markosdbg 0 Posted April 11, 2014 Malopre sam zvao za pve Bilstein i pitao da li su uljni,gasni.... itd. Kaze mi decko da su gasni. Koliko su oni dobri,sta mislite? Quote Share this post Link to post Share on other sites
Multijet forever 0 Posted April 11, 2014 Sad skoro svi imaju gasne, uljni zimi hoce neki put da stegnu kad je veci minus pa im treba vremena da prorade... Ja bi pre uzeo gasne. Quote Share this post Link to post Share on other sites
markosdbg 0 Posted April 11, 2014 Pa znaci mogao bih da uzmem te amortizere? Quote Share this post Link to post Share on other sites
Multijet forever 0 Posted April 11, 2014 (edited) Slobodno, to je ok cifra, pa koliko traju, traju. A i imas garanciju. Edited April 11, 2014 by Multijet forever Quote Share this post Link to post Share on other sites
YUgisa 2528 Posted April 11, 2014 Gasni su mnogo bolji od uljnih u svim aspektima Quote Share this post Link to post Share on other sites
markosdbg 0 Posted April 11, 2014 Ok drugari,hvala vam puno.Ipak je bolje proveriti sa ljudima koji su imali iskustva.Od ponedeljka ce pasti Bilstein za Puntica Quote Share this post Link to post Share on other sites
majstormica 25 Posted June 25, 2014 Jel si zamenio amortizere, sta si stavio, koja cena, kakvi su utisci...? Quote Share this post Link to post Share on other sites
markosdbg 0 Posted June 25, 2014 Stavio sam Bilstein pre 2 nedelje. Cena je bila 3300 po komadu. Zadovoljan sam rezultatom, dosta je stabilniji u krivinama i nema onih tupih udaraca pozadi, kad se naleti na neku rupu. Znaci, nije ono made in P.R.C. I ostalo, bas Nemacka pravi. Odlicno je za sada. 2 godine garancije sam dobio. Quote Share this post Link to post Share on other sites
majstormica 25 Posted June 26, 2014 Jel ti to cena za zadnje?Ja sam danas uzeo KYB Exel-G. Prednji 4400, zadnji 2600, i solje 1300. Quote Share this post Link to post Share on other sites
markosdbg 0 Posted June 26, 2014 Da, za zadnje amortizere. U pitanju su gasni. Quote Share this post Link to post Share on other sites
Rile_bg 347 Posted June 26, 2014 mico,gde si uzeo zadnje za te pare? kad sam zvao gazelu rekli su mi da su 3800 (zadnji) Quote Share this post Link to post Share on other sites
majstormica 25 Posted June 26, 2014 (edited) Kod drugara u Surcinu, doduse rece da mi je zadnje dao malo jeftinije, ne znam koliko su inace. Znaci dobro sam prosao Edited June 26, 2014 by majstormica Quote Share this post Link to post Share on other sites
nikolakonatar 1 Posted September 23, 2014 kupio sam polovne amortizere sportske za punta sa oprugama kad sam ih sklopio opruge nisu ni malo pod opterecenjem cak imaju i mali luft, decko od koga sam kupio kaze kad ih namontiram da ce da nalegne od tezine auta, ne znam koliko mi je to sigurno tako da namestim amortizere ili da stavim moje fabricke opruge na te amortizere i tako montiram. vrlo bi mi dobrodosao svaki savet.... Quote Share this post Link to post Share on other sites
YUgisa 2528 Posted September 23, 2014 Moje iskustvo da tako kad landara opruga jednostavno uvek se pomera pa se izmesti iz lezista jeste ona nalegla skroz pod tezinom auta ali kad se penjes na ivicnjake, prelazis preko rupa, sina i slicnih stvari desi se nekad da se izvuce amortizer skroz i pomeri se opruga... Mada ce ti vecina ljudi tvrditi da se ovo sto sam ja sad rekao ne desava i da oni nemaju nikakvih problema i da se njima nikad ne desi da se izvuce skroz amortizer i pomeri opruga pa na tebi je da odlucis kome ces da verujes... Resenje ti je da nadjes nekog stugara koji ce ti skratiti osovinu/klip