Kuvalja 406 Posted February 20, 2015 Tako je, HX7 10w40. Quote Share this post Link to post Share on other sites
paun 1 Posted February 20, 2015 @SikterBre ima Shell i u servisu,pre neki dan sam svracao za termostat,ali nisu imali za moj auto i pitam za shell.Kaze onaj da ga imaju na tocenje a cena ispod 500 din po litru.Doneses svoju ambalazu i sipaju,cak mi rece da ga forsiraju kada rade servise. Quote Share this post Link to post Share on other sites
SikterBre 31 Posted February 20, 2015 Tako je, a nije neki krš, ja sam istovarao kombi kada je stiglo u burićima.. Dobio sam i Ferari kačket i privezak uz sve to.. Quote Share this post Link to post Share on other sites
Ticma 533 Posted February 20, 2015 I upalu misica Quote Share this post Link to post Share on other sites
Kuvalja 406 Posted February 20, 2015 Sve je dobro dok nije imao upalu pisica Quote Share this post Link to post Share on other sites
Markoni Bg 74 Posted February 20, 2015 Na prošlom servisu sam sipao Shell helix ultra 5w40 , a sada cu hx7 c 5w40 razlika je u tome što je ultra ful sintetika i oba imaju fiat odobrenje , i čini mi se da pri niskim temperaturama lakše startuje i tiši je motor i posle 7-8000km u odnosu na seleniu. Quote Share this post Link to post Share on other sites
mitros 139 Posted March 2, 2015 Ajmo sad da vidimo.Kupio sam ga (Punto II;1,2;16v;dec.2000.).pre skoro 5 godina i tada uradio veliki servis.Od tada presao oko 7000km.Sta bi po vama (i dal bi) nesto trebao uraditi sto se tice nekog servisa. Garaziran sve vreme.Po kisi i snegu vozen,samo ako je bila velika potreba.Potrosnja po kompjuteru oko 8L u gradu,na putu 6-6,5L. p.s.molio bi ako moze bez komentara tipa: "Sta ce tebi auto" ili "Uzmi taxi" i sl. Pozdrav i hvala. Quote Share this post Link to post Share on other sites
Buca_Tipo 31 Posted March 2, 2015 Interesantno pitanje, ali odradi mu mali servis plus zupcasti, pumpa bi trebala da je ok, a nadam se i spaner. Jel nije promenio neki zvuk? Quote Share this post Link to post Share on other sites
Markobgd 609 Posted March 2, 2015 Slažem se sa kolegom. Kaiš čisto iz razloga što se isposti a nije skup pa da ne razmišljaš i rizikuješ. Quote Share this post Link to post Share on other sites
jkovacevic88 0 Posted March 4, 2015 Koliko kosta veliki i mali servis za fiat punto 1.9 jtd 2002 godiste ? Quote Share this post Link to post Share on other sites
Axic 19716 Posted March 5, 2015 Mozes pogledati npr. ovde koliko bi ispao veliki servis bez ulja. http://www.ap-sport.rs/prodavnica/index.php?dispatch=products.view&product_id=40697 Quote Share this post Link to post Share on other sites
cileee 1 Posted March 24, 2015 Posto sam nov sa benzincima, na koliko se radi veliki a na koliko mali servis/i na 1.2 8V motoru? Quote Share this post Link to post Share on other sites
Martini 11 Posted March 24, 2015 Mali radi na 10000 a veliki na 60-70000, iako fabrika propisuje vece intervale. Quote Share this post Link to post Share on other sites
Dimitrijus 3 Posted May 24, 2015 Imam u planu veliki servis... ovlašćeni servisi meni najbliži ... KG i Niš.. u KG ima 2 a Niš ima samo 1... a i čuo sam za dr Fiat isto Niš.. ali on nije ovlašćeni servis ... ali ima dobre preporuke... potrebna mi je pomoć kolega iz ovih gradova da preporuče neki od servisa... ovih ili nekih drugih.. u Boru nema tako većih servisa ... a hteo bih proveru celog auta.. što ovde ne može da se odradi... Quote Share this post Link to post Share on other sites
