petarcirjanic 70 Posted September 24, 2014 Nikako gusce ulje. Sipas ulje koje preporucuje proizvodjac. Quote Share this post Link to post Share on other sites
PsyBoza 0 Posted September 24, 2014 Eee majstori i gusće ulje .Pa ja u fiat uno 86 god stavljam ono sto je preporuceno i ne trosi ga.Stavi fabricko ulje i vidi sta je kvar dok ne bude kasno. Quote Share this post Link to post Share on other sites
redymusic 0 Posted October 6, 2014 Pa na kraju ce da se ispostavi da su ovi iz servisa bili u pravu i da treba da menjam tu turbinu.. Quote Share this post Link to post Share on other sites
milosstankovic 0 Posted October 13, 2014 Kolega iz Poljske mi je poslao link za radionicu za remont svih vrsta turbina: http://www.regeneracja-turbosprezarek.pl/cennik-regeneracji-naprawy-turbosprezarek.html Nisam se previse ududbljivao, a i ne znam poljski, ali, koliko vidim, kompletna reparacija turbine sa delovima kosta oko 600 zlota, sto je oko 150 EUR. Quote Share this post Link to post Share on other sites
Dovla 9 Posted October 13, 2014 I onda ti nosiš turbine njemu ili kako? Quote Share this post Link to post Share on other sites
redymusic 0 Posted October 15, 2014 Pa ajde da se raspitamo za to.. Danas cu da ih zovem pa javljam Quote Share this post Link to post Share on other sites
redymusic 0 Posted October 17, 2014 Niko ne govori engleski, poslah im mail pa cemo videti sta i kako.. Quote Share this post Link to post Share on other sites
redymusic 0 Posted November 14, 2014 samo da se javim, ipak je turbina, sto posto.... Quote Share this post Link to post Share on other sites
deki87 7 Posted November 14, 2014 A jesi saznao koji je to zuti osigurac koji je cistio? Quote Share this post Link to post Share on other sites
petarcirjanic 70 Posted November 19, 2014 Saljes turbinu u poljsku na remont? Quote Share this post Link to post Share on other sites
vnvedad 1 Posted July 3, 2016 Pozdrav, turbina mi je crkla prije pola godine, uzeo sam polovnu na otpadu i sve je bilo ok nekih 10 dana dok nije opet zvuk se pojavio ali nekako drukciji pa mi je majstor rekao da mi je gumistucna prosjecena od zastitne plastike, i tu sam gumistucnu zamjenio. Nije ista, ali je legla nekako. Evo proslo pola godine i ima deset dana ujutro kad upalim auto nista se ne cuje i ne dimi nista kad predjem nekih 15 kilometara kad se auto ugrije onda se osjeti opet to zvizdanje mada auto ne gubi nikakvu snagu i dima nema. Gledao sam gumistucnu nije pukla. i sto je jos osjeti se neki zvuk i kad auto naprimjer ide nekih 80 na sat i sad bio u cetvrtoj ili petoj ono bez gasa kad ides znaci ne dodajes gas ono se cuje .i tako konstantno ovih 10 dana. jel imao neko ovaj problem, sta mislite jeli turbina opet otisla. Quote Share this post Link to post Share on other sites
vnvedad 1 Posted July 4, 2016 evo slika i ovo crijevo ide sturbine izgleda da je masno dobro moze li biti do njega. Quote Share this post Link to post Share on other sites
neshaoct 9592 Posted July 4, 2016 Ne treba toliko osluškivati zvukove koje auto spolja pravi jer...on zvukove mora praviti. Ozbiljno, sam kažeš da ne dimi, nema problema sa snagom, ne prijavljuje grešku oko pritiska, ne troši motorno ulje...drugim rečima, sipaj nafte uvek dovoljno i vozi. Na šuspleh (plastiku donju) možeš da staviš neko malo parče gume tu gde prolazi crevo kako ti ne bi opet plastika isekla to crevo...ili malo iseci šuspleh da se ne dodiruju crevo i plastika. Quote Share this post Link to post Share on other sites
