Ivan 17587 Posted January 6, 2021 Ti aktivno nastavljas da lomis glavu o ovoj problematici i u novoj godini ? Naravno, zavese idu od vrha A stuba i zavrsavaju u C stubu. Mislim da imas poneku fotku zavesa i sa Nuova Bravo u ovim mojim DIY temama, identicna problematika: https://www.fiat-lancia.org.rs/forum/index.php?/topic/81541-nuova-bravo-ugradnja-nosačapolice-za-naočare/ https://www.fiat-lancia.org.rs/forum/index.php?/topic/39907-stilo-antena-prijem-signala-skidanje-antene/ 1 mitros reacted to this Quote Share this post Link to post Share on other sites
mitros 140 Posted February 6, 2021 Pitanje za milion $.Sin je sipao gorivo do cepa i stalo je 42,3L. Koliko je bilo u rezervoaru pre sipanja. Quote Share this post Link to post Share on other sites
MS PK 7729 Posted February 6, 2021 Bilo samo za do pumpe Quote Share this post Link to post Share on other sites
mitros 140 Posted February 6, 2021 54 minutes ago, MS PK said: Bilo samo za do pumpe Zavisi koje,ako je do one u Pančevu onda... Quote Share this post Link to post Share on other sites
neshtry 14785 Posted February 6, 2021 Manje od 5l,možda 3l Quote Share this post Link to post Share on other sites
nikola133 0 Posted February 21, 2021 Pozdrav! Nov sam ovde, i odlucio sam se za kupovinu Eva. Moze mala pomoc oko ovog? Sta mislite? http://www.polovniautomobili.com/auto-oglasi/17742893/fiat-evo-dinamic-full Quote Share this post Link to post Share on other sites
Axic 19974 Posted February 21, 2021 @nikola133Deluje baš uredno i očuvano. Dugmići na volanu, ostatak auta sve na mestu barem sa slika. Quote Share this post Link to post Share on other sites
Dule 021 660 Posted February 21, 2021 Jos da je 2012 sto ces proveriti kad nazoves jer s obzirom da je Dinamik i da mu je sve to odradjeno i da je jos 2012 nesto se tu ne uklapa. Problem je sto mnogo holandjana dolazi a tu su kilometri prilicno veliki i cesto budu za to godiste i preko 300k km a problem je u DPF-u i diznama na takvim kilometrazama. Po novom zakonu tu ce retko koji euro5 proci tehnicki pregled. Zato verujem da ce morati da smanje kriterijume jer mnogo kola nece proci tehnicki iako su mlada i lepa. Zasto kazem da je upitna cena? Zato sto meni stize jedan EVO ali cena ce biti nesto niza od ovog ali je stariji dve godine. Quote Share this post Link to post Share on other sites
Zvezdo 980 Posted February 21, 2021 Ja bih sa parama otišao da ga pogledam. Nema panoramu I zadnje podizače I verovatno još nešto dakle nije full ako može da pomogne u pregovorima. Po boci za antifriza mi izgleda da je OK kilometraža ali me buni što je menjan lanac što ne mora da znači da je prešao više. Quote Share this post Link to post Share on other sites
jovan90 9 Posted February 22, 2021 Proveri preko broja sasije na car vertical kilometrazu. Quote Share this post Link to post Share on other sites
Decak Iz Vode 161 Posted February 22, 2021 Na slikama lepo izgleda. Registrovan pa moze slobodno da se izveze na put i provoza,isproba. Ja bih ga svakako isao pogledati. Quote Share this post Link to post Share on other sites
Ivan 17587 Posted February 25, 2021 (edited) @mitros Molba da od teme za kupovinu Grande Punta ne pravimo "kupusaru", u kojoj pitamo o svemu sto nas zanima. Za to postoji gomila tehnickih tema, koje uglavnom samo treba pronaci pomocu Search (ili otvoriti novu ako takva slucajno ne postoji). Ovo nije jedina tema na forumu , vec je namenjena savetima kolegama u potrazi za GP. Prebacicemo i prethodnu pricu o pogresno sipanom gorivu. Diskusija o problemu sa alternatorom/akumulatorom je premestana u postojecu tehnicku temu: Edited February 25, 2021 by Ivan 2 1 Mijailović P., djomla and neshtry reacted to this Quote Share this post Link to post Share on other sites
