Jim9 79 Posted May 15, 2014 Meni se ovo dešava s vremena na vreme, obično nakon kiše i vetrometine Quote Share this post Link to post Share on other sites
DusanLE1975 0 Posted June 15, 2014 Bio sam kod električara. Kaže da ECU brljavi i da će njegovo izmeštanje rešiti problem, jer se navodno već sreo sa istim problemom... Quote Share this post Link to post Share on other sites
neshaoct 9584 Posted June 16, 2014 Ako hoćeš više da saznaš o tome, klik na:http://www.fiat-lancia.org.rs/forum/index.php?/topic/48755-fiat-stilo-16-16v-preme%C5%A1tanje-ecu-a-nov-ili-reparacija/ Quote Share this post Link to post Share on other sites
DusanLE1975 0 Posted July 31, 2014 Problem rešen. Računar, tačnije procesor stradao, servisiran i sad je sve ok. Quote Share this post Link to post Share on other sites
Cojara 0 Posted November 2, 2014 (edited) Postovani, vidim da se ovde nesto pisalo za Car Security, pa me zanima sto se to prikazuje, danas prvi put od kako vozim Stila mi se to pojavilo i samo vergla ja vratim kontakt dam opet i upali kao mina ? Do cega je to ? Hvala unapred i veliki pozdrav iz Banja Luke Edited November 3, 2014 by neshaoct prebačeno Quote Share this post Link to post Share on other sites
deki87 7 Posted November 3, 2014 Zeza imobilajzer. Quote Share this post Link to post Share on other sites
burgman75 0 Posted November 4, 2014 nadam se da nisam omasio temu ( da neotvaram novu ) stilo 1.9 jtd 2004 imam easy go.sistem paljenja pre neki dan mi se upalila lampica auto sa katancem car security failure i steering loked if doors loked inace auto pali normalno centralna brava funkcionise i sva se vrata zakljucavaju..... Quote Share this post Link to post Share on other sites
neshaoct 9584 Posted November 5, 2014 Proveri napon akumulatora, čisto da vidiš šta je sa prvim uzrokom svih tih fantomskih grešaka koje Stilo zna da prijavi, a sve ustvari radi iako je prijavio grešku. Quote Share this post Link to post Share on other sites
bogisa 0 Posted November 10, 2014 (edited) Pozdrav, mislio sam da cu svoj Stylo predstaviti drugacije ali moram ovde da pitam za savet. Da ne gusim, upalio sam normalno krenuo pola metra i auto se ugasio, na displeju stoji # car protection system failure#. Pokusao sam da skinem klemu ( - ) ali nikakvog uspeha, i dalje vergla ali ne pali. Ako neko ima iskustvo sa ovom greskom (kvarom) neka da savet sta valja ciniti. Hvala unapred Edited November 12, 2014 by neshaoct spojeno Quote Share this post Link to post Share on other sites
Mijailović P. 3396 Posted November 10, 2014 Kuj b'e auto? Ne vidim sa TT. Ako je taj što mislim, ondaK ima pregršt informacija... Quote Share this post Link to post Share on other sites
neshaoct 9584 Posted November 12, 2014 @ bogisa Pročitaj sada, nakon spajanja tema, sve ranije napisane odgovore u temi na kojoj smo. Quote Share this post Link to post Share on other sites
strucnjak 0 Posted December 8, 2014 (edited) narode imam problem, naime danas sam lepo parkirao auto u dvoristu. sve super coolmedjutim kljuc mi je nesrecnim spletom okolnosti dosao u dodir sa mnogo vode. otvorio sam ga i obrisao sam ga koliko je to bilo moguce, medjutim kad sam hteo posle 4h da idem negde kolima, cim sam ubacio kljuc u bravu stajao mi je cudesni zuti katanac i nisam mogao da upalim, samo je verglao i verglao?!neka ideja sta bi moglo biti? jel moguce da je u pitanju sam kljuc ili je ipak do auta?!u pitanju je fiat stilo 1.6 16v Edited December 9, 2014 by neshaoct spojeno Quote Share this post Link to post Share on other sites
Buca_Tipo 31 Posted December 9, 2014 Pa ako je kljuc doso u dodir s vodom do njega je, probaj sa rezervnim da vidis sta ce da se desi. Quote Share this post Link to post Share on other sites
Mi An 0 Posted December 9, 2014 (edited) Prvi put cujrm za ovako nesto.Probaj sa rezervnim kljucem, ako nece, moras da uneses sifru sa kod kartice preko kvacila nesto...Probaj rezervnim kljucem da upalis, ako ne javi, da potrazim negde,da vidim kako se unosi kljuc.Ili skini uputstvo za stila na srpskom, pa pronadji... Edited December 9, 2014 by Mi An Quote Share this post Link to post Share on other sites
zrnke 41 Posted December 9, 2014 Meni se desilo slicno na stilu. S tim da je meni kljuc dosao u dodir sa vodom i posle toga nije hteo da otkljucava na daljinski.Imao sam drugi isto fabricki sa tasterima pa sam njega koristio. Quote Share this post Link to post Share on other sites
Kuvalja 406 Posted December 9, 2014 Ok je da ne radi centralna, ali da ne pali ne bi smelo, kad si otvarao da ti nije ispao transponder ili da nije pukao, to je mala staklena ampulica u kojoj se vide namotaji, proveri da ti to nije ispalo iz kljica prilikom otvaranja ili doslo do ostecenja. Quote Share this post Link to post Share on other sites
strucnjak 0 Posted December 9, 2014 (edited) fora je u tome sto nemam rezervni kljuc :\pa nema te male ampulice?! sta sada? Edited December 9, 2014 by strucnjak Quote Share this post Link to post Share on other sites
Markobgd 609 Posted December 9, 2014 Tu gde si radio (sušio) ključ pogledaj da nije ispala negde. Baš izgleda kao tanki antibiotik(kapsula). Bez toga ga nećeš upaliti. Ne bi trebalo da tako lako može da ispadne iz ležišta...? Quote Share this post Link to post Share on other sites
strucnjak 0 Posted December 9, 2014 hmm... nasao sam, vratio je u kljuc ali dalje nista, samo vergla i pise car security i nista :\sta sada? Quote Share this post Link to post Share on other sites
Kuvalja 406 Posted December 9, 2014 Mora da legne u svoje leziste u cosku kljuca da bude sto blize bravi posto je oko brave antena, proveri da slucano nije naprsla.... Ako.je sve ok skini kleme na desetak minuta pa probaj ponovo Quote Share this post Link to post Share on other sites
strucnjak 0 Posted December 9, 2014 stavio sam je maksimalno blizo samom kljucu, i sada je uspeo da upali.hvala na savetima Quote Share this post Link to post Share on other sites
Mi An 0 Posted December 9, 2014 (edited) E bas super I razmisli o opciji da napravis rezervni kljuc Nikada ne znas kada ce ti trebati Edited December 9, 2014 by Mi An Quote Share this post Link to post Share on other sites
strucnjak 0 Posted December 9, 2014 jel zna neko kolike pare su u pitanju za taj rezervni kljuc? Quote Share this post Link to post Share on other sites
Kuvalja 406 Posted December 9, 2014 Obican kljuc bez komandi, znaci nije skakavac, ali moze da odkljuca i pali auto od cega ti vise i ne treba od rezervnog kljuca sam ja platio 80€ pre skoro 2 godine. Quote Share this post Link to post Share on other sites
