joshibeast 74 Posted July 7, 2015 Ja kapiram da oni iz predgrađa Bara idu stalno Quote Share this post Link to post Share on other sites
MS PK 7732 Posted July 7, 2015 Idu mestani sigurno, eventualno mozda neko iz Pg ali preko tunela Znam likove koji su islo po 100-tinak km u pravcu ali za takve destinacije nisam cuo Quote Share this post Link to post Share on other sites
beli_Punto 123 Posted July 7, 2015 Pa kad da stignes tamo? U oktobru? Quote Share this post Link to post Share on other sites
joshibeast 74 Posted July 7, 2015 Ja da krenem verovatno bih stigao do Meljaka negde i odustao u nekoj kafani Quote Share this post Link to post Share on other sites
MS PK 7732 Posted July 7, 2015 Ispalo bi ti ono kapce i pre toga jos Pa kad stignes jbg Skuter je za do prodavnice i za cigare i tako to ( 50cm3) ali zamlacuju se ljudi Quote Share this post Link to post Share on other sites
joshibeast 74 Posted July 7, 2015 Koliko cm3 toliko i kilometara u jednom pravcu Ne bi kapče spalo, sraslo je Quote Share this post Link to post Share on other sites
MS PK 7732 Posted July 7, 2015 Hahaha, sve si u pravu Quote Share this post Link to post Share on other sites
baron21 7 Posted July 7, 2015 Ja sam davno citao na nekom forumu, ne secam se tacno da li su isli ili se samo spremali, pokusacu kasnije da nadjem Quote Share this post Link to post Share on other sites
beli_Punto 123 Posted July 7, 2015 Mozda su krenuli Quote Share this post Link to post Share on other sites
Buca_Tipo 31 Posted July 7, 2015 Isla jedna budaletina iz Nisa, drugar inace, sa runnerom i stigo problema bez Quote Share this post Link to post Share on other sites
baron21 7 Posted July 7, 2015 (edited) http://forum.bjbikers.com/index.php?/topic/2550-na-more-skuterom-50-kubika/Evo za pocetak, ali sam citao pre o grupi ljudi Ja bih voleo da odem jednog dana, al sa npr nekim burgmanom 650 Edited July 7, 2015 by baron21 Quote Share this post Link to post Share on other sites
Markobgd 609 Posted July 7, 2015 (edited) Šure prodao svog Burgmana 650 pre metar dana. Odličan motor. Edited July 7, 2015 by Markobgd Quote Share this post Link to post Share on other sites
Ticma 537 Posted July 7, 2015 Burgman je nezgodan zato sto zahteva dobrog plasticara svaki put kad geknes Quote Share this post Link to post Share on other sites
gile smederevo 574 Posted July 7, 2015 Treba ti polozeno za E kategoriju!! Quote Share this post Link to post Share on other sites
srdjos 1602 Posted July 7, 2015 (edited) Bas, nista manje od E kategorije Burgman bas i nije za grad, bas je masivan. Sve zavisi ko sta hoce... Edited July 7, 2015 by srdjos Quote Share this post Link to post Share on other sites
Milos1 43 Posted July 10, 2015 (edited) Ja ne znam sta vidite u tim lezaljkama... skutere sam naravno vozio dok nisam dosao do prvog motora... ne vozio nego i tunirao, jedan piaggio free punio do 100ke za oko 8sec(a setup izmedju base i mid race, zamislite tek neki high end), ali su to bili "nervozni" laki a jaki i zanimljivi skutercici koje je bilo uzivanje voziti, stelovati i popravljati, kad je dosla prva 125ica sa menjacem nisam se vise pronalazio u skuterima.Kod motora sa menjacem jednostavno potpuno kontrolisem motor koji vozim tj. na obrtajima koje ja zelim a ne onim koje sam izabrao kad sam kupovao rolnice ili kontra oprugu(za skutere) Obucavao sam se za A2 na jednom piaggio X9 500 a morao da polazem u drugom gradu pa i drugog X9 vozikao da upoznam grad i jednostavno ja ne bih ni svog kineza 125cc(prethnodno inace yamaha 125cc a trenutno yamaha 600 i kinez keeway speed) sa menjacem dao za taj ultra mega giga skutere velike kubikaze.... ko ne deli moje misljenje....pozdravljam to, ali razmislite jos jednom tj isprobajte Edited July 10, 2015 by Milos1 Quote Share this post Link to post Share on other sites
srdjos 1602 Posted July 10, 2015 Ima tu jedna velika razlika, ti si već vozio skutere pa si se ispraksao, a mi matori koji u 38-oj tek sedamo na motor, idemo laganijim putem A opet, zavisi šta ciljaš, ja recimo ciljam prvenstveno gradsku vožnju a tu ti je CVT zakon (a hoću i sledeći auto da mi bude automatik) Slažem se s tobom oko jednog, za veće kubikaže bolje motor no skuter. Po meni, skuter do 300cm2, sve posle ozbiljan motor. Quote Share this post Link to post Share on other sites
Markobgd 609 Posted July 10, 2015 (edited) A ima i ona druga strana...Recimo šurak je terao uglavnom 750ke i 1000rke godinama a sad preferira velike skutere (tipa Burgmana) jer sa suprugom zna se provoza često.... Edited July 10, 2015 by Markobgd Quote Share this post Link to post Share on other sites
srdjos 1602 Posted July 10, 2015 To ide s godinama, što si stariji, manje si napaljen za divljanja a više uživaš u vožnji Quote Share this post Link to post Share on other sites
Zvezdo 991 Posted July 10, 2015 Zbog toga na choper i polako i opušteno!Samo što choper nije za grad. Quote Share this post Link to post Share on other sites
Ticma 537 Posted July 10, 2015 Jeste choper za grad kako nije, samo kulijana Ja gledam nesto do max 80ks posto sam pocetnik a sto se tice motora nemam neku zelju za divljanjem, za to sluze 4 tocka Quote Share this post Link to post Share on other sites
Zvezdo 991 Posted July 10, 2015 Sa choperom moraš stati u red pred semaforom kao i svi sa autima dok se sa skuterom (ili kako sam ja to svojevremeno nazivao "pokretna wc šolja") možeš provući između auta i krenuti prvi. To je prednost skutera u gradu. Ne kažem da se sa choperom ili drugim motorom ne može ali meni lično je bez veze. Inače kada sam na 4 točka ne volim kada se netko provlači sa leve strane pa to ne radim nikada kada sam na dva. Quote Share this post Link to post Share on other sites
Ticma 537 Posted July 10, 2015 Ne kupujem motor radi provlacenja izmedju kola na semaforu nego radi uzivanja Naravno ima tu i nekih prednosti ali uzivanje na prvom mestu Quote Share this post Link to post Share on other sites
Zvezdo 991 Posted July 10, 2015 E sad 80ks nije malo! Znam jednog koji je sa 50ccm odmah seo na 1000ccm i živ je i zdrav pored nekoliko padova,nažalost mnoge sam znao da to nisu uspeli. Čuvaj se!Ako je za uživanje onda sasvim druga stvar! Choper,otvoren put i to je život! Krstariš 50 Km na sat i opušteno! Quote Share this post Link to post Share on other sites
