freedole 0 Posted August 19, 2010 Imam Punta mk2 1.9 JTD Sporting 63KW i nasao sam na internetu da na njega ide Blow Off dok na punta 60 KW ne ide. E sad, volio bi da mi neko kaze detalj vise. Gledao sam taj Blow Off na ebay. ima ih raznih. Jel to neki specijalni za te stvari ili da gledam sto jeftinije nesto sto se zove blow off? i kako se ugradjuje? mogu li to sam uraditi? predpostavljam da se neko crijevo otkaci i stavi se taj ventil ???eto hvala. bilo kakva informacija je dorodosla. ovi majstori u bosni nemaju pojma sta pricam Quote Share this post Link to post Share on other sites
neshaoct 9592 Posted August 19, 2010 Imam Punta mk2 1.9 JTD...'' Blowoff služi za rasterećenje usisne grane od pritiska koji turbina pravi kad se otpusti gas. Dakle, kad se pusti gas i zatvori leptir gasa......Dizeli nemaju leptir gasa... Quote Share this post Link to post Share on other sites
bokija 83 Posted August 19, 2010 Al si nas prosvetliooooo,idemo da se stidimo Quote Share this post Link to post Share on other sites
boki 10 Posted August 19, 2010 moze i na dizela ali nije to to,ako oces da shistis ima i elektronski koji se povezuje na papucicu gasa ali nije to to Quote Share this post Link to post Share on other sites
freedole 0 Posted August 20, 2010 Hvala. Zadovoljan sam bilo kakvim odgovorom, ali kad sam vidio da sam odmah dobio odgovor, preezadovoljan.E sad. ovo sam nasao na google: Pop-off valve for Punto Sporting JTDSince Negrente has debuted worldwide with the pop-off valve for all the most common turbodiesel engines, even the Punto Sporting JTD can receive a pop-off valve. The most common perception about the usefulness of such valve is that also a diesel engine has somehow a counterpressure in the intake tubes, when changing to upper gears, just like the petrol engines. There is not an air barrier of the closed throttle body, which obstacles the pressured air to return back, but turbodiesel engines could have higher pressure rates.The main benefits of a popoff valve in the Punto Sporting JTD are listed here: * avoids stressing pressures during gear changing * frees a valuable amount of air, which obstacles the inlet turbocharger to pump faster more air to the engine * sounds very racing!Negrente has a complete kit that can be installed in the Punto Sporting JTD. Here there are some snapshots about an installed one. Znaci Pop-off nije isto sto i blow off?btw izvinite ako smaram ali stalo mi je da imam to na punticu Quote Share this post Link to post Share on other sites
neshaoct 9592 Posted August 20, 2010 Znaci Pop-off nije isto sto i blow off?Nije isto.Ali...to uopšte nije od uticaja za tvoj slučaj. Taj zvuk koji si ti čuo...to što želiš da dobiješ...za to je zadužen blow off, piše gore na kojim motorima postoji i kako i šta radi. Ti nemaš takav motor, ne možeš imati takav zvuk. Idi kupi turbo benzinca. Pop-off služi da spreči over boosting. Koristi se pre svega u pojedinim šampionatima (seriji trka) kako bi sprečio malverzacije oko snage motora. Kada čuješ njegov zvuk, posledica je smanjenje snage motora, jer višak pritiska sa kojim je neko hteo više snage, ode napolje. Zbog toga ga niko i ne stavlja na komercijalne automobile...i to što si čuo i što želiš na svom autu nije rezultat rada pop-off.-a Quote Share this post Link to post Share on other sites
freedole 0 Posted August 20, 2010 ok. thx.a bas sam se ponadao ali ako nekad nesto improvizujem, objavljujem. jednostavno ne mogu da se pomirim sa tom cinjenicom.Hvala jos jednom Quote Share this post Link to post Share on other sites
