Duško0501 1 Posted February 3, 2017 Hvala.Upravo ono što sam tražio,kao odgovor. Quote Share this post Link to post Share on other sites
Bingodalton 735 Posted February 3, 2017 A 1.9 pri 170 trosi ispod 8l Quote Share this post Link to post Share on other sites
Lufti 690 Posted February 3, 2017 Po meni je u svakom pogledu bolja kupovina jaceg motora sto se GP-a tice, da sam imao vise para, sigurno bih uzeo 1.9 sa 130 konja u punoj opremi... Ali to ne znaci da svi razmisljamo isto, nekom je potrebno da se preveze od tacke A do B bez potrebe za dizanjem adrenalina... Quote Share this post Link to post Share on other sites
vix 1 Posted February 3, 2017 Koliko para, toliko konja... Quote Share this post Link to post Share on other sites
MilanStilo 2 Posted February 4, 2017 Drustvo gledam da kupim jednog punta 2005god. 1.3mjt ali ima jedan problem, kada se upali motor mu lupa. Jel imao neko slicnu situaciju ili mozda zna sta bi moglo da bude? Ne verujem da mu motor moze prolupati tek tako mada hmmm... Quote Share this post Link to post Share on other sites
Bingodalton 735 Posted February 4, 2017 Vidim ovde bi svi GP sa 1.9 motorom, nadam se da to znaci da cu moj prilicno lako prodati kad dodje vreme Quote Share this post Link to post Share on other sites
neshaoct 9592 Posted February 4, 2017 Deo je prebačen u novu temu: https://www.fiat-lancia.org.rs/forum/index.php?/topic/73543-koliko-auto-treba-da-bude-jak-da-bi-bio-dovoljno-jak/ Quote Share this post Link to post Share on other sites
nesa 169 348 Posted February 4, 2017 On 2/4/2017 at 7:54 PM, MilanStilo said: Drustvo gledam da kupim jednog punta 2005god. 1.3mjt ali ima jedan problem, kada se upali motor mu lupa. Jel imao neko slicnu situaciju ili mozda zna sta bi moglo da bude? Ne verujem da mu motor moze prolupati tek tako mada hmmm... Da li lupa samo hladan ili uvek? Moze biti da je problem u nekom od nosaca motora. Quote Share this post Link to post Share on other sites
MilanStilo 2 Posted February 4, 2017 Nismo ga pustali da se zagreje, upalio cuo lupa I odmah ugasio. Koliko sam njega razumeo on misli da je problem u 3 klipu. Ja sam pomislio na diznu ali ne znam kako to da proverim sa sigurnoscu. Quote Share this post Link to post Share on other sites
Ticma 537 Posted February 4, 2017 Zasto bi uopste to kupovao i nagadjao sta je, okrenes se i nadjes nesto drugo. Quote Share this post Link to post Share on other sites
MS PK 7732 Posted February 4, 2017 Iskljuci tu diznu Quote Share this post Link to post Share on other sites
MilanStilo 2 Posted February 5, 2017 Cena je povoljna, to je u inostranstvu. To se nisam setio da probam, mada imam I dijagnostiku. Ma uzecu ga pa ko ga... Quote Share this post Link to post Share on other sites
nesa 169 348 Posted February 5, 2017 Budi obazriv, jako niska cena je uvek signal da nesto nije u redu, i to ne samo s motorom. Quote Share this post Link to post Share on other sites
MilanStilo 2 Posted February 5, 2017 Otkud znam, on kaze da mu je rekao neki mehanicar da nesto nije u redu sa trecim klipom, valjda ne radi dobro ili sta vec nije znao da mi objasni. Rekao bih po njemu da se ne razume oko kola e sad hm hm. Doterao sam jednog 2004god. 1.2 8v sa opremom bas lepom za puntica i mislio sam za zenu da ga ostavim medjutim dok sam ga ja tovario na prikolicu naidje covek i pita jel bi uzeli jos jednog i u prici kako i sta ja odem i pogledam ga na 5 minuta i onda se odlucim da je mozda bolje da joj uzmem tog 1.3mjt a ovog da prodam . Quote Share this post Link to post Share on other sites
