Djole_M 150 Posted March 18, 2017 Felne su čista perverzija Quote Share this post Link to post Share on other sites
Stex3105 107 Posted March 18, 2017 Trebalo bi da dodjem ali jos nista nije sigurno Quote Share this post Link to post Share on other sites
Branislav 722 Posted March 19, 2017 @Stex3105 Koju farbu si koristio za kocione viljuske? Quote Share this post Link to post Share on other sites
Stex3105 107 Posted March 19, 2017 za kociona klesta sam koristio obicnu farbu i drzi lepo Sad kad se stave 17 morace jos malo da se spusti jer je razlika za nekih 1cm u odnosu na 16 Quote Share this post Link to post Share on other sites
DiscoVolante 294 Posted March 19, 2017 (edited) Uh, kako su mu sjele felge! Auto odlično izgleda izuzev jednog detalja, zatvorene maske i Bad Look-a, mislim da bi bio puno ljepši bez toga. Edited March 19, 2017 by DiscoVolante Quote Share this post Link to post Share on other sites
Stex3105 107 Posted March 19, 2017 Tek cemo da vidimo kako ce da legnu kada stavim i prednje za sad nemam jos dve gume A sto se tice haube u planu je da se stavi standardna hauba sa maskom od maree ili da se ova preradi malo ali to cu tek videti naprolece Quote Share this post Link to post Share on other sites
Branislav 722 Posted March 19, 2017 Ja mislio ti koristio Motipov tuning sprej Meni je bad look skroz ok ali ono ukusi su razliciti Quote Share this post Link to post Share on other sites
Stex3105 107 Posted March 22, 2017 Suncanjeee Quote Share this post Link to post Share on other sites
Stex3105 107 Posted April 16, 2017 (edited) @bane17 Edited April 16, 2017 by Stex3105 Quote Share this post Link to post Share on other sites
DinoG 7 Posted April 17, 2017 Ne znam kako mi je promakao ovaj projekt Sad mi Bane poslao sliku vasa 2 auta i nisam mogao vjerovati kako dobro izgleda, svaka cast i samo naprijed Poslano sa mog SM-G930F koristeći Tapatalk Quote Share this post Link to post Share on other sites
Stex3105 107 Posted April 17, 2017 Hvala brate Quote Share this post Link to post Share on other sites
Stex3105 107 Posted May 2, 2017 Audi A8 4.2 V8 300ks bobine na 1,2 16V sve radi kako treba auto je nekako elasticniji u voznji,jos moram da nabavim svecice sa toplotnom vrednoscu 6 mora da vidim koja oznaka ide od ngk sa ovim navojem. Sledeca je klapna na redu da se poveca sa 40mm na 48 mm ako bude moglo.... Quote Share this post Link to post Share on other sites
YUgisa 2528 Posted May 2, 2017 (edited) U lepo Al sto crni NGK Bosch sa 4 kraka su puno bolje svecice Jel imas ostale cetiri bobine? hahahahaha Edited May 2, 2017 by YUgisa Quote Share this post Link to post Share on other sites
Stex3105 107 Posted May 2, 2017 Ne znam nekako mi deluje "plavi" ngk nekako najbolji Uglavnom videcu sta naletim Quote Share this post Link to post Share on other sites
YUgisa 2528 Posted May 2, 2017 To trazi Toplotna vrednost tamo negde 5-6 Quote Share this post Link to post Share on other sites
Stex3105 107 Posted May 2, 2017 Ja gadjam oko 6 toplotnu vrednost Sad trenutno vozim standardne Ngk Dcpr7en. To kad budem zavrsio klapnu Prepravljam fabricku na 48mm ne moze vise da se izvuce sad sam se upravo vratio od strugara. Quote Share this post Link to post Share on other sites
YUgisa 2528 Posted May 2, 2017 I sto bi stavljao toplije? Samo nek precizno napravi klapnu da dobro zatvara Quote Share this post Link to post Share on other sites
Stex3105 107 Posted May 3, 2017 Koliko sam gledao na motorima gde su ove bobine ide 6 toplotna vrednost. Pa sam isao tom nekom logikom da stavim i kod mene....Iskreno ne znam koliko ima razlike izmedju 6 i 7 osim sto je jedan broj manje ili vise Klapnu ja sutra turpijam izvuko je jedva nekako 48mm to je najvise sto moze da se izvuce iz standardnog tela isao sam malopre da uzmem. Quote Share this post Link to post Share on other sites
YUgisa 2528 Posted May 3, 2017 Toplotna vrednost ide prema motoru, nije povezano sa bobinama i sto je toplija to je veca sansa da detonira pri velikom opterecenju. Fabrika obicno ugradi najtoplije koje moze jer sa tim postize najbolje samociscenje svecica odnosno ciscenje nakon sto se zagaravi dok radi u rezimu hladnog motora jer je onda dodatno obogacena smesa. Sad koliko topla moze da bude zavisi od puno faktora, koliko je komora za sagorevanje sama po sebi otporna na detonacije, koliko ima paljenja, kakvo je izduvavanje itd... Hladnije svecice se vise zagarave tj treba im veca temperatura da se ociste nakon sto se zagarave ali izdrzavaju vecu temperaturu pre nego sto dodje do pregrevanja sto moze da izazove detonacije ili topljenje elektrode. Tu u pricu dolaze onda svecice sa 4 kraka, koje delimicno ponistavaju problem garavljenja svecica jer varnica se baci na najoptimalnijem kraku i ta eksplozija cisti delimicno ostala tri kraka Quote Share this post Link to post Share on other sites
Stex3105 107 Posted May 3, 2017 (edited) E odlicno objasnjeno svaka cast Sad gledam na ovim sedmicama boja smese je po nekoj mojoj proceni idealna. Neka kafena boja ne znam nija ja da je opisem bas Ovakva je boja nije moja slika al je odprilike to to Edited May 3, 2017 by Stex3105 Quote Share this post Link to post Share on other sites
YUgisa 2528 Posted May 3, 2017 Pa ova je mozda malo previse braonkasta, ali tu je negde, treba da bude onako ko nes kafa Mada ne moze se bas po boji podesavati, jer je dosta veliki raspon, pogotovo ove sa 4 kraka. Obrati paznju na boju kad ugradis veci leptir Quote Share this post Link to post Share on other sites
Stex3105 107 Posted May 3, 2017 Danas sam se ceo dan zajebavao sa leptirom i nesto tu ne stima Cim upalim auto obrtaji skoce ko ludi i onda upadne u neki safe mode gde ne reaguje na klapnu gasa. Nisam imao vise zivaca da se zajebavam sa time moram sutra detaljno da vidim sta je i kako je. Kao da negde povuce previse fals vazduha gledao sam na sve strane i nisam nista nasao Quote Share this post Link to post Share on other sites
YUgisa 2528 Posted May 3, 2017 Jel dobro zatvara? Quote Share this post Link to post Share on other sites
Stex3105 107 Posted May 3, 2017 Pravio sam isto da zatvara kao i fabricki sto je. I fabricki nije skroz zatvorena klapna ne dihtuje 100%...Sutra mora da napravim da dihtuje to 100% pa cu videti sta kaze.... Quote Share this post Link to post Share on other sites
