shortee 243 Posted August 16, 2015 Ma kolega opusteno tako je to kad se popije ☺☺☺ nego nasao sam neki od 15a jel nije problem da turim taj za sad dok ne nadjem od 20a..? Verujem da ne moze nista da skodi mozda ce tel samo slabije da se puni .... Quote Share this post Link to post Share on other sites
Axic 19728 Posted August 16, 2015 (edited) Bolje da sutra negde kupis rezervne osigurace i stavis preporucenu jacinu. Inace onaj od 7.5 A iznad sto sam prvobitno obelezio jeste za upaljac, tj. samo za osvetljenje upaljaca. Edited August 16, 2015 by Axic Quote Share this post Link to post Share on other sites
MS PK 7718 Posted August 16, 2015 Nece nista da mu fali Quote Share this post Link to post Share on other sites
shortee 243 Posted August 18, 2015 Ap sport 115din komplet osiguraca Quote Share this post Link to post Share on other sites
rage_man 128 Posted May 16, 2016 Ima li neko raspored osiguraca za 1.2 8v, konkretno treba mi za zadnji levi far Sent from my GT-I9305 using Tapatalk Quote Share this post Link to post Share on other sites
Timotije 2 Posted May 16, 2016 (edited) Šta ti je zadnji levi far? Stop svetlo? To je osigurač f37. Ako misliš na rikverc svetlo, to ti je f31. Ovo je šema. Edited May 16, 2016 by Timotije Ubačena slika Quote Share this post Link to post Share on other sites
rage_man 128 Posted May 16, 2016 Da, stop svetlo, ne radi mi pozicija i stop, samo migavac. Rikverc svetlo mi je na desnoj strani Sent from my GT-I9305 using Tapatalk Quote Share this post Link to post Share on other sites
rage_man 128 Posted May 17, 2016 Resio problem, nije bio u pitanju osigurac, vec kontakti, ocistio i sad sve radi, u svakom slucaju hvala na pomoci Sent from my GT-I9305 using Tapatalk Quote Share this post Link to post Share on other sites
Bojssa 66 Posted June 13, 2021 (edited) Neka preporuka iz iskustva, šta bih trebao prekontrolisati? Dešava mi se u zadnjih mesec dana da mi već treći put crkava osigurač od ventilatora kabine. Prvi put mi se desilo kada sam probao da upalim klimu koja mu inače ne radi od kako sam ga kupio. Bivsa vlasnica mi je odmah rekla da je nije ni koristila a da ne radi.Hteo sam da vidim da li se ispraznila i da li se barem čuje kompresor u radu. Stisnuo prekidač ka unutra, zasvetlela ona lampica ali ništa ne čuh. Vratim u standardan položaj, vidim ne duva ni na ventilator, proverim, vidim u kutiji izgoreo mu onaj osigurač od 30A. Zamenim osigurač, ventilator normalno duva. Više nisam čačkao oko prekidača u položaju klime ali sledeća dva puta nakon toga mi se opet desilo da ventilator sam prestane da duva. Ja zamenim osigurač, ventilator duva normalno. Jel imao ko sličan problem? Da li je moguće da mu sam prekidač pravi kakav kratak spoj ili je nešto do kompresora, koji čini mi se i ne radi tj. kada sam ga palio nisam čuo bilo kakav šum niti promenu broja obrtaja motora osim što zasvetli lampica!? Edited June 13, 2021 by Bojssa Quote Share this post Link to post Share on other sites
Bojssa 66 Posted June 23, 2021 Opet stao ventilator, crkao osigurač. Nedelju dana je radio normalno jer ga nisam ni akao, postavio na 2 i ostavio da duva. Žena juče vozila ceo dan i vrtela prekidač, jutros vidim opet crkao... Smrdi mi kao da je nešto do samog prekidača, da pravi neki kuršlus. Jel jednostavna zamena ili bolje da ne čačkam? Quote Share this post Link to post Share on other sites
ISV_01 3997 Posted June 23, 2021 Lici na neki kratak spoj pa sagori osigurac. Il elektricar ili kod majstora za klime, mozda i sama klima pravi problem jer ne radi. 1 Bojssa reacted to this Quote Share this post Link to post Share on other sites
Bojssa 66 Posted July 7, 2021 Za nekoga ko bude imao sličan problem kao moj sa pregorevanjem osigurača ventilatora, bio sam kod auto električara i reče motorčić ventilatora mu je otišao, kako sam ga razumeo iako radi, vuče jaču struju i pregoreva osigurač. A za klimu reče da ne radi jer je prazna. Rekoh pa ne daje nikakav znak života kada je uključim, kaže zato jer je skroz prazna, ok je kompresor. . . Quote Share this post Link to post Share on other sites
