kolega.jankovic 23 Posted October 30, 2015 I sad: Quote Share this post Link to post Share on other sites
Ivan 17649 Posted October 30, 2015 Brazilci . Sta li bi tek uradio da ima karavana... Quote Share this post Link to post Share on other sites
kolega.jankovic 23 Posted October 30, 2015 Pitaj imenjaka Quote Share this post Link to post Share on other sites
NenadAleksic 0 Posted November 5, 2015 Sprema se polako, nece biti kao kod brazilaca al mislim da ce solidno izgledati i isto tako se cuti. Quote Share this post Link to post Share on other sites
dinja 0 Posted February 6, 2016 A kakva bi procedura bila povezati fabricki woofer na aftermarket HU Pioneer,nema onog dzeka ispod tapacira?I da li se moze fabricki woofer lepo postaviti,postoji li odredjeno mesto na koje dolazi da to bude sto se kaze "sraf na sraf"? Quote Share this post Link to post Share on other sites
dinja 0 Posted February 16, 2016 Sema konektora na samom wooferu ako nekog zanima...na serbskom :-D Quote Share this post Link to post Share on other sites
Flex 1778 Posted March 18, 2019 Kakav je zvuk tog fabrickog vufera? Vidim da se moze naci dosta jeftino sada (20-ak eura) pa ne znam isplati li se? Quote Share this post Link to post Share on other sites
VOLK 0 Posted April 18, 2019 Ja ga imam i odlicno se cuje za onako mali zvucnik Quote Share this post Link to post Share on other sites
vmackm 0 Posted May 17, 2019 Kupio sam fabricki wufer sa kablom do connect nava, hocu da probam da ga ugradim na petovratnog stila. Ima li neko savet ako je to vec radio kuda da provlacim kablove za zvucnike i napajanje, cini mi se da ispod onih plastika uz vrata nema mesta. Takodje kuda ste izvlacili napajanje sa akumulatora i kako ste kacili wufer i krojili tapacir posto je ovo sve sto imam za trovratu verziju. Quote Share this post Link to post Share on other sites
BeX 0 Posted March 15, 2020 (edited) E ovako, treba mi pomoc. Uzeo sam android multimediju za fiat stila, u njega imam i onaj njegov fabricki vufer. Multimedija je povezana sve radi sem vufera, zvuk se cuje ali vufer ne radi. U Stilu sam pre toga imao njegovu fabricku multimediju. Sto se tice vezivanja, zuti dzek koji je stajao tamo sam isekao i tu braon zicu koja je isla u taj dzek sam vezao na kontakt, zvuk sam dobio ali vufer i dalje ne radi. Sta treba tu jos da se poveze da bi to radilo, ako neko zna neka pomogne bio bih mu veoma zahvalan.. Hvala vam unapred, zivi bili. Edited March 17, 2020 by Ivan Spojeno Quote Share this post Link to post Share on other sites
Ivan 17649 Posted March 16, 2020 (edited) Vufer ima 20 linija, po 8 ulaznih/izlaznih su za zvucnike (znaci, ukupno 16). Sto se dodatnih linija tice, treba da se poveze pin 2 u ISO A konektoru (Presence signal). Kao i pin 6 u Mini ISO konektoru (Switch ON/OFF signal). Bez ta dva signala, vufer/navigacija ne znaju za medjusobno postojanje. Preostala 2 signala na vuferu su napon sa akumulatora (sa osiguracem F54) i masa. U ovom postu sam ostavio fotke konektora navigacije sa bivseg auta, kao i fotke iz fabrickog uputstva za sta je koji pin, pa mozes da pogledas: Cetiri posta iznad imas jos detaljnije - sa semom vufera, polozajem komponenti na vozilu, detaljnim opisom sistema... Iako sam te slike prebacio svojevremeno sa Postimage na nas server - trenutno ne mogu da se vide, provericemo sta je u pitanju. Do tada svakako mozes da procitas napisano u tom postu : https://www.fiat-lancia.org.rs/forum/index.php?/topic/41574-fiat-stilo-ugradnja-pojačala-i-vufer-na-fabrički-cd-player/&do=findComment&comment=1273383 Ovu nepotrebno otvorenu temu, spojicemo sa postojecom. Edited March 16, 2020 by Ivan Quote Share this post Link to post Share on other sites
Ivan 17649 Posted March 19, 2020 On 3/16/2020 at 10:38 AM, Ivan said: Cetiri posta iznad imas jos detaljnije - sa semom vufera, polozajem komponenti na vozilu, detaljnim opisom sistema... Iako sam te slike prebacio svojevremeno sa Postimage na nas server - trenutno ne mogu da se vide, provericemo sta je u pitanju. Obnovio sam svoje slike koje su "nestale" iz pomenutog posta (na kraju sam ipak morao da ih ponovo izvadim iz eLearn). Tako da je sada sadrzaj ponovo kompletan, a sema Stilo woofera sazvakana do u detalje : Quote Share this post Link to post Share on other sites
