Dusan 4 Posted December 28, 2010 Da li neko radi, ili je radio cipovanje ovog motora, i kakve se performanse dobijaju? Isplatili se dati pare, ili je cisto pucanje u prazno? Quote Share this post Link to post Share on other sites
bokija 83 Posted December 28, 2010 Kod brave se promeni ceo chip.Iscupas i zabodes drugi.Imaju fabricki na 116 i 124 KS.Probaj da nadjes. Quote Share this post Link to post Share on other sites
Dusan 4 Posted December 28, 2010 Ovaj sa 124 Ks mi se svidja. Gde bi to moglo da se nadje, ima li kod nas, ili mora da se porucuje od preko? Quote Share this post Link to post Share on other sites
neshaoct 9584 Posted December 28, 2010 Treba biti ipak malo skeptičan prema tim ciframa jer...atmo. motor je u pitanju... Quote Share this post Link to post Share on other sites
kole 2 Posted December 28, 2010 (edited) http://www.revochip.com/print.php?id=730a raspitaj se i u SM Edited December 28, 2010 by kole Quote Share this post Link to post Share on other sites
bokija 83 Posted December 28, 2010 (edited) Boki je bio ponosni vlasnik original fabrickog chipa 124KS,al on izdade benzice i ode u poljoprivrednike...Ne bi me cudilo da mucenik koji je kupio auto od njega ne zna kakav draguljcic ima pod haubom. Edited December 28, 2010 by bokija Quote Share this post Link to post Share on other sites
svetozar 0 Posted December 28, 2010 na linku gore kazu da se potrosnja smanjuje 15 posto u zavisnosti od stanja motora i nacina voznje.moze li neko da mi objasni kako je moguce povecanjem snage umanjiti potrosnju? Quote Share this post Link to post Share on other sites
bokija 83 Posted December 28, 2010 Sve dok vozis pristojno,postizes veci ucinak sa manjim otvaranjem throtla.A kad oslobodis zmajove i stisnes cipelu o pod onda suce i 50% vise. Quote Share this post Link to post Share on other sites
kole 2 Posted December 28, 2010 Kakav je to fabrički čip na 124? Da je fabrički postojala bi verzija za 124KS u prodaji, a to nikad nije bilo. Quote Share this post Link to post Share on other sites
bokija 83 Posted December 28, 2010 (edited) Original,ja ga drzo u ruci dok ga nismo stavili Bokiju. Boc,i gotovo.Mozda ona slabija verzija jos moze da se nabavi,nisam siguran. Edited December 28, 2010 by bokija Quote Share this post Link to post Share on other sites
kole 2 Posted December 29, 2010 Za atmo motore čipom 10-12% puna šaka brade. Quote Share this post Link to post Share on other sites
TurboToys 0 Posted December 29, 2010 na linku gore kazu da se potrosnja smanjuje 15 posto u zavisnosti od stanja motora i nacina voznje.moze li neko da mi objasni kako je moguce povecanjem snage umanjiti potrosnju? Za atmo benzince je skoro nemoguce smanjiti potrosnju,najpre se poveca posle chip tuninga jer atmo motori zahtevaju obrtaje,i u visokim obrtajima idu najbolje..Original,ja ga drzo u ruci dok ga nismo stavili Bokiju. Boc,i gotovo.Mozda ona slabija verzija jos moze da se nabavi,nisam siguran.Malo su mi sumnjivi ti podatci,jer bravo 1.6 16v od 103ks sa drugom usisnom,izduvnom granom nekim sportskim filterom i boljim auspuhom,posle remapa max moze da se izvuce 120ks..Ne verujem da se samo drugom mapom na fabricki motor toliko snage moze dobiti... Quote Share this post Link to post Share on other sites
goransid 0 Posted May 23, 2011 Hteo sam i ja na mom Bravisi raditi cipovanje jer sam ga skoro kupio pa me intersuje sta dobijam a sta gubim,da lije stetno za motor itd.i naravno koliko kosta ta investicija recimo u ovlascenim servisima.Motor je 1.6 16v 2001 god.Molim za vase misljenje i savet.Hvala.http://postimage.org/image/10o829678/ Quote Share this post Link to post Share on other sites
Mitaicf 1 Posted August 24, 2017 (edited) Caoooo ljudiii.... dosao sam u posed fiat bravo 1.2(80ks) 2002, pored tipa kojeg vec imam... zanima me da li moze da se cipuje bravo, kolko postoji mogucnost da steti motoru?? Hvalaa na pomoci... Edited August 24, 2017 by neshaoct spojeno Quote Share this post Link to post Share on other sites
Milutinac 5905 Posted August 24, 2017 Ajmo ljudi...ko ce prvi?! Quote Share this post Link to post Share on other sites
dekirs 4818 Posted August 24, 2017 Nemas turbo, nemas zamajac - cipuj. A ne, cek.. :/ 1 Milutinac reacted to this Quote Share this post Link to post Share on other sites
neshaoct 9584 Posted August 24, 2017 @Mitaicf Nema od čipovanja na tom autu ništa. Nemoj uzalud da trošiš pare. ''Dobitak'' ne bi mogao da primetiš u vožnji. Čipuju se pre svega turbo motori i veeeeeeeliki atmo-benzinci (1.2 16v nije ništa od ta dva). 1 Branislav reacted to this Quote Share this post Link to post Share on other sites
Branislav 706 Posted August 24, 2017 Ubacis turbo na taj motor, razvalis trapove, ne mozes da ukocis i to je to Stvar je resena Quote Share this post Link to post Share on other sites
fiat ivan 0 Posted August 25, 2017 On 8/24/2017 at 3:40 PM, Mitaicf said: Caoooo ljudiii.... dosao sam u posed fiat bravo 1.2(80ks) 2002, pored tipa kojeg vec imam... zanima me da li moze da se cipuje bravo, kolko postoji mogucnost da steti motoru?? Hvalaa na pomoci... Svaki motor se može čipati,samo je pitanje isplativosti. Na tom motoru samo čipanjem bez mehaničkih dorada usisa i ispuha možeš dobiti jako malo. Ja sam mjenjao čip ECU-a na 1.2 8 ventilcu i pomak je bio 2ks 81>83 ks. Quote Share this post Link to post Share on other sites
Mitaicf 1 Posted August 25, 2017 Ljudiiii hvalaaa puno ustedeli ste mi pare.... pozdrav :-) 1 neshaoct reacted to this Quote Share this post Link to post Share on other sites
Branislav 706 Posted August 26, 2017 20 hours ago, Mitaicf said: Ljudiiii hvalaaa puno ustedeli ste mi pare.... pozdrav :-) Nema nista gore nego kad se neke nade i entuzijasti ugase recenicom "To mnogo kosta" Pa sta ima lepse kad sa 1.2 turbo motorom odvalis nekog izvikanog dizela... Quote Share this post Link to post Share on other sites
MS PK 7718 Posted August 26, 2017 Ne bi imalo nista lepse, kad bi to moglo 1 1 neshaoct and Branislav reacted to this Quote Share this post Link to post Share on other sites
cuore_sportivo 79 Posted September 27, 2017 Moze...ali da li se isplati...neeee Quote Share this post Link to post Share on other sites
Trofeo 115 Posted December 14, 2017 (edited) Mozda nekom zatreba 1.6 16v http://www.smchiptuning.com/122/fiat-brava-bravo-1.6-16v-103?lang=en 1.2 16v http://www.smchiptuning.com/121/fiat-brava-bravo-1.2-82 Edited December 14, 2017 by Trofeo Quote Share this post Link to post Share on other sites