vix 1 Posted February 5, 2017 Ja bi rekao da od 1.2 benzinca moze manje da zaboli glava nego od tog ocigledno neispravnog 1.3 mjt... Quote Share this post Link to post Share on other sites
MilanStilo 2 Posted February 5, 2017 Pa jeste ali idem na to kad ga sredim da je puno bolji od 1.2 benzinca. Ne znam, razmislicu jos neki dan ako se ne proda. Quote Share this post Link to post Share on other sites
D1ablo1g 0 Posted February 20, 2017 Uzeo sam grande punta 1.3 mjet 2006. Pre od prilils 3 meseca. I odusevio sam se! Auto je predobar, sve sto sam trazio sam i dobio. Kupio sam ga cipovanog na 105 ks. Potrosnja mu je smanjena, okretan, i pruzio mi je pravi dozivljaj kad sam presao sa Toyote jarisa. Istina je da variraju obrtaji na leru, i malo je trom do 1800 obrtaja, ali kako predje 2000 postaje prava zver. Nisam ocekivao da ce biti ovoliko dobar, i prijatno sam iznenadjen. Stvarno sve pohvale za Grande Punta. Ne mogu da raspravljam o nekim strucnijim stvarima, ne razumem se bas najbolje u sve to.. Ali sam hteo da podelim sa vama jedno ovako grubo misljenje Pozdrav Quote Share this post Link to post Share on other sites
Zvezdo 991 Posted February 20, 2017 a koliko si siguran u tih 105 ks? Jesi li merio? Koja je verzija u standardu, 75 ili 95 ks? Quote Share this post Link to post Share on other sites
DiscoVolante 294 Posted February 20, 2017 90 vjerojatno, jer 75 nije dolazio s ovim paketom opreme, a 95 je već redizajnirani model. Quote Share this post Link to post Share on other sites
Zvezdo 991 Posted February 20, 2017 jeste! Nisam ni gledao sliku. Quote Share this post Link to post Share on other sites
D1ablo1g 0 Posted February 20, 2017 On 2/20/2017 at 0:17 PM, Zvezdo said: a koliko si siguran u tih 105 ks? Jesi li merio? Koja je verzija u standardu, 75 ili 95 ks? 100% sam siguran. Prijatelj radi dijagnostiku i bas sam proveravao kad sam kupovao Quote Share this post Link to post Share on other sites
Zvezdo 991 Posted February 20, 2017 Ne postoji uređaj koji kada se poveže na auto da ti da informaciju koliko ti auto ima ks. Također niti jedan dijagnostički program ne može očitati snagu koju motor daje na radilici ili točkovima... odnosno barem ja nisam čuo za njega. Quote Share this post Link to post Share on other sites
DiscoVolante 294 Posted February 20, 2017 Taj motor u Grande Puntu ostavlja dobar dojam jer ima kratak prijenos, uredno se voziš 100injak km/h u šestoj brzini, tako da te možda i to zavarava. Pokušaj usporediti međuubrzanja i ubrzanja s podacima tvorničkog modela, to bi trebalo nešto pokazati. Quote Share this post Link to post Share on other sites
vagenovac 4533 Posted February 20, 2017 Mozda,je utvrdio preko dijagnostike da je cipnut, sto nije nemoguce, a sa 90 na 105ks odnosno samo 15ks treba da je laganica dici.P.s. da je rekao 120ks pa da budemo skepticni u broj ks Sent from my KIW-L21 using Tapatalk Quote Share this post Link to post Share on other sites
Zvezdo 991 Posted February 21, 2017 nisam skeptik po pitanju snage samo me zanima koliko je siguran da ima približno toliko. Pre dve godine se je govorilo o 20 ks više na papiru dok je na valjcima bilo max 10 ks sa puno dima, dakle realno 8 ks... tuneri su redom govorili da je taj ecu citiram "ubog" za tuniranje. U međuvremenu se je nešto promenilo ali ne znam šta. Zbog toga pitam. Quote Share this post Link to post Share on other sites