Buca_Tipo 31 Posted May 24, 2015 Auto MIG je ovlasceni za Nis, znaju da biju po usima Ja saradjujem sa EURO018 i ukoliko kupis delove kod njih i ugradis ih kod njih, dobijas i garanciju na 50.000km ako se ne varam. Zakazes jedan dan dodjea i odrade taj isti dan. Naravno Maksa (glavni serviser) moze da ti pretrese auto ukoliko zelis Quote Share this post Link to post Share on other sites
Dimitrijus 3 Posted May 24, 2015 Koliko li košta sve to... i to pretresanje... i kakve delove nabavlja? Quote Share this post Link to post Share on other sites
Buca_Tipo 31 Posted May 24, 2015 Oni drze radnju sa delovima. Uglavnom za italijanska vozila.Kupujem kod njih delove i kada je u pitanju veliki servis ne stede, ali uopste, znaci iskljucivo skf spanere, pumpe, conti kaise, uostalom sve kosta. Mogu sutra da ti se raspitam. Eno pogledaj u mojoj temi koje sam delove stavljao sada kada sam radio v servis i svasta nesto jos. Na njihovoj preporuci i ladno su mi rekli posle 4god da pocnem da razmisljam o zameni seta, kaze mozes i slobodno za 4god da predjem 80.000 nema nikakvih problema. Quote Share this post Link to post Share on other sites
Dimitrijus 3 Posted May 24, 2015 Fino to za delove a na koju temu misliš? Mora za 4 godine da se menja... pa ja ne prelazim toliko... možda 10-11 hiljada ... A tvoja tema... sad ukapirah.... Quote Share this post Link to post Share on other sites
Buca_Tipo 31 Posted May 24, 2015 Ja prolazim malo vise od tebe Od 15-18.000 zavisi kako kad. Ti taman za tvoju km si miran skoro 5godina. Znam da kad sam pitao za Micu MS PK za njegov stilo je cena za rad bila 2500din a na druga mesta od 4-5.000. I i da bi dobio garanciju treba da se odradi kod njih u servisu.Kolega @majkicbane odrzava kola kod njih i moze i on da ti prenese iskustvo sa njima.Gazda mi sam kaze kad je u pitanju veliki servis ne igram se sa delovima. Uvek kvalitetno stavlja jer nece da ga boli glava Quote Share this post Link to post Share on other sites
Dimitrijus 3 Posted May 24, 2015 Pa ja po gradu slabo a mali je ovo grad... svu kilometražu sakupim na putu za GR i DE... i idemo porodično tako da se malo plašim za te delove.. da mi se ne desi neki kvar negde u nedođiji a ja sa klincem... ako me razumeš... ali ako ljudi kažu da su ok ... onda sam za... Quote Share this post Link to post Share on other sites
Buca_Tipo 31 Posted May 24, 2015 Ne ide da te ubedjujem. Za svoje pare mozes gde hoces da kupis i ugradiis Firma u kojoj radim sve od njih uzima delove, evo vec cetvrta god kako ja znam za njih i otuda i mene kod njih A vozni park nam je raznolik, 5 punta mjet + corsa, doblo, caddy, sprinteri, iveco... Svasta nesto Quote Share this post Link to post Share on other sites
Dimitrijus 3 Posted May 24, 2015 Hvala tebi.... a odavno nisam jeo burek kod Nene i ..... zaboravih ime... ida se podsetim šetnje... sad sam oženjen pa ne smem da kažem sa kim... Quote Share this post Link to post Share on other sites
Buca_Tipo 31 Posted May 24, 2015 Hmmm Nene i Zokija burek, mislim da si tu jeo dobru pljesku A kod Micka dobar burek. Blizu su jedan do drugog.Da ne bude skroz off reci mi koj ti bese motor imas pa da pitam sutra ili hoces da ti dam broj? Quote Share this post Link to post Share on other sites
