MS PK 7718 Posted November 20, 2014 Ne znas koji od ove dvojice Quote Share this post Link to post Share on other sites
MS PK 7718 Posted November 20, 2014 Mora platis cepi prvo da ti reknem Quote Share this post Link to post Share on other sites
Markobgd 609 Posted November 20, 2014 (edited) Evo Mada znam ko je....Ivan Edited November 20, 2014 by Markobgd Quote Share this post Link to post Share on other sites
MS PK 7718 Posted November 20, 2014 Kako si znao Uzeli ovi matorci, Ivani i Totti da se k.rvaju po malo jos dok mogu...saturday night i to.. Quote Share this post Link to post Share on other sites
Sedla 2541 Posted November 28, 2014 (edited) Meni na Lybri je prosle godine ugradjen Valeo set kvacila,navodno "iz originala". Dobio ga za 17000din sa sve ugradnjom. Evo ga taj set gazi vec oko 80,000km, 90% gradske voznje i mog izivljavanja,potpisivanja i ostalih s**nja koje taxi vozilo inace podnosi....Naravno nece jos dugo,korpa pocinje pomalo da trese,lamela se dosta otanjila,druk poceo da se urezuje u korpu,cenim da ce isterati do 100,000km. Sve u svemu set koji je normalno i ravnomerno dotrajao. Pozdrav za sve "cipovane" kolege. Edited November 28, 2014 by Sedla Quote Share this post Link to post Share on other sites
Marko Topola 45 Posted November 28, 2014 A ovamo pricas kako nije cipovana........ Quote Share this post Link to post Share on other sites
Sedla 2541 Posted November 29, 2014 Pa nemam nikakav dokaz da je cipovana?!? Kako bih ja to mogao znati? Quote Share this post Link to post Share on other sites
igor0511 2823 Posted November 29, 2014 Iščitam ti ja mapu i za 2min proverimo da li je fabrika Quote Share this post Link to post Share on other sites
Sedla 2541 Posted November 29, 2014 Moze! Samo jos da se nadjemo negde... Quote Share this post Link to post Share on other sites
igor0511 2823 Posted November 29, 2014 Valjda će biti prilike Inače, ako tebi Valeo tera 100 000 takve vožnje onda bi bilo sasvim realno da izdrži 150 000 i jače neke mešovite ili otvorenog puta. Quote Share this post Link to post Share on other sites
ivan.ik 625 Posted November 29, 2014 100 000 x 3,5 minimum. Quote Share this post Link to post Share on other sites
igor0511 2823 Posted November 29, 2014 Kod mene za sada skoro 200 000, e sad dokle će videćemo Quote Share this post Link to post Share on other sites
Sedla 2541 Posted November 29, 2014 Da,verujem da bi mnogo vise isterao normalne voznje i otvorenog puta... Quote Share this post Link to post Share on other sites
DoX 0 Posted December 17, 2014 Aj jedno glupo pitanje. Kako da znam da li auto ima Zamajac bez rasturanja ? Quote Share this post Link to post Share on other sites
MS PK 7718 Posted December 17, 2014 Tesko. Moglo bi da se primeti u voznji ali morao bi da umes da prepoznas. Mnogo ugladjeniji polazak, nema cimanja pri saltanju i dodavanju gasa, mnogo ugladjenija voznja... Quote Share this post Link to post Share on other sites
DoX 0 Posted December 23, 2014 Pa posto mi je kvacilo na izdisaju vrlo verovatno ne mogu da donesem pravi zakljucak jer verujem da set kvacila treba biti u idealnom stanju da bi provalio da li ima zamajca ili ne. U svakom slucaju sad mi je malo jasnije.. Quote Share this post Link to post Share on other sites
Stilisa 312 Posted January 7, 2015 Drugar je skoro menjao plivajuci zamajac na Grande Puntu 1.9 mjt 131ks. Stavio je novi LUK-ov i zamenio druk lezaj. Majsotr rece da je kvacilo dobro i da nije moralo da se menja. E sad, problem je sto opet kad ga pali/gasi, cuje se metalni zvuk, bas simptom zamajca, bas kao pre. Inace kvacilo super odvaja, mekano, lamela ne kliza, upada lepo u brizne, ide dobro auto, ali zvuk pri startovanju/gasenju je tu. Iz servisa su rekli da to tako kao mora, ali nema sanse da to tako mora. Zanimljivo da je posle par dana nestao taj zvuk. Je l' moguce da zamajac mora da ''legne'' posle nekog vremena? Mi smo ga jedno 10-15 puta palili to vece i bilo je zvuka, posle nestade....Sta tu moze da bude? Quote Share this post Link to post Share on other sites
deki87 7 Posted January 7, 2015 Ko zna,mozda... Quote Share this post Link to post Share on other sites
bojankov 36 Posted January 7, 2015 Nesto mu se drugo cuje...zamajac novi je nategnut skoro sa ga rukom ne mozes pomjeriti ni u jednom smjeru i nikakvih zvukova ne ispusta... Quote Share this post Link to post Share on other sites
deki87 7 Posted January 7, 2015 Mozda neka remenica,kompresor,alnaser...prvo da se utvrdi odakle dolazi zvuk. Quote Share this post Link to post Share on other sites
igor0511 2823 Posted January 7, 2015 Sasmo da ne bude kao što je VladaNS zamenio zamajac i opet ostali isti simpotmi.. Quote Share this post Link to post Share on other sites
Stilisa 312 Posted January 7, 2015 Pa i meni je cudo da se opet cuje, ali sta znam....Nista drugo mi ne pada na pamet da moze da se cuje? Zvuk je bas udaranje metala neko. Sutradan hteo da snimim i da izbacim ovde, al' ko za inat prestade. Mozda se pojavi opet, ko zna, ja vise iz radoznalosti pitam. Inace, set je nov stavljen sigurno, stari je u gepeku, to nije sporno. Najverovatnije cemo se provozati opet do servisa cisto za savet. Quote Share this post Link to post Share on other sites
bojankov 36 Posted January 7, 2015 Moze biti remenica radilice. Prvo neka raskaci pk kais i nega proba i tako utvrdi da nije nesto od remenica iz tog kruga... Quote Share this post Link to post Share on other sites
Stilisa 312 Posted January 7, 2015 Mozda neka remenica,kompresor,alnaser...prvo da se utvrdi odakle dolazi zvuk.Paaa ne verujem da je remenica, ja sam menjao remenicu radilice i znam otprilike koji je zuvk. Vrlo je tesko opisati preko tastature zvuk. Auto je bio na kompletnom pregledu i menjano je sve sto je bilo za zamenu. Zamenjen je i nosac motora, tako da mislim da bi videli da je jos nesto za zamenu. Quote Share this post Link to post Share on other sites
