dusman13 80 Posted January 12, 2015 U bixenonu imas dugo i kratko to je razlika.Moze biti H4 i moze biti u projektoru koji ima selenoid koji klapnu dize i spusta pa imitira dugo i kratko svetlo, tu moze biti bilo joja H sijalica i xenon i halogena. A ovde pricamo o xenonu.Eto nadam se da si skapirao razliku Quote Share this post Link to post Share on other sites
bane17 24 Posted January 12, 2015 da..apsolutno..hvala..meni ipak za pocetak treba samo obican H7 set..a posle ce na red da dodje dugo sa cini mi se H1 sijalicom... Quote Share this post Link to post Share on other sites
Vule 795 Posted January 12, 2015 a sta da uguram kod mene u farove...dal je bolje ac ili dc...i koji da budu 4300,6000,8000 Uguraj projektore, jer ćeš samo sa xenon setom u tim farovima toliko da zaslepiš ove što ti dolaze iz suprotnog smera, dobiće boju kao da su se sunčali ceo dan I naravno, kasnije 4300k Quote Share this post Link to post Share on other sites
bane17 24 Posted January 12, 2015 prati temu moju vule..vidi mi farove..kakvi su crni..koga cu da zaslepim Quote Share this post Link to post Share on other sites
nikola01 0 Posted January 12, 2015 hvala na obavestenju ! ubuduce mala slova Quote Share this post Link to post Share on other sites
SimkeBGD 48 Posted January 13, 2015 Da li je stavljao neko 5500k? http://www.kupujemprodajem.com/Xenon-BEAR-EXTREME-canbus-AC-18217756-oglas.htm Quote Share this post Link to post Share on other sites
Ivan 17666 Posted January 13, 2015 Kako vecinom edukativno nastupamo . Quote Share this post Link to post Share on other sites
bane17 24 Posted January 14, 2015 Samo 4300k 4300k sa folijom na farovima Quote Share this post Link to post Share on other sites
Vule 795 Posted January 14, 2015 Ne bih komentarisao foliju na farovima Quote Share this post Link to post Share on other sites
Vule 795 Posted January 14, 2015 Zato što je to nešto najgore što možeš uraditi. Bar ako pričamo o svetlu. Te priče "nije slabije svetlo" bilo kome normalnom mogu samo da budu smešne, jer nemaju logike - naravno da je slabije svetlo, jer si zatamnio plastiku kroz koju prolazi, kao da ti je blago prljav far. Ako već želite da radite taj "black look" sa sve xenonima, onda ga uradite kako treba - otvaranje farova, ugradnja projektora, farbanje rozetni u crno, i pakovanje nazad. Em izgleda 20x bolje od glupe folije, em sija 30x bolje od ugrađenih xenona u H7 far. I ne mislim Bane ovde samo na tebe, nisi ti jedini koji stavlja foliju na farove Quote Share this post Link to post Share on other sites
kolega.jankovic 23 Posted January 14, 2015 Jeste sve to tacno, ali taj posao kosta 150-200€ a folija........Jeste da se vidi losije ali ne i 200€ losije :) Zato je i stavio xenon-taman ce biti tu negde halogena=xenon + folija Quote Share this post Link to post Share on other sites
Vule 795 Posted January 14, 2015 Kakvih 150-200e? Projektori su 40e, xenon set je 35, crni sprej je 500 dinara. Ili odneseš kod nekog da ti lepo ofarba, neće ti uzeti više od 20e ako je normalan, ako i toliko. Otvoriš farove, ugradiš, ofarbaš, namestiš i teraš. Svakako čovek sam radi auto, zašto ne bi uradio i to... Ili jednostavno nemoj ništa ni raditi ako već nedostaje love, bolje da nešto sačeka pravi momenat nego da se skarabudže folije... Quote Share this post Link to post Share on other sites
Milutinac 5906 Posted January 14, 2015 (edited) A jbg, ako stavis xenon stavi ga zbog bezbednosti i bolje vidjlivosti onoga sto osvetljavas onda, a ne zbog toga da mu stavis foliju i onda ono sto imas od xenona je samo da nije zuto svetlo vec belo...Smatram da svetla treba iskoristiti potpuno, nije zjbncija s tim, zato i stelujem farove svakih 15 dana, nikad nisam zadovoljan...-desna crta malo vise dole, leva desno i gore, ajd da probam ovako, ajd da probam onako itd... Edited January 14, 2015 by milutin-NS Quote Share this post Link to post Share on other sites
Ivan 17666 Posted January 14, 2015 I meni su te folije na farovima totalni promasaj u svakom smislu.Apsolutno se slazem sa Vuletom - ili radi kako treba (pre svega funcionalnost+estetika) ili nemoj uopste raditi.Cisto licni stav... Quote Share this post Link to post Share on other sites
Rile_bg 347 Posted January 14, 2015 ...kao i xenoni bez projektora,to ume bas da zaslepi. Quote Share this post Link to post Share on other sites
zrnke 41 Posted January 14, 2015 Mene zaslepi i obican far na ovom novijem Puntu, a tek ksenoni.. Quote Share this post Link to post Share on other sites
Vule 795 Posted January 14, 2015 O tome i pričam, vozio sam tog Punta, znam koliko smeta ljudima, ajd' što sam vozio, nego kad god me neko iz suprotnog smera zaslepi, znam da je ili Punto mk2b ili Fabija neka službena natovarena... A da ne pričamo kad se stave xenoni u taj običan far, bože sačuvaj... Quote Share this post Link to post Share on other sites
beli_Punto 123 Posted January 14, 2015 Zato je Bane preventivno zatamnio far Quote Share this post Link to post Share on other sites
Dule 021 660 Posted January 14, 2015 Ja evo ovih dana vozim Golf V sa naknadno ugradjenim ksenonima i ne vidim da ikome smetam i niko mi jos nije ablendovao. Jos je lik ugradio ksenone i u maglenke a dosao je nocu da odradimo trampu i dok sam ga cekao ispred kapije vidim dolazi nesto extra lepo a lik upalio i maglenke za koje nisam znao da imaju ksenone. Kad ono staje ispred mene i meni drago jer sam dobio lep auto.Na mom autu su bili fabricki ksenoni sa projektorima i pravo da vam kazem nisam ja tu neku razliku primetio u osvetljenju.Problem kod puntovih farova je sto kad stavis kineza dovoljna je i obicna sijalica pa da zaslepljavas sve oko sebe a kamoli da ubacis ksenone jer onda si opasnost na putu. Quote Share this post Link to post Share on other sites
totti 13165 Posted January 14, 2015 Lično im ne blicam, ali mnogi realno smetaju - što kad mi dolaze u susret, što u retrovizoru. Quote Share this post Link to post Share on other sites
zrnke 41 Posted January 14, 2015 Neki zato imaju fotoosetljivi retrovizor Quote Share this post Link to post Share on other sites
MS PK 7732 Posted January 15, 2015 Lično im ne blicam, ali mnogi realno smetaju - što kad mi dolaze u susret, što u retrovizoru.Da sam ti ja naiso, blicao bi, svirao i " redjao sve po kalendaru" , sto bi rekli carapani Quote Share this post Link to post Share on other sites
