the_reaper 2 Posted January 22, 2010 xaxa kakav gospodin Quote Share this post Link to post Share on other sites
chikavili 511 Posted January 22, 2010 Sjajno!!! Quote Share this post Link to post Share on other sites
NED 10 Posted January 22, 2010 Iz auta pravo u dnevnu sobu...... Quote Share this post Link to post Share on other sites
Sirius9 29 Posted January 22, 2010 (edited) A ko ce da zatvori kapiju... Edited January 22, 2010 by Sirius9 Quote Share this post Link to post Share on other sites
Damjanović 9 Posted January 22, 2010 Nema kapija!. Auto je kapija, a fotelje su brava! Mada, može neko da mu izvuče Una napolje. Povuče samo za branik - šlog da ga strefi sutra kad otvori vrata! Quote Share this post Link to post Share on other sites
mikisxy 6 Posted January 22, 2010 pa deka ce voziti ovu pandu za zivota a kad umre ide sa njim Quote Share this post Link to post Share on other sites
kAcA 0 Posted January 22, 2010 Haha svaka cast za ovo Quote Share this post Link to post Share on other sites
neshaoct 9591 Posted December 7, 2013 Ginisov rekord u parkiranju kamiona...pod ručnom! Paralelno parkiranje? Znate ono kada se uglavljujete u tesan prostor između dva automobila parkirana jedan iza drugog? Mi to obično ne radimo pod ručnom, a pogotovo ne sa kamionom pod ručnom kao što je to učinio Zhang Hua iz kineskog grada Yuncheng. On je 2. novembra ušao u Ginisovu knjigu rekorda, parkirajući kamion pod ručnom između dva šlepera ostavljajući slobodan prostor od samo 90 cm. preuzeto sa - Auto Blog http://www.youtube.com/watch?v=36bQLXbI7BY Quote Share this post Link to post Share on other sites
Mijailović P. 3432 Posted December 7, 2013 Onaj lik mu za malo ote plaketu ! Quote Share this post Link to post Share on other sites
neshaoct 9591 Posted March 22, 2014 Savladajte paralelno parkiranje Quote Share this post Link to post Share on other sites
sindrom 18 Posted June 30, 2014 Ovo sa kamionom tj. tegljacem nije "pod rucnom" vec voznja sa gasom. Tegljac ima veoma malo osovinsko opterecenje na diferencijalu pa je ovo vise drift. Quote Share this post Link to post Share on other sites
totti 13160 Posted June 30, 2014 Savladajte paralelno parkiranje Nekada davno sam gledao na DSF-u školu lakog paralelnog parkiranja.Kad se pođe u rikverc, čim suvozačev retrovizor "prođe" vozačev retrovizor na parkiranom autu sa desne strane, počinje motanje pun desni. Kad suvozačev retrovizor dođe u visinu zadnjeg branika na parkiranom autu sa desne strane, mota se kontra pun levi. Savršeno uspeva svaki put, skoro da može i bez gledanja.Bitna stavka je da se pre početka manevrisanja ne približite baš previše već parkiranom autu, otp. 1 metar treba da bude prostora između. Quote Share this post Link to post Share on other sites
Dante Bg 4 Posted June 30, 2014 Ima da probam pa cu da javim,ali ako si me zaj Quote Share this post Link to post Share on other sites
ivan.ik 625 Posted June 30, 2014 Ginisov rekord u parkiranju kamiona...pod ručnom! preuzeto sa - Auto Blog http://www.youtube.com/watch?v=36bQLXbI7BY Gledam kakva je ovo mečka sa Volvo-om kabinom, tek onda provalim kinez plagijat. Nekada davno sam gledao na DSF-u školu lakog paralelnog parkiranja.Kad se pođe u rikverc, čim suvozačev retrovizor "prođe" vozačev retrovizor na parkiranom autu sa desne strane, počinje motanje pun desni. Kad suvozačev retrovizor dođe u visinu zadnjeg branika na parkiranom autu sa desne strane, mota se kontra pun levi. Savršeno uspeva svaki put, skoro da može i bez gledanja.Bitna stavka je da se pre početka manevrisanja ne približite baš previše već parkiranom autu, otp. 1 metar treba da bude prostora između. Slično sa solo autobusom. Isto se ne prilazi blizu (paralelno baz 75 -100 cm) i čim zadnja osovina pređe zadnji kraj vozila iza koga parkiraš, lagano i ne brzo motaš desni (ne do kraja) i kada u levom retovizoru poklopiš zadnji levi ćošak sa prednjim desnim ćoskom vozila (ispred koga se parkiraš) ispravljaš volan i tako ga teraš sve dok u desnom uglu ne vidiš levi zadnji ćošak vozila iz koga ga parkiraš, onda motaš pun levi i parkiraš ga na 10 cm od ivičnjaka. Samo ne treba brzo motati volan.Probao milion puta i radi. Quote Share this post Link to post Share on other sites
ivan.ik 625 Posted June 30, 2014 Ovo je isparkiravanje. Quote Share this post Link to post Share on other sites
nemanjas 0 Posted July 1, 2014 jeste tako je,al je snimatelj napisao na snimku da je najgore parkiranje.al kad se ovako isparkirava mozes da zamislis kako joj ide parkiranje Quote Share this post Link to post Share on other sites
DinoG 7 Posted July 1, 2014 http://youtu.be/lb1awXgoyQE Quote Share this post Link to post Share on other sites
sindrom 18 Posted July 1, 2014 http://youtu.be/lb1awXgoyQEJa ovo i svasta jos radio sa jednom Prismom od 108 KS pre petnaestak godina. Dan danas mi zao tog auta i motora, leteo. Quote Share this post Link to post Share on other sites
