ivan.ik 625 Posted March 8, 2015 Injteresuje me da li je neko radio i kako ide instalacija navigacije na Iphone 5? Priprema za Apple pre ubacivanja Quote Share this post Link to post Share on other sites
Mijailović P. 3432 Posted March 8, 2015 O ne! Zar i ovde?! Quote Share this post Link to post Share on other sites
MS PK 7729 Posted March 9, 2015 Nemo žena da te provali da se krećeš van asfalta. Zavisi kako su odradili mape i šta je štiklirano u telefonu tj koji se putevi sve koriste. Vidim da su neka sela (što meni treba) po jugu malo detaljnije odrađeni tj ubačeni nazivi zaseoka.Znaci ima ono, gornja mala, donha mala, centar pred prodavnicu i to Quote Share this post Link to post Share on other sites
genca 2 Posted March 9, 2015 Jel ima neko novu mapu za Rumuniju? Quote Share this post Link to post Share on other sites
MS PK 7729 Posted March 9, 2015 Sta ce ti, ista je ko i sto je bila prosle godine Quote Share this post Link to post Share on other sites
ivan.ik 625 Posted March 9, 2015 Mićo ima onu banderu. Quote Share this post Link to post Share on other sites
MS PK 7729 Posted March 9, 2015 Nece on tamo. On oce na onaj novi put da juri Quote Share this post Link to post Share on other sites
genca 2 Posted March 9, 2015 Imam 2012,sad ne znam da li se nesto promenilo u centralnoj Rumuniji.Nikada nisam isao tamo,a non-stop nesto rade,grade... Quote Share this post Link to post Share on other sites
ivan.ik 625 Posted March 9, 2015 Romania 2014 Q3 15,97 MB pa uporedi sa tvojom iz 2012. Quote Share this post Link to post Share on other sites
Dusan 4 Posted March 9, 2015 Skinuo sam Igo sa Kikass torenta, sad me zanima kako ide instalacij na Iphone, samo prekopiram ceo fajl ili je potrebno jos nesto uraditi? Quote Share this post Link to post Share on other sites
igor0511 2877 Posted March 9, 2015 Evo nekog uputstva: 1. Download iGO My Way 2010 for here2. Jailbreak iPhone ( if not jailbreak ) . Read here .3. Install AppSync ( to install application with crack ) .4. Add iGO to iTunes after download and press Syncronize. Quote Share this post Link to post Share on other sites
Dusan 4 Posted March 9, 2015 Bem ti Ios, upravo pokusavam sve to ali bez jailbreak-a... Quote Share this post Link to post Share on other sites
igor0511 2877 Posted March 10, 2015 Ista stvar svuda. I na Androidu ako želiš nešto ozbiljnije da uradiš mora biti root-ovan.Jedino još ne znam šta treba raditi Windws Phone-u kada krenu permisije da zezaju Quote Share this post Link to post Share on other sites
Nidzo 2 Posted March 10, 2015 Na Androidi možeš da instaliraš navigaciju ili bilo koji apk koji nije skinut sa Play Store-q bez root-aNa iPhone treba JB. Ima i Garmin za iOS. Quote Share this post Link to post Share on other sites
igor0511 2877 Posted March 10, 2015 Ne može baš svaki Ja sam skidao par igrica za koje treba root. Quote Share this post Link to post Share on other sites
Dusan 4 Posted March 10, 2015 Na kraju cu da batralim, jer izgubi celu noc u zezanju i trasenju raznoraznih aplikacija. Za ios postoji Ipawind koji je nesto kao Blackmarket na androidu, samo sto se placa 15$ godisnje i sve aplikacije skidas besplatno.... Quote Share this post Link to post Share on other sites
diskusija 9 Posted March 10, 2015 A šta se na Androidu dobija sa tim Blackmarket-tom? Quote Share this post Link to post Share on other sites
MiroslavL 0 Posted March 10, 2015 Sve besplatno ! Quote Share this post Link to post Share on other sites
neshaoct 9591 Posted March 23, 2015 ja instalirao Here maps for android i do sada rade odlicno. Ima opcija da skines mape na telefon i koristis offline navigacija http://here.com/beta/android/?lang=en-US Ima je od skoro i na Play Store kao finalne verzije, i radi ok. Sve je besplatno, navigacija i mape. Nakon klika na podešavanja: ...tu je i opcija za offline i svašta nešto: Primer neke relacije, sa sve alternativnim putanjama: Da bi radilo offline, mape morate prethodno skinuti. U podešavanjima podesite da li želite da mape idu u okviru interne memorije fona, ili na karticu. Kao što se vidi, mogu se skidati mape celih kontinenata, ili pojedinačnih država. Ko hoće glas tokom putovanja, ima navođenje na engleskom i brdu ostalih jezika, ima naravno i na srpskom, ali samo muška varijanta za sada. Quote Share this post Link to post Share on other sites
dejanhn 11 Posted March 23, 2015 Da li ima neke velike razlike za igo mape 2014 q1 i q3 ? Quote Share this post Link to post Share on other sites
RSS 0 Posted April 4, 2015 Ima li neki link da skinem sve odjednom za samsung edge 1600x2560 ??? Hvala Quote Share this post Link to post Share on other sites
igor0511 2877 Posted April 4, 2015 Koliko ja vidim malo imaš problematičnu rezoluciju. Sada sam gledao torente i nema za tu. Evo zanimlijve teme pa pogledaj, nisam baš stigao sve da prelistam http://forum.xda-developers.com/note-4/help/igo-primo-t2963883 Quote Share this post Link to post Share on other sites
siera 2 Posted April 4, 2015 Ako ti nešta znači pogledaj ovo na FB https://www.facebook.com/svezanavigaciju?fref=ts Čovek ih je odradio mnogo pogotovu što su nama za kamione zahtevnije karte i informacje radi odlično Quote Share this post Link to post Share on other sites
RSS 0 Posted April 4, 2015 Mislim da je to za Edge 4, stize veceras pa da se lepo sve odradi.pa nista, juricu pravicu sys ako treba Quote Share this post Link to post Share on other sites
pavaobg 0 Posted April 4, 2015 HERE sa skinutim mapama se odlično pokazao do Nemačke i nazad. Nije bio primarna navigacija, ali sam ga često palio da proveravam Garmin.U saobraćaju se čak pokazao bolje od Garnina sa novim mapama. Tražili smo neko malo mesto pored Berlina koje u originalnom nazivu ima a sa dve tačke koje se zamenjuju sa ae, garmin nije hteo da prepozna dok nisamo ukucali a sa tačkama, a HERE je našao odmah sa ae. Jedina mana koju sam primetio dok smo šetali gradovima je da se trenutni položaj označava krugom koji ima neki vrh koji negde gleda i konstantno zbunjuje jer podsvest smet tog vrha prepoznaje kao pravac u kom treba ići. Radi se o režinu kada nije aktivirano navođenje. Znači upalim ga da vidim gde sam, da se orjentišem, vidim taj špic na krugu i krenem u pravcu koji on pokazuje. Quote Share this post Link to post Share on other sites