amortizera u toj meri da ne landara opruga... E sad ono sto je problem tu je da ako te opruge vec sad landaraju, pitanje je kako one zaista funkcionisu sa tim amortizerima jer nije bitno samo da opruga ne landara... Sad pitanje je sta se tacno moze uraditi da se to dovede u redovno stanje ako postoji neki problem. Opet ako su ti amortizeri kraci od fabrickih samo ne dovoljno kratki za te opruge mozda ce biti amortizeri prekratki za fabricke opruge tako da ti ni to nije resenje na koje se mozes 100% osloniti... Usustini ja bih ti znao reci sta i kako kad bih to mogao licno da vidim, ovako na nevidjeno je nemoguce pa sad ti ostaje da reskiras ili da slusas neki drugi savet i da se nadas da je sve super Quote Share this post Link to post Share on other sites
banjo1990 264 Posted September 23, 2014 Ukratko, ako nemaš drugog izbora, stavi tako. Kod jednog drugara je bio isti slučaj, i on tvrdi da nije imao problema. Ja lično, kada bih unapred znao da je takva situacija, ne bi ih stavljao, jer tu definitivno nije pogođena prava kombinacija opruge i amortizera. Tu je pitanje i da li je odgovarajuća kombinacija same krutosti opruge i amortizera. U svakom slučaju, ako ti je kasno da odustaneš od te varijante i nađeš bolju, stavi ih tako. Quote Share this post Link to post Share on other sites
nikolakonatar 1 Posted September 24, 2014 ok drustvo, hvala za savete. Probacu da ih stavim tako pa cemo videti, ako ne bude kako treba ili bude previse nizak iskombinovacu sa standardnim oprugma Quote Share this post Link to post Share on other sites
BULE JTD 0 Posted November 8, 2014 Pozdrav svima...mozda sam u pogresnoj temi ali moram da pitam...jel zna neko gde mogu da spustim punta mk2?Komplet napred i pozadi sa sve amortizerima. Hvala unapred Quote Share this post Link to post Share on other sites
YUgisa 2528 Posted November 8, 2014 Kupis opruge i amortizere i odes kod automehanicara Quote Share this post Link to post Share on other sites
vicent 1263 Posted November 8, 2014 (edited) Ako imaš entuzijazma,bar nekog iskustva i alata,možeš i sam. Treba ti par ključeva (8,10,13,17,19,24 i možda 28, alat za sabijanje opruga, tzv MAČKA ili Papagaj),neko da ti pripomogne, i uštedećeš 50-ak eur.Mlađi sin je kupio Polo-a (nekada Alfa 145),za smešne pare je kupio FKS opruge i amortizere,pa smo u 3 dana, 4 puta skidali i montirali sva 4 amortizera. Prva demontaža-montaža je trajala 2 sata, a poslednja 45min. http://postimg.org/gallery/93g7vxu8/ Edited November 8, 2014 by vicent Quote Share this post Link to post Share on other sites
DRAGANCE 21 Posted November 16, 2014 (edited) od alata mi treba gedore 17 , 19 ,27 i kljuc 15 ,naravno i mackice, to je sve da bi se demontirali amorizeri (prednji i zadnji) na puntu 2 Edited November 16, 2014 by DRAGANCE Quote Share this post Link to post Share on other sites
vicent 1263 Posted November 16, 2014 Tako je! Quote Share this post Link to post Share on other sites
beli_Punto 123 Posted November 16, 2014 (edited) Sta su mackice? Edit: Sad sam procitao gornji Vicentov post Edited November 16, 2014 by beli_Punto Quote Share this post Link to post Share on other sites
vicent 1263 Posted November 16, 2014 Alat za sabijanje opruga! Za fabričke su neophodne,a za tvrde,skraćene, možda i ne treba! Quote Share this post Link to post Share on other sites
Rile_bg 347 Posted November 16, 2014 Bas lep polo,sredjen taman koliko treba :-) Quote Share this post Link to post Share on other sites
vicent 1263 Posted November 17, 2014 Hvala Rile. Quote Share this post Link to post Share on other sites
