jevta 251 Posted January 12, 2018 Ako nećeš na trke 1,2 sve uradi i najrentabilni je. Jeste malo slab na otvorenom ali kako nam je bar 95% grad to je prihvatljivo. Posedovao 12, sa plinom 6 godina i sve što mi je trebalo je uradio za jako malo para. Quote Share this post Link to post Share on other sites
Bumblebee 18 Posted January 13, 2018 (edited) Sta kazete na ovaj primerak, kako se pokazao ovaj motor jel ima nekih zackuljica oko njega? Burazer je vozio taj slabiji 1.4 i nisam bio bas zadovoljan kako ide. Ciji je ovo motor? http://www.polovniautomobili.com/putnicka-vozila/11406540/fiat-grande-punto-evo-14-b-sport Edited January 13, 2018 by Bumblebee Quote Share this post Link to post Share on other sites
nikolapfc89 3 Posted January 16, 2018 Koja je razlika u odrzavanju tj cene malog i velikog servisa kod 1.3mjet 75ks i benzinaca 65ks? Hvala. Quote Share this post Link to post Share on other sites
Zvezdo 982 Posted January 16, 2018 Daj si malo vremena pa procitaj prethodne postove, sve vec pise odavno.... 1.3 MJET ima veliki servis na 250 000 ili pre kada se menja lanac... Quote Share this post Link to post Share on other sites
nikolapfc89 3 Posted January 16, 2018 Nemam vremena zbog posla, ni da prelistam nazalost a verujem da je pisano. Quote Share this post Link to post Share on other sites
Goksi1980 43 Posted January 19, 2018 On 1/16/2018 at 11:59 AM, nikolapfc89 said: Koja je razlika u odrzavanju tj cene malog i velikog servisa kod 1.3mjet 75ks i benzinaca 65ks? Hvala. Razlika je velika.Mali servis oko 6 hiljada za benzinca a za dizela oko 9 hiljada. Quote Share this post Link to post Share on other sites
Zvezdo 982 Posted January 19, 2018 kako 9 hiljada? 3 litre Selenije WR i filter ulja je 3500-4000 hiljade jos filter za vazduh i klimu ako treba. Quote Share this post Link to post Share on other sites
Bingodalton 735 Posted January 19, 2018 I goriva papreno.Sent from my SM-A510F using Tapatalk Quote Share this post Link to post Share on other sites
Goksi1980 43 Posted January 20, 2018 13 hours ago, Zvezdo said: kako 9 hiljada? 3 litre Selenije WR i filter ulja je 3500-4000 hiljade jos filter za vazduh i klimu ako treba. Tako lepo,9 hiljada.Zvao 5 servisa u BG,to je cena. Ide 4 litre ulje(3,2 sa filterom staje,visak ostave u gepeku).To je oko 4000din,filter ulja i vazduha oko 1000,filter goriva oko 1500 i filter klime.Sve zajedno preko 7 hiljada delovi. Quote Share this post Link to post Share on other sites
The Punisher 6612 Posted January 20, 2018 Uštediš 2000 ako sam zameniš. Quote Share this post Link to post Share on other sites
Goksi1980 43 Posted January 20, 2018 Ja da iznesem svoje utiske za prvih 10 hiljada km.Imam Grande 1.3 mjt 55kw,crni metalik,skoro sve od opreme.Do sada hvala bogu kvarova nula:)neka tako i ostane.Menjao set kvacila odmah po kupovini,20 hiljada,diskovi plocice 10 hiljada,sajla rucne i regulator pritiska oko 10 hiljada.Uz neke sitnice ulaganje 400 evra u prvih par meseci(ulaganje ili odrzavanje kako god).Toliko sam i spustio cenu pri kupovini.Pre sam vozio Fabiu 1.4,za god dana usteda na gorivu skoro 200 e sa Fiatom. 6 minutes ago, The Punisher said: Uštediš 2000 ako sam zameniš. Tako je Quote Share this post Link to post Share on other sites
Zvezdo 982 Posted January 20, 2018 filter goriva je jako skup ali menja se po preporuci proizvođača na svakih 60 000 km tako da realno nema smisla menjati ga pre 50 000 i tu se može dosta uštedeti. za mali servis nije potreban neki specijalan alat tako da ga može gotovo svatko sam napraviti jedino je problem malo ispustiti ulje ali nije nemoguće i tako se stvori prostor za veliku uštedu. Quote Share this post Link to post Share on other sites
