Lj_ubica 78 Posted March 21, 2015 Pre nesto nisam voleo ove Abarth felnice... Al sad sto ih na vise auta vidjam, vise mi se svidjaju Lepo mu cuce Quote Share this post Link to post Share on other sites
Bumblebee 18 Posted March 21, 2015 kad ističe ya menjanje zimskih guma. Hoćemo se vidjati sutra? Quote Share this post Link to post Share on other sites
Ivan BG 718 Posted March 21, 2015 Do 01.04. je obaveza da se vozi na zimskim gumama, naravno ako na putu ima snega i leda. Quote Share this post Link to post Share on other sites
Milutinac 5906 Posted March 21, 2015 (edited) Hvala drugari, konacno letnja - tako je @dezurni - zadovoljan! Nalepio samo preko cepa starog...nisam mogao da petljam, nije mi se dalo@ milosnis - slazem se. 16 je prava mera za punta 2 ali ovo su mi jedine 15-ice na koje pristajem. Da ih nisam mogao naci vec bi kotrljao neke 16-iceJaoooo kako lezi sa ovim gumama sada...kao djostik umesto volana da imam i zaboravio sam kakav je osecajI pranje. I za danas dosta Edited March 21, 2015 by milutin-NS Quote Share this post Link to post Share on other sites
Axic 19972 Posted March 21, 2015 Jel bese cekas diskove da bi stavio nove plocice ili si vec zamenio ? Quote Share this post Link to post Share on other sites
Dezurni 399 Posted March 21, 2015 Probaj da opereš kola u Partizanskoj Quote Share this post Link to post Share on other sites
Milutinac 5906 Posted March 21, 2015 Bio bi izvestaj vec kolega Axicu sa sve slikama da su stigli Sledece nedelje stizu diskovi sigurno, a onda montaza bukvalno sledeci dan. Bice slike @dezurni - bio, nisam odusevljen Quote Share this post Link to post Share on other sites
Dezurni 399 Posted March 21, 2015 Khm, khm. Ja sam na obuci u ponedeljak. Lokacija Munze. Misli o tome Quote Share this post Link to post Share on other sites
Milutinac 5906 Posted March 21, 2015 Vremenska odrednica? Quote Share this post Link to post Share on other sites
Milutinac 5906 Posted March 21, 2015 Auh...tesko... Quote Share this post Link to post Share on other sites
Milutinac 5906 Posted March 22, 2015 Malo mi bilo dosadno sinoc Quote Share this post Link to post Share on other sites
Markobgd 609 Posted March 22, 2015 (edited) Sviđa mi se što si promenio znakove na felnama jer sa onim crvenim ove felne su mi uvek izgledale kao cvetić neki (onako nekako gej ).Sad imaju potpuno drugačiju dimenziju i baš leže na autu! Edited March 22, 2015 by Markobgd Quote Share this post Link to post Share on other sites
VladaRS4 6 Posted March 22, 2015 Extra slicicee... koji aparat imas? Quote Share this post Link to post Share on other sites
Milutinac 5906 Posted March 22, 2015 @marko - mnogo mnogo bolje...bas sam zadovoljan kako sada izgleda@vlada - nikon d3000 + ovde je stativ naravno koristen Quote Share this post Link to post Share on other sites
Axic 19972 Posted March 23, 2015 Kakve li ti slike ispadnu kad ti je mnogo dosadno. Quote Share this post Link to post Share on other sites
Dante Bg 4 Posted March 23, 2015 Koje ulje sipas u Punta? Quote Share this post Link to post Share on other sites
Milutinac 5906 Posted March 23, 2015 Sunoco Synturo Gold 5w40...sutra bas stize...radim i mali servis i diskove odjedared@kolega Axicu - ovo je tek treci put da koristim stativ...i meni to ok izgleda ali znam da moze dosta bolje. Cim sam prebacio na komp vidim mogao sam ovo mogao sam ono...ovako - onako ali dobro ok Quote Share this post Link to post Share on other sites
Dante Bg 4 Posted March 23, 2015 Zasto bas to Jesi sipao jos nesto pa primetio razliku? Quote Share this post Link to post Share on other sites
gorank82 183 Posted March 23, 2015 Sigurno Seleniu 20 k ? Quote Share this post Link to post Share on other sites
Milutinac 5906 Posted March 24, 2015 Naravno sipao seleniu 20k cetiri puta i sad poslednji put presao na sunoco. А selenia...ono, solidno ulje, ali nista vise od toga... Sto se mojih utisaka sa sunocom tice, a to je potpuno miran rad motora, uravnotezen...a i odgovara mi variatoru...da kazem da sam sa 20k imao odredjeni problem sto ovde zbog kvaliteta ulja vise nije izrazeno...Recimo stalker na blogu kaze: Synturo Gold 5W40 Namenjeno je automobilima i lakim teretnim vozilima, bilo turbo bilo ne, a pogodno je za sve vrste goriva (benzin, TNG, dizel). Takođe je namenjeno za sve a naročito teške uslove vožnje. I naravno spada u potpuno sintetička ulja u modernom smislu te reči (HC i/ili SHC osnova). Specifikacije: API SL/SJ/CF, ACEA A3/B4, BMW LongLife 98, MB 229.3, Porche i VW 502.00/505.00. Tipične osobine (tipična analiza):Spec. gustina: 0,853; viskoznost na 40°C: 87mm2/s, na 100°C je 14,3 uz indeks viskoznosti od 171. Na –30°C viskoznost je standardna (manja od 6500mPa·s) a tačka tečenja takođe jer iznosi –39°C. Tačka paljenja (natprosečnih) 235°C, isparljivost po Noack-u vrlo dobrih 11%. HTHS viskoznost je 3,8 a TBN (odličnih) 10,2. Ovo je zaista dobro ulje. Na prvi pogled „zlatna sredina“ no par osobina je natprosečno a naročito bih pohvalio vrednost TBN. Quote Share this post Link to post Share on other sites
loodilo 0 Posted March 24, 2015 Ja u mog puntosakija sipam Motul. Prezadovoljan! Mada kontam da je i taj Sunoco odličan, ne bi ga sipali u BMW da nije Pozdrav Milutine Quote Share this post Link to post Share on other sites
Milutinac 5906 Posted March 24, 2015 Poz Sto se same firme sunoco tice...belgijska firma pod patronatom Petronasa, sunoco pravi recimo aditive za ulja za vecinu svetskih proizvodjaca ulja, a imaju naravno i svoje ulje, pumpe po USA, snabdevaju nascar itd itd itd. Quote Share this post Link to post Share on other sites
Rile_bg 347 Posted March 24, 2015 i koliko ti popije ulja od zamene do zamene? Quote Share this post Link to post Share on other sites
Milutinac 5906 Posted March 24, 2015 Tacno litru...ali zeznuo sam se pa prosli put nisam kupio cep kartera...vec je drug izvadio neku podlosku sto je on kao palio...i zato imam ovo doleKad sam kretao za Lefkadu u avgustu prosle godine ulje 2mm ispod max, vratim se...2600 km...2mm ispod max... Quote Share this post Link to post Share on other sites
