu o nekakvom flet kablu od starog štampača No, hvala na savetima! Razmisliću još, ionako sad imam preča posla oko auta Quote Share this post Link to post Share on other sites
DraganUS 449 Posted December 26, 2017 Narode za cega sluzi spulna. Nikad me nije zanimalo pa pitam. Hocu da stavim duboki omp volan jer mi ovaj bode oci. Jel moze da se skine spulna i volan i montira glava od omp volana. Znam da gubim airbag funkciju ali da li ima jos sta? Quote Share this post Link to post Share on other sites
ChobbyNS 303 Posted December 26, 2017 Koliko ja znam ne bi trebalo da imas problema. U spulni se nalazi instalacija za mf komande, airbag, sirena i ne znam da li jos nesto ide. Senzor polozaja volana valjda ide na ablender, bar je tako na alfi ako se dobro secam. In vehicle steering systems a clock spring orclockspring is a spiral-wound special rotary electrical connector which allows a vehicle's steering wheel to turn while still making an electrical connection between the steering wheel airbag and/or the vehicle's horn and other devices and the vehicle's electrical systems. Quote Share this post Link to post Share on other sites
Kuvalja 406 Posted December 26, 2017 Spulna je kuciste u koje je namotan flet kabal koji se koristi za airbag, sirenu, komande na volanu i menjanje brzina ko ima automataki menjac i samaraljke na volanu.... senzor polozaja volana stoji na ablenderu kao sto vec rece Chobby.Sent from my HTC One M9 using Tapatalk 1 ChobbyNS reacted to this Quote Share this post Link to post Share on other sites
Ivan 17593 Posted December 26, 2017 Iliti omogucava ozicenje i rad kompletne elektrike/elektronike koja postoji na konkretnom volanu i omogucava rotaciju komandi zajedno sa volanom . 1 ChobbyNS reacted to this Quote Share this post Link to post Share on other sites
DraganUS 449 Posted December 26, 2017 Znaci moze dole. Hvala na potvrdi drustvo. Sutra update za stila. Sent from my SM-J710F using Tapatalk Quote Share this post Link to post Share on other sites
Stefan95 1 Posted January 13, 2018 Da li neko zna u koje pinove dzeka koji ide u mf spulnu treba da ubodem zice za can a i b i + ??? Quote Share this post Link to post Share on other sites
Ivan 17593 Posted January 15, 2018 Prelistaj temu, sve je sazvakano jos pre par godina : Quote Share this post Link to post Share on other sites
Stefan95 1 Posted February 15, 2018 Namestio sam mf volan i spulnu ,kupio drugi dzek spulne i prebacio pinove i sve povezao ,kada sam sve vratio izbacilo mi gresku airbeg-a .Da li je moguce da sam sprzio spulnu ,komande na volanu rade??? Quote Share this post Link to post Share on other sites
Ivan 17593 Posted February 15, 2018 Mozda su neke linije nove MF spulne u prekidu (ako je sa starom sve radilo normalno). Quote Share this post Link to post Share on other sites
Stefan95 1 Posted February 16, 2018 Sa starom spulnom je sve radilo ,nikada do sada nisam imao problema sa greskama oko airbeg-a.Moze li spulna da se popravi ili moram da kupim drugu? Quote Share this post Link to post Share on other sites
Kuvalja 406 Posted February 16, 2018 A da nisi zamenio mesta zicama u novom dzeku? A da nisi davao kontakt u nekom trenutku dok je nesto bilo razdzekano, nakacis na dijagnostiku pa vidi sta je i obrisi gresku......Sent from my HTC One M9 using Tapatalk Quote Share this post Link to post Share on other sites
Stefan95 1 Posted February 17, 2018 Pukli su mi pinovi na spulni 2 kom bas od airbeg-a ,izgleda da moram drugu spulnu da kupim. Quote Share this post Link to post Share on other sites
milanns128 1 Posted March 22, 2018 Poz svima danas stigao volan i spulna,bice ugradjeno po vasim semama.Sad me zanima jel ima neko iz NS od kolega da mi ugasi ono blinkanje km.A ako nema nikog od kolega onda da mi preporucite kod koga da odem da mi to resi. Quote Share this post Link to post Share on other sites
Ivan 17593 Posted March 22, 2018 Ako se ne javi niko od kolega, svaki krsten servis moze da ti odradi Proxy Alignment. Nikakva nauka da bi ti trebala preporuka, nakaci se dijagnostika i par klikova misem. Quote Share this post Link to post Share on other sites
Kuvalja 406 Posted March 22, 2018 Ili ako ides za BG ti se javi pa ce ti neko ovde odraditi...Prodjes kroz Batajnicu i zavrsicemo to.Sent from my HTC One M9 using Tapatalk Quote Share this post Link to post Share on other sites
milanns128 1 Posted March 25, 2018 Hvala puno Kuvalja ako ne resim ovde kod mene zovem te da se upoznamo i da mi resis ovo. Quote Share this post Link to post Share on other sites
Lazar357 5 Posted May 4, 2018 Da li mi moze neko pomoci? Dakle uspem da skinem airbag sa volana. Ali mi dalje nije jasno kako skinuti volan ? A zatim i spulnu koji alat i to. Nigde nisam nasao o tome. Hvala unapred na odgovoru Quote Share this post Link to post Share on other sites
Kuvalja 406 Posted May 4, 2018 Kad skines airbag imas u centru maticu 24 koji odvrnes i onda polako svlacis volan...Kad skines volan prisao si spulni...Sent from my HTC One M9 using Tapatalk Quote Share this post Link to post Share on other sites
Lazar357 5 Posted May 5, 2018 Ok . Danas bih trebao da montiram mf volan. Imam obican tako da cu morati i spulnu da menjam. Koliko sam razumeo ona se odsrafljuje ili kako? Tj ona ima lozu ? Kada ugradim . Postavljam slike . Quote Share this post Link to post Share on other sites
Kuvalja 406 Posted May 5, 2018 Da li te je mrzelo da procitas temu od pocetka?Ima sve lepo objasnjeno i slikano.Spulna se drzi sa tri srafa.Sent from my HTC One M9 using Tapatalk Quote Share this post Link to post Share on other sites
Lazar357 5 Posted May 5, 2018 Bas naprotiv procitao odprvog posta do zadnjeg. Ili sam preskocio ili nism video. Hvala . Quote Share this post Link to post Share on other sites
Kuvalja 406 Posted May 5, 2018 Onda verovatno nisi obratio paznju, na Ivanovim slikama u prvom postu je spulna na kojoj se vide usice kroz koje prolaze srafovi, ako se dobro secam u pitanju su krstaci. Sent from my HTC One M9 using Tapatalk Quote Share this post Link to post Share on other sites
Lazar357 5 Posted May 5, 2018 Na to nisam obratio paznju. Sve u svemu . Danas namestio. I ako sam procitao da je obrnut redosled can magistrli ipak sam pratio Ivanovu sliku pa sam posle prevezao kako treba. Nista tesko nije. Samo da se prati kako i sta da se radi. Evo slike starog i novog. Quote Share this post Link to post Share on other sites
Kuvalja 406 Posted May 5, 2018 Super.Sent from my HTC One M9 using Tapatalk Quote Share this post Link to post Share on other sites