Bojan1989 0 Posted March 6, 2021 (edited) Planiram da kupim manji gradski auto, koji nije mnogo skup za odrzavanje. Odlucio sam da to bude benzinac Grande Punto. Razmisljao sam da uzmem 1.2 8V, ali vidim da ima i 1.4 8V. Zanima me, da li je velika razlika u potrosnji i odrzavanju izmedju ova dva auta? Ili su u principu oba motora ista? Edited March 6, 2021 by neshaoct spojeno Quote Share this post Link to post Share on other sites
neshaoct 9590 Posted March 6, 2021 @Bojan1989 Pogledaj sada, posle spajanja, prethodno napisano u temi na kojoj smo. Nisu oba motora ista, ali nema veće razlike u održavanju između 1.2 8v i 1.4 8v. Naravno, 1.2 8v je malo jeftiniji. Možeš pogledati cene delova za oba, koristeći npr. online katalog delova Euroauta: https://www.fiat-lancia.org.rs/forum/index.php?/topic/68872-online-katalog-euroauto/ 1 Bojan1989 reacted to this Quote Share this post Link to post Share on other sites
Bojan1989 0 Posted March 6, 2021 (edited) Hvala na brzom odgovoru. 1.4 ima nesto vise konja, pa ako su delovi otprilike slicne cene, mozda je bolje uzeti 1.4 8V. Edited March 6, 2021 by neshaoct formatiranje Quote Share this post Link to post Share on other sites
Mijailović P. 3431 Posted March 6, 2021 Naravno da je bolje uzeti auto sa jačim agregatom. Iako ni taj ne obiluje snagom a, viška snage i para nikad dosta, ipak je neka merica za grad. Obzirom da je u temi rasčlanjeno sve do detalja, da ne mlatim praznu slamu. Samo se treba poslužiti već napisanim... Quote Share this post Link to post Share on other sites
Bojan1989 0 Posted March 8, 2021 Stigao sam do 55 strane citanja razgovora na ovu temu. Ima dosta zanimljivih stvari. Lepo je sto je forum aktivan i sto nekome ova pitanja i odgovori mogu nekome pomoci. Nadam se da cu i ja naci odgovore na svoja pitanja o GP ovde. Quote Share this post Link to post Share on other sites
Dule 021 660 Posted March 8, 2021 Iz mog iskustva a imao sam oba ja bih pre uzeo 1,2 a zasto? Pa zato sto 1,4 fabricki trosi ulje dok 1,2 mi nije trosio. Razlika kako idu jedan i drugi nije velika jer se radi o 10-tak ks ali bio sam veoma razocaran kako ide 1,4 8V. Posle tog auta sam registrovao Kangoo 1,5Dci sa 85 ks i to je bila formula za GP. 1 shuxx reacted to this Quote Share this post Link to post Share on other sites
Flex 1778 Posted March 8, 2021 Cudo bi bilo da nije formula. Sent from my SM-A520F using Tapatalk Quote Share this post Link to post Share on other sites
Dule 021 660 Posted March 8, 2021 A zasto? Bio jedan moj a onda sam i drugog registrovao i nisam ih prodavao. Znam kako su isli i sa kojim sam bio zadovoljniji. Quote Share this post Link to post Share on other sites
Bojan1989 0 Posted March 8, 2021 17 minutes ago, Dule 021 said: Iz mog iskustva a imao sam oba ja bih pre uzeo 1,2 a zasto? Pa zato sto 1,4 fabricki trosi ulje dok 1,2 mi nije trosio. Razlika kako idu jedan i drugi nije velika jer se radi o 10-tak ks ali bio sam veoma razocaran kako ide 1,4 8V. Posle tog auta sam registrovao Kangoo 1,5Dci sa 85 ks i to je bila formula za GP. Ja godinama vozim Zafiru. I trenuto je vozim. Zafira B, 1.7 CDTI 125ks. 2012 god. Auto je skup za odrzavanje, a trenutno imam u planu da skupljam novce za nesto drugo, a ne da dajem na dizne, zamajce i turbine. Porodica mi je