fiatmkd 0 Posted September 23, 2014 (edited) Zdravo ljudi,pre neki dan imao sam problem sa radio (fabricko) u stilo iz 2002 godine.radi normalno kad odjednom pocinje ono sssssssssssssssss i ako pokusam da promenim vec memorisanu stanicu onda vrti u krug i ne pronadje nit jednu stanicu...jucer i danas radio savrseno, veceras na kratko me iznervirao, ali nakon voznja je sve bio OK...jel to neki generalni problem sa tuner, koliko kosta eventualna popravka????il mozda je nesto jednostavnije kao neki kablovi il mozda antena???da lise i vama to desio???pozdrav iz makedonije )) Edited September 23, 2014 by Ivan Prebaceno Quote Share this post Link to post Share on other sites
neshaoct 9592 Posted September 24, 2014 Sada, nakon spajanja tema, pročitaj sve ranije napisano u temi na kojoj smo...piše baš to što te zanima.Ukratko, poznat problem koji pogodi dosta fabričkih uređaja kod Stila i popravka se uglavnom ekonomski ne isplati. Quote Share this post Link to post Share on other sites
fiatmkd 0 Posted September 26, 2014 napravio sam SELF TEST Cassette / CD / MP3 Player Test MenuThe instructions below describe how to access a few in-built diagnostic tests the Visteon Stereo's have in-built:1. Turn the Stereo ON2. Press buttons "3" and "6" together for a few seconds, until a pitch note is heard on the speakers.Now you're in test mode, here are the tests you can do:A. SPEAKER TEST - Pressing the ">>" button will test all the (8) speakers the car has - 4 speakers, 4 tweeters. Once finsihed, it will exit the test mode, and you'll have to go back in (above).B. SIGNAL STRENGTH - Whilst in test mode (with the pitch note heard), press button "3" again. An indication of the intensity of the radio signal the tuner is receiving is displayed as a measure of voltage (e.g. SIGNAL STRENGTH 1.6V). My averages are 2V-3V.C. SHORT & OPEN CIRCUITS - Whilst in test mode (with the pitch note heard), press button "6" again. Check that the words "SHORT CIRCUIT - OK" appears (i.e. no problems).D. PROCESSOR & MODULES COMMS TEST - Whilst in test mode (with the pitch note heard), press button "1". "COMMS TEST - PASS" should appear.E. CHECKSUM (internal EEPROM) TEST - Whilst in test mode (with the pitch note heard), press button "4". "CHECKSUM - PASS" should appear.F. DISPLAY OPERATION TEST - Whilst in test mode (with the pitch note heard), press button "5". All the pixels on the display should appear.G. CD CHANGER COMMUNICATION TEST - Whilst in test mode (with the pitch note heard), press button "2". If a Blaupunkt IDC-A09 is fitted, "CDC CONNECTED" should appear. If not, there is a problem with communication between the units, or no unit is fitted (duh!)To exit the diagnostic test, turn the stereo off normally.sve je OK osim jacina signala...ona varira 0.0V - 2.6V nekoliko puta u sekundi...il staje na 0.8 V il 1.4 i cini se da je to premalo...e sad, jel ovo znaci da je tuner crko ??? il imam neki problem sa antenom???pozdrav Quote Share this post Link to post Share on other sites
Ivan 17637 Posted September 26, 2014 Na osnovu jacine signala, tj. varijacija bih rekao da je tuner odsvirao svoje, nazalost.Antena retko pravi problem, a i ako sumnjas mozes da zamenis sa nekim uredjaj za probu (ako Stila ima i priblizno kao kod nas ), skida se za sekund. Quote Share this post Link to post Share on other sites
SrdjanNS86 20 Posted October 12, 2014 Upravo tako to se i meni desilo a uzeo sam Stila pre par dana i radio dva tri dana i cao svirno tjuner.A taman sam mislio da cu uzeti samo microlink i ponekad ukljucim radio kad mi ovo dosadi kad ono cvrc.Sad ako izdam kes za cd plejer microlink ce morati da ceka malo opet. Quote Share this post Link to post Share on other sites
srkibess 8 Posted December 7, 2014 (edited) Slabo hvata stanice cd player (fabricki).....Ima li elektronsku antenu i gde se ona nalazi? Edited December 7, 2014 by neshaoct spojeno Quote Share this post Link to post Share on other sites
neshaoct 9592 Posted December 7, 2014 Pročitaj sada, nakon spajanja tema sve ranije napisane odgovore u temi na kojoj smo. Quote Share this post Link to post Share on other sites
cobra11 1 Posted January 25, 2015 Danas naletih na ovo... Interesanto mozda je van teme i negde spominjano, ne da mi se da sve redom cimtam ali ajde.U pitanju je povezivanje tefelona i fabrickog radija, valjda kao aux evo link. https://www.youtube.com/watch?v=EZBpJQ8bPco Quote Share this post Link to post Share on other sites
Angell 11 Posted January 25, 2015 U pitanju je opcija phone, a ne aux.Super je zvuk, samo je problem sto ne moze mnogo glasno da se pusti.Ali sta je tu je, moze da posluzi Quote Share this post Link to post Share on other sites
