Ticma 537 Posted September 25, 2012 Zasto bre cist antifriz, nemoj tako dugo da ga vozis, trebali ste pola pola. Quote Share this post Link to post Share on other sites
Hardvet 2 Posted September 25, 2012 Zato i pitam sta su radili. Mozda samo dosuli cist u cistu vodu koja je vec unutra... Quote Share this post Link to post Share on other sites
MS PK 7732 Posted September 25, 2012 A mozda cist 40%, a Quote Share this post Link to post Share on other sites
Ticma 537 Posted September 25, 2012 Nisam razmisljao u tom pravcu, mada nisam ni video da negde ima paraflu od 40% Quote Share this post Link to post Share on other sites
ivan.ik 625 Posted September 25, 2012 Sledeći problem za dva meseca nama grejanje. Quote Share this post Link to post Share on other sites
Hardvet 2 Posted September 26, 2012 Niko ne prodaje 40%. Ni ja nisam video godinama. Quote Share this post Link to post Share on other sites
climatic 0 Posted September 26, 2012 Sipali smo Galax korsantin 40% uzeo na benzinskoj pumpi.Kazem ja njemu da sam cuo da ide u njega paraflu i da se mesa sa destilovanom vodom pola pola a on ma to je prica za malu decu antifriz je antifriz.Razlika je u proizvodjacu i ceni a istu funkciju vrse. Quote Share this post Link to post Share on other sites
ivan.ik 625 Posted September 26, 2012 Menjaj majstora i antifriz i sipaj to što si čuo paraflu ili neki istih karakteristika. Quote Share this post Link to post Share on other sites
Ticma 537 Posted September 26, 2012 Ako pise paraflu sipa se paraflu! Quote Share this post Link to post Share on other sites
Hardvet 2 Posted September 26, 2012 Ili nesto od G12, predvidjeno za ALU hladnjake.Dakle, ispustaj to i sipaj sta je preporuceno. Quote Share this post Link to post Share on other sites
markom22 0 Posted February 13, 2013 (edited) Imam punto classic 1.2 8v, primetio sam da mi se od u septembru sam dolio nekih 150ml paraflu antifriz tecnosti, posto sam primetio da mi se spustio nivo vrlo malo ispod min...upravo sam primetio, posle nekih 5 meseci (oko 3000km uglavnom gradske voznje) da je se smanjio nivo na min, pa sam dolio otprilike 100ml...nisam primetio da mi curi nigde, niti da mesa sa uljem...da li je moguce da isparava? Edited February 13, 2013 by neshaoct prebačeno Quote Share this post Link to post Share on other sites
markom22 0 Posted February 13, 2013 Hvala Gusare! Quote Share this post Link to post Share on other sites
ivcha1979 0 Posted February 15, 2013 da se nadovezem sa slicnim problemom: naime antifriz mi negde curi,evo trazim vec 4 meseca odakle ali bezuspesno. to se obicno desava kada ugasim auto pa posle recimo sat vremena ostavlja dve flekice tacno ispod motora negde na sastavu motora i menjaca,sva creva suva svi spojevi ok,sve selne ok,a antifriza nema,dosipam pola case od 2 dl nedeljno,inace temperatura ok,zakucana na pola...inace dnevno prelazim po 50-60 km i nikakvih problema nema u vidu seckanja,trokiranja itd. jedan majstor mi rece da postoji mogucnost da neki konusni sigurnosni cep popustio na bloku motora pa se to desava,inace jedino moze da se vidi kad se skine menjac...jel imao neko slican problem i pitam za savet sta dalje? Quote Share this post Link to post Share on other sites
Gusar 4 Posted February 15, 2013 To sto ti je reko majstor popularno se naziva slepo oko... Proveri da li curi na kucistu termostata... Quote Share this post Link to post Share on other sites