zoranzo 18 Posted March 4, 2021 (edited) Drugovi borci,treba mi pomoc oko fabrickog vufera za stila,juce sam ga kupio,gledam ove seme koje su okacene i mucim se,iskreno Prvi problem je sto nemam izvedenu fabricku instalaciju za vufer,imam stila sa troje vrata,a izgleda da imam izvedene zice sa multimedije,samo ne znam dokle su te zice isle,kad ih nema u gepeku okacio sam slike gde pin 2 u ISO A konektoru ima vec izvedenu zicu,i pin 6 u Mini ISO konektoru ima vec izvedenu zicu..ako su krenule te zice iz medije kako ih nema u gepeku?? Drugo pitanje je,na 2 strani teme ,druga slika,linije sa vufera A2,3,4,5,6,7 B2,3 idu ka zvucnicima na konektore K M N L, koji su to konektori i gde su Trece pitanje,konektor na vuferu sa 3 reda pinova,jel ima negde da se kupi zenski konektor i kako se zove,da se to poveze lepo ako moze Edited March 4, 2021 by Ivan Sredjene slike Quote Share this post Link to post Share on other sites
zoranzo 18 Posted May 8, 2021 Neko slovo da napisem dokle sam stigao,a i za one koji ce tek da se upuste u ovu avanturu sa vuferom da znaju sta ih ceka od prilike Sto se tice povezivanja sve je objasnjeno lepo u predhodnim postovima,treba samo dobro da se promucka sta sve pise Kupio sam sve od kablova sto treba,taman sam mislio sve ce da bude ok samo da nabavim male buksne za konektor na vuferu sa 18 pinova,pinovi su ispod 2 mm,najmanje buksne koje sam nasao su 2,5 mm,i jednostavno ne moze da stane buksna do buksne,nema mesta.Znaci moracete da lemite svaki pin posebno ili neka druga terapija .Uspeo sam da nadjem instalaciju orginal,pa cak i sa njom sam u problemu Sema koja je postavljena za taj konektor vufera iznad nije tacna,ili nisu svi konektori isti,na slikama se vidi da su plus i minus na kontra stranama,i ispratio sam jednu zicu zvucnika i ona nije na mestu po ovoj semi iznad Ako neko ima neki predlog ,nek napise bicu zahvalan Quote Share this post Link to post Share on other sites
zoranzo 18 Posted May 15, 2021 Uspeo sam veceras da povezem najzad sve,pomoc 0 sa svih strana,cak komsija vrhunski autoelektricar nije hteo da se zeza sa povezivanjem.. Morao sam da nateram sam sebe da sve ispratim od pocetka do kraja Ovo gore sto sam napisao je cist primer ne citanja sta pise,slika je konektor sa vufera a ne dzeka sa kablovima,okrenuto je kontra na dzeku povezivanje Kako sam resio sve probleme,raskacio sve zice sa pinovima sa ovog gore zuto ljubicastog dzeka,i krenuo od navigacije redom,zica b8,boja ta i ta,svaku ispratio,i ubadao u ovaj dzek Na drugoj strani u ivanovom postu,prve 2 slike sve govore,nista vise nije potrebno,treba da se samo dobrooo sagleda sve,i da covek sam sebe natera da odradi sve Sto se tice zvuka ocekivao sam mnogo vise,izvadio sam zadnje sediste i dasku pa mozda kad vratim sutra bude malo bolje Evo neka slika,i srecno povezivanje stilise 1 neshaoct reacted to this Quote Share this post Link to post Share on other sites
Ivan 17649 Posted May 15, 2021 38 minutes ago, zoranzo said: Na drugoj strani u ivanovom postu,prve 2 slike sve govore,nista vise nije potrebno,treba da se samo dobrooo sagleda sve,i da covek sam sebe natera da odradi sve Htedoh upravo to jos ranije da ti pomenem, ali sam racunao da si procitao temu, ako si se vec upustio u radove i pises. Za bilo sta od elektronike, najvise pomazu pomenute kompletne seme ozicenja koje obicno postavljam - tu je sve sazvakano. I to je najvise sto mozemo ovako virtuelno da pomognemo, samo se treba snaci po njima. Kod slika konektora nemas bas puno toga, a u eLearn semama postoji Front i Rear strana pa i o tome treba voditi racuna. 1 zoranzo reacted to this Quote Share this post Link to post Share on other sites
Nemanja87bgd 0 Posted June 10, 2021 Cao svima, imam Peugeot 5008 i njegovi zvucnici su produvali, hteo bih 2 para novih i aktivnu bazuku za gepek ali low cost varijantu cisto da bude jedan nivo bolje od fabrike. Sve bi islo na fabricki radio cd, jel uopste moze da se povezu svi zvucnici na ovaj vufer? Mislio sam ovo da uzmem pa sta mislite? Vufer https://xenonsijalice.rs/vufer-univerzalni-sa-aktivnim-pojacalom-400w-10-incaa/ Zvucnici oko kojih se dvoumim su https://xenonsijalice.rs/auto-zvucnici-jbl-13cm-90w-set-2-komada/ 1400 din https://www.elementa.rs/proizvod/51664/auto-zvucnici-130mm-2x75w 2000 din https://www.elementa.rs/proizvod/51664/auto-zvucnici-130mm-2x75w https://xenonsijalice.rs/auto-zvucnici-jbl-13cm-90w-set-2-komada/ Quote Share this post Link to post Share on other sites
