Martini 11 Posted November 10, 2012 Uz modul za centralnu si sigurno morao dobiti i uputstvo za povezivanje. Quote Share this post Link to post Share on other sites
Nidzo 2 Posted November 17, 2012 Drugari planiram da ugradim daljinsko zaključavanje u Puntića i vidim da ima dosta "renomiranih" marki na tržištu ali ovaj Bear mi je zapao za oko pa me zanima vaše mišljenje. Takođe na Limundu sam našao jedan univerzalni motorić za centralnu bravu te me zanima može li se iskoristiti za otvaranje gepeka na Puntu i da li je komplikovano za ugradnju i povezivanje?Hvala unapred. Quote Share this post Link to post Share on other sites
Slavko Krajčik 0 Posted November 23, 2012 (edited) Ja sam danas ugradio u Punto Classic 2 Bear daljinsko otkljucavanje (DK-LD-009-095 skakavac kljuc), 2300 din.Stavio crvenu led diode za indikaciju, spojio na migavce, cak sam ugradio motorcic u gepek da otkljucavam gepek daljinski.Sve lepo radi, ja sam zadovoljan.At the bottom of the fuse box is a 40pin connector. In this, you will find:White and green wire, this is your LOCK wire.Blue and purple wire, this is your UNLOCK wire.Also in the 40 pin connector at the bottom of the fuse box, are a pink wire, and a pink and white wire. These are for your indicators and can be connected to your RCL control box so that they flash when you lock/unlock the car. Edited November 23, 2012 by Slavko Krajčik Quote Share this post Link to post Share on other sites
Nidzo 2 Posted November 23, 2012 Ja sam danas ugradio u Punto Classic 2 Bear daljinsko otkljucavanje (DK-LD-009-095 skakavac kljuc), 2300 din.Stavio crvenu led diode za indikaciju, spojio na migavce, cak sam ugradio motorcic u gepek da otkljucavam gepek daljinski.Sve lepo radi, ja sam zadovoljan.At the bottom of the fuse box is a 40pin connector. In this, you will find:White and green wire, this is your LOCK wire.Blue and purple wire, this is your UNLOCK wire.Also in the 40 pin connector at the bottom of the fuse box, are a pink wire, and a pink and white wire. These are for your indicators and can be connected to your RCL control box so that they flash when you lock/unlock the car.Kuda si provlačio kabal za otključavanje gepeka i gdje si nakačio dodatni motorčić? Da nisi kojim slučajem uslikao tu akciju? Ja sam se zeznuo pa pazario onaj plavi Bear sa alarmom ali nisam htio alarm već samo daljinsko zaključavanje, a malo je komplikovano to izvesti pa se majstor napatio Ovde sam to detaljnije opisao u pohvali "Vitez-a" Sad planiram i gepek da uradim pošto sam u međuvremenu nabavio motorčić. Quote Share this post Link to post Share on other sites
Slavko Krajčik 0 Posted November 24, 2012 Taj tvoj alarm Bear ima opciju da se aktivira samo daljinsko otkljucavanje, procitaj uputstvo. A kabel (jedna licnasta zica) se provlaci ispod plasticnih pragova sa desne strane (tamo gde idu fabricki kablovi). Quote Share this post Link to post Share on other sites
SikterBre 31 Posted November 24, 2012 Kada je meni majstor vezivao, nije mogao da poveže na migavce, pa je vezao na pozicije, a to me jako nervira, jer su mi prvenstveno bile led pozicije u autu i crkle su mi, pa posle sam stavio druge, crkle su i one, e sada mi stoje obične žute, a to mi u paru sa ksenonima ružno izgleda, ali mi jedino tako traje već evo neko duže vreme... Da li je moguće da se to bilo kako preveže na migavce? Quote Share this post Link to post Share on other sites
ivan.ik 625 Posted November 24, 2012 Veže za žice posle automata za migavce. Quote Share this post Link to post Share on other sites
neshaoct 9584 Posted November 24, 2012 Deo odgovora (oko ugradnje alarma u Stila) je prebačen ovde:http://www.fiat-lancia.org.rs/forum/index.php?showtopic=42566entry854255 Quote Share this post Link to post Share on other sites
Slavko Krajčik 0 Posted November 25, 2012 (edited) Migavci se vezuju na kabel na levoj strani koji ide nazad na roze i roze-belu zicu. Alarm ima u sebi diode da ne bi pravilo probleme.Vezivanje signalizacije alarma na poziciju je potpuno bez veze. Edited November 25, 2012 by Slavko Krajčik Quote Share this post Link to post Share on other sites
SikterBre 31 Posted November 25, 2012 meni je taj lik to vezivao i najviše se zamlaćivao sa tim da veže na migavce i otišao tražio po netu nešto i kao navodno ne može na migavce, kao moraće na poziciju da ide i tako je i uradio.. Kasnije mi je neki lik rekao da mora da može i zvao nekog drugara koji mu je rekao da može da se preveže to na migavce... Quote Share this post Link to post Share on other sites
