viper 108 Posted December 12, 2018 Ipak moze da se okrpi trajno. 1 neshaoct reacted to this Quote Share this post Link to post Share on other sites
hgt 6 Posted December 12, 2018 Sa kog auta ti ova pumpa ? Quote Share this post Link to post Share on other sites
viper 108 Posted December 12, 2018 Alfa 156 2.0jts 1 kreator reacted to this Quote Share this post Link to post Share on other sites
bokija 83 Posted December 13, 2018 Pa osim slika...uputi ljude cime si krpio? Quote Share this post Link to post Share on other sites
viper 108 Posted December 13, 2018 Sve te pumpe pucaju tu kod regulatora pritiska, pucuce i nova kad tad, greška konstrukcije. Krpio sam sa super lepak i soda bikarbona. Quote Share this post Link to post Share on other sites
Miki.Zvrk 22 Posted December 14, 2018 (edited) Ina da se kupi nova u Sabcu. Oko 50€ cini mi se Edited December 14, 2018 by Miki.Zvrk Quote Share this post Link to post Share on other sites
kreator 288 Posted December 14, 2018 Zar nije bolje da su probao toplim lepkom tj plastikom? Quote Share this post Link to post Share on other sites
hgt 6 Posted December 14, 2018 4 hours ago, Miki.Zvrk said: Ina da se kupi nova u Sabcu. Oko 50€ cini mi se U sapcu sam je i kupio 60 e nova , pumpa dolazi bez regulatora pritiska goriva tako je meni stigla pa sam stavio regulator od staru pumpu , koji izgleda nije ispravan , na pumpu nista ne pise kao da ih prave u neki podrum , puko sam 60 e i opet imam problem prvo paljenje ujutru , vergla do 10 sekunde dok upali . Quote Share this post Link to post Share on other sites
viper 108 Posted December 14, 2018 47 minutes ago, kreator said: Zar nije bolje da su probao toplim lepkom tj plastikom? Ti probaj pa nam javi rezultat. Quote Share this post Link to post Share on other sites
kreator 288 Posted December 14, 2018 Nemam potrebe da probam pošto je kod mene to ok..Inače stvar koju sam krpio sa toplom plastikom je posuda za pranje šoferke.. Verovatno je ostala voda kod predhodnog vlasnika pa je napukla pri dnu..Iako je plastika dosta glatka uspeo sam da zakrpim iz par pokušaja.. Koristio sam lemilicu i onu plastčnu šipku i uspeo..Drži tečnost i ne curi.. Quote Share this post Link to post Share on other sites
viper 108 Posted December 14, 2018 E sad probaj super lepak i soda bikarbona, nadam se da znaš postupak. Quote Share this post Link to post Share on other sites
Miki.Zvrk 22 Posted December 14, 2018 Topla plastika ima manu bas zato sto je topla, leti otpusti i nema nikakva svojstva. A sodu bikarbonu i lepak sam koristio u slijevima. Lepak pa preko sodu bikarbonu i tako par puta. Hvala bogu pa evo sarka na lap topu drzi vec 2 godine Quote Share this post Link to post Share on other sites
viper 108 Posted December 14, 2018 Tako je, onda znaš koliko brzo steže ova mešavina, bukvalno trenutno. Quote Share this post Link to post Share on other sites
Djuk85 2984 Posted December 14, 2018 Nisam znao za foru do sad...a bas moze biti korisna Quote Share this post Link to post Share on other sites
hgt 6 Posted December 15, 2018 Jel zna neko da da ima posebno da se kupi regulstor pritiska goriva koji se nalazi na kuciste pumpe u pitanju je fiat bravo 1.6 16v 2001 god ? Quote Share this post Link to post Share on other sites
tox 42 Posted December 15, 2018 Mislim da nema za 1.6 posto je regulator integrisan u kucistu pumpe,na 1.8 ima regulator pritiska na grani gde su dizne i moze sam da se zameni. Na otpadu da. Quote Share this post Link to post Share on other sites
bokija 83 Posted December 16, 2018 Zato sam pumpu sa integrisanim regulatorom platio 18000 novu.... Quote Share this post Link to post Share on other sites
Komatina17 2 Posted August 3, 2019 (edited) imam fiat bravo 1.4 12v i ne radi mi pumpa za gorivo.kada sam je izvadio iz rezervara i spojio direktno na akumulator pumpa radi,ali kada je spojim ne radi,ne znam u cemu je problem,pokusavao sam i sa kontaktom i kada verglam nista se ne desava, a ispravna je Edited August 6, 2019 by neshaoct spojeno 1 neshtry reacted to this Quote Share this post Link to post Share on other sites