Goksi1980 43 Posted January 20, 2018 Ja imam dvoje male dece kuci i nemam vremena za auto tako da moram da platim majstora.Sto se tice filtera goriva mozda ga i ne budem menjao sad,razmislicu.. Quote Share this post Link to post Share on other sites
djomla 8386 Posted January 20, 2018 Ima masa servisa, radnji koje rade besplatnu zamenu filtera i ulja, ako se kod njih kupuju isti. Meni majstor za ruke uzme 1000 din. Stilo 1.9 jtd. Filtere sam kupujem, mada mi je rekao da svi filteri izadju 2500, nisam pitao koji su, kapiram da je neki Filtron. Sent from my 3310 Quote Share this post Link to post Share on other sites
Ivan 17637 Posted January 20, 2018 12 minutes ago, djomla said: mada mi je rekao da svi filteri izadju 2500, nisam pitao koji su Pa samo kvalitetan filter goriva je skoro toliko . Npr. UFI filter goriva je oko 2 somica, UFI filter ulja je blizu hiljadarke, a UFI filter vazduha malo iznad hiljadarke. Tj. krsteni motorni filteri izadju oko 4000, plus minimum toliko za 5l kvalitetnijeg 5-40 ulja, plus filter kabine (od 500 din za papirni do 2500 din koliko je bio Knecht sa aktivnim ugljem, pa sta ko voli). Ovo sve za 1.9 JTD, pa se izvinjavam za off . Quote Share this post Link to post Share on other sites
Bingodalton 735 Posted January 20, 2018 Cuj, za 1.9mjet je filter goriva skoro 50 eur.Uz popuste koje dobijem od 25% mali servis sa svim Mann filterima i Shell uljem je oko 100 Eur. Sad sam vec poceo da mesam cifre.Sent from my SM-A510F using Tapatalk Quote Share this post Link to post Share on other sites
djomla 8386 Posted January 20, 2018 Zato i rekoh da sam kupujem Sent from my 3310 Quote Share this post Link to post Share on other sites
Ivan 17637 Posted January 20, 2018 Takodje sam biram i kupujem, zato i ja kazem . 1 djomla reacted to this Quote Share this post Link to post Share on other sites
MilanStilo 2 Posted January 20, 2018 Ako mene pitas, a ne pitas. Bolje ti je da uzmes 1.4 nego 1.2 mislim ako se odlucis za benzinca. 1.2 vise trosi i bas bas nikako ne ide u odnosu na 1.4. Nemas sad neku snagu ni sa 1.4 motorom ali dosta bolje ubrzava. Poslato sa WAS-LX1 uz pomoć Tapatoka Quote Share this post Link to post Share on other sites
igor0511 2880 Posted January 20, 2018 Ccc sad ispade mali servis za 1.9 oko 100e, a kad sam ja pricao da sam placao 12 000din ljudi se zgrazali Quote Share this post Link to post Share on other sites
MS PK 7731 Posted January 20, 2018 Zgrazavao sam se i tad, zgrazavam se i sad Послато са SM-J320FN уз помоћ Тапатока Quote Share this post Link to post Share on other sites
igor0511 2880 Posted January 20, 2018 Vidis kako moze nov auto da ispadne jeftiniji od polovnog Quote Share this post Link to post Share on other sites
Ivan 17637 Posted January 21, 2018 11 hours ago, igor0511 said: Ccc sad ispade mali servis za 1.9 oko 100e, a kad sam ja pricao da sam placao 12 000din ljudi se zgrazali Svi krsteni filteri+ulje su 70 EUR min. Sa filterom goriva koga naravno ne menjas na svakom malom servisu i koji je nepunih 20 evropejaca. A vecina to uradi za znatno povoljniju cifru . Quote Share this post Link to post Share on other sites
silenci 2337 Posted January 21, 2018 za 3litra ulja cena je oko 2700 castrol EDGE plus filter ulja knecht mahle 650 dinara i majstoru 500 dinara sto mi uzme za zamenu,to je zadni put,prezadnji put sam menjao sam,bez problema,a filter vazduha i kabine sam stalno menjam,a filter nafte je majstor mi menjao kad sam menjao amortizere Quote Share this post Link to post Share on other sites
srkiv 1 Posted January 21, 2018 Razmisljao sam o kupovini Gp abarth. U oglasima se vrti jedan crni mat. Ali mi je cudno sto je crn mat,sto nema pozadi znak,i nema zadnji brisac. Quote Share this post Link to post Share on other sites
