gorank82 173 Posted October 30, 2015 I ja imam zelju al nemam dovoljno konja Quote Share this post Link to post Share on other sites
rocker87 5 Posted October 30, 2015 Ja imam šanse ako će netko od vas dvojice da vozi u rikverc. Quote Share this post Link to post Share on other sites
gorank82 173 Posted October 30, 2015 Imas sansi jedino sa mnom Quote Share this post Link to post Share on other sites
jevta BG 111 Posted October 30, 2015 I onda dodje bojke i pobedi Quote Share this post Link to post Share on other sites
bojke 126 Posted October 30, 2015 Nisam vam ja za neka takmicenja.Vise volim da se provozam brzo nekim dobrim putem i po krivinama. E sad ako bas naleti neka Panamera,R8,BMW i slicno pa se poteramo to je vec druga stvar. Quote Share this post Link to post Share on other sites
DRAGANCE 21 Posted October 30, 2015 (edited) Moze naravno i ja imam zelju da se potrkam sa naslednikom... U tri dobijene... Spektakl u najavi a da probas kombinaciju naslednog motora i starog tela?? a moze i bojke da se ukljuci , cuo sam da je cetvorka super Edited October 30, 2015 by DRAGANCE Quote Share this post Link to post Share on other sites
Zhorz 102 Posted November 5, 2015 Bojke, od tih panamera, bmw itd ...nisi naleteo da se poteras sa presretacima? Quote Share this post Link to post Share on other sites
bojke 126 Posted November 5, 2015 Imao sam i tu situaciju ali sam imao srecu da na vreme shvatim o cemu se radi i na vreme odustanem. Inace bi bilo veselo. Quote Share this post Link to post Share on other sites
bojke 126 Posted November 8, 2015 Konacno zavrsena ugradja water methanol sistema. Radi. Quote Share this post Link to post Share on other sites
YUgisa 2513 Posted November 8, 2015 Ide na vodu Quote Share this post Link to post Share on other sites
jevta BG 111 Posted November 8, 2015 extra... jedno pitanje jel to moze da se mesa sa plinom ili mora benzin... Quote Share this post Link to post Share on other sites
bojke 126 Posted November 8, 2015 Ma mi u Srbiji mozemo da mesamo sta hoces. Quote Share this post Link to post Share on other sites
PuntoAbart 2 Posted November 9, 2015 Da li ovu brizgaljku ima jednu ili svaki cilindar ima svoju.Ako nije tajna koliko košta uređaj. Quote Share this post Link to post Share on other sites
bojke 126 Posted November 9, 2015 Samo je jedna brizgaljka za ceo sistem i montira se pre leptira na oko 20 cm udaljenosti.To je najbolje mesto za mesanje vazduha sa tecnoscu koja se ubrizgava. Quote Share this post Link to post Share on other sites
bojke 126 Posted November 15, 2015 Testiran sistem u voznji i radi bez problema.Smesa je sada prebogata i mora da se koriguje zbog toga sto je metanol dodatno pojacao smesu. Kao rezultat su sledece slike. Ovako izgleda linijski kajs posle "tretmana" od skoro 500 ks.Zadnji put kad se ovo desilo ostao sam bez 10 ventila.Inace linijski kajs se bukvalno pocepa od pritiska. Srecom ,naucen predhodnim iskustvom,ugradjena je modifikovana remenica radilice koja sprecava parcice linijskog kajsa da podlete pod zupcasti i naprave havariju. Verovatno ce se ,kad se nadje vremena,preci na elektricnu servo pumpu,i skinucu kompresor klime da malo olaksamo posao linijskom kajsu i smanjimo otpor. Quote Share this post Link to post Share on other sites
YUgisa 2513 Posted November 15, 2015 Ja bih to prepravio na zupcasti isto Quote Share this post Link to post Share on other sites
bojke 126 Posted November 15, 2015 Ili lanac? Quote Share this post Link to post Share on other sites
YUgisa 2513 Posted November 15, 2015 Hahahahaha ipak bolje na zupcasti da ne zveci Quote Share this post Link to post Share on other sites
bojke 126 Posted November 15, 2015 Mrzi me da se bakcem da pravim. Quote Share this post Link to post Share on other sites
rocker87 5 Posted November 28, 2015 Treba li šljiva za metanol? Quote Share this post Link to post Share on other sites
bojke 126 Posted November 28, 2015 Ma jok ,ima Zorka iz Sabca sve sto treba. Quote Share this post Link to post Share on other sites
bojke 126 Posted December 9, 2015 Stigla nova injekcija,mapa koja je updejt zbog ugradnje metanola. Ostaje da se proba. Nadam se jos nekom konjicu vise. Quote Share this post Link to post Share on other sites
FantomX 5 Posted December 9, 2015 U planu do leta da se spremi donji deo motora kompletno kovan i izbalansiran.U tom slucaju snaga motora od 500+ konja sa jos nekim preradama veoma lako ostvariva.Bice potrebna jos veca turbina itd.Do 500 ks ma da grebes ko macka, 350 je neki maximum sa ovom konfiguracijom koju si pomenuo. Za vise ti treba...Struja, Dizne 1000cc, menjac, brege, titanijumski ventili... Veruj mi, jos niko u Srbiji a i sire nema 500ks na 2.0 motoru a ulozili su boga oca znanja i para. Nemoj da shvatis ovo kao neku kritiku, nego kao savet da se ne razocaras kad budes shvatio da od 500ks nema nista. Inace ovo sto si odradio mi se svidja, to ja zovem silk tuning. Izobjasnjavas lozanama u limuzinama, sve je postojano i trajno, nije prenasvirano i lepo moze da se vozi.Sa srecom nek te sluzi i da ga lepo nasviras i da se navooozis ko pravi.POZ.Šta reče ovaj majstor? Quote Share this post Link to post Share on other sites