kreator 288 Posted August 3, 2019 Kad daš kontakt treba na kratko da odradi pumpa i da stane.Nekolko sekundi.Proveri napon na kablu koji daje napajanje na pumpu.Ako nema pogledaj relej i osigurač pumpe goriva. 1 neshaoct reacted to this Quote Share this post Link to post Share on other sites
Komatina17 2 Posted August 4, 2019 Bilo je do releja, hvala ti Quote Share this post Link to post Share on other sites
NemanjaLip 6 Posted October 10, 2020 Ljudi imam problem sa Fiat Bravo 1.6 2001 benzin-plin Benzin mi je bio na mrtvoj rezervi, pokusao sam da upalim auto, nije hteo uopste, otisao sam na pumpu sipao u kantu 10l benzina i upalio je, posle toga(sutra dan) nije hteo na benzin nikako i nece do danasnjeg dana, na plin pali u fulu bez muke(kad je topije vreme), skidao sam dovodno crevo iz pumpe i ne baca uopste benzin na njega. Da li moze da mi objasni neko gde se nalazi pumpa i kako moze da joj se pridje(ako treba nekom moj br telefona neka se javi u poruci na forumu) Quote Share this post Link to post Share on other sites
Goran Zemun 441 Posted October 10, 2020 5 minutes ago, NemanjaLip said: Ljudi imam problem sa Fiat Bravo 1.6 2001 benzin-plin Benzin mi je bio na mrtvoj rezervi, pokusao sam da upalim auto, nije hteo uopste, otisao sam na pumpu sipao u kantu 10l benzina i upalio je, posle toga(sutra dan) nije hteo na benzin nikako i nece do danasnjeg dana, na plin pali u fulu bez muke(kad je topije vreme), skidao sam dovodno crevo iz pumpe i ne baca uopste benzin na njega. Da li moze da mi objasni neko gde se nalazi pumpa i kako moze da joj se pridje(ako treba nekom moj br telefona neka se javi u poruci na forumu) Nemanja... Javi se.. I ja sam u Lipovici.. Quote Share this post Link to post Share on other sites
kreator 288 Posted October 30, 2020 Zna li neko kolki je prečnik creva kod pumpe goriva za Bravo 1,6 16 v.Ugradio bi jednosmerni ventil pošto mi izgleda vrati gorivo nazad ako ga ne palim duze vreme. Inače kada ga upalim kasnije ceo dan pali bez problema. Quote Share this post Link to post Share on other sites
lomisa 9 Posted November 29, 2020 Fiat brava 1.2 16v. Nakon 7 dana bez akumulatora, kupio nov, spojio i auto vergla, ali ne pali! Gasi code key lampicu i vergla, ali se ne čuje pumpa goriva da zuji kada se daje kontakt. Pretpostavljam da je nešto do dužeg stajanja bez akumulatora, ili je crkla pumpa. Ima li neko ideju? Gde se na ovom modelu nalazi relej pumpe? Da li može da crkne ecu, ako stoji bez akumulatora... Jedino mi ostaje da proverim unimerom da li dolazi struja do pumpe. Da li je neko imao sličan problem? Quote Share this post Link to post Share on other sites
lomisa 9 Posted December 6, 2020 On 11/29/2020 at 5:04 PM, lomisa said: Fiat brava 1.2 16v. Nakon 7 dana bez akumulatora, kupio nov, spojio i auto vergla, ali ne pali! Gasi code key lampicu i vergla, ali se ne čuje pumpa goriva da zuji kada se daje kontakt. Pretpostavljam da je nešto do dužeg stajanja bez akumulatora, ili je crkla pumpa. Ima li neko ideju? Gde se na ovom modelu nalazi relej pumpe? Da li može da crkne ecu, ako stoji bez akumulatora... Jedino mi ostaje da proverim unimerom da li dolazi struja do pumpe. Da li je neko imao sličan problem? Rešio sam problem. Izmerio naporne na relej i do pumpe, video da ima struje. Bilo je do pumpe, zaglavila se od stajanja i lošeg goriva. Razglavio sam je sa wd40 i okretanjem u oba smera, promenom polariteta struje na akumulator, uz blago kucanje gumenim čekićem... Ispalo neko đubre iz nje... Inače, sad lepo i ravnomerno okreće. Polovna je mačka u džaku. Može da se zameni samo uložak pumpe, koji košta oko 1500 din.,ali su problem plastična creva, koja treba skinuti, i koja treba najčešće iseći. To su specijalna creva za potapajuce pumpe, plastična, koja su sa obe strane otporna na razaranje od benzina, i teško se savijaju. Ima ih da se kupe u pojedinim radnjama i na internetu... Tako da se pumpa može reparirati. Inače filter goriva je na samoj pumpi i zavaren u crnu plastiku i mislim da se ne može zameniti,možda se može malo isprati i produvati kompresorom kroz kućište. 1 Mijailović P. reacted to this Quote Share this post Link to post Share on other sites
