luka75 0 Posted November 21, 2012 (edited) ...vec neko vreme fabricki radio kasetofon slabo hvata stanice ili hvata samo pojedine ( rts1, 202, ) ili nece nista da uhvati..... menjao sam antenu- nije do nje, proverio sam kontakte pozadi na radiju-nisu, ostaje mi dilema da li su kablovi negde u prekidu ili je stradao tuner..... ako moze neko da mi kaze kakvi su simptomi kada otkaze tuner? je l onda ne hvata nijednu stanicu, cuje se samo sustanje ili sta?....... naglasavam da neke stanice moze da uhvati ali npr 2 ili 3 max dok kod ostalih se cuje samo sustanje kao da antena nije prikljucena....... izludjuje me totalno a ne bih da skidam tu fabricku konzolu pa da stavljam CD, meni je dovoljan radio .... Edited November 22, 2012 by neshaoct spojeno Quote Share this post Link to post Share on other sites
Mijailović P. 3442 Posted November 21, 2012 Nema mu spasa, barem jeftinog!Malo pretrage nece skoditi! U odeljku Stilo ima tema o trandzi pa je sve vec receno.Pozdrav ! Quote Share this post Link to post Share on other sites
kicerica 5 Posted November 22, 2012 Ne bi ja tako grubo nastupio, ako je recimo hetero onda ima nade i spasa i naravno moze da se popravi. Quote Share this post Link to post Share on other sites
Mijailović P. 3442 Posted November 22, 2012 Argumenti su izostali...zulutapka Quote Share this post Link to post Share on other sites
kicerica 5 Posted November 22, 2012 (edited) Cika Voja 063203122 0643410408 prosle godine resio problem sa radiom kod njega.25eKolega jel sad u redu? Edited November 22, 2012 by kicerica Quote Share this post Link to post Share on other sites
Mijailović P. 3442 Posted November 22, 2012 Eto vidiš. Kad se hoće , ...zulutapka Quote Share this post Link to post Share on other sites
kicerica 5 Posted November 22, 2012 Blagodarim. Quote Share this post Link to post Share on other sites
luka75 0 Posted November 22, 2012 ...ok sve to, koliko shvatam izgleda da je tuner zakucao.......... pretpostavljam da je tako ali opet bih da iskljucim ostale sitnice, tipa osigurac radio pojacala itd..... video sam temu o na forumu ali mi nije potpuno potvrdila sumnju da je tuner otisao....ako je on riknuo je l zanci da moze da hvata i dalje neke stanice ili ne? Quote Share this post Link to post Share on other sites
Ivan 17648 Posted November 22, 2012 A sto jednostavno (da bi eliminisao bilo kakav problem u ozicenju) ne probas da zamenis ceo tvoj uredjaj? Probas tvoj kod nekoga ili obrnuto, bar Stila ima gde god se okrenes... Quote Share this post Link to post Share on other sites
luka75 0 Posted November 22, 2012 .... to i jurim upravo.... probao sam sa cd~om iz burazerovog Puntica ali ima zez ... nije isti ulaz za antenu i akcija propala ... trazim dalje Quote Share this post Link to post Share on other sites
Mijailović P. 3442 Posted November 22, 2012 Stilo=Stilo ; Punto=Punto ; Stilo=Punto? Nece da moze !Naravno, kod probanja sa jednog auta na drugi , trazi code ! Quote Share this post Link to post Share on other sites
Ivan 17648 Posted November 22, 2012 I naravno, tu smo opet mi , samo neka ostavi SN Visteon uredjaja ( http://www.fiat-lancia.org.rs/forum/index.php?showtopic=42458&st=140#entry841812 ) . Quote Share this post Link to post Share on other sites
kicerica 5 Posted November 22, 2012 Luka jesi u Bg-u? Quote Share this post Link to post Share on other sites
luka75 0 Posted November 23, 2012 jesam...U BG Quote Share this post Link to post Share on other sites
kicerica 5 Posted November 23, 2012 (edited) Imam ja jedan fabricki kas za stila sa kojeg sam skinuo displej pa mozemo da prebacimo sa tvog i da probamoda li je sve ostalo kod tvog auta ok. Edited November 23, 2012 by kicerica Quote Share this post Link to post Share on other sites
zoranbr1 0 Posted January 5, 2013 (edited) Od skoro imam problem sa FM modom tjunera na mom fabričkom visteonu sa cd plejerom. Jednostavno, prvo je radio na prekide, onda je počeo više da ne radi nego što radi i na kraju - FM mod "Kaputt"! Lutajući po forumima zaključio sam da je to boljka svih fabričkih visteona u stilu tj. taj FM mod tjunera. Inače cd plejer je u savršenom stanju, sve ostalo radi savršeno i teško mi je da ga otpišem zbog tjunera. Pitanje: Da li je moguće izvršiti popravku fm moda na visteonu, znate li nekoga ko to radi i koliko bi to eventualno koštalo? Edited January 5, 2013 by neshaoct spojeno Quote Share this post Link to post Share on other sites
Rax011 0 Posted January 5, 2013 (edited) Ja imam fabricki radio od stila gde fm radi odlicno, ali kaseta ne radi i displej na njemu. Kome treba moze povoljno da prepakuje fm na svoj radio veoma lako i brzo! Ja ga ne koristim godinama jer imam ugradjen drugi radio sa cd i usb. Kome treba neka mi se javi na PM. Edited January 5, 2013 by Rax011 Quote Share this post Link to post Share on other sites
kicerica 5 Posted January 5, 2013 Stampa nije ista na cd i tape uredjajima. Quote Share this post Link to post Share on other sites
Goran Zemun 441 Posted January 6, 2013 Pre mesec dana smo radili veliki servis i sijalicu fara na jenom stilu. Nakon preuzamanja auta vlasnik se vratio i reklamirao da mu ne radi FM na radiju. Tvrdio je da smo spalili radio kada smo menjali sijalicu ili kada smo kacili examiner da ponistimo servis. Naravno ja sam bez ikakve diskusije zamenio radio i resio problem. Zanima me da li je jos nekom crkao radio kada je menjo sijalicu ili brisao servis....ipak su gremlini medju nama.....:) Quote Share this post Link to post Share on other sites
kicerica 5 Posted January 6, 2013 Ne verujem sta sam procitao. Ovo je za novu temu koja bi trebala da se zove,Utisci o musterijama, klijentima. Quote Share this post Link to post Share on other sites
MMica 0 Posted January 9, 2013 To vam je problem naseg posla (serviseri ,usluzne delatnosti).Kod mene u servisu (BG elektronik) se cesto srecem sa takvim folirantima koji prijave samo neku glupost od kvara a ozbiljnije kvarove slucajno zaborave misleci da ce tako jeftinije da prodju......btw, ovaj kvar na Visteonovom tjuneru se resava Quote Share this post Link to post Share on other sites
autoremont_stankovic 0 Posted January 22, 2013 (edited) Problem sa radio nekada hvata stanice a uglavnom ne . Sta moze da bude problem. Hvala unapred Edited January 23, 2013 by neshaoct spojeno by Ivan :) Quote Share this post Link to post Share on other sites
Gusar 4 Posted January 22, 2013 (edited) mozda los kontakt ka anteni... Edited January 22, 2013 by Gusar Quote Share this post Link to post Share on other sites
autoremont_stankovic 0 Posted January 22, 2013 ubacao sam i elektricnu antenu nece Quote Share this post Link to post Share on other sites
Mijailović P. 3442 Posted January 22, 2013 Prvi znaci kliničke smrti. Quote Share this post Link to post Share on other sites
