Goran Zemun 441 Posted October 10, 2013 Da li je ovo MAP senzor? Ovo na slici je senzor faze...ili senzor polozaja bregaste...zavisi kako ga ko zove.. Quote Share this post Link to post Share on other sites
markosdbg 0 Posted October 10, 2013 http://www.youtube.com/watch?v=yR7bTpQpxmM&feature=player_embedded Ja sam ovu klapnu gasa ili kako se zove cistio.U principu pre 2 godine sam odsrafio celu klapnu i skinuo,ali ne mogu da se setim tog MAP-a. Quote Share this post Link to post Share on other sites
Skajnet 0 Posted October 10, 2013 Map je na levoj strani usisne grane (kad staneš ispred auta),crne boje,piše Bosch na njemu(bar kod mene) Tapatalk 2 Quote Share this post Link to post Share on other sites
markosdbg 0 Posted October 10, 2013 Pa ja moram da skidam celu klapnu (ponovo),da bih dosao do MAP-a? Quote Share this post Link to post Share on other sites
Skajnet 0 Posted October 10, 2013 Ma ne,klapna je ispod ECU,a Map na suprotnoj strani Tapatalk 2 Quote Share this post Link to post Share on other sites
Rile_bg 347 Posted October 11, 2013 ja mislim da je 9,1 poprilicno korektna potrosnja za gradsku voznju,posebno kod mene u bgu,gde je gust saobracaj i relacije nisu toliko velike... Quote Share this post Link to post Share on other sites
markosdbg 0 Posted October 11, 2013 Uspeo sam da ocistim danas MAP.Evo slika..Hvala svima na pomoci.. Quote Share this post Link to post Share on other sites
MS PK 7732 Posted October 11, 2013 Napisi ono glavno, tj. da li ima promene u radu motora, i da li si resio problem time? Quote Share this post Link to post Share on other sites
Dante Bg 4 Posted October 12, 2013 Da,da bas to! Quote Share this post Link to post Share on other sites
markosdbg 0 Posted October 12, 2013 Ima promena,ali ne drasticnih.Barem ne onoliko koliko sam ja ocekivao.U principu,malo bolje ubrzava.Ovih dana cu kupiti sprej za klapnu,pa cu i to detaljno ocistiti i verovatno cu ponovo morati map. Quote Share this post Link to post Share on other sites
acavozd 0 Posted October 16, 2013 (edited) Pozdrav, klapnu gasa sam otvorio i posle toga leptir ne otvara maksimalno, vec pod punim gasom maksimalno otvori oko 45 stepeni. Nesto sam skrsio. Trebao bih sada da proverim sta je problem, pa mi treba sema struje koja dolazi na klapnu.Negde sam video da je voltaza oko 5.5V ali se ne secam gde a nisam snimio stranicu Hvala. Edited October 17, 2013 by neshaoct spojeno Quote Share this post Link to post Share on other sites
neshaoct 9592 Posted October 17, 2013 Možda si video u temi na kojoj smo sada nakon spajanja (proveri), a možda i ovde:http://www.fiat-lancia.org.rs/forum/index.php?showtopic=44458 Quote Share this post Link to post Share on other sites
acavozd 0 Posted October 17, 2013 (edited) Pozdrav, Citao sam ovde, ali sam pokvario leptir gasa, sada pokusavam da nadjem tu strujnu semu i da pokusam da popravim elektroniku.... Ako ima neko da zna... bio bih zahvalan Edited October 17, 2013 by acavozd Quote Share this post Link to post Share on other sites
Mijailović P. 3448 Posted October 17, 2013 Evo nesto na brzinu ... Quote Share this post Link to post Share on other sites
markosdbg 0 Posted March 16, 2014 Drugari,poceo je da mi se javlja novi problem.Znaci nemam probleme sa klapnom ili ubrzavanjem,sve je to extra,za sada.Moj problem je,kad auto vozim u bilo kojoj brzini i prelazim preko 3500 rpm,pocinje da stuca i moram da oduzmem gas.Da li neko zna sta bi to moglo da bude? Quote Share this post Link to post Share on other sites
gile smederevo 574 Posted March 16, 2014 Kablovi, svecice, bobina..-pravac dijagnostika Quote Share this post Link to post Share on other sites
markosdbg 0 Posted March 16, 2014 Ali stvar je u tome,sto mi ne izbacuje nikakvu gresku. Quote Share this post Link to post Share on other sites
markosdbg 0 Posted March 26, 2014 Danas mi majstor zamenio svecice.Stare su bile istrosene vise od mm.Neverovatno je,kako se oseti razlika.Bolje ubrzava i nema vise trzanja.Bas sam ga forsirao. Quote Share this post Link to post Share on other sites
Nidzo 2 Posted August 17, 2014 Prešao danas u cugu 160km, nakon par sati prešao još 5-6 i onda počinje igranka. Upalim auto i odmah izbaci ckeck engine i počne da radi kao na tri klipa i a trese motor u leru. Dam blagi gas i korigujem to drndanje ali auto slabo vuče. Prikačim ELM i očita mi grešku bobine.Nakon par stotina metara takve vožnje osjetom da je dobio na snazi i da se vratilo sve u normalu. Poništim grešku, gasio, palio auto bez problema, kasnije se i vozao i onda opet kreće. Upali check engine i počne da drnda i nakon nekog vremena se vrati u normalu. Pokvari mi izlet Quote Share this post Link to post Share on other sites
MS PK 7732 Posted August 17, 2014 "Bobina komsija" Proveri sve, i kablove i svecice i bobinu. Quote Share this post Link to post Share on other sites
Nidzo 2 Posted August 17, 2014 Ma bregasta Idem sad da spavam pa ću da smišljam sutra šta ću. Quote Share this post Link to post Share on other sites
MS PK 7732 Posted August 17, 2014 Jezik pregrizo, kakva bregasta Alnaser Quote Share this post Link to post Share on other sites
slavisa87 0 Posted August 19, 2014 Pozdrav ekipa.Evo i mene sa slicnim problemom.Dakle kad uplaim auto (kad je skroz hladan) prvih 10tak sekundi moram da dodajem gas jer obrtaji se podignu do 1200rpm i odmah zatim padnu ispod 700 rpm i pomalo nemirno radi.Takodje kad je na radnoj temperaturu kad mu dam gas secne malo pa onda krece polako da prima gas,kao da se gusi.Da li je to problem do step motora ili do neceg drugog, i da li na ovom motoru ima protokomer.U pitanju je 1.2 8 v. Quote Share this post Link to post Share on other sites
Dante Bg 4 Posted August 19, 2014 Deluje kao da je problem do step motora i klapne gasa,ja bih proverio i dizne...Variraju li obrtaji u leru i da li se gasi prilikom stajanja na semafor? Quote Share this post Link to post Share on other sites
slavisa87 0 Posted August 19, 2014 Dizne su ociscene pre dva meseca.Na leru radi stabilno,ne gasi se na semaforu,desi se ponekad da kad stanem i izbacim u ler podigne obrtaje na 1100-1200rpm i posle 2-3 sekunde vrati na normalu. Quote Share this post Link to post Share on other sites
