ivan.ik 625 Posted July 4, 2012 Sreća više se ne slušaju ploče inače bilo bi strašnih stvari. Quote Share this post Link to post Share on other sites
Ticma 537 Posted July 4, 2012 Brate, kako si uspeo ovoda ubacis u ovoAhahahhahahahhaha Quote Share this post Link to post Share on other sites
milos66 39 Posted July 4, 2012 (edited) ja se izvinjavam u plejer sam stavio cd. Edited July 4, 2012 by milos66 nema potrebe za takvim recnikom Quote Share this post Link to post Share on other sites
podvarak 1 Posted July 4, 2012 Razjasnili smo o cemu se radi, sad bi mogli malo da se vratimo na topic ... Quote Share this post Link to post Share on other sites
milos66 39 Posted July 4, 2012 Razjasnili smo o cemu se radi, sad bi mogli malo da se vratimo na topic ... brate svaka cast za trud.. perfektno... ma iznervirao sma se preteruju ono ili se prave ludi znaju o cemu se radi.. ok i ja sam mozda pogresio u kuckanju al brate ilikazi ako znac o cemu se radi ili ticu... Quote Share this post Link to post Share on other sites
milos66 39 Posted July 4, 2012 Brate, kako si uspeo ovoda ubacis u ovomoja greska na plejer sam mislio .... Quote Share this post Link to post Share on other sites
Hardvet 2 Posted July 4, 2012 O tome ti i pricamo... Quote Share this post Link to post Share on other sites
milos66 39 Posted July 4, 2012 kapirao sam da nisu fazonu da smaraju... jel znas mozda resenje mog problema... Quote Share this post Link to post Share on other sites
Hardvet 2 Posted July 4, 2012 rečeno ti vadi kas ili šta je već napolje (dve do četiri igle ili dva nožića) malo hirurgije i sve sređeno. Da se više ne smejemo jedni drugima. Quote Share this post Link to post Share on other sites
milos66 39 Posted July 4, 2012 ok... ako mora nije tesko e pa hvala.. Quote Share this post Link to post Share on other sites
Hardvet 2 Posted July 4, 2012 Mora. Nema drugog resenja. I vise ga ne guraj...tu... Quote Share this post Link to post Share on other sites
milos66 39 Posted July 4, 2012 a jebiga,nas kad kupis auto pa te sve zanima dal radi... ))) Quote Share this post Link to post Share on other sites
kopecky 0 Posted November 9, 2013 Da li neko zna koje je snage player iz punta ? http://static.kupindoslike.com/CD-player-Fiat-Punto2_slika_L_6743113.jpg Quote Share this post Link to post Share on other sites
Axic 20041 Posted January 17, 2014 Kako mogu resetovati svoj fabrički Blaupunkt kasetaš koji sam dobio uz auto ? Od pre nekog vremena se dešava da kad ugasim kasetofon neprestano blinka svetlo oko onog točkića gde se pali/gasi kasetofon (prikazano na slici). Skinuo sam kleme sa auta, vratio ih posle 2 minuta, upalio kasetofon on pokaže na 2-3 sekundi SEARCH, ne potraži kod nego uključi radio ali se to sa neprestanim bliknanjem ponavlja. Onih 6 radio stanica koje su memorisane se ne obrišu uopšte. Ranije se fabrički gasio na 10 ili 15 minuta ukoliko zaboravim da ga ugasim a sad sam probao nekih 30-ak i više minuta i nije se sam ugasio. Inače imam kod za kasetofon. Šta mi je činiti, da li da probam da skinem džekove koji idu u kasetofon pa da na taj način probam da resetujem kasetofon i ubacim kod ili postoji i neki drugi način ? Quote Share this post Link to post Share on other sites
gile smederevo 574 Posted February 26, 2016 Je l' postoji nacin da se popravi dispelej kod Blaupunkt kasetasa u mk2? Fali poneka crtica. Mislim, malo me nervira jer ponekad ne mogu da provalim frekvenciju radio stanice. I jos jedna stvar-potenciometar za pojacavanje/smanjivanje ponekad se necka da radi. Je l ima tu neke pomoci ili samo zamena celog radia? Quote Share this post Link to post Share on other sites
Milutinac 5906 Posted February 26, 2016 (edited) Ista stvar kod mene...na navi uredjaju To je standardna boljka... Edited February 26, 2016 by Milutin-NS Quote Share this post Link to post Share on other sites
ivansd 13 Posted February 26, 2016 On 1/17/2014 at 8:52 PM, Axic said: jel provalio neko kako da se veze aux na ovakvom kasetasu? Quote Share this post Link to post Share on other sites
Axic 20041 Posted February 26, 2016 Ne znam da li je uopste izvodljivo. Skinuo sam ga i stavio neki Radio CD/mp3 plejer, ionako je na fabrickom poceo onaj ekrancic da zeza i da se sve manje vide slova i brojevi. Quote Share this post Link to post Share on other sites
ivansd 13 Posted February 26, 2016 ja kao ajde da ga ne menjam lepse je sa fabrickim, al moracu da ubacim sa usb-eom sto mi ostao iz mazde Quote Share this post Link to post Share on other sites
gile smederevo 574 Posted February 26, 2016 2 hours ago, ivansd said: jel provalio neko kako da se veze aux na ovakvom kasetasu? Ne moze. Ja probavao. Quote Share this post Link to post Share on other sites
Axic 20041 Posted February 26, 2016 Ja nisam jos probao na onom fabrickim CD Navi da ubacim CD charger sto mi je na Multijetu. Imam i cd charger i znam da bi morao da menjam centralnu konzolu zbog chargera ali nisam jos vadio CD Navi da vidim kako se povezuje pozadi i gde mu se nalazi taj dzek tj. gde treba da ga udzekujem. Quote Share this post Link to post Share on other sites
ivansd 13 Posted February 26, 2016 1 hour ago, gile smederevo said: Ne moze. Ja probavao. Znaci ipak ne moze petljao sam i ja nesto ali nisam uspeo reko mozda je do mene Quote Share this post Link to post Share on other sites
VozimFiat 1 Posted June 5, 2017 (edited) Na fabričkom CD plejeru u Puntu MK2 mi je stradao potenciometar/taster kojim se urađaj pali-gasi i pojačava zvuk.Dali neko zna kako se to tačno zove,eventualno oznaku,zamenski deo? Edited June 5, 2017 by VozimFiat Quote Share this post Link to post Share on other sites