vnvedad 1 Posted July 4, 2016 ne trosi ulje, ali mi izjutra nekad se pojavi greska oil level presure nekih deset sekundi i ugasi se. Tokom dana se ne pali nikako vise, ali ta mi se greska pojavljuje odkad sam servis radio i tu sam se pokacio stim majstorom radi toga. Kaze on nije do njega isao u drugog majstora koji mi je otklonio grijanje motora gdje sam promjenio hladnjak i termostat.i on mi je fekao da se ta greska pojavljuje u vezi uljne pumpe pa da dodjem kod njega da to vidimo drugi put .medjutim nikako da odem jos. Quote Share this post Link to post Share on other sites
neshaoct 9592 Posted July 4, 2016 Kao što ti je rekao taj drugi majstor, ta greška nema veze sa pričom oko turbine. Dok ne odeš kod tog drugog majstora, ipak proveri nivo ulja. Quote Share this post Link to post Share on other sites
vnvedad 1 Posted July 4, 2016 ma provjeravao sam nivo ulja je ok i kod paljenja se pojavi da su sve tacke pune i na sipci je ok ali mi je ulje nekako crnkasto ko zna sta je ovaj usuo kod servisa .prvo cu da odem da promjenim filter i ulje .vasa preporuka koje da uzmem motor je 1.9 jtd 2002 85 kw. presao 270 hiljada. Quote Share this post Link to post Share on other sites
neshaoct 9592 Posted July 4, 2016 Pa, ok je ako je ulje crno. Tema o uljima (iskustva, preporuke) je ovde: https://www.fiat-lancia.org.rs/forum/index.php?/topic/33155-selenia-koje-ulje-sipati/ Quote Share this post Link to post Share on other sites
vnvedad 1 Posted July 24, 2016 samo da odgovorim ulje sam promijenio usuo sam wr 5 w/40 selenia prije nekih sedam dana i sad auto radi ko singerica nema vise zvizdanja nikakvih .da napomenem ko zna kakvo je majstor ulje usuo mozda neko da ima posla cesce sa mojim autom .znaci do ulja je bilo. Quote Share this post Link to post Share on other sites
neshaoct 9592 Posted July 26, 2016 @vnvedad Hvala na prenetom iskustvu. Quote Share this post Link to post Share on other sites
vnvedad 1 Posted July 30, 2016 samo da napomenem da mi se ne pali vise ni sijalica oil lewel presure kako sam ulje promjenio. pa da prenesem samo. Quote Share this post Link to post Share on other sites
MS PK 7734 Posted July 30, 2016 @vnvedad Pa jel taj tebi uopste i promenio ulje? Quote Share this post Link to post Share on other sites
vnvedad 1 Posted July 30, 2016 ne znam svegami jer prije servisa na mjesec sam ja promjenio ulje na svoju ruku i malo sam se zeznuo usuo neko 15/40 i tad mi je ubrzo otisla turbina i poslije toga mi je i semering neki bio puknuo i ulje mi iscurilo i nakon toga sam radio da ne bi samo mjenjao semering radio servis. Kad je servis uradjen pocelo mi se auto grijati uzastranu vec sam o tome postavljao pitanja i ta mi se lampica palila vjerovatno je sipao ulje posto je ovo staro iscurilo skroz. Poslije toga sam promjenio nov hladnjak i termostat i sve je ok bilo sto se tice grijanja motora. Ali nesto se culo ponovo kao da je otisla turbina i sad kad sam usuo ulje koje sam spomenuo sve je ok. Samo da napomenem u mene je ovaj auto ima sedam godina i nikad nisam ulozio u njega ni marke cak i prosle godine kad sam na more isao govore mi ljudi barem promjeni filter zraka i nafte ja to u sedam godina nikad nisam mjenjao. Auto me slusao dok nisam otisao kod ovog majstora ......znaci do ulja mi je bilo sigurno i lampica oil level presure i ovo sto je zvizdilo jer sad je sve perfekt Quote Share this post Link to post Share on other sites
werp690 459 Posted July 30, 2016 Jel si promenio na kraju taj filter vazduha i goriva? Filter klime? Dobro je da si resio to zvizdanje i pritisak... Quote Share this post Link to post Share on other sites
neshaoct 9592 Posted July 30, 2016 3 hours ago, vnvedad said: u mene je ovaj auto ima sedam godina i nikad nisam ulozio u njega ni marke cak i prosle godine kad sam na more isao govore mi ljudi barem promjeni filter zraka i nafte ja to u sedam godina nikad nisam mjenjao. Što kaže @werp690 , promeni mu barem sada sve filtere. Quote Share this post Link to post Share on other sites
