Vule 789 Posted December 8, 2011 Fotke će tek da budu extra Quote Share this post Link to post Share on other sites
Milutinac 5905 Posted December 8, 2011 @nemanja - nisam ja! Ja sam na relaciji Liman - Cirpanova... @vule - sto pre, sto pre... Quote Share this post Link to post Share on other sites
hidro_mont 1 Posted December 8, 2011 Druže auto je extra, štopke odlično legle samo prednji kraj mora još dole ostalo Quote Share this post Link to post Share on other sites
David_WRRT 1 Posted December 8, 2011 Lep je ali zaista je taj znak suvisan Quote Share this post Link to post Share on other sites
Vule 789 Posted December 8, 2011 Napraviće Milutin ovakav gepek, samo još uvek nije svestan toga Quote Share this post Link to post Share on other sites
saleTIPO 3 Posted December 8, 2011 To je ono sto mi je falilo! Sada je Quote Share this post Link to post Share on other sites
Milutinac 5905 Posted December 9, 2011 (edited) @Vule - nece nece...Gepek ostaje kakav jeste, mozda samo znak leti dole...sto se folija tice, mozda samo krov uradim, ali svi takvi poduhvati se ostavljaju za prolece...sem auspuha naravno! Edited December 9, 2011 by milutin-NS Quote Share this post Link to post Share on other sites
kostaNBG 0 Posted December 11, 2011 (edited) Dobar je !! I ja mislim da bi morao da skines znak i ja bi neke distance stavio, mozda 10mm napred i pozadi Edited December 11, 2011 by Kosta_punto Quote Share this post Link to post Share on other sites
Milutinac 5905 Posted December 12, 2011 Nesto sam skeptican prema distancima, ali sto ga vise gledam to vise mislim da mu nazad treba 1 cm, i verovatno idu na prolece...Kod mene je godinu dana, malo i vise, i mislim da je za godinu dana dosta uradjeno...Ima nesto malo popravku - tj. dizne bi trebalo ocistiti, nosac motora zamenuti... od onih lepsih stvari - folija ide na krov, felne 16`` i cekam januar da krenem sa izduvom, ne ide od jednom odnosno samo zadnji lonac pa zvizdi kako zvizdi, vec pocinjem polako da bih dobio zvuk bas onako kako ja zelim Quote Share this post Link to post Share on other sites
Milutinac 5905 Posted March 23, 2012 Skinut onaj znak sa gepeka...sada tek vidim koliko je nepotreban bio...Evo par slicica, sledece neke ce biti vezane za auspuh...vise i to da resim Quote Share this post Link to post Share on other sites
Vule 789 Posted March 23, 2012 (edited) Ne znam da li je možda ovaj momak sa srebrnom Bravom na forumu, da vidimo šta je tu turpijano? Edited March 23, 2012 by Vule Quote Share this post Link to post Share on other sites
Milutinac 5905 Posted March 23, 2012 Sta je on tebi rekao, ja bi rekao da je to obican 1.8 i nista drugo, ostavili smo ga obojica propisno...?! Quote Share this post Link to post Share on other sites
Vule 789 Posted March 23, 2012 Nešto kao 1.6 budžen na 1.8 pa onda turpijano ne znam ni ja šta Najbolje od svega, kad smo se vratili, viče iz auta "ajmo još, ajmo još" Quote Share this post Link to post Share on other sites
Milutinac 5905 Posted March 23, 2012 (edited) Ma, tu je samo ubacen 1.8, nista drugo...Samo kad je vec ubacivao 1.8 trebao je traziti iz punta ili stila, to bi bilo vec nesto...ili petaka iz bravo HGT-a, uh... Edited March 23, 2012 by milutin-NS Quote Share this post Link to post Share on other sites
Vule 789 Posted March 23, 2012 Sve i da je ubacio stock petaka, ostao bi iza Quote Share this post Link to post Share on other sites
Milutinac 5905 Posted March 30, 2012 Stigao auspuh konacno...Odusevljen sam, kakva muzika...Kada se vozi polako, opusteno...tek tek pocinje da se cuje, ne smeta ni malo, ima zvuka ali jednostavno se ne primeti...kada se potopi gas pocinje rezanje, dubok zvuk, na to sam i ciljao. Spustio sam prozor danas, presao po gradu tako jedno 20 km prelep zvuk, brze menjanje brzine na jedno 5000-5500 - neopisivo...Katalizator ne moze dole inace bi leteo danas jer ima posle njega sonda koja bi pobrljavila sve i svasta, tako da verovatno ostaje ali nema veze... PS - nema vise onog suvisnog znaka nazad na bravici gepeka, mnogo lepse ovako izgleda, cistije... Quote Share this post Link to post Share on other sites
*mishko* 1 Posted March 30, 2012 Kulturiška, nema šta. Odlično sređen puntisha. Quote Share this post Link to post Share on other sites
Stephan 0 Posted March 31, 2012 Prelep punto Interesuje me kako taj HGT stoji sa potrosnjom i odrzavanjem? Znam samo da ide ko meceva... Quote Share this post Link to post Share on other sites
Milutinac 5905 Posted April 1, 2012 (edited) Hvala!Nema tu mnogo filozofije, trosi onako kako ga vozis, moze to poprilicno umereno da bude ako se vozi lagano, ali zato ako se malo opustis moze da popije koliko on hoce, ali zato onda nema vece zabave i lepseg osecaja Odrzavanje - servis mali i veliki standardno, mali me izadje oko 5 hiljada, a veliki kada sam ga uzeo bese nesto oko 20 ne secam se sada...oko ostalih delova sva sreca nisam do sada petljao, ali u proseku malo su skuplji nego kod "obicnog" punta...dosta delova deli sa alfama, stilom... Edited April 1, 2012 by milutin-NS Quote Share this post Link to post Share on other sites
Yugiša 0 Posted June 24, 2012 Odličan Fino leži,tako će i moj kad mi prodaš opruge Quote Share this post Link to post Share on other sites
Milutinac 5905 Posted June 25, 2012 Razume se...cim nabavim gewinde ima da dobijes ove, lepo cu ti ih upakovati, jos ces i masnu od gore da dobijes... :-) Quote Share this post Link to post Share on other sites
hidro_mont 1 Posted June 27, 2012 Misliš da ne bi smio skinuti katalizatore? Meni je začepljen ali ne znam da li ih smijem skinuti... Quote Share this post Link to post Share on other sites
Milutinac 5905 Posted June 27, 2012 Kako je meni rekao majstor koji mi je radio auspuh ima sonda posle katalizatora, sto ja nisam znao...Brljavila bi to je sigurno, prvo -check engine-, jer sonda koja treba da daje rezultate gasova sa katalizatorom odjednom dobija svakakve gasove bez onoga sto kat treba da odradi...Ne znam ni sam, cuo sam o nekom prevezivanju sonde, o njenom premestanju, ali mislim da sam odustao od toga... kod mene nema nikakvih cudnih mirisa, ne pali check engine, i skidanjem bih poremetio zvuk izduva kojim sam za sada jako zadovoljan... Quote Share this post Link to post Share on other sites
Branko 23 1 Posted June 27, 2012 Auspuh je ekstra,svaka cast Quote Share this post Link to post Share on other sites
