G.P. 3 Posted January 20, 2017 ja inace volim te "divlje" boje, tako da kazem samo naprijed Quote Share this post Link to post Share on other sites
YUgisa 2528 Posted January 20, 2017 Ja nemam nista protiv divljih boja, ako ostatak auta prati taj detalj (tipa neka unikatna boja), ali kad je to jedini detalj koji strci samo tako onda mi izgleda ko da se vlasnik prvo naduvao farbe pa onda ofarbao Ali ne tvrdim da sam u pravu, cisto subjektivno misljenje Quote Share this post Link to post Share on other sites
Stex3105 107 Posted January 20, 2017 Ako se odlucim za neku perverznu ljubicastu onda idu i klipnjace u tu istu boju i navlake brembo u sivu sa ljubicastim natpisom. Ili ce ici dvoklipna bendix klesta od s klase..... Quote Share this post Link to post Share on other sites
G.P. 3 Posted January 20, 2017 cuj druze, ne treba radit ciruks od auta slazem se, ali samo recem da su meni fora pervezne ili kricave boje jel. a sad kako ce tko radit i sredivat si auto to ovisi o toj osobi, jer svatko radi sebi i za sebe Quote Share this post Link to post Share on other sites
Stex3105 107 Posted January 20, 2017 Ukusi su razliciti Quote Share this post Link to post Share on other sites
YUgisa 2528 Posted February 15, 2017 Sad si mi simpa, kad zavrsis one druge felne, onda si mi buuuuuuuuu Quote Share this post Link to post Share on other sites
Stex3105 107 Posted February 15, 2017 Videcemo uzeo sam totalno drugaciju boju nego sto sam pricao videcu kad ofarbam kako ce da ispadne Quote Share this post Link to post Share on other sites
YUgisa 2528 Posted February 15, 2017 Nema veze, bice poliran rub i to nis ne valja Quote Share this post Link to post Share on other sites
Stex3105 107 Posted February 16, 2017 Mozda i ne bude Quote Share this post Link to post Share on other sites
YUgisa 2528 Posted February 16, 2017 Uuuuuuuuuuuuuu Quote Share this post Link to post Share on other sites
YUgisa 2528 Posted February 19, 2017 A ipak nista, druzicu se sa tobom kad izaberes nove rejsing posle ovih Quote Share this post Link to post Share on other sites
Stex3105 107 Posted February 19, 2017 ma bice felni samo da se naleti na nesto Sad sam trenutno u fazi da cackam nesto oko struje da budu 4 bobine od vagena 1.8 T i veca klapna gasa mislim od alfe neke da ce odgovarati. Quote Share this post Link to post Share on other sites
YUgisa 2528 Posted February 19, 2017 Prodaj ti to a za ovo si me zainteresovao Ako ima wasted spark paljenje onda nije tesko odraditi, mada nisam siguran bas da li su neke merljive benificije, a za klapnu gasa ne znam koliko prostora ima, ali moze i fabricka da se prepradi najverovatnije Ja sam moju povecavao sa 45 na 51mm Quote Share this post Link to post Share on other sites
Stex3105 107 Posted February 19, 2017 Jeste kod mene je wased spark Probao sam sa onim vagenovim starijim bobinama sa tri pina i funkcionisalo je da baca varnicu pri verglanju kako treba ali je problem jer su kratke pa ne mogu da stignu do svecice.Zato cekam novije sa 4 pina koje mogu da dohvate ali treba da se odradi jos neka zajebancija jer su nesto komplikovanije unutra to cu tek da izucim sta je i kako je jer sam uspeo vec jednu da spalim Sto se tice klapne to cu videti kad zavrsim bobine Kod mene mislim da je 40mm sad,ako bude oko struje sve funkcionisalo lako cu da napravim nosace za nju. a sad te dve stavke pa posle dalje Quote Share this post Link to post Share on other sites
Branislav 721 Posted March 12, 2017 (edited) Reci mi kako si ga namrstio tako? Koji su to farovi na njemu? Edited March 12, 2017 by Branislav Quote Share this post Link to post Share on other sites
Stex3105 107 Posted March 13, 2017 Farovi sa socivima od maree A odradjeno je spustanje haube kod limara Quote Share this post Link to post Share on other sites
nstyner 171 Posted March 16, 2017 Ala sijaaa...! Quote Share this post Link to post Share on other sites
Branislav 721 Posted March 17, 2017 On 3/13/2017 at 1:26 PM, Stex3105 said: Farovi sa socivima od maree A odradjeno je spustanje haube kod limara Reci mi gde si nabavio one silne stikere na gepek vratima? Quote Share this post Link to post Share on other sites
Stex3105 107 Posted March 17, 2017 Drugar imao u fijoci ja mu pokupio ne znam gde je nabavio Quote Share this post Link to post Share on other sites
Branislav 721 Posted March 17, 2017 1 hour ago, Stex3105 said: Drugar imao u fijoci ja mu pokupio ne znam gde je nabavio Kako ja nemam takvog druga? Ko ti je pravio taj bad look na haubi? Quote Share this post Link to post Share on other sites
Stex3105 107 Posted March 18, 2017 hahah pa ne znam A haubu sam ja pravio a drugar mi farbao uprincipu sve sto mogu ja sam uradim Quote Share this post Link to post Share on other sites
Branislav 721 Posted March 18, 2017 59 minutes ago, Stex3105 said: hahah pa ne znam A haubu sam ja pravio a drugar mi farbao uprincipu sve sto mogu ja sam uradim Jel dolazis na okupljanja? Da vidim kako izgleda uzivo Quote Share this post Link to post Share on other sites