Ivan 17637 Posted January 25, 2015 Odavno provaljeno, odgovarajuca tema: http://www.fiat-lancia.org.rs/forum/index.php?/topic/44697-stilo-handsfree-u-aux-in/ Quote Share this post Link to post Share on other sites
lancemi_zen 0 Posted February 15, 2015 Jel moze neko spajanje sa tememom kako se vadi fabricki player na stilu ili neki tutorijal hocu da proverim da mi nije otkacena antena? Quote Share this post Link to post Share on other sites
DjoleKG 0 Posted February 15, 2015 (edited) u te 4 zaokruzene rupice sa slike gurnes istovremeno 4 parceta zice da bi popustile zabice, onda povuces ka sebi i to je to Edited February 15, 2015 by DjoleKG Quote Share this post Link to post Share on other sites
Ivan 17637 Posted February 15, 2015 Uz malo koriscenja Search (http://www.fiat-lancia.org.rs/forum/index.php?showtopic=54042) dodje se do necega sto je prezvakano vec X puta na forumu. Postupak, nacin kopcanja, potrebna debljina i duzina zice, slicica iz eLearn...: http://www.fiat-lancia.org.rs/forum/index.php?/topic/26440-stilo-zamena-fabri%C4%8Dke-muzike-zvu%C4%8Dnika/page-13#entry1097113 Quote Share this post Link to post Share on other sites
SerAlex 37 Posted May 16, 2015 Jel zna neko nekog ko jos radi popravku tjunera posto momci iz Panceva vise ne rade, a da je na teritoriji BG ili uzoj okolini? Quote Share this post Link to post Share on other sites
neshaoct 9592 Posted May 18, 2015 Pitaj kod njih:http://www.ecuservis.rs/ Quote Share this post Link to post Share on other sites
SerAlex 37 Posted May 18, 2015 ^^Hvala Neso raspitacu se. U najgorem slucaju bih da nadjem nekog ko zna da skida i stavlja ove cipove, pa cu ja da nabavim ovaj i da mu odnesem da ga zameni. Quote Share this post Link to post Share on other sites
SerAlex 37 Posted May 23, 2015 Konacno sam sredio player i to tako sto sam od 2 komada napravio 1 koji radi posto sam ja toliki baksuz da cip tjunera koji se nalazi u mom playeru je drugi tip i nema ga nigde za kupovinu. Quote Share this post Link to post Share on other sites
neshaoct 9592 Posted May 23, 2015 Bitno da si sredio. Quote Share this post Link to post Share on other sites
Martinnis13 1 Posted October 2, 2015 Momci, imam problem sa antenom.... Na fabričkom stilovom tjuneru (cd/radio). Nece da hvata stanice... Probao sam svasta, kada sam u isto vreme pritisnuo 3 i 6 culo se pištanje, a nakon toga sam kliknuo 6 i prvo mi je pisalo "Antena: Open CCT" a nakon toga "Short circuit - Fail". Sta da radim ? da li je neko imao vec problem sa time i kako da rešim to ? Quote Share this post Link to post Share on other sites
Ivan 17637 Posted October 2, 2015 Zameni radio sa nekim, cisto da laicki 100% lociras da li je problem do tunera ili do antene.Bar Stila imas na svakom cosku, a to proveris za 5 min... Quote Share this post Link to post Share on other sites
Martinnis13 1 Posted October 2, 2015 Stila ovde kod mene nisam video.. Barem ga niko nema kod mene u kraju. Stavljao sam drugu antenu na krovu isti slučaj... Da li postoji neki poseban osigurač za antenu ili kako sam čitao neki "pojačavač antene". I da li neko zna gde tačno prolazi koksijalni kabl antene, da li pored lajsne vozača ili krova ? Quote Share this post Link to post Share on other sites
neshaoct 9592 Posted October 2, 2015 Stila ovde kod mene nisam video.. Barem ga niko nema kod mene u kraju. Dođi onda u ovaj kraj prekosutra:https://www.fiat-lancia.org.rs/forum/index.php?/topic/69384-20-zvani%C4%8Dno-flcs-okupljanje-ro%C5%A1tilj/ Quote Share this post Link to post Share on other sites
Martinnis13 1 Posted October 2, 2015 Radim druže svakog dana, ja sam fotograf.... Inače da ne skrećemo sa teme, ako nema ima odgovor kako da popravim ili proverim ono neka javi Quote Share this post Link to post Share on other sites
Ivan 17637 Posted October 2, 2015 (edited) da li neko zna gde tačno prolazi koksijalni kabl antene, da li pored lajsne vozača ili krova ?Ne ide pored vozaca. Sa krova ide desno (gledajuci u smeru kretanja), ulazi u desni C stub i prolazi kroz desni prag.Zatim se pored cut-off prekidaca kod nogu suvozaca penje u tablu, do zadnje strane uredjaja.Ne postoji nikakav osigurac za antenu, jesi li vadio uredjaj da vidis sta je sa konektorom koaksijalnog kabla? Ako je to OK, tipujem da ti je 99% crkao tuner, standardna boljka na Visteonu. Kazem ti kako najlakse sigurno laicki da proveris, ako neces da dajes pare majstoru. Edited October 2, 2015 by Ivan Quote Share this post Link to post Share on other sites
Martinnis13 1 Posted October 2, 2015 http://postimg.org/image/mq8e7usw9/ Evo sta mi izadje kada na radiju stisnem 3 i 6 u isto vreme pa onda kliknem 6.... Umesto ok meni pise failure... Sta tu onda trebam da pogledam? Quote Share this post Link to post Share on other sites