MS PK 7732 Posted February 15, 2013 Proveri i da licuri na sastavu bloka i glave motora, to je vrlo cesta pojava kod punta, nekome dihtung probije na unutra a nekome na spolja, nista bitno se nemanja u voznji samo gubi tecnost pomalo a i to mozes da vidis tek kada je ugasen. Ako je do toga, probaj da sipas neko sredstvo za zaptivanje ili kada otopli razblazi antifriz. Quote Share this post Link to post Share on other sites
ivcha1979 0 Posted February 15, 2013 hvala na savetima,nije na kucistu termostata,nije na dihtungu,sve selne proverene,cak posle 2-3 sata podignem haubu proverim sastave,creva selne sve suvo,a ispod sastava motora i menjaca dve flekice od antifriza... Quote Share this post Link to post Share on other sites
MS PK 7732 Posted February 15, 2013 Slije se odozgo kod sastava motora i glave ali je to bas tanko i tesko se okom primeti, jedino kada gledas ispod auta vidi se kapka na samom sastavu motora i menjaca. Probaj prstom da opipas svude gde ide dihtung glave, kada je hladan auto i kada stoji malo duze. Obrati posebno paznju na deo prema menjacu ispod bobina. Nemora da znaci da je bas to kod tebe, nego samo pregledaj pazljivo. Quote Share this post Link to post Share on other sites
ivcha1979 0 Posted February 15, 2013 ok,hvala na savetima,obraticu paznju sutra ujutru pa javljam... pozz Quote Share this post Link to post Share on other sites
CrackFox 16 Posted June 11, 2013 (edited) Imam problem sa gubitkom vode u posudi za dolevanje. Motor cudno radi na leru ali preko 2000 ob se ponasa normalno , ne gubi na snazi. na auspuhu kad dajem gas izlazi beli dim tj vodenu paru, dlan mokar posle par sekundi drzanja na izduvu. Ulje na meracu je normalne boje ali na cepu je pozutelo, kao majonez. Sumnja se na dihtung glave pa me zanima koliko je to ozbiljan posao posto nisam u Srbiji a majstor iz komsiluka mi kaze da moze zamenuti dihtung antifriz i dest vodu za nekih 100e. Zanima me da li je obavezno ravnanje glave , struganje prilikom zamene dihtunga ili se moze samo dobro ocistiti kako mi majstor kaze. Da li u 99% slucajeva napukne glava pa se osteti dihtung ili moze biti i samo diht? Dajte mi neki savet koliko je ozbiljno ovo sve i sta je najbolje za ciniti. Punto mk.2 1.2 8v Pozdrav Edited June 12, 2013 by neshaoct spojeno Quote Share this post Link to post Share on other sites
Phikret 0 Posted June 11, 2013 Imao sam iste simptome i kod mene je zamenjen dihtung glave ali uz ravnanje iste. Nisam siguran da li ce moci bez ravnanja da se odradi. Nadam se da ce neko vec napisati. Quote Share this post Link to post Share on other sites
CrackFox 16 Posted June 11, 2013 Pa da , bojim se da bez rvnanja glave nece biti dugotrajno resen problemSamo da napomenem da kad upalim auto , kad je jos hladan , na povrsini posude gde se sipa voda izlaze mehurici. Sa druge strane kad je motor ugrejan creva koja vode iz i u hladnjak nisu pod pritiskom tj nisu tvrda. Mozda ovo jos nesto govori o ozbiljnosti i velicini kvara. Quote Share this post Link to post Share on other sites
Mijailović P. 3448 Posted June 11, 2013 Cek , cek zar ne bi trebalo da ima pritiska (povisenog) u crevima na ugrejan motor ako je negde probio zaptivac?Ovde mi nisu jasne neke stvari.Kakve su svecice? Zaprljane (garave) ili ... ? Quote Share this post Link to post Share on other sites
CrackFox 16 Posted June 11, 2013 nije motor jos rastavljen. pre 2 meseca je radjen veliki servis. Mozda ga nisam dovoljno ugrejao pre provere tvrdoce creva. radio je nepunih 5 min na leru. Quote Share this post Link to post Share on other sites
Phikret 0 Posted June 11, 2013 Trebalo bi duze da radi. I ako budu tvrda creva onda je sigurno dihtung. Ali i ovako ti je sigurno, cim baca beli dim i vodu! Quote Share this post Link to post Share on other sites
