djomla 8386 Posted November 23, 2017 Ovo matoro u pm Sent from my 3310 Quote Share this post Link to post Share on other sites
Ivan 17593 Posted November 23, 2017 (edited) 3 hours ago, rocket said: Kebina pesma... U mog strica osam kobasica, sedam przi, osmu strina drzi . Edited November 23, 2017 by Ivan 1 rocket reacted to this Quote Share this post Link to post Share on other sites
djomla 8386 Posted November 23, 2017 Hahahhahahaha, a ja hteo da budem fin i iskulirao taj hit Sent from my 3310 Quote Share this post Link to post Share on other sites
Gogica 0 Posted February 1, 2018 Može li neka preporuka za amortizere? Unapred hvala... Quote Share this post Link to post Share on other sites
neshaoct 9591 Posted February 1, 2018 @Gogica Imamo temu o amortizerima, tj. iskustvima sa njima, pogledaj: https://www.fiat-lancia.org.rs/forum/index.php?/topic/43947-iskustva-sa-amortizerima/ Možeš da je čitaš od početka (2008. godina), il' možda je bolje da pogledaš upise u poslednjih barem par godina. Quote Share this post Link to post Share on other sites
Gogica 0 Posted February 2, 2018 @neshaoct Hvala, pogledaću Quote Share this post Link to post Share on other sites
vojke 1 Posted February 13, 2018 Pozdrav drustvo, Fiat Stilo 1.9 JTD 85kw 2001. Da li sam to umislio ili je nesto u pitanju nisam siguran, kod desnog prednjeg tocka kad se sagnem skroz blizu cuje se onako kao sistanje ssssssssss,kao kad guma pusta (samo dosta slabije od toga se cuje nego cisto da vam opisem tip zvuka ) Da li je to normalno? Mozda nisam obracao paznju ranije,mozda je to tako bilo uvek,ali cisto da vas pitam i proverim. Nemam problema sa autom,ide kao i uvek,znaci nikakve promene. Hvala Quote Share this post Link to post Share on other sites
Ivan 17593 Posted February 13, 2018 Opisi malo detaljnije, u kojim uslovima se tacno javlja, menja li intenzitet (najbolje snimi)... Pa da prebacimo u odgovarajucu temu, pretpostavljam da nema veze sa trapom . Quote Share this post Link to post Share on other sites
vojke 1 Posted February 13, 2018 Nisam imao predstavu gde da stavim pitanje upalim auto i odmah se cuje, bez obzira vozio 20km ili tek sto sam ga upalio,ne znam kako bih opisao detaljnije , kao kad ispustate vazduh iz gume samo dosta blazi zvuk i ujednacen,istog intenziteta i to samo kad se priblizim bas desnom prednjem tocku. Mozda jos eto slicno kao kad isparava voda recimo,ali ne gubi tecnost nista, isti je nivo. Ako to nije dovoljno probacu snimiti pa mozda bude detaljnije,tj nadam se da ce se cuti uopste od rada motora. Quote Share this post Link to post Share on other sites
vojke 1 Posted February 18, 2018 Pozdrav, evo snimak zvuka ,a objasnjenje 2 posta gore Quote Share this post Link to post Share on other sites
MS PK 7729 Posted February 18, 2018 Skini pk kajs pa probaj bez njegaПослато са SM-J320FN уз помоћ Тапатока Quote Share this post Link to post Share on other sites
Gogica 0 Posted February 25, 2018 Juče sam stavio napred nove amortizere ( Monro ), i sredio viljuške. Stavljeni su puni silen blokovi od astre f. Kao da je drugi auto. Quote Share this post Link to post Share on other sites
milos16v 0 Posted June 1, 2018 Pozdrav ljudi, Imam problem sa nekom nepodnosljivom skripom koja dolazi negde iz predela desnog prednjeg tocka. Prosle godine je odradjen kompletan trap i ova uzasna skripa se desava drugo let zaredom. Sto je zanimljivo samo leti se cuje, po visim temperaturama. Kao neki metal o metal da grebe, jeziva skripa i najvise se cuje po blagim neravninama i sporijoj voznji. Zamenjene solje pre dve nedelje i nista, sve isto. Majstor hvala Bogu kad ne zna sta je kaze "ma sve je u redu". Pomagajte, mrzim ovakve kvarove gde ne znas ni sta ni kako ni zasto se desava. Quote Share this post Link to post Share on other sites
djomla 8386 Posted June 1, 2018 Vrlo jednostavno, promeni majstora. Oteraj auto kod valjanog trapadžije i reši problem. Sent from my 3310 Quote Share this post Link to post Share on other sites
Nmilan85 0 Posted June 14, 2018 zdravo forumasi...pre godinu dana sam kupio stilo,sto je dovoljno da se upoznam sa svim njegovim manama.Zadnja koja me brine je ta,da kad okrenem skroz desno ili levo tockove i krenem u rikverc cijem odredjeno puckanje ili pucanje ispod nogu..to mi se desava i kad pri velikoj brzini zakocim malo jace.Hvala unapred svakom ko mi pomogne oko problema! Quote Share this post Link to post Share on other sites
Milutinac 5906 Posted June 14, 2018 Dovoljno opasan problem da odes kod majstora i da auto ne izlazi iz servisa dok se ne resi...zar ne? Quote Share this post Link to post Share on other sites
Nmilan85 0 Posted June 14, 2018 ma vec sam ga odneo kod Gorana altine,cekam da mi javi,pa vam pisem....mada ima dosta izdataka za ovaj fiat...druga stvar koju trena da vidim je crno iz auspuha kojii izlazi kad dam malo jaci gas i ovaj senzor za air bag Quote Share this post Link to post Share on other sites
Ivan 17593 Posted June 14, 2018 5 minutes ago, Nmilan85 said: mada ima dosta izdataka za ovaj fiat Ima, ima, pogotovo kad se "tera tako" pa se nakupi ... Na osnovu ostatka posta, verujem da je u pitanju JTD - auto je prilicno robustan, delovi dostupni na svakom cosku, povoljni sa cenom, a i u razlicitim rangovima kvaliteta za svaciji dzep... Tako da moze vrlo lepo, pouzdano i jeftino da sluzi, uz minimum truda vlasnika oko redovnog odrzavanja (pod uslovom da nije kupljen sa izvadjenom dusom). Ako auto dimi nenormalno crno, problem je sa viskom nafte, a oko Airbag-a najlakse je prvo dijagnostikom proveriti da li je u pitanju neki kontakt ili OCS ako je pre restyle (najcesce stvari) ili nesto trece... Za sve imamo posebne teme, koje se mogu pronaci i pomocu Search. Quote Share this post Link to post Share on other sites