boki 10 Posted August 20, 2010 mozes da stavis i na taj auto,stim sto nabavi elektronski i povezi na gas izadje negde oko 80ak evra Quote Share this post Link to post Share on other sites
chela 2 Posted August 20, 2010 Znaci Pop-off nije isto sto i blow off?Pop off nije apsolutno isto sto i blow off, samo je preradjeno i optimizovano za dizele da vrsi istu funkciju kao i blow off.Nije ti potreban leptir gasa da bi stavio blow off, samo malo volje zelje i znanja da b se namestilo. Ali dzabe kad nema istu funkciju kao kod benzinjara... Quote Share this post Link to post Share on other sites
FlamingO 1 Posted September 1, 2010 Malo sam gledao po netu, interesuje me posto vidim da na autima sa turbinom je moguce uraditi Blow off ventil, reci te mi jel ovo ok? I da li se isplati ulagati u to gledao sam neki HKS SSQV 2 BOV Blow off valve Universal Black limited, pa molim strucnjakeza uputu, i gdje to moze da se uradi! Ko sa tim radi! bdw zvuk je fenomenalan sto me iznenadilo! ( nisam neki strucnjak ali mi se stvarka svidja )Unaprijed Hvala! Quote Share this post Link to post Share on other sites
boki 10 Posted September 1, 2010 ne znam sta ce ti ali probaj OVDE Quote Share this post Link to post Share on other sites
oktopod 283 Posted September 1, 2010 (edited) A evo ti konkretna mišljenja i iskustva Britanaca sa foruma fiatforumKoliko vidim na brzinu, sem zvuka ne dobijaš ništa,na performansama čak gubiš!Na dizelima čak ni nema praktično svojstvo neko, samo dobiješ taj zvuk šššš...a i košta preko 200 eur dobar kako kapiramhttp://www.fiatforum.com/punto/130903-dump-valve.htmlI za jtd bašhttp://www.fiatforum.com/punto/217901-blow-off-valve-jtd.html Edited September 1, 2010 by Oktopod Quote Share this post Link to post Share on other sites
neshaoct 9592 Posted September 1, 2010 Pitanje je spojeno sa ranijom pričom o ovome, pa bi bilo dobro FlamingO da pročitaš sada temu od početka, tj. i ove dodate postove. Quote Share this post Link to post Share on other sites
FlamingO 1 Posted September 2, 2010 ^^^ Hvala u svakom slucaju ima informacija Quote Share this post Link to post Share on other sites
banjo1990 264 Posted September 2, 2010 A sta se na ovom traktoru cuje? Quote Share this post Link to post Share on other sites
neshaoct 9592 Posted September 2, 2010 Pisano je...imaš pop off koji daje sličan zvuk, ali mu je efekat da čim se on čuje gubiš snagu, jer mu je to i uloga.Šta će ti to na komercijalnom autu...Ljudi...hoćete da budete trkači? Onda benzin sa mnogo kubika, ili benzin sa malo manje kubika, ali Turbo. Quote Share this post Link to post Share on other sites
oktopod 283 Posted September 2, 2010 ili naučite jako da zviždite :whistle: :whistle: Quote Share this post Link to post Share on other sites
neshaoct 9592 Posted September 4, 2010 Deo postova ovde:http://www.fiat-lancia.org.rs/forum/index.php?showtopic=37285&view=findpost&p=700436 Quote Share this post Link to post Share on other sites
c++ 60 Posted January 13, 2022 (edited) Da li je moguće? 1.9JTD motor? prijatelj mi kaže da se ubaci samo ravna cijev i dobije se taj zvuk? tako je on kod sebe napravio? Edited January 13, 2022 by neshaoct spojeno Quote Share this post Link to post Share on other sites
neshaoct 9592 Posted January 13, 2022 (edited) @c++ Pročitaj sada, nakon spajanja, sve ranije napisano u temi na kojoj smo. Možeš baciti pogled i na ovde napisano: - Blow Off Edited January 13, 2022 by neshaoct dopuna Quote Share this post Link to post Share on other sites
