Goran Zemun 441 Posted April 4, 2012 Imam, donesi uzorke kada rasturis menjac pa cemo da vidimo. Quote Share this post Link to post Share on other sites
ranko mitic 0 Posted April 6, 2012 pa ja sam iz Niša, ali javiću kada vidim šta zeza pa možemo da dogovorimo oko slanja ako matematika bude odgovarala i tebi i meni. Quote Share this post Link to post Share on other sites
aca novicic 0 Posted April 28, 2012 (edited) kada vozim auto uzbrdo u 3 brzini desava se da menjac pocne da uji i da zavija i cim prebacim u 2 brzinu taj cudan zvuk prestane ,obicno pocne da se cuje ujanje na pola neke velike uzbrdice pa sam zakljucio da kada je veliko opterecenje manjaca u trecoj brzini nesto nije u redu. Zna li neko sta moze da bude da mozda mu ne hvali ulja u menjacu? Edited April 28, 2012 by neshaoct spojeno Quote Share this post Link to post Share on other sites
neshaoct 9591 Posted April 28, 2012 Baci pogled i ovde:http://www.fiat-lancia.org.rs/forum/index.php?showtopic=47782 Quote Share this post Link to post Share on other sites
Zoranic MNE 0 Posted May 21, 2012 ljudi zna li ko koliko ide litara ulja u mjenjac na Punta 1.9 JTD?ocu da mjenjam ulje al ne znam koliko litara da narucim,posto bi da kupim onu Tutelu fabricki sto ide... ? Quote Share this post Link to post Share on other sites
neshaoct 9591 Posted May 21, 2012 Ova tema:http://www.fiat-lancia.org.rs/forum/index.php?showtopic=33480 Quote Share this post Link to post Share on other sites
milos21 0 Posted December 10, 2012 pozdrav,interesuje me zasto se menjac zamrzo ne pomera se uopate sta da radim? hvala Quote Share this post Link to post Share on other sites
Ticma 535 Posted December 10, 2012 Pokusaj da ga zagrejes u mestu dok je izbacen iz brzine, moguce da je ulje matoro i da se steglo zbog niske temperature. Quote Share this post Link to post Share on other sites
MS PK 7729 Posted December 10, 2012 Ili su nekako sajle zaledile? Quote Share this post Link to post Share on other sites
nikola01 0 Posted January 20, 2013 imam problem u pitanju je punto 1.9 d 2001 god ,menjac krci kada prebacujem iz pete u cetvrtu brzinu ne znam da li je otisao neki sinhron i da li bi pomogao neki aditiv da ga sipam!!!! Quote Share this post Link to post Share on other sites
MS PK 7729 Posted January 20, 2013 Ako je sinhron tesko ali nista neces izgubiti da probas tj. nece da skodi, samo gledaj da je odgovarajuci tvome ulju Quote Share this post Link to post Share on other sites
Ticma 535 Posted January 21, 2013 Nema tu aditiva koji moze da ti resi problem, vracaj ga sporije iz 5 u 4 kako bi zupcanik imao vremena da se zaleti ili skidaj menjac i menjaj sinhron. Quote Share this post Link to post Share on other sites
medobrundo 1 Posted May 5, 2013 Već neko vreme na puntu 2 jtd 80 ks imam problem sa prebacivanjem iz 4. u 3. brzinu. Jednostavno, ne ide glatko u 3. uvek, a nekad vratim u 4. pa ponovo spustim u 3. i onda prodje. U principu, ne smeta mi mnogo (jer auto vozi žena, a ja samo ponekad po gradu), ali jednostavno ne volim takve stvari. Pošto žene po pravilu više mlate sa kvačilom osetio sam da pri polasku malo trese i kapiram da je korpa. Nekako u isto vreme se počelo dešavati ovo sa menjačem, ali ne smem 100 % da tvrdim da je istovremeno jer ne vozim auto svakodnevno. Da li je moguće da su ove dve stvari povezane? Ima li neko ideju šta je problem? Quote Share this post Link to post Share on other sites
Denis891 11 Posted November 24, 2019 (edited) Pozz Zanima me koju gradaciju ulja sipati u menjac na 1.9ds? Otisla mi leva manzetna do menjaca i tu curi ulje i fali ulja e sad bio sam u nekoliko radnji i u svakoj sam po katalogu dobio razlicit odgovor u sp sportu 75 85 u kit komercu 75 90 u jednoj drugoj radnji 75 80 i sad ne znam koje ulje da dolijem a da necrkne menjac Nudili su mi i neko venol u top auto 75 90 ali je gl4 specifikacija a meni valjda treba gl5- kako mi je reko majistor Necu da menjam ocu da dolijem Edited November 29, 2019 by neshaoct spojeno Quote Share this post Link to post Share on other sites
neshtry 14790 Posted November 24, 2019 @Ivan zna 1 BGMilos reacted to this Quote Share this post Link to post Share on other sites
Axic 19989 Posted November 24, 2019 4 minutes ago, Denis891 said: Pozz Zanima me koju gradaciju ulja sipati u menjac na 1.9ds? Otisla mi leva manzetna do menjaca i tu curi ulje i fali ulja e sad bio sam u nekoliko radnji i u svakoj sam po katalogu dobio razlicit odgovor u sp sportu 75 85 u kit komercu 75 90 u jednoj drugoj radnji 75 80 i sad ne znam koje ulje da dolijem a da necrkne menjac Nudili su mi i neko venol u top auto 75 90 ali je gl4 specifikacija a meni valjda treba gl5- kako mi je reko majistor Necu da menjam ocu da dolijem Tutela 75w85 kao sa slike, skoro sam menjao i bolje i ti zameni a ne samo da dolijes jer ionako nije neki izdatak a vredi jer je pitanje da li je iko pre tebe menjao. 1 neshaoct reacted to this Quote Share this post Link to post Share on other sites
Denis891 11 Posted November 24, 2019 Menjano je pre 2 god ali sam izgubio papir pa nemogu se setim koje ide mislio sam da zamenim cak mislim da je kod mene 75 90 al nisam siguran Quote Share this post Link to post Share on other sites
Axic 19989 Posted November 24, 2019 @Denis891najgore bi bilo da pomesas gradacije ako nisi siguran sta je prethodno sipano. Bolje naspes novo po fabrickoj preporuci i ne razmisljaj za 15€ (2L) sta bi bilo ako bi dosipao ovo ili ono. Quote Share this post Link to post Share on other sites
Denis891 11 Posted November 24, 2019 Tako cu i da uradim mada mislim da cu mozda morati da menjam menjac na manzetni malo slini al kasno sam primetio i kad je auto u brzini podignem ga na dizalicu i na kanal i kad krenem tocak da pomeram napred nazad cuje se nesto da cakce u menjacu pa ako nista izvadicu ga posle pa cu sipati u drugi menjac znaci ide tacno 2l? 1 BGMilos reacted to this Quote Share this post Link to post Share on other sites
Axic 19989 Posted November 24, 2019 Malo manje od 2L ali imaj u rezervi ostatak. Quote Share this post Link to post Share on other sites