velika, ali stisnucemo se malo neko vreme. Zanimljiv mi je GP. Misljenja su podeljena sto se benzinaca tice. Bar je tako na ovom forumu. Ne trazim trkacki auto. Kao sto sam ovde negde procitao, sluzice mi da se odvezem od tacke A do tacke B. I uglavnom je gradska voznja. Siguran sam da cu uzeti GP 1.2 8V ili 1.48V. Posto nemam iskustva sa GP, zelim da saznam da li je uopste znacajna razlika sto se voznje tice izmedju ova dva agregata. I posto je prosao dugi niz godina kako ova tema postoji, verujem da na forumu ima ljudi koji dugo voze neki od pomenutih benzinaca, pa da cujem iz prve ruke, koje su boljke na 1.2 8V a koje na 1.4 8V. Inace, primecujem da na oglasima postoji veca ponuda za 1.2 8V. Quote Share this post Link to post Share on other sites
Dule 021 660 Posted March 8, 2021 Ja samo mogu da kazem da sam imao priliku da probam GP 1,2 i da ide ok. Nije trkac ali ide od tacke A do tacke B super. Danas sam produzio registraciju na zeninom Puntu 1,2 8V 2003 i izasla je citavih 14900 dinara sa tehnickim pregledom koji dobijam povoljnije. 1,2 ce manje trositi u gradu, manja mu je rega i za tu malu razliku u ubrzanjima i maksimalnoj brzini koja nam nije ni bitna ja bih pre uzeo njega. E sad secam se kad sam prodao 1,4 8v zeninom rodjaku da je govorio kako mora da doliva ulje a i licno sam se nagledao mnogo tih puntica sa 1,4 motorima i uljem ispod minimuma i to kad dolaze na kamionima iz inostranstva. Nit ga imam niti ga nudim ali dajem svoje misljenje da neki ne vi pomislili kako imam sad GP 1,2 po starom obicaju. Inace sam danas vratio jedan prelep EVO sa 1,3 Mjet motorom od 86ks a koji je presao pravih 158k km i koji je estetski bio malten nov a takav mu je bio i enterijer. Jednostavno ti euro5 motori su smece i ne mozes naci jedan da radi kako treba na prvom paljenju a ovaj je jos izbacivao ulje na auspuh jer ili je turbina otisla na tako maloj kilometrazi ili su otisle karike. Nisam hteo da eksperimentisem jer danas na jutarnjem oaljenju je brljavio u radu a kad dam gas dizne su krljale samo tako i vratio sam ga uvozniku jer nije vilo lufta za opravku jer je debeleo placen zbog kilometara. I ne nije presao vise kako bi odmah neki opleli nego jednostavno to je motor sa problematicnim DPF-om a eto i turvine su im daleko losije od onog starog i proverenog motora sa 75ks koji je euro4. Pazite kad uvoznik vise nece da uzima vise GP i Corsu D koji nose taj motor jer kaze da svaki ima problem sa DPF-om i da nece prolaziti tehnicki pregled na gasovima. I zato ja kazem da cemo praviti od blata euro3 i neke euro4 motore ali otom potom jer vreme ce pokazati svoje. A evo i dokaza da ovaj EVO nije imao velike kilometre. 2 1 Bojan1989, shuxx and igor0511 reacted to this Quote Share this post Link to post Share on other sites
Bojan1989 0 Posted March 8, 2021 (edited) Mnogo hvala. Sada sam gotovo siguran da cu kupiti GP 1.2 8V. Cim prodam ovu moju zafiru. Edited March 9, 2021 by Woodoo ne citiraj upis napisan neposrednog pre tvog Quote Share this post Link to post Share on other sites
Flex 1778 Posted March 8, 2021 A zasto? Bio jedan moj a onda sam i drugog registrovao i nisam ih prodavao. Znam kako su isli i sa kojim sam bio zadovoljniji. Pa kako zasto? Pa 1.5dci je formula za taj 1.2 kao sto si i sam rekao. Sent from my SM-A520F using Tapatalk Quote Share this post Link to post Share on other sites
jevta 251 Posted March 9, 2021 Do prvog kvara tog 1.5Послато са Redmi Note 8T помоћу Тапатока Quote Share this post Link to post Share on other sites