miske17 0 Posted November 25, 2012 I ja planiram da ugradim daljinsko. Imam vec daljinsko ali je povezano sa alarmom, neka sklopocija. Opet bih sve to odradio, stim sto bih ubacio i otvaranje gepeka. Sad na ovom da ne kazem sr*nju mi se desava da zabodu sva 4 migavca, i neam pojma kako to da resim. Da poludi covek Quote Share this post Link to post Share on other sites
lemmy 0 Posted December 3, 2012 Uradjeno danas kod Viteza. Bez podizanja prozora pošto nemam confort modul? Uredno i korektno uradjen posao.Objasni druze sta i kako su ti ugradili kod viteza i koja cena za ugradnju?U pitanju je punto classic sa centralnim zakljucavanjem,znaci treba mi instalacija modula. Quote Share this post Link to post Share on other sites
Nidzo 2 Posted December 3, 2012 Nedavno sam bio kod Viteza i meni je rekao da je 40€ modul za daljinsko zaključavanje sa ugradnjom. Vezuje ti na migavce. Sama ugradnja traje brzo, možda 30-ak minuta. Kod mene se oteglo pošto sam donio svoj modul sa alarmom, a htio sam samo daljinsko zaključavanje/otključavanje bez alarma i bespotrebno sam iskomplikovao ali kad sam uzimao modul nisam znao za Daču "Viteza-a". Najbolje da ga nazoveš i raspitaš se. Quote Share this post Link to post Share on other sites
darkfusion 0 Posted December 23, 2012 (edited) Interesujeme da li je komplikavano ugradnjaCentralna brava sa modulom u fiat punto (2009 godiste ) i kvalitet nasao samProizvođač: Bear AutomotiveHvala unapred na odg Edited December 24, 2012 by neshaoct spojeno Quote Share this post Link to post Share on other sites
~eon~ 2 Posted December 24, 2012 (edited) interesuje me da li je komplikovano ugraditi daljinsko zakljucavanje u fiata bravu Edited December 24, 2012 by neshaoct spojeno Quote Share this post Link to post Share on other sites
odejan 3 Posted December 27, 2012 (edited) hteo bih centralnu na daljinski ,pa ako neko zna sta kako.....da li fabricka gde ima ili neka univerzalna.....u principu me interesuje samougradjivanje bilo bi mi od pomoci vasi saveti i predloziMultipla JTD Edited December 27, 2012 by neshaoct spojeno Quote Share this post Link to post Share on other sites
Delic9 2 Posted April 29, 2013 (edited) Može li mi neko reći gde mogu da ugradim modul za daljinsko zaključavanje (kupio sam Bear), a da nije Vitez u Bataji? To mi je mnogo daleko. Hvala Edited May 1, 2013 by neshaoct spojeno Quote Share this post Link to post Share on other sites
beli_Punto 123 Posted April 30, 2013 kod svakog auto elektricara, a mozda mozes i sam ako se bar malo razumes oko toga Quote Share this post Link to post Share on other sites
AdamGT 1 Posted April 30, 2013 ako ti odgovara bezanijska kosa,javi se na pp da ti dam broj,covek radi extra a nije skup,meni je ugradjivao u punta prosle godine isto bear Quote Share this post Link to post Share on other sites
Nikolatj 0 Posted May 3, 2013 Pozdrav! Imam Stila jtd 3 vrata, uz njega sam dobio kljuc bez daljinskog zakljucavanja. Koliko kosta taj modul i da li postoji neka marka koju bih trebao da biram (ili neka koju da izbegavam). Hvala unapred! Quote Share this post Link to post Share on other sites
miske17 0 Posted May 3, 2013 ako ti odgovara bezanijska kosa,javi se na pp da ti dam broj,covek radi extra a nije skup,meni je ugradjivao u punta prosle godine isto bearA jel moze taj da uradi da radi i kontrola prozora i gepeka na daljisnkom? Quote Share this post Link to post Share on other sites
AdamGT 1 Posted May 4, 2013 naravno da moze,i ja sam hteo to isto,ali za prozore ti treba neki dodatni modul a za gepek jedan motoric za centralnu tako da sam ja odustao Quote Share this post Link to post Share on other sites
miske17 0 Posted May 5, 2013 Javicu ti se za broj, samo da resim da uradim to. Imam dosta posla pre toga. Quote Share this post Link to post Share on other sites
Nikolatj 0 Posted May 5, 2013 Da, ali na stilu vec ima sve to fabricki, samo se kljuc sa dugmicima negde zagubio. Meni sad samo treba daljinac, pa me zanima cena tog tzv modula. Majstor mi trazi 50 evara, to mi je malo cipos! Quote Share this post Link to post Share on other sites
Nikolatj 0 Posted May 5, 2013 Da ne bude zabune, zanima me samo gde u Subotici da nabavim modul za daljinsko zakljucavanje i koju marku? Eventualno ako neko zna i cenu ugradnje bilo bi super. Hvala. Quote Share this post Link to post Share on other sites
